    1:15 AM
    Good to hear :D
  2. Josephm
    Josephm Active Member
    132
    44
    10:15 PM
    1.9.5
    10.0.21
    Just tried again in my localhost from fresh Centos 7 installation. Things are working well ;)
    Check ccache Version:
    ccache version 3.1.9
    Copyright (C) 2009-2011 Joel Rosdahl
    version.
    Check Nginx Version:
    nginx version: nginx/1.7.6
    built by gcc 4.8.2 20140120 (Red Hat 4.8.2-16) (GCC)
    TLS SNI support enabled
    configure arguments: --sbin-path=/usr/local/sbin/nginx --conf-path=/usr/local/nginx/conf/nginx.conf --with-http_ssl_module --with-http_gzip_static_module --with-http_stub_status_module --with-http_sub_module --with-http_addition_module --with-http_image_filter_module --with-http_secure_link_module --with-http_flv_module --with-http_realip_module --with-openssl-opt=enable-tlsext --add-module=../ngx-fancyindex-ngx-fancyindex --add-module=../ngx_cache_purge-2.1 --add-module=../headers-more-nginx-module-0.25 --add-module=../nginx-accesskey-2.0.3 --add-module=../nginx-http-concat-master --with-http_dav_module --add-module=../nginx-dav-ext-module-0.0.3 --add-module=../openresty-memc-nginx-module-1518da4 --add-module=../openresty-srcache-nginx-module-ffa9ab7 --add-module=../nginx-sticky-module-1.2.5 --add-module=../nginx_upstream_check_module-0.1.9 --with-openssl=../openssl-1.0.1i --with-libatomic --with-pcre=../pcre-8.35 --with-pcre-jit --with-http_spdy_module --add-module=../ngx_pagespeed-release-1.9.32.1-beta
    Check PHP-FPM Version:
    PHP 5.4.33 (cli) (built: Oct 10 2014 06:20:16)
    MariaDB-server-10.0.14-1.el7.centos.x86_64
    MariaDB-client-10.0.14-1.el7.centos.x86_64
    MariaDB-shared-10.0.14-1.el7.centos.x86_64
    MariaDB-common-10.0.14-1.el7.centos.x86_64
    MariaDB-compat-10.0.14-1.el7.centos.x86_64
    MariaDB-devel-10.0.14-1.el7.centos.x86_64
    memcached 1.4.20
    Check CSF Firewall Version:
    csf: v7.54 (generic)
    SIEGE 3.0.8
    Copyright (C) 2014 by Jeffrey Fulmer, et al.
    FOR A PARTICULAR PURPOSE.
    Detected 7.0
    pscontrol handler
    pscontrol edit
    pscontrol on
    pscontrol off
    pscontrol statson
    pscontrol statsoff
    Check mysqlreport version:
    Check NSD Bind Version:
    NSD version 3.2.17
    Written by NLnet Labs.
    Check YUM Repo List
    99 packages excluded due to repository priority protections
    repo id  repo name  status
    base/7/x86_64  CentOS-7 - Base  6,551+1,914
    epel/x86_64  Extra Packages for Enterprise Linux 7 - x86_64  5,404+602
    extras/7/x86_64  CentOS-7 - Extras  44
    mariadb  MariaDB  12
    rpmforge  RHEL 7 - RPMforge.net - dag  232+13
    updates/7/x86_64  CentOS-7 - Updates  730+265
    repolist: 12,973
    grep: 10: No such file or directory
    * Centmin Mod install completed....
    *  Setup memcached_*.php admin page ...
