Featured Nginx How to use Brotli compression for Centmin Mod Nginx web servers
Discussion in 'Centmin Mod User Tutorials & Guides' started by eva2000, Mar 6, 2017.
    60,000
    12,566
    12:03 AM
    Centmin Mod is provide as is, so short of scripted related bugs or issues, any further optimisation to the web stack components - nginx, php-fpm, mariadb mysql, csf firewall etc or web app level specific configurations such as wordpress are left to the Centmin Mod user to deal with. So I do not provide any free support for such.
    But whether gzip or brotli is used doesn't matter that much at Cloudflare level as you're performance will be good either way. So I wouldn't worry too much about it.
  2. Nitin
    Nitin New Member
    24
    7:33 PM
    ok. I understand. Thanks for the help. Even its not working but i have learned many new thing (y). Salute to your efforts for helping me. You are awesome. I am not going back to shared hosting again..:p
  3. Nitin
    Nitin New Member
    24
    7:33 PM
    New Update: Cloudflare says "It is currently disabled pending a patch, but should be back online shortly." :LOL:
    60,000
    12,566
    12:03 AM
    You're welcome and yes once you go VPS/dedicated very hard to go back to shared hosting - so much control :D
    :LOL::banghead: so Cloudflare had disabled it on their end !
  5. Kuro
    Kuro Member
    109
    13
    9:03 PM
    1.15.10
    10.3
    Hi, i'm using CF pro plan, THIS IS NECESSARY or should i use both?
    now i installed both (CF and custom Config) but when i check my homepage. It is Gzip :D
    and when i on TLS 1.3 on my website:
    This site can't provide a secure connection (i must back TLS 1.2)
    My custom_config.inc
    60,000
    12,566
    12:03 AM
    60,000
    12,566
    12:03 AM
  8. rdan
    10:03 PM
    How can we check if this thing is being used by Cloudflare or just useless with CF? :unsure:
    60,000
    12,566
    12:03 AM
    Brotli usage where at Cloudflare to Visitor stage or you mean between Cloudflare and Centmin Mod Nginx ? Seems Cloudflare may have turned off Brotli temporary on their servers Nginx - How to use Brotli compression for Centmin Mod Nginx web servers ?
    On CentOS 7 you can use curl resolve command to bypass Cloudflare to check headers for Centmin Mod Nginx backend origin to see if Brotli is supported.
    Inspecting output for commands. For posting code or output from commands to keep the formatting, you might want to use CODE tags for code How to use forum BBCODE code tags
    curl -sI -H "Accept-Encoding: gzip,br" https://yourdomain.com
    curl -sI -H "Accept-Encoding: gzip,br" http://yourdomain.com
    checking the Content-Encoding: line to see if it shows gzip or br
    Cloudflare Users & Brotli
    You can verify if cloudflare or centmin mod nginx is where the gzip compression is coming from by running curl command which bypasses cloudflare to connect with centmin mod nginx backend replacing YOURREALSERVER_IP with your real server IP address below and yourdomain.com with your domain name. You may want to mask your real ip when you post the output on this forum to protect your real IP address
    curl -sI -H "Accept-Encoding: gzip,br" --resolve 'yourdomain.com:443:YOURREALSERVER_IP' https://yourdomain.com
    compare it to header check with cloudflare in front
    Inspecting whether Content-Encoding shows br or gzip. If bypass curl header check shows br but cloudflare curl header check shows gzip, then something at web app level i.e. wordpress is precompressing static assets as gzip.
    Cloudflare Origin Authentication Pull And Brotli
    If you have Cloudflare origin authentication setup then curl header bypass command will result in HTTP/1.1 400 Bad Request error as regular HTTPS requests to https backend nginx site are only allowed via Cloudflare, then you need to temporarily disable Cloudflare origin authentication by commenting out the line in your nginx vhost domain config file
    changing line from
    ssl_client_certificate /usr/local/nginx/conf/ssl/cloudflare/domain.com/origin.crt;
    ssl_verify_client on;
    to comment out and disable them with hash in front
    #ssl_client_certificate /usr/local/nginx/conf/ssl/cloudflare/domain.com/origin.crt;
    #ssl_verify_client on;
    restart Nginx and PHP-FPM services
    nprestart
    Then disable Original Authentication Pull in Cloudflare dashboard.
    Then re-run single command line for curl header check that bypasses cloudflare
    curl -sI -H"Accept-Encoding: gzip,br" --resolve yourdomain.com:443:YOURREALSERVER_IP' https://yourdomain.com
    After you got output, re-enable Cloudflare origin authentication by removing comment hashes from the 2 lines and then restarting nginx and php-fpm services and then re-enable Original Authentication Pull in Cloudflare dashboard.
