Featured Nginx How to use Brotli compression for Centmin Mod Nginx web servers
Discussion in 'Centmin Mod User Tutorials & Guides' started by eva2000, Mar 6, 2017.
    55,685
    12,270
    8:22 AM
    Brotli compression for web servers is an alternative to Gzip compression for static files. It is one of the performance configuration tips I listed in my guide at Insight Guide - How to boost Centmin Mod LEMP stack performance. April 18, 2020: ngx_brotli module has an update to fix a 100% cpu load issue. See info on how to update at Nginx Brotli Module Update To Fix 100% CPU Load Issues
    You can read about Brotli compression in web server context over on Cloudflare's blog and the current state of web browser adoption at http://caniuse.com/#search=brotli. Google Play Store on a daily basis saves 1.5 petabytes (1.5 million gigabytes) of bandwidth each day using Brotli !
    Notes:
    • Centmin Mod Nginx Brotli is used for page load speed - better compression means smaller compressed file sizes. But it comes at expense of scalability in terms of handling larger concurrency traffic loads according to benchmarks here. However, this only applies to Nginx Brotli implementation. If you use Cloudflare in front of your server, using Cloudflare's Brotli implementation is faster than Cloudflare zlib/gzip in terms of page load speed + scales just as well so Cloudflare Brotli is a good to have enabled. So for Centmin Mod Nginx you may want to disable ngx_brotli (the default state already) if you have alot of concurrent user traffic and you're hitting server resource limits. Though for page load speed ngx_brotli is better so if you have the server resources to handle the concurrent traffic load and not running against server resource limits, ngx_brotli is still viable option to enable.
    How To Use Nginx Brotli Compression
    To properly utilise Brotli compression, your web server needs to be able to serve Brotli Content-Encoding headers to only web browsers that support it and your web site needs to serve the web assets, css and js etc over HTTPS with SSL certificate.
    For Nginx there is an ngx_brotli module which can be compiled into Nginx to support such. Centmin Mod Nginx uses a more up to date fork of original Google ngx_brotli module maintained and developed by one of the original Google Brotli authors, Eugene Kliuchnikov at eustas/ngx_brotli. However, Eugene recently moved development back to original Google Nginx Brotli Github repo at https://github.com/google/ngx_brotli/ so Centmin Mod Nginx has moved back as well.
    Since October 2015, Centmin Mod latest 123.09beta01 branch's Nginx server has built in support for ngx_brotli module that can optionally be enabled or disabled via persistent config file /etc/centminmod/custom_config.inc set variables below:
    NGXDYNAMIC_BROTLI='y'
    NGINX_LIBBROTLI='y'
    Once variables set, you recompile Centmin Mod Nginx via centmin.sh menu option 4 and will have ngx_brotli support enabled. Centmin Mod Nginx dynamic modules are loaded from /usr/local/nginx/modules directory via an include file /usr/local/nginx/conf/dynamic-modules.conf in /usr/local/nginx/conf/nginx.conf.
    1).  Centmin Install
    2).  Add Nginx vhost domain
    5).  PHP Upgrade / Downgrade
    6).  XCache Re-install
    7).  APC Cache Re-install
    8).  XCache Install
    9).  APC Cache Install
    14). SELinux disable
    16). Change SSHD Port Number
    20). NSD Install/Re-Install
    24). Exit
    Enter option [ 1 - 24 ]
    You can check Centmin Mod Nginx has ngx_brotli enabled via command below to show Nginx's compiled and enabled modules
    nginx -V
    Look for the line --add-dynamic-module=../ngx_brotli
    With the added update I made, the Nginx version command (nginx -V) will output a build tag which also displays ngx_brotli module's latest commit hash so you can check if you have latest ngx_brotli module updates built for Centmin Mod Nginx binary :)
    Example below where (190420-104720-centos7-5cd76ab-br-bcceaab) is the build tag which now shows data stamp 190420 for April 19, 2020 build AT 10:47:20 AM from Centmin Mod commit 5cd76ab from commit history at centminmod/centminmod and because NGINX_LIBBROTLI='y' was enabled as per instructions, also shows bcceaab which at time of writing is latest commit from ngx_brotli history at google/ngx_brotli. This makes troubleshooting easier as you know the state of the Nginx version built.
    In /usr/local/nginx/conf/nginx.conf contains include file to load Nginx dynamic modules
    include /usr/local/nginx/conf/dynamic-modules.conf;
    And also contains an include file with actual Nginx Brotli settings
    include /usr/local/nginx/conf/brotli_inc.conf;
    Contents of /usr/local/nginx/conf/dynamic-modules.conf will contain Nginx Brotli's dynamic and static modules
    load_module "modules/ngx_http_brotli_filter_module.so";
    load_module "modules/ngx_http_brotli_static_module.so";
    Contents of /usr/local/nginx/conf/brotli_inc.conf with ngx_brotli settings
    brotli on;
    brotli_static on;
    brotli_min_length 1000;
    brotli_buffers 32 8k;
    brotli_comp_level 5;
    brotli_types text/plain text/css text/xml application/javascript application/x-javascript application/xml application/xml+rss application/ecmascript application/json image/svg+xml;
    With Centmin Mod Nginx's Brotli module enabled, this will configure both Brotli on the fly compression as well as support Brotli static file serving if a *.br extension file is detected. To test, you can use curl command with appropate Accept-Encoding directives for gzip and br.
