Nginx PageSpeed ngx_pagespeed advertising conflicts ?
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by eva2000, Jun 2, 2014.
    2:08 PM
    When you create an ad, you can select Responsive :)
    59,585
    12,540
    4:08 PM
    ah i see it's buried half way down the list of ad units to select !
    will try now
    Just switched to async responsive smart sizing code
    59,585
    12,540
    4:08 PM
    yeah the responsive async adsense code https://support.google.com/adsense/answer/3213689 gives me 400 bad request error
    while trying async non-response with moved adsbygoogle.js works it still shows an error in console (but ads are reproted as served)
    Error in event handler for (unknown): Blocked a frame with origin "http://googleads.g.doubleclick.net" from accessing a cross-origin frame.
    Stack trace: Error: Blocked a frame with origin "http://googleads.g.doubleclick.net" from accessing a cross-origin frame.
        at Error (native)
        at setupffoverrides (chrome-extension://hnjalnkldgigidggphhmacmimbdlafdo/onloadwff.js:151:86)
        at checkgenpwfillforms (chrome-extension://hnjalnkldgigidggphhmacmimbdlafdo/onloadwff.js:152:33)
        at receiveBG (chrome-extension://hnjalnkldgigidggphhmacmimbdlafdo/onloadwff.js:130:210)
        at Function.target.(anonymous function) (extensions::SafeBuiltins:19:14)
        at EventImpl.dispatchToListener (extensions::event_bindings:395:22)
        at publicClass.(anonymous function) [as dispatchToListener] (extensions::utils:69:26)
        at EventImpl.dispatch_ (extensions::event_bindings:378:35)
        at EventImpl.dispatch (extensions::event_bindings:401:17)
    looks more like a Chrome/Opera warning ?
    well Adsense do list async responsive as beta though heh
    maybe related to the technical considerations for responsive ad units ?
    I know the ad i have doesn't have a width set in parent container
    59,585
    12,540
    4:08 PM
    Got async responsive working needed to specifically define width css3 elements
    <style>
    .cmres1 { width: 320px; height: 50px; }
    @media(min-width: 500px) { .cmres1 { width: 468px; height: 60px; } }
    @media(min-width: 800px) { .cmres1 { width: 728px; height: 90px; } }
    </style>
    <!-- cmres1 -->
    <ins class="adsbygoogle cmres1"
         style="display:inline-block"
         data-ad-client="ca-pub-6669518204467592"
         data-ad-slot="2827005149"></ins>
    <script>
    (adsbygoogle = window.adsbygoogle || []).push({});
    </script>
    stripped out adsbygoogle.js and put that in PAGE_CONTAINER template
    HTML:
    <script async src="//pagead2.googlesyndication.com/pagead/js/adsbygoogle.js"></script>
    </head>
    Also added second responsive async add below content and working as well. Only time you sometimes see missing after first post responsive async ads is when you use jump to last post of a thread in forum thread list view because there's no way to load the first post view port of the window I guess if you jump to last post as opposed to coming in from top of the thread
    edit: even fixed the missing after post post ad missing too all you need to do is wrap Adsense code around a div tag with specified width element
    i.e.
    HTML:
    <div style="padding-top:10px;width:"85%";">
    <style>
    </style>
    <!-- cmres1 -->
    <script>
    </script>
    </div>
  5. rdan
    2:08 PM
    Did you already applied this fix to your site @BamaStangGuy ?
  6. rdan
    2:08 PM
    So you're using Advance code?
    Not the Smart Sizing? Responsive.
    59,585
    12,540
    4:08 PM
    Yup Adsense Responsive Async Advanced Code + a extra DIV wrapper tag. Been working so far :D
  8. rdan
    2:08 PM
    I change my width to 100%, because with 85%, it's not centered.
    OK, I will enable ngx_pagespeed defer js and let see how it goes :)
    59,585
    12,540
    4:08 PM
    i used 85% for after post spot here seems to be okay for me heh
  10. rdan
    2:08 PM
    You need to check your code :)
    59,585
    12,540
    4:08 PM
  12. rdan
    2:08 PM
    I have a problem now :( , to re-produce.
    1st - Please do this on another browser just for testing
    2nd - Clear all data/cache
    3rd - Open my homepage: https://www.phcorner.net/
    On console view, you will notice this error which causing the ads don't load on first time visitor:
    and related to pagespeed:
  13. rdan
    2:08 PM
    59,585
    12,540
    4:08 PM
    don't want to clear my passwords and cookies heh
    does this happen on this forum when you clear all that data ?
