Featured Nginx Nginx with Cloudflare zlib fork VS nxg_brotli compression level tests
Discussion in 'Nginx and PHP-FPM news & discussions' started by eva2000, Jan 24, 2018.
    55,915
    12,281
    6:47 AM
    Quick wrk load testing comparison benchmarks between Centmin Mod Nginx 1.13.8 using cloudflare zlib performance forked library for HTTPS based compressed static index file tests versus Nginx 1.13.8 with Google ngx_brotli module for brotli compression instead. First set of compression level 1-9 tests are for cloudflare zlib and second set are for ngx_brotli based. You can see ngx_brotli scales badly at high compression levels. FYI, Centmin Mod defaults to compression level 5 for both zlib and brotli usually. Though ngx_brotli has smaller file sizes than zlib/gzip based compression in Nginx.
    Tests done on OVH Core i7 4790K server with Centmin Mod compiled with GCC 8 20180114 snapshot.
    Centmin Mod Ngixn 1.13.8 + cloudflare zlib
    domain=https://domain.com
    for l in {1..9}; do
    sleep 5;
    echo -e "\ntest gzip_comp_level $l";
    sed -ie "s|BROTLI=.*|BROTLI='n'|" /usr/local/bin/curltest
    /usr/local/bin/curltest $domain;
    sed -ie "s|gzip_comp_level .*|gzip_comp_level $l;|" /usr/local/nginx/conf/nginx.conf | grep gzip_comp_level
    ngxrestart >/dev/null 2>&1;
    echo "wrk-cmm -t3 -c200 -d5s --breakout -H 'Accept-Encoding: gzip' -s scripts/setup.lua --latency $domain 2>&1 | egrep -A1 'Thread Stats|Requests/sec';"
    done;
    sed -ie "s|gzip_comp_level .*|gzip_comp_level 5;|" /usr/local/nginx/conf/nginx.conf | grep gzip_comp_level
    test gzip_comp_level 1
    URI: https://domain.com
    Uncompressed size : 3.71 KiB
    Compressed size   : 1.53 KiB
    wrk-cmm -t3 -c200 -d5s --breakout -H 'Accept-Encoding: gzip' -s scripts/setup.lua --latency https://domain.com 2>&1 | egrep -A1 'Thread Stats|Requests/sec';
      Thread Stats   Avg      Stdev     Max   +/- Stdev
        Latency     3.64ms    2.78ms  91.47ms   82.86%
    Requests/sec:  57328.78
    Transfer/sec:    117.00MB
    test gzip_comp_level 2
    Compressed size   : 1.60 KiB
        Latency     3.72ms    2.80ms  89.40ms   80.65%
    Requests/sec:  56372.51
    Transfer/sec:    114.14MB
    test gzip_comp_level 3
    Compressed size   : 1.59 KiB
        Latency     3.68ms    2.31ms  23.55ms   76.99%
    Requests/sec:  55660.12
    Transfer/sec:    112.11MB
    test gzip_comp_level 4
    Compressed size   : 1.58 KiB
        Latency     4.14ms    2.51ms  40.27ms   80.86%
    Requests/sec:  49335.99
    Transfer/sec:     97.63MB
    test gzip_comp_level 5
    Compressed size   : 1.54 KiB
        Latency     4.38ms    2.88ms  28.23ms   75.97%
    Requests/sec:  46941.20
    Transfer/sec:     92.31MB
    test gzip_comp_level 6
        Latency     4.47ms    3.63ms 109.23ms   87.82%
    Requests/sec:  46594.92
    Transfer/sec:     91.67MB
    test gzip_comp_level 7
        Latency     4.45ms    2.74ms  34.57ms   79.50%
    Requests/sec:  46192.65
    Transfer/sec:     90.88MB
    test gzip_comp_level 8
        Latency     4.50ms    2.88ms  30.34ms   75.30%
    Requests/sec:  45833.67
    Transfer/sec:     90.18MB
    test gzip_comp_level 9
        Latency     4.37ms    2.76ms  31.79ms   75.67%
    Requests/sec:  46975.52
    Transfer/sec:     92.42MB
    55,915
    12,281
    6:47 AM
    Centmin Mod Ngixn 1.13.8 ngx_brotli
