AMD Ryzen 9 7950X3D Dedicated Server discussions
Discussion in 'Dedicated server hosting' started by eva2000, Nov 8, 2023.
    12:15 AM
    @duderuud you have a beast of a dedicated server with AMD Ryzen 9 7950X3D https://community.centminmod.com/threads/post-your-130-00beta01-el9-install-times.24241/#post-97700
    So would you mind running some benchmarks? :) You don't have to if you don't want to. Just curious :)
    Some Centmin Mod Nginx HTTP/2 h2load benchmarks from https://github.com/centminmod/h2load-benchmarks as per https://community.centminmod.com/th...-00beta01-test-installation.24233/#post-97648
    Setup
    /usr/bin/nv -d domain.com -s y -u YOURFTPusername
    CNIP=$(curl -s https://geoip.centminmod.com/v4 | jq -r ".ip") && echo "$CNIP domain.com" >> /etc/hosts
    cat /etc/hosts
    curl -Ik https://domain.com
    cd /home; git clone https://github.com/centminmod/h2load-benchmarks
    Then HTTP/2 h2load benchmark run
    with 1 thread -t1
    /home/h2load-benchmarks/h2load-bench.sh -t1 -c100 -n5000 -u https://domain.com | grep -oP '{.*}' | jq -r | tee -a /home/nginxh2loadbench-summary1.log
    with 2 thread -t2
    /home/h2load-benchmarks/h2load-bench.sh -t2 -c100 -n5000 -u https://domain.com | grep -oP '{.*}' | jq -r | tee -a /home/nginxh2loadbench-summary2.log
    with 4 thread -t4
    /home/h2load-benchmarks/h2load-bench.sh -t4 -c100 -n5000 -u https://domain.com | grep -oP '{.*}' | jq -r | tee -a /home/nginxh2loadbench-summary4.log
    with 8 thread -t8
    /home/h2load-benchmarks/h2load-bench.sh -t8 -c100 -n5000 -u https://domain.com | grep -oP '{.*}' | jq -r | tee -a /home/nginxh2loadbench-summary8.log
    with 16 thread -t16
    /home/h2load-benchmarks/h2load-bench.sh -t16 -c100 -n5000 -u https://domain.com | grep -oP '{.*}' | jq -r | tee -a /home/nginxh2loadbench-summary16.log
    with 24 thread -t24
    /home/h2load-benchmarks/h2load-bench.sh -t24 -c100 -n5000 -u https://domain.com | grep -oP '{.*}' | jq -r | tee -a /home/nginxh2loadbench-summary24.log
    with 32 thread -t32
    /home/h2load-benchmarks/h2load-bench.sh -t32 -c100 -n5000 -u https://domain.com | grep -oP '{.*}' | jq -r | tee -a /home/nginxh2loadbench-summary32.log
    Then sysbench benchmarks setup
    mkdir -p /root/tools/sysbench
    cd /root/tools/sysbench
    wget -O /root/tools/sysbench/sysbench.sh https://github.com/centminmod/centminmod-sysbench/raw/master/sysbench.sh
    chmod +x sysbench.sh
    ./sysbench.sh install
    Run benchmarks
    ./sysbench.sh cpu
    ./sysbench.sh mem
    ./sysbench.sh file
    ./sysbench.sh file-16k
    ./sysbench.sh file-64k
    ./sysbench.sh file-512k
    ./sysbench.sh file-1m
    ./sysbench.sh mysqloltpnew
  2. duderuud
    duderuud Active Member
    328
    98
    The Netherlands
    4:15 PM
    1.29 x
    11.4
    See attachment. Not a 100% sure the h2load benchmarks are correct though.
    12:15 AM
    Cheers. Those Nginx HTTP/2 HTTPS h2load benchmarks look right to me, though higher numbers in terms of requests/s
  4. rdan
    10:15 PM
    Does it have 100% uptime?
    Like Xeon servers.
    I tried some of the older AMD Ryzen servers from Hetzner auctions (AMD Ryzen 9 5950X), and after 40+ days of running it just hangs up for unknown reasons (I cannot find some reasons on the logs).
    I also suspect it could be because I'm using HWE kernels at that time.
  5. duderuud
    328
    98
    The Netherlands
    4:15 PM
    1.29 x
    11.4
    I have not experienced the hang ups...
  6. rdan
    10:15 PM
    Maximum days its been up and online?
    I might try the same CPU config from Hetzner.
    Thank you.
  7. duderuud
    328
    98
    The Netherlands
    4:15 PM
    1.29 x
    11.4
    No idea really but 30+ days was no issue at all. I regularly reboot servers after significant updates.
  8. Wormonow
    Wormonow New Member
    5:15 PM
    I've been looking into servers like this one, too, and while they offer some solid performance, especially for benchmarks, it's worth checking out options that are more geared toward streaming and high-demand applications.
  9. Menserret
    Menserret New Member
    15
    5:15 PM
    There are many advantages of AMD Ryzen 9:
    1) High core and thread counts make it ideal for heavy multitasking, virtualization, and content creation.
    2) Handles multiple VMs, containers, and high-traffic applications smoothly.
    3) Faster NVMe storage and GPU performance for modern systems.
  10. Grombahen
    Grombahen New Member
    5:15 PM
    With 12–16 cores and 24–32 threads (depending on the model), Ryzen 9 servers can: 1) Handle heavy multitasking: 2) Run multiple VPS instances; 3) Manage virtualization efficiently; 4) Support large databases and web applications
  11. Mctokens
    Mctokens New Member
    27
    5:15 PM
    As I see it, the main advantages of running Ryzen 9 is high clock speeds plus technologies like Precision Boost and 3D V-Cache (in X3D models) help Ryzen 9 chips deliver excellent gaming performance — improving frame rates and responsiveness, especially in CPU-dependent game scenarios.
  12. AYKS
    AYKS New Member
    15
    5:15 PM
    Definitely know that truth comes out of a comparison. Also choose time-tested and trusted host - keep in mind these few guidelines and you'll turn your project into success.
  13. rumso
    rumso New Member
    5:15 PM
    Believe it will be better to choose the host that suits your needs and provides constant and uninterrupted services and support. There are many web hosts available with global server lineup with the latest AMD Ryzen 9 CPUs to deliver more power and performance across multiple data centers.
  14. FireVM
    FireVM New Member
    13
    5:15 PM
    Are there set-up fees? If so, what are they – and are they waived for first-time subscribers?
  15. duderuud
    328
    98
    The Netherlands
    4:15 PM
    1.29 x
    11.4