    Curl content encoding gzip,br check for Centmin Mod Nginx based server with ngx_brotli enabled. Check for Content-Encoding: br to confirm that Nginx is serving Brotli compressed version of the css or js file.
    curl -sI /dev/null -H"Accept-Encoding: gzip,br" https://domain.com/brotlitest2/bootstrap.min.css
    HTTP/1.1 200 OK
    Date: Sun, 05 Mar 2017 16:39:04 GMT
    Content-Type: text/css
    Content-Length: 16149
    Last-Modified: Mon, 25 Jul 2016 16:08:01 GMT
    Connection: keep-alive
    Vary: Accept-Encoding
    ETag: "57963961-3f15"
    Server: nginx centminmod
    X-Powered-By: centminmod
    Expires: Tue, 04 Apr 2017 16:39:04 GMT
    Cache-Control: max-age=2592000
    Access-Control-Allow-Origin: *
    Cache-Control: public, must-revalidate, proxy-revalidate
    Curl content encoding gzip check for Centmin Mod Nginx based server with ngx_brotli enabled. Check for Content-Encoding: gzip to confirm that Nginx is serving Gzip compressed version of the css or js file.
    curl -sI /dev/null -H"Accept-Encoding: gzip" https://domain.com/brotlitest2/bootstrap.min.css
    HTTP/1.1 200 OK
    Date: Sun, 05 Mar 2017 16:40:19 GMT
    Content-Length: 18322
    ETag: "57963961-4792"
    Expires: Tue, 04 Apr 2017 16:40:19 GMT
    Other Notes
    • For Xenforo you may need to add to your library/config.php the setting
      $config['enableGzip'] = false;
    55,685
    12,270
    8:22 AM
    Also posted on Github a brotli.sh tool to generate static brotli (*.br) and gzip (*.gz) assets for css and js files you can play with at https://centminmod.com/brotlistatic
    • brotli.sh tool to auto compress css and js files by specifying path on CentOS based Centmin Mod LEMP web stack servers.
    • Appending clean flag on end of directory path will remove any *.br or *.gz compressed files. I usually place my tools at /root/tools but you can place brotli.sh whereever you want.
    • Appending display flag will find and display all *.br and *.gz compressed css and js files.
    Usage
    /root/tools/brotli.sh /path/to/parent/directory
    /root/tools/brotli.sh /path/to/parent/directory clean
    /root/tools/brotli.sh /path/to/parent/directory display
    gzip_static and brotli_static options in Nginx are enabled by default. So when Nginx sees a html, css, js file it wants to serve to visitors, it can either serve and compress on the fly at visitor request time the static file using gzip or brotli (if supported) or with gzip_static and brotli_static enabled look for *.gz or *.br precompressed versions of the static file and serve that instead.
    Precompressed static assets can be compressed using higher compression levels to further reduce the size of the static assets and improve page loading performance without the expensive cpu overhead of on the fly compression. You can see dramatic difference in performance if you can safely serve pre-compressed gzip and/or brotli static file assets compared to on the fly gzip or brotli compression in benchmarks posted here and below results table.
    config compressed size req/s avg latency max latency
    Centmin Mod Nginx zlib level 5 pre-compress static (cf fork) 3.79KB 72443 3.27ms 32.38ms
    Centmin Mod Nginx zlib level 6 pre-compress static (cf fork) 3.79KB 71905 3.36ms 50.43ms
    Centmin Mod Nginx brotli level 5 pre-compress static 3.38KB 84643 2.76ms 39.79ms
    Centmin Mod Nginx brotli level 6 pre-compress static 3.38KB 84975 2.96ms 87.54ms
    Centmin Mod Nginx zlib level 5 dynamic (cf fork) 4.12KB 21906 9.07ms 74.32ms
    Centmin Mod Nginx zlib level 6 dynamic (cf fork) 4.00KB 16997 11.67ms 49.06ms
    Centmin Mod Nginx brotli level 5 dynamic 3.93KB 5060 38.61ms 167.43ms
    Centmin Mod Nginx brotli level 6 dynamic 3.66KB 4875 40.12ms 119.51ms
    55,685
    12,270
    8:22 AM
    You can also use your Chrome or web browser's developer tools network tab to see Content-Encoding of site's assets i.e. html file index for centminmod.com has Content-Encoding = br for brotli compression. Page is served over HTTP/2 based HTTPS (Protocol = h2).
