Wordpress Some WordPress issues
Discussion in 'Blogs & CMS usage' started by fly, Jan 24, 2020.
  1. Nik
    Nik Member
    103
    7
    2:23 AM
    From that blog directory. Same as the formerly working server.
    60,092
    12,584
    4:23 PM
    strange then, i retested with PHP 7.4.3 and wp cli only reports an issue with PHP 7.4 compatibility AFAIK but still works
    when run with PHP 7.4.3
    wp plugin status
    Notice: Trying to access array offset on value of type null in phar:///usr/bin/wp/vendor/wp-cli/extension-command/src/Plugin_Command.php on line 662
    Notice: Trying to access array offset on value of type null in phar:///usr/bin/wp/vendor/wp-cli/extension-command/src/Plugin_Command.php on line 663
    9 installed plugins:
      I akismet            4.1.3
      A autoptimize        2.6.1
      A autoptimize-gzip   0.1
      A cache-enabler      1.3.4
      I cdn-enabler        1.0.9
      A classic-editor     1.5
      A disable-xml-rpc    1.0.1
      A sucuri-scanner     1.8.24
      D advanced-cache.php
    when run with PHP 7.3.15
    wp plugin status
      I akismet            4.1.3
      A autoptimize        2.6.1
      I cdn-enabler        1.0.9
    Legend: I = Inactive, A = Active, D = Drop-In
  3. Nik
    Nik Member
    103
    7
    2:23 AM
    Did you go through the recompile steps? In my case it only started after a recompile.
  4. Nik
    Nik Member
    103
    7
    2:23 AM
    60,092
    12,584
    4:23 PM
    yes i did
    can you share the contents of your persistent config file /etc/centminmod/custom_config.inc as well ?
  6. Nik
    Nik Member
    103
    7
    2:23 AM
    Sure. Here's the old server contents:
    NGINX_PAGESPEED=y
    NGINX_ZLIBCUSTOM='y'
    ORESTY_LUANGINX=n
    NGINX_XSLT='n'
    NGINX_LIBBROTLI='y'
    NGXDYNAMIC_XSLT='n'
    NGXDYNAMIC_IMAGEFILTER='y'
    NGXDYNAMIC_GEOIP='y'
    NGXDYNAMIC_STREAM='y'
    NGXDYNAMIC_HEADERSMORE='y'
    NGXDYNAMIC_SETMISC='y'
    NGXDYNAMIC_ECHO='y'
    NGXDYNAMIC_SRCCACHE='y'
    NGXDYNAMIC_MEMC='y'
    NGXDYNAMIC_REDISTWO='y'
    NGXDYNAMIC_NGXPAGESPEED='y'
    NGXDYNAMIC_BROTLI='y'
    PHPMSSQL='y'
    PHP_PGO='y'
    PHP_PGO_CENTOSSIX='y'
    NGINX_DEVTOOLSETGCC='y'
    GENERAL_DEVTOOLSETGCC='y'
    CLANG='n'
    LIBRESSL_SWITCH='n'
    MARIADB_INSTALLTENTHREE='y'
    LETSENCRYPT_DETECT='y'
    PHPFINFO=y
    CLOUDFLARE_ZLIBPHP='y'
    DUALCERTS='y'
    New server custom:
    ALERTEMAIL='myemail@gmail.com'
    MM_LICENSE_KEY='keykeykey'
    NGINX_PAGESPEED='n'
    ORESTY_LUANGINX=n
    NGINX_XSLT='n'
    NGINX_LIBBROTLI='y'
    NGXDYNAMIC_XSLT='n'
    NGXDYNAMIC_ECHO='y'
    NGXDYNAMIC_MEMC='y'
    PHPMSSQL='y'
    PHP_PGO='y'
    CLANG='n'
    LIBRESSL_SWITCH='n'
    PHPFINFO=y
    #CLOUDFLARE_ZLIBPHP='y'
    DUALCERTS='y'
    AUTODETECPHP_OVERRIDE='y'
    PHP_BROTLI='y'
    PHP_LZFOUR='y'
    PHP_LZF='y'
    PHP_ZSTD='y'
    # Maintenance Mode (will run maintenance mode during these upgrades)
    NGINX_UPDATEMAINTENANCE='y'
    PHP_UPDATEMAINTENANCE='y'
    MARIADB_UPDATEMAINTENANCE='y'
    NGINX_IOURING_PATCH='y' #disable
    NGINX_HPACK='y' #Disable
    AUTOTUNE_CLIENTMAXBODY='y'
    NGINX_DYNAMICTLS='y' #disable
    AUTOHARDTUNE_NGINXBACKLOG='y'
    ZSTD_LOGROTATE_NGINX='y'
    ZSTD_LOGROTATE_PHPFPM='y'
    #NGINX_ZERODT='y'
    CRYPTO_DEVTOOLSETGCC='y'
    MARCH_TARGETNATIVE='y'
    MARCH_TARGETNATIVE_ALWAYS='y'
    DEVTOOLSETNINE='y'
    Both having the same issue as I mentioned earlier.
