Wordpress My first Wordpress Autoptimize Gzip Companion Plugin !
Discussion in 'Blogs & CMS usage' started by eva2000, Jul 19, 2018.
  1. Mrbo
    Mrbo Member
    9:34 PM
    60,001
    12,566
    12:34 AM
    no conflicts though if you have Cloudflare with Brotli, you don't need Centmin Mod Nginx with brotli nor do you need Brotli PHP extension.
  3. Mrbo
    Mrbo Member
    9:34 PM
    So can I use the plugin without making any changes to the config file or dont I need the plugin if I use cloudflare?
    60,001
    12,566
    12:34 AM
    Yup
  5. yunos
    yunos Member
    130
    4:34 PM
    1.8.0
    how would you test if your companion plugin is using gzip to serve the static files to the clients browser?
    i use cloudflare as front and have your companion plugin and autooptimizer installed.
    i do indeed see br and gzip files being generated but not entirely sure if its being served as .gzip or .br to the visitors
    reason it got me wonder is due to pingdom test site reporting poor result of gzip
    https://i.imgur.com/c2tuSE9.png
    60,001
    12,566
    12:34 AM
    if you have cloudflare in front, then cloudflare servers will serve gzip and brotli compressed files not centmin mod nginx so nothing to do with centmin mod nginx :)
    click the down arrow to reveal what specific assets are reporting gzip issues if they're 3rd party domains, you have no control over them
  7. yunos
    yunos Member
    130
    4:34 PM
    1.8.0
    60,001
    12,566
    12:34 AM
    fonts like images can't be compressed generally so wouldn't expect them to be
  9. EckyBrazzz
    190
    11:34 AM
    60,001
    12,566
    12:34 AM