    for l in {1..9}; do
    sleep 5;
    echo -e "\ntest brotli_comp_level $l";
    sed -ie "s|BROTLI=.*|BROTLI='y'|" /usr/local/bin/curltest
    sed -ie "s|brotli_comp_level .*|brotli_comp_level $l;|" /usr/local/nginx/conf/brotli_inc.conf | grep brotli_comp_level
    echo "wrk-cmm -t3 -c200 -d5s --breakout -H 'Accept-Encoding: br' -s scripts/setup.lua --latency $domain 2>&1 | egrep -A1 'Thread Stats|Requests/sec';"
    done;
    sed -ie "s|brotli_comp_level .*|brotli_comp_level 5;|" /usr/local/nginx/conf/brotli_inc.conf | grep brotli_comp_level
    test brotli_comp_level 1
    Compressed size   : 1.27 KiB
    wrk-cmm -t3 -c200 -d5s --breakout -H 'Accept-Encoding: br' -s scripts/setup.lua --latency https://domain.com 2>&1 | egrep -A1 'Thread Stats|Requests/sec';
        Latency     3.10ms    2.36ms  21.26ms   80.09%
    Requests/sec:  69216.96
    Transfer/sec:    149.85MB
    test brotli_comp_level 2
    Compressed size   : 1.73 KiB
        Latency     4.15ms    3.62ms 109.56ms   88.92%
    Requests/sec:  51881.04
    Transfer/sec:    106.28MB
    test brotli_comp_level 3
    Compressed size   : 1.61 KiB
        Latency     4.89ms    2.91ms  38.35ms   81.21%
    Requests/sec:  41836.26
    Transfer/sec:     84.74MB
    test brotli_comp_level 4
        Latency     6.12ms    3.29ms  47.08ms   81.60%
    Requests/sec:  33020.04
    Transfer/sec:     59.58MB
    test brotli_comp_level 5
    Compressed size   : 1.36 KiB
        Latency     6.99ms    3.24ms  31.60ms   75.34%
    Requests/sec:  28453.59
    Transfer/sec:     48.84MB
    test brotli_comp_level 6
        Latency     7.18ms    3.40ms  70.95ms   84.31%
    Requests/sec:  27902.55
    Transfer/sec:     47.90MB
    test brotli_comp_level 7
        Latency     7.48ms    2.79ms  29.54ms   77.60%
    Requests/sec:  26428.62
    Transfer/sec:     45.24MB
    test brotli_comp_level 8
        Latency     7.53ms    2.56ms  36.67ms   82.18%
    Requests/sec:  26221.07
    Transfer/sec:     44.89MB
    test brotli_comp_level 9
        Latency    21.16ms    7.13ms  69.63ms   58.05%
    Requests/sec:   9278.82
    Transfer/sec:     15.87MB
    55,915
    12,281
    6:47 AM
    Specifically comparing levels 5 & 6 compression for Cloudflare zlib and Google ngx_brotli
    Cloudflare zlib
    Google ngx_brotli
  4. rdan
    1,412
    4:47 AM
    So it's faster to deliver to each visitor.
    But how much difference we are talking?
    55,915
    12,281
    6:47 AM
    see the latency numbers in above benchmarks, probably not enough to notice really though throughput has zlib winning
  6. rdan
    1,412
    4:47 AM
    But Cloudflare itself uses brotli, so it's worth using I think.
    55,915
    12,281
    6:47 AM
    most like they they take backend brotli compressed assets and store them temporarily so using brotli pre-compressed served files which don't add as much overhead as on the fly brotli compression. Just like pre-gzipped static files vs on the fly gzip compressed files. So yes maybe for Cloudflare enabled Brotli compression, then it would be fine.
    55,915
    12,281
    6:47 AM
    From above Centmin Mod Nginx zlib is much faster in terms of scalability than ngx_brotli. But with Cloudflare's brotli implementation it matches and slightly exceeds their zlib scalability performance centminmod.com DNS update.