    60,092
    12,584
    4:23 PM
    you using CentOS 6.10 or CentOS 7.7 ?
  8. Nik
    Nik Member
    103
    7
    2:23 AM
    Always 7....
    Both configs were derived from beta-installerlatest...
    I was actually wondering about that parameter yesterday and why it was added. Should I set that to No (or remove it entirely)
    60,092
    12,584
    4:23 PM
    if using CentOS 7, then you can remove PHP_PGO_CENTOSSIX='y' as it isn't needed but should be related to your wp cli phar issue anyway
  10. Nik
    Nik Member
    103
    7
    2:23 AM
    Thanks, removed it and doing a recompile though that option has always been there since day 1.
  11. Nik
    Nik Member
    103
    7
    2:23 AM
    No that was not the issue sadly.
  12. Nik
    Nik Member
    103
    7
    2:23 AM
    OK, so tried it on another WP site (that's in root) same config and it works so looks like specific to /subdirectory..... Hmmmm. Plot thickens.
    60,092
    12,584
    4:23 PM
    i meant should NOT be related heh
    interesting
    tried downgrading to PHP 7.2.28 first ?
  14. Nik
    Nik Member
    103
    7
    2:23 AM
    OK, 7.2.28 exactly same issue. /blog subdir doesn't work, root works.
    It appears to be subdirectory related and appears to be an issue introduced in the last 6-8 weeks or so. It's been that long since I ran cmupdate and did a php upgrade on the old server.
    60,092
    12,584
    4:23 PM
    what about command like
    wp plugin status --path=/home/nginx/domains/mysite.com/public/blog
    60,092
    12,584
    4:23 PM
    also try
    wp plugin status --path=/home/nginx/domains/mysite.com/public/blog --debug
  17. Nik
    Nik Member
    103
    7
    2:23 AM
    Same issue though I do get many screens of debug bootstrap commands and what appear to be my plugins and a An unexpected error occurred. Please try again later. at the end.... It's a huge log so let me know if you want it....
    60,092
    12,584
    4:23 PM
    sounds like a plugin incompatibility with wp-cli, it's been known to happen. Try temporarily disabling wp plugins and re-running wp plugin status command to isolate which wordpress plugin (s) maybe having issues
    you can also try isolated testing via wp plugin status with --skip-plugins argument too on command line wp plugin status | WordPress Developer Resources
  19. Nik
    Nik Member
    103
    7
    2:23 AM
    I don't understand how this would happen at all, it's an unused server, it worked, I did a PHP upgrade then stopped working. I appreciate your time on this issue. It's quite possible it could be widespread and people are not combing through their logs to spot it.
    60,092
    12,584
    4:23 PM
    yeah it could happen if wordpress plugin updated and made it incompatible as centmin.sh menu option 22 wordpress installs have a cronjob setup to auto update wordpress plugins every 8hrs. So while you had an unused/idle server, it would of still had auto updated wordpress plugins :)