    Setup Memcached Server Admin Login Details for /usr/local/nginx/html/memcache_479058d9.php
    current memcached username: memcacheuser
    current memcached password: memcachepass
    Memcached Server Admin Login: /usr/local/nginx/html/memcache_479058d9.php
    new memcached username: memadmin00aac4e7b1
    new memcached password: 07a8bdb1c53a92e
    * memcache_479058d9.php admin page installed
    * MariaDB Security Setup
    MySQL root user password set
    MySQL root user added to /root/.my.cnf
    MySQL root password: ndvOquQnXuJ
    * MariaDB Security Setup Completed
    Please bookmark:
    * Getting Started Guide - http://centminmod.com/getstarted.html
    * Find the latest Centmin Mod version - http://centminmod.com
    * Centmin Mod FAQ - http://centminmod.com/faq.html
    * Change Log - http://centminmod.com/changelog.html
    * Google+ Page latest news http://centminmod.com/gpage
    * Community Forums https://community.centminmod.com (signup)
    # Cheap VPS Hosting at Digitalocean
    # https://www.digitalocean.com/?refcode=c1cb367108e8
    ccache stats:
    cache directory  /home/.ccache
    cache hit (direct)  765
    cache hit (preprocessed)  303
    cache miss  2640
    called for link  156
    called for preprocessing  226
    compile failed  32
    preprocessor error  27
    bad compiler arguments  49
    unsupported source language  57
    autoconf compile/link  541
    unsupported compiler option  14
    no input file  122
    files in cache  5627
    cache size  140.9 Mbytes
    max cache size  2.0 Gbytes
    Total YUM Time: 276.641623939 seconds
    Total Centmin Mod Install Time: 2441.884395228 seconds
    1:15 AM
    excellent @Josephm thanks for the continued testing :D
    from Centmin Mod Nginx + ngx_pagespeed 1.9.32.1 beta point of view, need a workaround for the ngx_pagespeed 1.9.32.1 changed behaviour by adding an additional pagespeed on/off setting in /usr/local/nginx/conf/pagespeedadmin.conf and modifying pscontrol script to turn on/off pagespeed from both pagespeed on/off instances located in both /usr/local/nginx/conf/pagespeedadmin.conf and /usr/local/nginx/conf/pagespeed.conf files.
    I have started with updating Centmin Mod .08 beta01 with such changes (not yet tested) with commit at update for ngx_pagespeed 1.9.32.1 beta changed behaviour for .08 beta · 4bc1bbd · centminmod/centminmod · GitHub Will eventually do Centmin Mod .07 stable.
    Existing users: Syncing changes for ngx_pagespeed 1.9.32.1
    For existing .07 stable and .08 beta users to sync these ngx_pagespeed 1.9.32.1 beta changes with their working servers, you need to download the latest .07 stable or .08centos7beta01 zip file to /svr-setup to replace your existing zip and remove old extracted zip folder and unzip and extract the new latest zipf ile and chmod +x centmin.sh and then run centmin.sh and run a nginx recompile via menu option #4. What this will do is trigger inc/ningx_pagespeed.inc pagespeeduptask function at line 360. This pagespeeduptask function is responsible for checking existing Centmin Mod installs to see if there are any outdated or not expected nginx pagespeed config settings in the pagespeed include config files. If this function detects outdated config options, it will automatically replace the old pagespeed conf file with a new one based on functions outlined in inc/nginx_pagespeed.inc.
    In this case the made change is in pagespeedadmin.conf the addition of a pagespeed off; variable. Line 458 to 466 of pagespeeduptask function is what checks for pagespeed off variable in your server's copy at /usr/local/nginx/conf/pagespeedadmin.conf
    Line 460 checks for pagespeed on; or pagspeed off; variable and then if empty, it replaces your pagespeedadmin.conf with updated one via line 462 to 466 which in turn calls the makepsadmin function on lines 272 to 308.
  4. Josephm
    132
    44
    10:15 PM
    1.9.5
    10.0.21
    For me, enabled Pagespeed by default is a good point :D. I have to switch it on after installation anyway.
    1:15 AM
    1:15 AM
    1:15 AM
  8. Josephm
    132
    44
    10:15 PM
    1.9.5
    10.0.21
    Sometimes I've got forbidden message from centminmod server; seems firewall stopped me:
    Download siege-3.0.8.tar.gz ...
