Site broken in Internet Explorer/Edge
Discussion in 'Forum Feedback & Suggestions' started by Xon, Dec 6, 2016.
  1. RB1
    RB1 Active Member
    292
    75
    California
    1:35 PM
    MariaDB 10.1.x
    I can't believe people still use IE!
    Some of the screenshots in this thread look like other websites when you have AdBlock enabled :)
    Edit: Don't forget to disable AdBlock/uBlock for centminmod.com! I just remembered to whitelist...didn't notice it was blocking :ninja:
    6:35 AM
    ~5-6% of forum visitors use MS Edge and IE11 - MS Edge makes up 2-4% of total.
  3. RB1
    RB1 Active Member
    292
    75
    California
    1:35 PM
    MariaDB 10.1.x
    One of my websites is upwards of 30-35%
  4. Xon
    Xon Active Member
    173
    61
    4:35 AM
    Rather broken again
    6:35 AM
    yeah leaving it in place so ngx_pagespeed and ngx_brotli folks can see and diagnose the issue for now :)
  6. tuwi
    tuwi New Member
    10:35 PM
    hi,
    the issue is back weirdly..
    6:35 AM
    see my previous reply, i re-enabled broken ngx_brotli so the devs can troubleshoot the issue :)
    6:35 AM
  9. upgrade81
    upgrade81 Member
    296
    CH
    10:35 PM
    1.17
    10.3
    Hello everyone, recently I am a happy user of centminmod for my sites.
    I also re-encountered the exact same problem, you can visit one of my sites with Microsoft Edge and note that many files needed to render the page are not loaded or remain in stand-by.
    you can try disdette.pro or samsungmobile.it
    These sites have been installed with option 22 and redis cache, but it does so on ALL the sites on this dedicated server with both redis / or cache enabler.
    If I use cloudflare, they work. Currently I use cloudflare only in dns mode.
    PS: I do not use brotli ever configured.
    Server configured 7 days ago.
    I use the last beta available and this is my custom inc.
    LETSENCRYPT_DETECT='y'
    NGINX_DYNAMICTLS='y'
    #CLOUDFLARE_ZLIB='y'
    NGINX_HPACK='y'
    OPENSSL_VERSION='1.1.0g'
    LIBRESSL_SWITCH='n'
    OPENSSLECDSA_PATCH='y'
    OPENSSLECDHX_PATCH='y'
    NGINX_IPV='y'
    NGINX_STREAM=n               # http://nginx.org/en/docs/stream/ngx_stream_core_module.html
    NGINX_RTMP=n                 # Nginx RTMP Module support https://github.com/arut/nginx-rtmp-module
    NGINX_FLV=n                  # http://nginx.org/en/docs/http/ngx_http_flv_module.html
    NGINX_MP4=n                  # Nginx MP4 Module http://nginx.org/en/docs/http/ngx_http_mp4_module.html
    NGINX_AUTHREQ=n              # http://nginx.org/en/docs/http/ngx_http_auth_request_module.html
    NGINX_SECURELINK=y           # http://nginx.org/en/docs/http/ngx_http_secure_link_module.html
    NGINX_FANCYINDEX=n           # http://wiki.nginx.org/NgxFancyIndex
    NGINX_VHOSTSTATS=n           # https://github.com/vozlt/nginx-module-vts
    NGINX_PAGESPEED=n            # Install ngx_pagespeed
    NGINX_PASSENGER='n'          # Install Phusion Passenger requires installing addons/passenger.sh before hand
    NGINX_WEBDAV=n               # Nginx WebDAV and nginx-dav-ext-module
    NGINX_UPSTREAMCHECK='n'      # nginx upstream check https://github.com/yaoweibin/nginx_upstream_check_module
    NGINX_OPENRESTY='n'            # Agentzh's openresty Nginx modules
    LUAJIT_GITINSTALL='n'        # opt to install luajit 2.1 from dev branch http://repo.or.cz/w/luajit-2.0.git/shortlog/refs/heads/v2.1
    ORESTY_LUANGINX='n'             # enable or disable or ORESTY_LUA* nginx modules below
    #Php Custom
    PHP_PGO='y'
    PHP_VERSION='7.1.13'
    GCCINTEL_PHP='y'
    6:35 AM