    So looks like with Centmin Mod Nginx brotli usage you choose between page load speed which it does better than zlib but at expense of scalability performance. While with Cloudflare they seem to have engineered brotli to scale as well as zlib so that both brotli and zlib are good at both page load speed (due to higher compression = smaller file size) and scalability in terms of higher concurrency loads.
    Or I should look at using Cloudflare's ngx_brotli implementation cloudflare/ngx_brotli_module instead of the current one I use at eustas/ngx_brotli which is maintained by official Google Brotli developer ? But Cloudflare no longer solely use Nginx for web server so given their ngx_brotli code hasn't been updated in years it might not be that implementation which is allowing Cloudflare's Brotli performance to scale to match zlib ?
    Update: looks like Centmin Mod used ngx_brotli module at eustas/ngx_brotli was completely rewritten after April 2018 and updated to use Google Brotli 1.0.4. So performance of above tests are using old version of ngx_brotli and will need to be redone against the newly rewritten ngx_brotli version.
    55,915
    12,281
    6:47 AM
    Centmin Mod Nginx Cloudflare zlib VS nxg_brotli Update
    Looks like Centmin Mod used ngx_brotli module at eustas/ngx_brotli was completely rewritten after April 2018 and updated to use Google Brotli 1.0.4. So performance of above tests are using old version of ngx_brotli and will need to be redone against the newly rewritten ngx_brotli version
    The tests will be done CentOS 7 with master branch Nginx 1.15.0 with ngx_brotli rewritten module with Google Brotli 1.0.4 and Cloudflare zlib performance patched Nginx. Nginx 1.15.0 will be compiled against latest GCC 8.1.0 compiler.
    brotli -V
    brotli 1.0.4
    Centmin Mod Nginx 1.15.0 + Cloudflare Zlib Compression
    for l in {1..9}; do
    sleep 5;
    /usr/local/bin/curltest gzip $domain;
    done;
    URI: https://domain.com (gzip)
        Latency     4.24ms    2.99ms  34.01ms   81.71%
    Requests/sec:  49358.76
    Transfer/sec:    100.73MB
        Latency     4.48ms    3.25ms  41.12ms   77.17%
    Requests/sec:  46669.40
    Transfer/sec:     94.49MB
        Latency     4.58ms    3.45ms  57.45ms   80.06%
    Requests/sec:  45950.19
    Transfer/sec:     92.55MB
        Latency     4.92ms    3.45ms  52.51ms   78.37%
    Requests/sec:  42095.78
    Transfer/sec:     83.31MB
        Latency     5.18ms    3.40ms  43.19ms   77.18%
    Requests/sec:  39559.15
    Transfer/sec:     77.79MB
        Latency     5.23ms    4.85ms 116.98ms   91.59%
    Requests/sec:  40064.29
    Transfer/sec:     78.82MB
        Latency     5.17ms    3.04ms  31.59ms   81.79%
    Requests/sec:  39017.16
    Transfer/sec:     76.76MB
        Latency     5.17ms    3.38ms  35.73ms   80.64%
    Requests/sec:  39925.48
    Transfer/sec:     78.55MB
        Latency     5.31ms    3.85ms  76.48ms   82.75%
    Requests/sec:  39348.09
    Transfer/sec:     77.42MB
    Centmin Mod Nginx 1.15.0 + Brotli Compression
    for l in {1..9}; do
    sleep 5;
    /usr/local/bin/curltest br $domain;
    done;
    URI: https://domain.com (br)
        Latency     5.67ms    3.33ms  41.49ms   82.83%
    Requests/sec:  35996.20
    Transfer/sec:     77.93MB
        Latency     9.52ms    4.43ms  48.01ms   81.59%
    Requests/sec:  20866.94
    Transfer/sec:     42.81MB
    Compressed size   : 1.62 KiB
        Latency     8.64ms    2.59ms  30.90ms   77.40%
    Requests/sec:  22791.34
    Transfer/sec:     46.12MB
        Latency    12.16ms    2.51ms  56.29ms   72.57%
    Requests/sec:  16154.26
    Transfer/sec:     29.13MB
        Latency    16.80ms    9.02ms 127.80ms   86.60%
    Requests/sec:  11960.71
    Transfer/sec:     20.53MB
        Latency    13.65ms    3.09ms  37.01ms   73.62%
    Requests/sec:  14376.27
    Transfer/sec:     24.68MB
        Latency    14.78ms    3.09ms  94.52ms   93.45%
    Requests/sec:  13290.59
    Transfer/sec:     22.75MB
        Latency    18.00ms    8.88ms 181.58ms   86.28%
    Requests/sec:  11041.09
    Transfer/sec:     18.90MB
        Latency    29.72ms    8.35ms 108.39ms   79.39%
    Requests/sec:   6606.58
    Transfer/sec:     11.30MB
    Cloudflare Zlib vs Brotli Level 1, 5 & 6
    Comparing the default Nginx zlib and Brotli compression levels set in Centmin Mod Nginx
    Cloudflare zlib 5 and 6
    Brotli level 1, 5 and 6 - - level 1 has same compressed size 1.27KB as level 6 !