    Initializing download: http://centminmod.com/centminmodparts/siege/siege-3.0.8.tar.gz
    HTTP/1.0 403 Forbidden
    Error: siege-3.0.8.tar.gz download failed.
    check Centmin Mod log for details at /root/centminlogs/
    Aborting script...
    ccache stats:
    cache hit (direct)  0
    cache hit (preprocessed)  0
    cache miss  0
    files in cache  0
    cache size  0 Kbytes
    [root@centmin7 centminmod-123.08centos7beta01]# wget  http://centminmod.com/centminmodparts/siege/siege-3.0.8.tar.gz
    --2014-10-14 11:00:52--  http://centminmod.com/centminmodparts/siege/siege-3.0.8.tar.gz
    Resolving centminmod.com (centminmod.com)... 205.185.121.179
    Connecting to centminmod.com (centminmod.com)|205.185.121.179|:80... connected.
    HTTP request sent, awaiting response... 403 Forbidden
    2014-10-14 11:00:53 ERROR 403: Forbidden.
    is it possible for you to change these to author link? and other files as well?
    1:15 AM
    For all centminmod.com download links you get 403 forbidden ? Can you private message me your server's IP address so I can check my servers to see if you're being blocked for some reason. Centminmod.com is load balanced across 6+ VPS servers, so you might have hit a block on one of the servers or maybe all of them heh. You can visit the url below to check which server you're hitting
    http://centminmod.com/id.txt
    so on server affected try curl grab of the file
    curl http://centminmod.com/id.txt
    web1
    which shows I am hitting web1 server cluster
    Or change your inc/downloadlinks.inc yourself.
    But reason why you got Siege centminmod.com download link is that is the backup local download incase Siege primary download link is down. And seems Siege changed their download url so it failed when Centmin Mod tried to download, so fell back to the backup local centminmod download but you got 403 forbidden - lucky you :D j/k
    Commit fixed for updated Siege download url for all .07 stable and .08 betas at update /inc/downloadlinks.inc Siege download url changed · 6c3ddfb · centminmod/centminmod · GitHub
  10. Josephm
    132
    44
    10:15 PM
    1.9.5
    10.0.21
    Actually I do not see problems from my vps, but sometimes I'd like to test from my local internet (dynamic ip address) so I think it's a blacklisted ip.
    Btw; donot know why I'm always having unlucky things that others do not meet :(
  11. Josephm
    132
    44
    10:15 PM
    1.9.5
    10.0.21
    And one more thing; sometimes I had to use http instead of https for the installation code; otherwise, nothing happed:
    curl -sL https://gist.github.com/centminmod/dbe765784e03bc4b0d40/raw/installer.sh | bash
    1:15 AM
    strange could be like before some github's mirrored download urls redirect to a server with a problematic SSL configuration for some reasons... never experienced it myself and I've done 100s of installs using the that curl install method heh
    1:15 AM
    1:15 AM
    Updated both Centmin Mod 1.2.3-eva2000.07 stable and 1.2.3-eva2000.08 beta with OpenSSL 1.0.1j now :D
    Instructions for updating existing Centmin Mod Nginx installs for OpenSSL 1.0.1j at Nginx - Updating OpenSSL 1.0.1j for Centmin Mod | Centmin Mod Community
    1:15 AM
  16. Andy
    Andy Active Member
    546
    90
    10:15 AM
    wooo
    George living dangerously!!!!!
    1:15 AM
  18. Andy
    Andy Active Member
    546
    90
    10:15 AM
    1:15 AM
    Indeed hoping OpenSSL 1.0.2 becomes stable or that BoringSSL support in Nginx matures as that can allow dual SSL certificate support so you could give ECDSA or RSA exchanges depending on the visitor browser support Nginx - Nginx 1.7.5 overdue discussions | Centmin Mod Community !
  20. GhoHan
    GhoHan Member
    33
    14
    10:15 PM
    Nginx 1.13.X
    MariaDB 10.1.X
    @eva2000 i have tested CentOS 7.x - Centmin Mod .08 beta 01 today i think working fine just need Mcrypt PHP extension required for some framework like laravel.