    55,685
    12,270
    8:22 AM
    Don't have a HTTP/2 based HTTPS site yet for Brotli ? Centmin Mod Nginx has 2 guides for setting up free Letsencrypt SSL certificates and Centmin Mod Nginx HTTP/2 based HTTPS below:
  5. pamamolf
    4,101
    428
    1:22 AM
    Nginx-1.26.x
    So it can automaticaly check if user browser support brotli and serve a .br file and if not it will use a .gz file?
    It will auto fallback so no issues if the user uses an old browser ?
    Also how brotli handle css/js file changes ? It is autodetect them and recompress them?
    Also how it plays with Cloudflare enabled?
  6. SFLC
    SFLC Active Member
    223
    59
    The Canadas
    12:22 AM
    Works perfectly for me, I think you'd have to run with clean and then run it again on the path when you make changes as there's no way for it to detect changes automatically.
    Also, I'm using cloudflare and definitely no issues there, it's a lot faster and using this provides a noticeable improvement in my page load times.
    Can't get it to work with wordpress though but I think it's because I have it set to output HTTP/1.1 503 Service Temporarily Unavailable in the header as that site's not officially open to the public yet
    55,685
    12,270
    8:22 AM
    yes .br should only be served to browsers that support it. Though i have one issue related to Sucuri cloudproxy's caching of brotli files and serving to non supported browsers https://community.centminmod.com/threads/site-broken-in-internet-explorer-edge.9701/. So turned off brotli for forums when behind Sucuri cloudproxy.
    Yes for on the fly compression if no precompressed .br or .gz files are detected. Otherwise if precompressed .br or .gz files detected, they get served and can get out of date and need recompressing if you precompress files i.e. using brotli.sh from centminmod.com/brotlistatic
    Works for me on centminmod.com cloudflare mirror at centmin.sh though not sure why files are served gzip and not brotli there.
    55,685
    12,270
    8:22 AM
    If you use wordpress plugins that cache and/or pre-gzip compress files, then you'll already have pre-gzipped compressed versions that Centmin Mod Nginx serves via gzip_static directive. Not sure but IIRC pre-gzipped files take priority over on the fly brotli compression. But I believe if both pre-gzipped and pre-brotli compressed files exist, pre-brotli compressed files take priority if browser supports brotli.
    HTTP/1.1 200 OK
  9. BamaStangGuy
    BamaStangGuy Active Member
    668
    192
    5:22 PM
    I have this enabled on Christian Forums but not seeing any content being served via br. Do I need to flush CloudFlare cache or change anything else?
  10. RB1
    RB1 Active Member
    292
    75
    California
    3:22 PM
    MariaDB 10.1.x
    How do I force Brotli to start working :p
    I'm using a supported browser, Brotli is compiled in nginx, and all Brotli config files exist.
    Currently testing on a static website (not Wordpress) over HTTPS with all PageSpeed and Cloudflare cache cleared however it's still showing gzip headers and KeyCDN Brotli Test | Brotli compression check showing Brotli unsupported.
    Edit: Also restarted server.
    55,685
    12,270
    8:22 AM
    i see the same for my mirror under Cloudflare
    @RB1 and @BamaStangGuy so probably doesn't work with Cloudflare - might need to ask tech support at CF
  12. RB1
    RB1 Active Member
    292
    75
    California
    3:22 PM
    MariaDB 10.1.x
    Just opened a ticket with CF; I'll post here when they get back to me.
  13. BamaStangGuy
    668
    192
    5:22 PM
    I opened a ticket with them.
  14. RB1
    RB1 Active Member
    292
    75
    California
    3:22 PM
    MariaDB 10.1.x
    Cloudflare response:
    Not exactly the answer I was looking for because I'm still having the problem, but CF seems to have Brotli working... :D
  15. BamaStangGuy
    668
    192
    5:22 PM
  16. BamaStangGuy
    668
    192
    5:22 PM
    So since CloudFlare also can compress (and will if we don't do it), I wonder what the performance impact would be if we do not do any compression on our server and instead let CloudFlare cache our content and do the compression on their end?
    55,685
    12,270
    8:22 AM
    Guess for cloudflare you could turn off gzip and brotli on the backend then if you want
  18. BamaStangGuy
    668
    192
    5:22 PM
    All of our servers now disable gzip caching via nginx.conf. So the initial request from cloudflare will see be uncompressed but every request after that will see cloudflare compressed cache.
  19. RB1
    RB1 Active Member
    292
    75
    California
    3:22 PM
    MariaDB 10.1.x
    So is Brotli working with this configuration?
  20. BamaStangGuy
    668
    192
    5:22 PM
    No, I am not using any compression at all since CloudFlare will ignore the Brotli. Nginx serves uncompressed content to CloudFlare and then CloudFlare compresses and caches it. All future requests for the content are served by CloudFlare and never touch our server.