  15. rdan
    2:08 PM
  16. rdan
    2:08 PM
    BTW, here's my config:
    pagespeed on;
    # Custom for PHCorner.Net / fix for https only
    pagespeed LoadFromFile "http://www.phcorner.net" "/home/nginx/domains/phcorner.net/public";
    pagespeed LoadFromFile "https://www.phcorner.net" "/home/nginx/domains/phcorner.net/public";
    # End
    pagespeed Disallow "*/admin.php*";
    pagespeed Disallow "*/css.php*";
    pagespeed Disallow "*/mark-read*";
    pagespeed Disallow "*/forums/-/mark-read*";
    pagespeed Disallow "*/reply/preview*";
    pagespeed Disallow "*/account/alerts-popup*";
    pagespeed Disallow "*/conversations/popup*";
    pagespeed Disallow "*/conversations/*";
    pagespeed Disallow "*/account/alerts/*";
    pagespeed Disallow "*/?card*";
    pagespeed Disallow "*/misc/quick-navigation-menu*";
    pagespeed Disallow "*/misc/update-cache-ttl*";
    pagespeed Disallow "*/deferred.php*";
    pagespeed Disallow "*/attachments/*";
    pagespeed Disallow "*/rgba.php*";
    pagespeed Disallow "*/edit-inline*";
    pagespeed Disallow "*/save-inline*";
    pagespeed Disallow "*/posts/*/save-inline*";
    pagespeed Disallow "*/posts/*/edit*";
    pagespeed Disallow "*/posts/*/delete*";
    pagespeed Disallow "*/posts/*/ip*";
    pagespeed Disallow "*/posts/*/report*";
    pagespeed Disallow "*/proxy.php*";
    pagespeed Disallow "*/js/xenforo/xenforo.js*";
    pagespeed Disallow "*/?&_xfRequestUri*";
    pagespeed Disallow "*/alerts-popup*";
    pagespeed Disallow "*/js/rellect/AdblockDetector/advertisement.js*";
    ###pagespeed Disallow "*/data/bdCache/css/*";
    pagespeed Disallow "*adsbygoogle*";
    pagespeed Disallow "*google_ad*";
    pagespeed Disallow "*show_ad*";
    pagespeed Disallow "*/adsbygoogle.js*";
    pagespeed MemcachedThreads 1;
    pagespeed MemcachedServers "localhost:11211";
    pagespeed MemcachedTimeoutUs 100000;
    pagespeed MaxCombinedCssBytes -1;
    pagespeed PreserveUrlRelativity on;
    pagespeed ImageResolutionLimitBytes 16777216;
    pagespeed AvoidRenamingIntrospectiveJavascript on;
    pagespeed ImageInlineMaxBytes 3072;
    pagespeed CssImageInlineMaxBytes 0;
    pagespeed MaxInlinedPreviewImagesIndex -1;
    pagespeed MinImageSizeLowResolutionBytes 3072;
    pagespeed MaxCombinedJsBytes 840000;
    ###pagespeed FetchHttps enable;
    ## ngx_pagespeed filters settings below ##
    pagespeed RewriteLevel CoreFilters;
    pagespeed EnableFilters collapse_whitespace,remove_comments;
    pagespeed EnableFilters move_css_above_scripts;
    pagespeed EnableFilters combine_css;
    pagespeed EnableFilters combine_javascript;
    pagespeed EnableFilters rewrite_css;
    pagespeed EnableFilters rewrite_javascript;
    pagespeed EnableFilters inline_javascript;
    pagespeed EnableFilters resize_mobile_images;
    pagespeed EnableFilters rewrite_images;
    pagespeed EnableFilters convert_png_to_jpeg;
    pagespeed EnableFilters convert_jpeg_to_webp;
    pagespeed EnableFilters convert_to_webp_lossless;
    pagespeed EnableFilters rewrite_css,sprite_images;
    pagespeed EnableFilters dedup_inlined_images;
    pagespeed EnableFilters elide_attributes;
    pagespeed EnableFilters lazyload_images;
    pagespeed LazyloadImagesAfterOnload off;
    pagespeed EnableFilters local_storage_cache;
    pagespeed EnableFilters insert_dns_prefetch;
    pagespeed EnableFilters remove_quotes;
    pagespeed EnableFilters trim_urls;
    pagespeed EnableFilters make_google_analytics_async;
    pagespeed EnableFilters inline_google_font_css;
    pagespeed EnableFilters inline_preview_images;
    pagespeed EnableFilters move_css_to_head;
    pagespeed EnableFilters prioritize_critical_css;
    pagespeed EnableFilters defer_javascript;
    ###pagespeed DisableFilters defer_javascript;
    ### END
    59,585
    12,540
    4:08 PM
    did you edit /usr/local/nginx/conf/pagespeedhandler.conf
    for the correction for ngx_pagespeed 1.8.31.3 beta
    from
    location ~ "^/ngx_pagespeed_static/" { }
    to
    location ~ "^/pagespeed_static/" { }
    then restart nginx
  18. rdan
    2:08 PM
    59,585
    12,540
    4:08 PM
    you seem to be using smartsizing class adsense code, try using the advanced code
    59,585
    12,540
    4:08 PM
