Wordpress Some WordPress issues
Discussion in 'Blogs & CMS usage' started by fly, Jan 24, 2020.
  1. Nik
    Nik Member
    103
    7
    2:23 AM
    To clarify it worked then I updated PHP then it immediately didn't work, I didn't wait any number of hours . Now recreatable on 2 servers. I will remove all plugins but I seriously doubt that's it.
  2. SineDave
    SineDave New Member
    1:23 AM
    Hi @eva2000 - I'm having the same problem now. I did run an option 13 yesterday to install Redis. Anyone else reporting this issue?
    @Nik did you ever resolve this?
  3. Nik
    Nik Member
    103
    7
    2:23 AM
    Nope I did not. I live with it now.
    Are you running XF btw?
  4. SineDave
    SineDave New Member
    1:23 AM
    Yes
  5. Nik
    Nik Member
    103
    7
    2:23 AM
    It was definitely triggered by
    Are you running TH XPress?
  6. Nik
    Nik Member
    103
    7
    2:23 AM
    @eva2000
    There's something super wrong with XF on your site right now. It's caching responses and frequently clocking when hitting Post Reply. Thought I'd mention it.
  7. pamamolf
    4,128
    8:23 AM
    No issues for Wordpress and Invision forum using the latest Redis...
    It may help to post all your plugins that you are using...
    60,092
    12,584
    4:23 PM
    what is exact error messages you see as there's different issues discussed in this thread. I can't reproduce phar error but PHP 7.4 incompatible errors I confirmed is related to PHP 7.4 which is resolved if you downgrade to PHP 7.3 Wordpress - Some WordPress issues
    But if you're using Wordpress with Xenforo bridge addon, then that could be where problem lies in Xenforo related PHP code and not Wordpress. Unfortunately can't help with that as Wordpress setup wasn't tested or intended for as a bridge to Xenforo addon.
    If you are using Xenforo wordpress bridge addon, try disabling all forms of caching on Xenforo side i.e. disable Xenforo full page guest html cache, any redis caching etc and see. So try disabling the bridge addon in Xenforo and see.
  9. Nik
    Nik Member
    103
    7
    2:23 AM
    I don't think the other report confirms use of the bridge addon, waiting to hear back.
    So I can successfully get rid of this error by disabling the TH bridge addon. I don't know if the other reports are using it or not. Nothing else in my config has actively changes beyond updates to centmin and various recompiles. What I can confirm back when the post was created was that one of those recompiles resulted in these errors going forward. It's php version agnostic as I've proven personally. Unfortunately I cannot live without XPress and albeit issue was reported to TH a while back they are a shell of their former selves so fully expect that this will never get resolved unless many others report it.
    Interested to see if anyone else is running the bridge addon.
    I'm not running any caching on the WP side of the integration.
  10. SineDave
    SineDave New Member
    1:23 AM
    I am also using TH Xpress. Here is the error:
    [21:51][root@xf.domain.com centminmod]# cd /home/nginx/domains/domain.com/public/
    [21:51][root@xf.domain.com public]# wp plugin update --all
    Fatal error: Uncaught ErrorException: file_exists(): Unable to find the wrapper "phar" - did you forget to enable it when you configured PHP? in /root/.wp-cli/packages/vendor/composer/ClassLoader.php:394
    Stack trace:
    #0 [internal function]: XenForo_Application::handlePhpError(2, 'file_exists(): ...', '/root/.wp-cli/p...', 394, Array)
    #1 /root/.wp-cli/packages/vendor/composer/ClassLoader.php(394): file_exists('phar:///usr/bin...')
    #2 /root/.wp-cli/packages/vendor/composer/ClassLoader.php(351): Composer\Autoload\ClassLoader->findFileWithExtension('XenForo_Error', '.php')
    #3 /root/.wp-cli/packages/vendor/composer/ClassLoader.php(321): Composer\Autoload\ClassLoader->findFile('XenForo_Error')
    #4 [internal function]: Composer\Autoload\ClassLoader->loadClass('XenForo_Error')
    #5 /home/nginx/domains/domain.com/public/community/library/XenForo/Application.php(380): spl_autoload_call('XenForo_Error')
    #6 [internal function]: XenForo_Application::handleException(Object(ErrorException))
    #7 {main}
      thrown in /root/.wp-cli/packages/vendor/composer/ClassLoader.php on line 394
  11. Nik
    Nik Member
    103
    7
    2:23 AM
    Interesting. So it is xpress related but why it started breaking after a CM update I do not know.
    I logged it already here, you may want to add to it as TH of course incorrectly closed it already so it's taken an effort to relog issues.
    WP CLI is Broken by XPress · Issue #597 · Audentio/xlink-issues
  12. SineDave
    SineDave New Member
    1:23 AM
    @Nik Audentio and I have chatted about this. They are confident it's not their code, but a conflict with another item, but they do have a workaround:
    It is possible to manually patch the issue by inserting the following line at the start of <wp_root>/wp-content/plugins/wp-xpress-plugins/thxpress.php, but the patch needs to be performed each time the file is updated:
    stream_wrapper_restore('phar');​
  13. Nik
    Nik Member
    103
    7
    2:23 AM
    That's great. Yes I'm confident it's not their issue even though disabling every plugin except for theirs still produces the issue but you know what do I know...
    Thank you for coming back with a fix.
  14. SineDave
    SineDave New Member
    1:23 AM
    Some time in the recent past, Audentio's fix stopped working. I stumbled across a thread on the XF forums that they're disabling phar in XF now to solve security issues. XF is loaded at all times with XPress, which made me think maybe the problem was in XF and not WP.
    I was able to restore phar functionality on my server and WP CLI in kind by adding the below to the xenforo /src/config.php file at the top:
    60,092
    12,584
    4:23 PM
    Thanks @SineDave for the update! (y)
    edit: Actually, I think I ran into this for a recent paying client of mine when I setup staging server copy of his site. He uses XPress too for his Wordpress + Xenforo site. But they're planning on removing XPress and decoupling their Wordpress and Xenforo sites
