Install Ask everything about Centminmod
Discussion in 'Install & Upgrades or Pre-Install Questions' started by zhaosin, Aug 11, 2014.
  1. zhaosin
    zhaosin New Member
    10:13 PM
    MariaDB 5.5
    @eva2000
    59,717
    1:13 AM
  3. zhaosin
    zhaosin New Member
    10:13 PM
    MariaDB 5.5
    Can you provide your php-fpm.conf ?
    59,717
    1:13 AM
    FAQ 16 Centmin Mod FAQ - Menu based Nginx installer
    shortcut is fpmconf = /usr/local/etc/php-fpm.conf
  5. zhaosin
    zhaosin New Member
    10:13 PM
    MariaDB 5.5
    59,717
    1:13 AM
    won't help as you need to tune for you specific loads and well my forum is running multi PHP-FPM pool config so different from Centmin Mod defaults
    see
    basically if you're running a cpu limit at same time as max_children, you do not have enough cpu threads/core to handle your work load (you only have 2 cpu threads to use)
    59,717
    1:13 AM
  8. rdan
    11:13 PM
  9. zhaosin
    zhaosin New Member
    10:13 PM
    MariaDB 5.5
    I tried upgrade to Ram 4RB but still load high CPU, that mean, not VPS, just centmint , but don't know what problem and how to fix it @@
    59,717
    1:13 AM
  11. zhaosin
    zhaosin New Member
    10:13 PM
    MariaDB 5.5
    See picture with command 'top'
    59,717
    1:13 AM
    not enough cpu threads to service your php-fpm loads but you need to figure out where the PHP load is from as well as tune your php-fpm conf settings accordingly.
    also cpu load is for 1 minute interval so spikes are normal and it's only 2.95/2 = 1.48 cpu load average so not that bad
  13. zhaosin
    zhaosin New Member
    10:13 PM
    MariaDB 5.5
    How i can find the error @@
    59,717
    1:13 AM
    it ain't errors just normal PHP load or abnormal PHP load.. that's a whole process of troubleshooting that you need to do i.e. doing straces on php processes etc
    I don't provide support for that as Centmin Mod is provided as is, you'll have to do that or hire someone to do it for you
    Google might help see Let me google that for you
    but it could simply be the fact you PHP load is greater than number of cpu cores you have available - this would be a server hardware (cpu cores available) sizing issue for your specific php loads