    For further checks I suppose you can do a custom Nginx log format which includes the content-encoding header being logged to nginx access log similar to Cloudflare logging done for CF-RAY header at Cloudflare - Cloudflare custom Nginx logging
  10. buik
    2,044
    527
    Flanders
    4:03 PM
    Why using Brotli anyway?:)
    Gzip is supported by all for all.
    With Cloudflare Gzip (Zlib), you get the maximum out of it.
    If you use both, you must test both: test updates, compile updates, extra layer for debugging problems over and over again.
    60,000
    12,566
    12:03 AM
    Actually doesn't matter if Brotli isn't used it falls back to Gzip on either Cloudflare or Centmin Mod Nginx layer. So there's no troubleshooting involved - let server decide which to server visitors with - either Gzip or Brotli compression when available.
  12. buik
    2,044
    527
    Flanders
    4:03 PM
    I limit myself to Centminmod. That is what this topic is about.
    True giving the fact that a nice fall back is realized by Nginx Brotli if Brotli isn't supported.
    If all is settled and done.
    Problem is that the Nginx Brotli plugin isn't maintained since 2016.
    There is a fork. But the pre-existence is very uncertain. Given this quote:
    60,000
    12,566
    12:03 AM
    Yeah Centmin Mod Nginx used more updated ngx_brotli fork at eustas/ngx_brotli though the maintainer is also the maintainer for official Google Brotli library too so there would be some updating I suppose :)
  14. buik
    2,044
    527
    Flanders
    4:03 PM
    Did you bench Coudflare Zlib vs Brotli? curious about the results
    60,000
    12,566
    12:03 AM
    60,000
    12,566
    12:03 AM
    @Nitin @Kuro @RoldanLT looks like Cloudflare has now re-enabled Brotli on their end
    curl -I -H "Accept-Encoding: gzip,br" https://community.centminmod.com/
    HTTP/2 200
    date: Fri, 18 May 2018 04:18:38 GMT
    content-type: text/html; charset=UTF-8
    set-cookie: __cfduid=dea2e1bcf37bd11ca3ffd795c8b3ec2461526617118; expires=Sat, 18-May-19 04:18:38 GMT; path=/; domain=.centminmod.com; HttpOnly
    vary: Accept-Encoding
    expires: Thu, 19 Nov 1981 08:52:00 GMT
    cache-control: private, max-age=0
    set-cookie: xfcmi_session=20f5c86be55b597512003266b97262a8; path=/; secure; HttpOnly
    x-frame-options: SAMEORIGIN
    x-xss-protection: 1
    x-powered-by: centminmod
    x-content-type-options: nosniff
    referrer-policy: strict-origin-when-cross-origin
    strict-transport-security: max-age=31536000; includeSubdomains
    link: </styles/xenbase/font-awesome/css/font-awesome.min.css>; rel="preload" as="style"
    link: </js/jquery/jquery-1.11.0.min.js>; rel="preload" as="script"
    link: </js/xenforo/xenforo.js>; rel="preload" as="script"
    link: </OneSignalSDK.js>; rel="preload" as="script"
    link: </styles/xenbase/font-awesome/fonts/fontawesome-webfont.woff2?v=4.7.0>; rel="preload" as="font" crossorigin
    expect-ct: max-age=604800, report-uri="https://report-uri.cloudflare.com/cdn-cgi/beacon/expect-ct"
    server: cloudflare
    cf-ray: 41cb855e6be41ead-SJC
    content-encoding: br
  17. rdan
    10:03 PM
    I run this on my Ubuntu Desktop and doesn't output anything.
    This works fine:
    My CURL installed:
    curl -V
    curl 7.58.0 (x86_64-pc-linux-gnu) libcurl/7.58.0 OpenSSL/1.1.0g zlib/1.2.11 libidn2/2.0.4 libpsl/0.19.1 (+libidn2/2.0.4) nghttp2/1.30.0 librtmp/2.3
    Release-Date: 2018-01-24
    Protocols: dict file ftp ftps gopher http https imap imaps ldap ldaps pop3 pop3s rtmp rtsp smb smbs smtp smtps telnet tftp
    Features: AsynchDNS IDN IPv6 Largefile GSS-API Kerberos SPNEGO NTLM NTLM_WB SSL libz TLS-SRP HTTP2 UnixSockets HTTPS-proxy PSL
  18. rdan
    10:03 PM
    Yes, between Cloudflare Edge server to/from our CMM Server.
  19. rdan
    10:03 PM
    Aha :D
    Seems cert error because I use Cloudflare ECC own cert.
  20. rdan
    10:03 PM
    Works now:
    curl -sI -H "Accept-Encoding: gzip,br" -k --resolve 'yourdomain.com:443:YOURREALSERVER_IP' https://yourdomain.com