    Seems both Cloudflare zlib and brotli have a dip in performance at level 5 to jump back up in performance at level 6 ! But still like before Centmin Mod Nginx with Cloudflare zlib performed better than Nginx Brotli for scalability.
    55,915
    12,281
    6:47 AM
    Centmin Mod Nginx zlib/brotli vs Cloudflare zlib/brotli
    Next test is direct comparison against Cloudflare reverse proxied zlib/brotli and Centmin Mod Nginx with Cloudflare zlib fork and ngx_brotli. As Cloudflare only caches static files can't test against index.html normally, so change to testing against css file = pure-min.css.
    curl -I $domain/pure-min.css
    HTTP/2 200
    date: Fri, 18 May 2018 21:29:01 GMT
    content-type: text/css
    content-length: 17286
    last-modified: Tue, 27 Sep 2016 15:04:57 GMT
    vary: Accept-Encoding
    etag: "57ea8a99-4386"
    server: nginx centminmod
    x-powered-by: centminmod
    expires: Sun, 17 Jun 2018 21:29:01 GMT
    cache-control: max-age=2592000
    access-control-allow-origin: *
    cache-control: public, must-revalidate, proxy-revalidate
    accept-ranges: bytes
    Centmin Mod Nginx 1.15.0 + Cloudflare zlib fork
    for l in {1..9}; do
    sleep 5;
    /usr/local/bin/curltest gzip $domain/pure-min.css;
    echo "wrk-cmm -t3 -c200 -d5s --breakout -H 'Accept-Encoding: gzip' -s scripts/setup.lua --latency $domain/pure-min.css 2>&1 | egrep -A1 'Thread Stats|Requests/sec';"
    done;
    URI: https://domain.com/pure-min.css (gzip)
    Uncompressed size : 16.88 KiB
    Compressed size   : 4.00 KiB
    wrk-cmm -t3 -c200 -d5s --breakout -H 'Accept-Encoding: gzip' -s scripts/setup.lua --latency https://domain.com/pure-min.css 2>&1 | egrep -A1 'Thread Stats|Requests/sec';
        Latency     7.02ms    3.66ms  59.75ms   82.90%
    Requests/sec:  28579.66
    Transfer/sec:    139.31MB
    Compressed size   : 4.52 KiB
        Latency     6.78ms    3.44ms  32.14ms   80.32%
    Requests/sec:  29648.73
    Transfer/sec:    141.49MB
    Compressed size   : 4.42 KiB
        Latency     8.46ms    4.18ms  50.52ms   81.48%
    Requests/sec:  23588.88
    Transfer/sec:    111.36MB
    Compressed size   : 4.36 KiB
        Latency     9.76ms    5.00ms  72.75ms   78.03%
    Requests/sec:  20516.19
    Transfer/sec:     92.06MB
    Compressed size   : 4.12 KiB
        Latency     9.07ms    3.75ms  74.32ms   84.27%
    Requests/sec:  21906.21
    Transfer/sec:     95.56MB
        Latency    11.67ms    5.36ms  49.06ms   80.21%
    Requests/sec:  16996.54
    Transfer/sec:     73.80MB
    Compressed size   : 3.98 KiB
        Latency    10.23ms    3.28ms  34.06ms   69.40%
    Requests/sec:  19185.81
    Transfer/sec:     83.27MB
    Compressed size   : 3.97 KiB
        Latency    11.70ms    3.34ms  54.31ms   74.89%
    Requests/sec:  16812.23
    Transfer/sec:     72.90MB
        Latency    14.24ms    6.72ms  57.65ms   77.27%
    Requests/sec:  13975.82
    Transfer/sec:     60.60MB
    Centmin Mod Nginx 1.15.0 + Nginx Brotli
    for l in {1..9}; do
