Featured Nginx How to use Brotli compression for Centmin Mod Nginx web servers
Discussion in 'Centmin Mod User Tutorials & Guides' started by eva2000, Mar 6, 2017.
    60,044
    12,572
    9:42 PM
    Yes Cloudflare Origin certs are untrusted certs outside of Cloudflare communication :)
  2. rdan
    7:42 PM
    I think this is the right way to inspect cf to/from our server.
  3. rdan
    7:42 PM
    What concerns me now, Is Cloudflare using this pre compiled/generated .br & .gz files?
    I hope it still useful behind CLoudflare.
    60,044
    12,572
    9:42 PM
    doesn't really matter if used = good, if not = no harm
  5. rdan
    7:42 PM
    Additional Disk Space ;).
    60,044
    12,572
    9:42 PM
    that's what proper disk spec/allocation decisions are for, so it doesn't become an issue :)
  7. buik
    2,044
    527
    Flanders
    1:42 PM
    Can't reply in the above topic, so hereby.
    Thanks. regrettable it is a benchmark about Cloudflare's services.
    I thought this is a Centminmod forum, so expected one benchmark of Centminmod's compiled Cloudflare zlib v.s. Centminmod Nginx Brotli.:)
    60,044
    12,572
    9:42 PM
    Already did those benchmarks for Cloudflare zlib vs Brotli for Centmin Mod Nginx and Zlib wins by a country mile Nginx - Nginx with Cloudflare zlib fork VS nxg_brotli compression level tests
  9. MaxFein
    MaxFein New Member
    14
    4:42 AM
    https://centmin.sh/ -->
    Error 1014 Ray ID: 43f0d5b74a4abb18 • 2018-07-23 20:18:11 UTC
    CNAME Cross-User Banned
    60,044
    12,572
    9:42 PM
    ah centmin.sh uses centminmod.com CNAME flattened entry for origin and centminmod.com move to cloudflare blocks that.. so need to change to using IP origin instead
  11. MaxFein
    MaxFein New Member
    14
    4:42 AM
    yeah, I used to configure like this too... it was awesome... sad that it is changed...
    have seen some references that if target domain is using a paid CF plan then it is possible to contact CF support and request that they allow incoming CNAME from other accounts... also, have seen some anecdotal reports that CNAME flattening may still work if you deactivate CF for that record (no orange cloud)... this would be nice, need to test it myself but its been awhile since I was using CF heavily... back into the fray now though ;)
    Cheers, Max
    60,044
    12,572
    9:42 PM
    Just updated to IP origin with 3x VPSes in my cluster for round robin so that should be fine :D
  13. negative
    negative Active Member
    415
    50
    2:42 PM
    1.9.10
    10.1.11
    @eva2000 If i use cloudflare pro plan and Brotli enabled, should we add the brotli support on nginx too ?
    Encoding looks BR
    MacBook-Pro:~ $ curl -sI -H "Accept-Encoding: gzip,br" https://www.domain.com
    HTTP/2 200
    date: Thu, 25 Oct 2018 13:25:25 GMT
    content-type: text/html; charset=UTF-8
    vary: Accept-Encoding
    cache-control: no-cache
    x-powered-by: nginx
    x-fastcgi-cache: HIT
    strict-transport-security: max-age=15552000; includeSubDomains; preload
    x-content-type-options: nosniff
    expect-ct: max-age=604800, report-uri="https://report-uri.cloudflare.com/cdn-cgi/beacon/expect-ct"
    server: cloudflare
    cf-ray: 46f50251dada72f5-AMS
    content-encoding: br
    But i didn't understand exactly the CLOUDFLARE ZLIB option enable on centminmod ?
    60,044
    12,572
    9:42 PM
    With cloudflare in front, ngx_brotli not needed.
    it's better performing version of nginx zlib/gzip up to 40% better
  15. negative
    415
    50
    2:42 PM
    1.9.10
    10.1.11
    Need that even cloudflare using in front too ?
    60,044
    12,572
    9:42 PM
    no you don't but centmin mod 123.09beta01 defaults to cloudflare zlib usage and can't be disabled completely as nginx needs zlib itself in some form or another.
  17. negative
    415
    50
    2:42 PM
    1.9.10
    10.1.11
    Okay than anyway i added the cloudflare zlip configuration to centminmod configuration and i go upgrade the php soon. Thanks
    60,044
    12,572
    9:42 PM
  19. rdan
    7:42 PM
    60,044
    12,572
    9:42 PM
