pure-ftpd login problem with .08 beta
Discussion in 'Beta release code' started by Cr0w, Mar 31, 2015.
    12,578
    8:28 PM
    I see what you mean by W3 Total Cache's self hosted CDN. Unfortunately using FTP via non TLS/SSL is not secure and isn't recommended so use at your own risk.
    As to error, you'd have to ask W3 Total Cache support too as I am not familiar with self hosted CDN feature they have. Could be related to FTP Path you set
  2. Cr0w
    Cr0w Member
    165
    9
    Iran
    1:58 PM
    1.9.x
    5.5
    i changed directory to /home/nginx/domains/mashtyha.com
    its works ,
    Test passed
    12,578
    8:28 PM
    but FTP path says
    doc root would be
    /home/nginx/domains/mashtyha.com/public
  4. Cr0w
    Cr0w Member
    165
    9
    Iran
    1:58 PM
    1.9.x
    5.5
    its working but Uploading ftp files on /home/nginx/domains/mashtyha.com/
    i want to upload here /home/nginx/domains/mashtyha.com/public
    12,578
    8:28 PM
    as per post 43 that's why i said doc root is public ;)
  6. Cr0w
    Cr0w Member
    165
    9
    Iran
    1:58 PM
    1.9.x
    5.5
    when i set /home/nginx/domains/mashtyha.com/public
    i have problem
    but when i set /home/nginx/domains/mashtyha.com/ its working
  7. Cr0w
    Cr0w Member
    165
    9
    Iran
    1:58 PM
    1.9.x
    5.5
    Error: Unable to change directory to: /home/nginx/domains/mashtyha.com/public (ftp_chdir(): Can't change directory to /home/nginx/domains/mashtyha.com/public: No such file or directory).
    12,578
    8:28 PM
    what problem ? test not passed ?
    permissions output from these 2 commands
    ls -lah /home/nginx/domains/
    ls -lah /home/nginx/domains/mashtyha.com/
  9. Cr0w
    Cr0w Member
    165
    9
    Iran
    1:58 PM
    1.9.x
    5.5
    drwxr-s--- 5 nginx nginx 4.0K Mar 31 17:54 .
    drwx--S--- 4 nginx nginx 4.0K Mar 30 21:38 ..
    drwxr-x--- 6 nginx nginx 4.0K Mar 30 19:56 demodomain.com
    drwxr-s--- 6 nginx nginx 4.0K Mar 31 17:54 img.mashtyha.com
    drwxr-s--- 6 nginx nginx 4.0K Mar 31 20:31 mashtyha.com
    drwxr-s--- 6 nginx nginx 4.0K Mar 31 20:31 .
    drwxr-s--- 5 nginx nginx 4.0K Mar 31 17:54 ..
    drwxr-s--- 2 nginx nginx 4.0K Mar 30 21:07 backup
    drwxr-s--- 2 nginx nginx 4.0K Mar 30 21:07 log
    drwxr-s--- 2 nginx nginx 4.0K Mar 30 21:07 private
    drwxrwsr-x 5 nginx nginx 4.0K Mar 31 20:31 public
    12,578
    8:28 PM
    could be when you incorrectly created pure-ftpd virtual user you created 2 users locking one to /home/nginx/domains/mashtyha.com/public and one to /home/nginx/domains/mashtyha.com
    what does output of these 2 commands give
    pure-pw list
    pure-pw show yourusername
    you might need to delete and re-create that user
    pure-pw userdel yourusername
    pure-pw mkdb
    service pure-ftpd restart
    pure-pw useradd yourusername -u nginx -g nginx -d /home/nginx/domains/mashtyha.com
    pure-pw mkdb
  11. Cr0w
    Cr0w Member
    165
    9
    Iran
    1:58 PM
    1.9.x
    5.5
    Example ?
    i set
    then error
    12,578
    8:28 PM
    yeah unfortunately, seems right now W3 Total Cache self hosted CDN doesn't support pure-ftp virtual FTP user unfortunately. Only when I have some more free time will I be able to look into this.
  13. Cr0w
    Cr0w Member
    165
    9
    Iran
    1:58 PM
    1.9.x
    5.5
    Nah , i found the problem . i will give you information but first help me to set up an subdomain at main domain document root
    for example
    /home/nginx/domains/mashtyha.com/public/subdomain
    subdomain.mashtyha.com
    12,578
    8:28 PM
    can do that manually or easier way via centmin.sh menu option 2 to create a new account = subdomain.yourdomain.com and then in that /usr/local/nginx/conf/conf.d/subdomain.yourdomain.com.conf nginx vhost change root path from /home/nginx/domains/mashtyha.com/public to /home/nginx/domains/mashtyha.com/public/subdomainand restart nginx server
    manual way is to copy your /usr/local/nginx/conf/conf.d/yourdomain.com.conf to a new file at /usr/local/nginx/conf/conf.d/subdomain.yourdomain.com.conf and again change root path from /home/nginx/domains/mashtyha.com/public to /home/nginx/domains/mashtyha.com/public/subdomain and change server_name to subdomain.yourdomain.com and restart nginx server
  15. Cr0w
    Cr0w Member
    165
    9
    Iran
    1:58 PM
    1.9.x
    5.5
    12,578
    8:28 PM
    you got the screenshot for w3 total cache self hosted cdn settings ?
    i might have a work around to keep FTP over TLS/SSL enabled by editing W3 Total Cache code
    W3 Total Cache self hosted CDN doesn't support FTP over TLS mode due to line 69 of w3-total-cache/lib/W3/Cdn/Ftp.php and use of ftp_connect(). So you need to change ftp_connect() to ftp_ssl_connect() (PHP: ftp_ssl_connect - Manual at line 69
    see wp-w3-total-cache/Ftp.php at master · crowdfavorite-mirrors/wp-w3-total-cache · GitHub
    original W3 Total Cache line 69 of w3-total-cache/lib/W3/Cdn/Ftp.php
    grep -Rn ftp_connect w3-total-cache/lib/W3/Cdn/Ftp.php
    69:        $this->_ftp = @ftp_connect($this->_config['host'], (int) $this->_config['port'], W3TC_CDN_FTP_CONNECT_TIMEOUT);
    change line 69 in w3-total-cache/lib/W3/Cdn/Ftp.php
    from
    to
    $this->_ftp = @ftp_ssl_connect($this->_config['host'], (int) $this->_config['port'], W3TC_CDN_FTP_CONNECT_TIMEOUT);
    12,578
    8:28 PM
    Ah i see what you mean, you set the following + using my ftp_ssl_connect workaround does work
    misunderstood, FTP hostname above is that of the cdn host you want to ftp into.
    and create subdomain with root of off public at root /home/nginx/domains/newdomain2.com/public/cdn
    subdomain Nginx vhost /usr/local/nginx/conf/conf.d/cdn.newdomain2.com.conf
    server_name cdn.newdomain2.com;
    # ssi on;
    access_log /home/nginx/domains/newdomain2.com/log/access.log combined buffer=32k;
    error_log /home/nginx/domains/newdomain2.com/log/error.log;
    root /home/nginx/domains/newdomain2.com/public/cdn;
    include /usr/local/nginx/conf/wpsupercache_newdomain2.com.conf;
    #autoindex on;
    try_files /wp-content/cache/supercache/$http_host/$cache_uri/index.html $uri $uri/ /index.php;
    include /usr/local/nginx/conf/wpsecure_newdomain2.com.conf;
