Sysadmin monitoring and alert tools?
Discussion in 'System Administration' started by Zykov, May 31, 2014.
  1. dorobo
    dorobo Active Member
    420
    104
    6:20 PM
    latest
    latest
    50 Free Uptime Monitoring Services
    http://blog.woorank.com/2014/05/50-free-uptime-monitoring-services/
  2. Matt
    Matt Well-Known Member
    937
    415
    Rotherham, UK
    11:20 AM
    1.5.15
    MariaDB 10.2
    Yeah, we've just had to upgrade the VM it's running on, as we needed more CPU to allocate to the pollers
    ^^ one of the dashboard we've built in it.
  3. palPalani
    palPalani Member
    30
    12
    Chennai, IN
    3:50 PM
    Nginx 1.7
    MariaDB 5.5
    12,578
    8:20 PM
    thanks for sharing :)
    OPSView looks interesting http://www.opsview.com/technology/guides-help/monitoring-examples/application-monitoring
    OPSView install http://docs.opsview.com/doku.php?id=opsview-core:centos-installation and http://www.opsview.com/technology/guides-help/opsview-installation/centos
    12,578
    8:20 PM
    12,578
    8:20 PM
    12,578
    8:20 PM
    Mmonit gave me an idea for custom shell script to check PHP uptime and status, checkphp.sh. Will expand it to add pushover notification support https://community.centminmod.com/threads/pushover.142/ :)
    i.e. checkphp.sh against 3x PHP-FPM TCP pools www, www2 and www3.
    /root/tools/checkphp.sh
    /root/tools/checkphp.sh {ping|status}
    /root/tools/checkphp.sh ping
    pong
    pong
    pong
    /root/tools/checkphp.sh status
    pool:                 www
    process manager:      ondemand
    start time:           29/Jun/2014:14:04:52 +0000
    start since:          3115
    accepted conn:        247
    listen queue:         0
    max listen queue:     0
    listen queue len:     32724
    idle processes:       0
    active processes:     1
    total processes:      1
    max active processes: 1
    max children reached: 0
    slow requests:        0
    pool:                 www2
    start since:          3115
    accepted conn:        437
    listen queue:         0
    max listen queue:     1
    idle processes:       0
    active processes:     1
    total processes:      1
    max active processes: 3
    slow requests:        0
    pool:                 www3
    start since:          3115
    accepted conn:        244
    listen queue:         0
    max listen queue:     0
    idle processes:       0
    active processes:     1
    total processes:      1
    slow requests:        0
  8. dorobo
    420
    104
    6:20 PM
    latest
    latest
    12,578
    8:20 PM
    thanks to @Matt idea for using constellix to check if ipv6 is working (y)
  10. Peter Downey
    Peter Downey Member
    64
    24
    6:20 AM
    I don't believe this was listed yet. Uptimerobot.com
    They have lots of configurable alert conditions as well as free text message, email, and twitter alerts when something goes down. Quite useful if you prefer SMS alerts.
    12,578
    8:20 PM
    Yup I alway use Uptimerobot as well monitoring and alert tools? | Centmin Mod Community :)
  12. Floren
    Floren Active Member
    148
    77
    6:20 AM
    @eva2000, those graphics are fancy but they don't do you any good. What if you want to see what process caused a load to the server at 0:48? Those tools don't do much good. I personally use Sealion as it reflects the true Linux processes and also allows you to customize everything based on your needs. Take a look at the custom top output I set:
  13. Floren
    148
    77
    6:20 AM
    This is how I do it in Sealion:
    Terminal flavor, much better. :)
    12,578
    8:20 PM
    Nice @Floren, the Constellix is only for uptime monitoring for cpu load there's other tools. But have to check out Sealion. Thanks for sharing :D
    12,578
    8:20 PM
    @Floren I like :woot: (y)
    but don't think sealion likes that system has only 128MB memory - some zombied processes heh
  16. Floren
    148
    77
    6:20 AM
    @eva2000 I posted into my review the commands we use at AXIVO. Try them and let me know if you get any zombies. IMO, they are due to the first initial load. Try:
    # service sealion restart
    12,578
    8:20 PM
    it's partly due to OpenVZ and how it handles memory used it counts VIRT as used memory and with CentOS default stack size of 10M can balloon memory. Tweaked stack size for Sealion process and now memory usage is better on OpenVZ :)
  18. Floren
    148
    77
    6:20 AM
    @eva2000, get rid of all extra commands you don't need, many of default ones are redundant.
    Also for iostat, use:
    Their default value generates server load and does not truly show you valuable disk info. Modify the commands to match the ones I posted into review.
  19. deltahf
    600
    274
    6:20 AM
    I use NewRelic and I absolutely love it. :)
    12,578
    8:20 PM
    yeah I use NewRelic too :)