    sleep 5;
    /usr/local/bin/curltest br $domain/pure-min.css;
    echo "wrk-cmm -t3 -c200 -d5s --breakout -H 'Accept-Encoding: br' -s scripts/setup.lua --latency $domain/pure-min.css 2>&1 | egrep -A1 'Thread Stats|Requests/sec';"
    done;
    URI: https://domain.com/pure-min.css (br)
    Compressed size   : 3.66 KiB
    wrk-cmm -t3 -c200 -d5s --breakout -H 'Accept-Encoding: br' -s scripts/setup.lua --latency https://domain.com/pure-min.css 2>&1 | egrep -A1 'Thread Stats|Requests/sec';
        Latency    12.28ms    5.31ms  76.79ms   80.91%
    Requests/sec:  16190.71
    Transfer/sec:     82.07MB
    Compressed size   : 4.72 KiB
        Latency    19.99ms    5.38ms 134.65ms   88.46%
    Requests/sec:   9843.13
    Transfer/sec:     45.59MB
    Compressed size   : 4.27 KiB
        Latency    21.23ms    4.19ms  60.41ms   67.43%
    Requests/sec:   9225.87
    Transfer/sec:     41.83MB
    Compressed size   : 4.17 KiB
        Latency    28.90ms    7.26ms  55.69ms   74.15%
    Requests/sec:   6769.71
    Transfer/sec:     29.09MB
    Compressed size   : 3.93 KiB
        Latency    38.61ms    8.43ms 167.43ms   85.94%
    Requests/sec:   5059.95
    Transfer/sec:     20.38MB
        Latency    40.12ms    5.15ms 119.51ms   90.46%
    Requests/sec:   4874.63
    Transfer/sec:     19.50MB
    Compressed size   : 3.63 KiB
        Latency    46.61ms   13.16ms 157.93ms   75.22%
    Requests/sec:   4190.27
    Transfer/sec:     16.76MB
        Latency    50.76ms   15.73ms 213.52ms   83.17%
    Requests/sec:   3855.11
    Transfer/sec:     15.41MB
    Compressed size   : 3.62 KiB
        Latency    70.71ms   17.86ms 229.45ms   82.74%
    Requests/sec:   2755.16
    Transfer/sec:     10.99MB
    Interesting Brotli level 1 vs level 5 & 6 compression size. Brotli level 1 and 6 result in same compressed size 3.66KB !
    Cloudflare Reverse Proxy Zlib & Brotli Performance
    Next compare with Cloudflare enabled as reverse proxy in front of Centmin Mod Nginx 1.15.0 server from above tests to compare Cloudflare's edge server Zlib and Brotli performance against pure-min.css file.
    HTTP/2 200
    date: Fri, 18 May 2018 21:40:03 GMT
    set-cookie: __cfduid=d80ebaa41be4bf47e2feb95071a1b4c221526679603; expires=Sat, 18-May-19 21:40:03 GMT; path=/; domain=.domain.com; HttpOnly
    etag: W/"57ea8a99-4386"
    expires: Sun, 17 Jun 2018 21:40:03 GMT
    cache-control: public, max-age=2592000
    cf-cache-status: MISS
    expect-ct: max-age=604800, report-uri="https://report-uri.cloudflare.com/cdn-cgi/beacon/expect-ct"
    server: cloudflare
    cf-ray: 41d17ae1bff64728-EWR
    echo -e "\ntest cloudflare proxy zlib/gzip compression";
        Latency   133.71ms  278.11ms   2.00s    88.93%
    Requests/sec:   3693.35
    Transfer/sec:     16.96MB
        Latency    38.08ms  135.60ms   1.93s    97.09%
    Requests/sec:   8223.68
    Transfer/sec:     37.77MB
    Cloudflare Reverse Proxy Brotli
    Need to purge pure-min.css from Cloudflare cache for retesting next test.
