pure-ftpd login problem with .08 beta
Discussion in 'Beta release code' started by Cr0w, Mar 31, 2015.
  1. Cr0w
    Cr0w Member
    165
    9
    Iran
    1:58 PM
    1.9.x
    5.5
    so can't fix it ?
    would you working on it ? for updating centminmod beta08 ? :(
    i need this . can't use sftp
    12,578
    8:28 PM
    yeah need to work on it to figure out what the problem is
  3. Cr0w
    Cr0w Member
    165
    9
    Iran
    1:58 PM
    1.9.x
    5.5
    how much take long ? FTP Is must important tool for my work
    12,578
    8:28 PM
    working on it now, but I only work on Centmin Mod in my free time so hard to say. I have pinpointed some fixes to make just testing them now.
    Btw, can you confirm pure-ftpd service is actually running for me
    service pure-ftpd status
  5. Cr0w
    Cr0w Member
    165
    9
    Iran
    1:58 PM
    1.9.x
    5.5
    i stop it and installed vsftpd can work with CentminMod ?
    12,578
    8:28 PM
    as per my reply to your post at I need ftp server with Centminmod | Centmin Mod Community vsftpd will work just not user isolation so any ftp user will have access to other accounts as explained at I need ftp server with Centminmod | Centmin Mod Community
    if you need user isolation in FTP, then pure-ftpd feature in .08 beta is only way
    I already commited the pure-ftpd fix to .08 beta 02 branch code at fix pure-ftpd configuration routine for missing files · centminmod/centminmod@1fdcbfd · GitHub
    You can run this command line to run a script to try and fix pure-ftpd and then you will need to manually re-create all pure-ftpd virtual FTP users as per the instructions at end of the script output
    run command/script
    curl -sL https://bitbucket.org/snippets/eva2000/B89b/raw/master/pureftp_fix.sh | bash
    example of output and instructions for manually re-create all pure-ftpd virtual FTP users
    ensure TLS Cipher preference protects against poodle attacks
    create /etc/pure-ftpd/pureftpd.passwd
    check tweaks in /etc/pure-ftpd/pure-ftpd.conf
    VerboseLog                  yes
    UnixAuthentication            yes
    # UnixAuthentication can be used only once, but they can be combined
    # together. For instance, if you use MySQLConfigFile, then UnixAuthentication,
    PassivePortRange    3000 3050
    CreateHomeDir               yes
    # 0 : disable SSL/TLS encryption layer (default).
    # 2 : refuse connections that don't use SSL/TLS security mechanisms,
    # 1) Your server has been compiled with SSL/TLS support (--with-tls),
    TLS                      2
    TLSCipherSuite           HIGH:MEDIUM:+TLSv1:!SSLv2:!SSLv3
    pure-ftpd installed
    Stopping pure-ftpd: [  OK  ]
    Starting pure-ftpd: [  OK  ]
    check /etc/pure-ftpd/pureftpd.passwd
    -rw------- 1 root root 0 Mar 31 17:52 /etc/pure-ftpd/pureftpd.passwd
    check /etc/pure-ftpd/pureftpd.pdb
    -rw------- 1 root root 2.1K Mar 31 17:52 /etc/pure-ftpd/pureftpd.pdb
    end of output will show
    # Fix completed
    because /etc/pure-ftpd/pureftpd.passwd was missing, you will need to
    manually re-create your pure-ftpd virtual FTP user accounts for existing
    nginx vhost accounts using below 3 commands:
    where YOURUSERNAME = your FTP username
    where YOURDOMAINNAME.com = your existing domain name Nginx vhost
    # 3 commands to manually re-create virtual FTP users
        pure-pw useradd YOURUSERNAME -u nginx -g nginx -d /home/nginx/domains/YOURDOMAINNAME.com
        pure-pw mkdb
        service pure-ftpd restart
  7. Cr0w
    Cr0w Member
    165
    9
    Iran
    1:58 PM
    1.9.x
    5.5
    directory must be : -d /home/nginx/domains/mashtyha.com or -d /home/nginx/domains/mashtyha.com/public ?
    12,578
    8:28 PM
    top level of your Nginx vhost at
  9. Cr0w
    Cr0w Member
    165
    9
    Iran
    1:58 PM
    1.9.x
    5.5
    thanks . finally done , but i still have problem with wordpress ftp , i want to transfer my attachments to img.mashtyha.com subdomain , its very important and helps my seo website , but Wordpress FTP Plugin Does't supports FTP Explicit (SSL) What should i do ? :(
    i try cuteFTP Its work fine but not working on wordpress
    i set
    should i change it ?
    12,578
    8:28 PM
    12,578
    8:28 PM
    it should be
  12. Cr0w
    Cr0w Member
    165
    9
    Iran
    1:58 PM
    1.9.x
    5.5
    so there is no way to fix that problem with wordpress ?
    ok i will change it to main directory . by the way thanks for help me to fix my problems , you are the best developer in linux ;)
    12,578
    8:28 PM
  14. Cr0w
    Cr0w Member
    165
    9
    Iran
    1:58 PM
    1.9.x
    5.5
    12,578
    8:28 PM
  16. Cr0w
    Cr0w Member
    165
    9
    Iran
    1:58 PM
    1.9.x
    5.5
    * For developers: WordPress debugging mode.
    * Change this to true to enable the display of notices during development.
    * It is strongly recommended that plugin and theme developers use WP_DEBUG
    * in their development environments.
    define('WP_DEBUG', false);
    /* That's all, stop editing! Happy blogging. */
    /** Absolute path to the WordPress directory. */
    if ( !defined('ABSPATH') )
        define('ABSPATH', dirname(__FILE__) . '/');
    /** Sets up WordPress vars and included files. */
    require_once(ABSPATH . 'wp-settings.php');
    define('FS_METHOD','direct');
  17. Cr0w
    Cr0w Member
    165
    9
    Iran
    1:58 PM
    1.9.x
    5.5
    the problem is Explicit connection , W3 total Cache Does't support that ability !
    i have't any problems with wordpress updates my problem is Connecting to FTP Via Wordpress
    i want to make an Self-Hosted CDN ;) Thats need a ftp connection to transfer js and css files to Test Page for the Centmin Mod Nginx HTTP Server
    12,578
    8:28 PM
    what feature in W3 Total Cache requires ftp connection ? for setting up CDN you mean ?
  19. Cr0w
    Cr0w Member
    165
    9
    Iran
    1:58 PM
    1.9.x
    5.5
    look at the pic ,
    this is Self-hosted CDN Config
    thats must connect with ftp , after connection will be alerted by Green spoiler , now you'll see red
  20. Cr0w
    Cr0w Member
    165
    9
    Iran
    1:58 PM
    1.9.x
    5.5
    uhh , i found it the porblem was solved by disabling TLS On Pureftpd i have set connection type to non-ssl and its fixed
    but the new problem :(
    Error: Test directory was made in your site root, not on separate FTP host or path. Change path or FTP information: test_dir_680a4981bb6ad5b243ae2154716ec92a.