    echo -e "\ntest cloudflare proxy brotli compression";
        Latency    23.45ms   34.95ms 778.50ms   96.29%
    Requests/sec:   6634.20
    Transfer/sec:     28.30MB
    retest cached performance
        Latency    24.99ms   60.59ms   1.40s    97.81%
    Requests/sec:   7293.99
    Transfer/sec:     31.12MB
    Summary
    • Seems pretty clear that Cloudflare has further optimised their Brotli compression compared to Zlib/gzip even on their own Cloudflare edge servers for uncached runs. Cached runs zlib seems to fair better. But this could just depend on the Cloudflare edge servers you hit as there would be many edge servers in their cluster so variance would be expected.
    • However seems local Centmin Mod zlib (cloudflare forked) seem to have performed best in this test skewed by fact that local tests were done on local network where average wrk-cmm latency was ~11ms versus Cloudflare reverse proxy which had to transverse a network with wrk0cmm latency ~38ms so more than 3x times the latency as local network tests.
    Centmin Mod Nginx tests were do via local network so latency is much less than Cloudflare reverse proxy and thus skews results. But this is a comparison of relative zlib and brotli implementations as well to see how they fair on their respective web servers - Centmin Mod Nginx and Cloudflare edge servers.
    config compressed size req/s avg latency max latency
    Centmin Mod Nginx zlib level 5 (cf fork) 4.12KB 21906 9.07ms 74.32ms
    Centmin Mod Nginx zlib level 6 (cf fork) 4.00KB 16997 11.67ms 49.06ms
    Centmin Mod Nginx brotli level 5 3.93KB 5060 38.61ms 167.43ms
    Centmin Mod Nginx brotli level 6 3.66KB 4875 40.12ms 119.51ms
    Cloudflare Reverse Proxy zlib 1st run 4.00KB 3693 133.71ms 2000.0ms
    Cloudflare Reverse Proxy zlib 2nd run 4.00KB 8224 38.08ms 1930.0ms
    Cloudflare Reverse Proxy brotli 1st run 3.66KB 6634 23.45ms 778.5ms
    Cloudflare Reverse Proxy brotli 2nd run 3.66KB 7294 24.99ms 1400.0ms
    For Cloudflare zlib vs brotli tests
    55,915
    12,281
    6:47 AM
    Centmin Mod Nginx zlib/brotli vs Cloudflare zlib/brotli - static compression
    Another theory is Clouldflare Brotli is using static Brotli compression instead of dynamic Brotli compression by storing pre-Brotli compressed assets on edge servers. So lets test pre-gzip and pre-brotli compressed pure-min.css. I used pigz level 11 which uses better Zopfli based gzip compression level which is higher than standard zlib level 9 compression.
    cd /usr/local/nginx/html/
    pigz -11kf /usr/local/nginx/html/pure-min.css
    brotli -q 11 --force /usr/local/nginx/html/pure-min.css --output=/usr/local/nginx/html/pure-min.css.br
    ls -lh | grep pure-min.css
    -rw-r--r--  1 root  nginx  17K Sep 27  2016 pure-min.css
    -rw-r--r--  1 root  nginx 3.4K Sep 27  2016 pure-min.css.br
    -rw-r--r--  1 root  nginx 3.8K Sep 27  2016 pure-min.css.gz
    Centmin Mod Nginx 1.15.0 + Cloudflare zlib fork (pre-zip compressed pure-min.css)
    for l in {1..9}; do
    sleep 5;
    done;
    Compressed size   : 3.79 KiB
        Latency     3.02ms    2.77ms  30.07ms   85.84%
    Requests/sec:  75612.32
    Transfer/sec:    312.88MB
        Latency     3.32ms    3.54ms  69.33ms   88.26%
    Requests/sec:  72866.07
    Transfer/sec:    301.55MB
        Latency     3.41ms    3.38ms  33.86ms   86.28%
    Requests/sec:  71070.23
    Transfer/sec:    294.10MB
        Latency     3.40ms    3.52ms  64.03ms   86.99%
    Requests/sec:  71715.11
    Transfer/sec:    296.78MB
        Latency     3.27ms    3.17ms  32.38ms   86.62%
    Requests/sec:  72443.07
    Transfer/sec:    299.79MB
        Latency     3.36ms    3.39ms  50.43ms   87.24%
    Requests/sec:  71905.31
    Transfer/sec:    297.55MB
        Latency     3.33ms    3.37ms  39.83ms   87.15%
    Requests/sec:  71885.71
    Transfer/sec:    297.49MB
        Latency     3.30ms    3.21ms  36.53ms   86.61%
    Requests/sec:  72355.43
    Transfer/sec:    299.43MB
        Latency     3.27ms    3.16ms  31.73ms   87.18%
    Requests/sec:  71312.88
    Transfer/sec:    295.12MB
    Centmin Mod Nginx 1.15.0 + Nginx Brotli (pre-brotli compressed pure-min.css)
    for l in {1..9}; do
    sleep 5;
    done;
    Compressed size   : 3.38 KiB
        Latency     2.66ms    2.66ms  51.53ms   87.71%
    Requests/sec:  89472.49
    Transfer/sec:    334.08MB
        Latency     2.82ms    2.91ms  41.43ms   87.14%
    Requests/sec:  85518.35
    Transfer/sec:    319.32MB
        Latency     2.70ms    2.52ms  29.44ms   87.35%
    Requests/sec:  83973.56
    Transfer/sec:    313.55MB
        Latency     2.75ms    2.67ms  33.84ms   86.93%
    Requests/sec:  85561.93
    Transfer/sec:    319.47MB
        Latency     2.76ms    2.72ms  39.79ms   87.91%
    Requests/sec:  84643.04
    Transfer/sec:    316.05MB
        Latency     2.86ms    3.39ms  87.54ms   89.78%
    Requests/sec:  84974.72
    Transfer/sec:    317.28MB
        Latency     4.35ms   12.63ms 165.20ms   97.76%
    Requests/sec:  84183.69
    Transfer/sec:    314.33MB
        Latency     2.75ms    2.77ms  43.95ms   88.19%
    Requests/sec:  85118.24
    Transfer/sec:    317.82MB
        Latency     2.73ms    2.61ms  31.51ms   86.12%
    Requests/sec:  85812.28
    Transfer/sec:    320.41MB
    Zlib level 5 & 6
    Brotli level 5 & 6
    Centmin Mod Nginx zlib level 5 pre-compress static (cf fork) 3.79KB 72443 3.27ms 32.38ms
    Centmin Mod Nginx zlib level 6 pre-compress static (cf fork) 3.79KB 71905 3.36ms 50.43ms
    Centmin Mod Nginx brotli level 5 pre-compress static 3.38KB 84643 2.76ms 39.79ms
    Centmin Mod Nginx brotli level 6 pre-compress static 3.38KB 84975 2.96ms 87.54ms
    Centmin Mod Nginx zlib level 5 dynamic (cf fork) 4.12KB 21906 9.07ms 74.32ms
    Centmin Mod Nginx zlib level 6 dynamic (cf fork) 4.00KB 16997 11.67ms 49.06ms
    Centmin Mod Nginx brotli level 5 dynamic 3.93KB 5060 38.61ms 167.43ms
    Centmin Mod Nginx brotli level 6 dynamic 3.66KB 4875 40.12ms 119.51ms
  12. rdan
    1,412
    4:47 AM
    Before Cloudflare zlib VS after Google nxg_brotli
    San Fransisco
    Sydney
    55,915
    12,281
    6:47 AM
    Interesting but 2 different locations or do you mean the drop after Nov 26th is ngx_brotli ?
  14. rdan
    1,412
    4:47 AM
    Yes.
  15. pamamolf
    4,101
    428
    11:47 PM
    Nginx-1.26.x
    Which service do you use for these stats? :)
    55,915
    12,281
    6:47 AM
