    1:15 AM
    mcrypt already exists, check php loaded modules
    php -m
     php -m
    [PHP Modules]
    bcmath
    bz2
    calendar
    Core
    ctype
    curl
    date
    dom
    enchant
    ereg
    exif
    filter
    ftp
    gd
    geoip
    gettext
    gmp
    hash
    iconv
    igbinary
    imagick
    imap
    intl
    json
    libxml
    mbstring
    mcrypt
    memcache
    memcached
    mhash
    mysql
    mysqli
    mysqlnd
    newrelic
    openssl
    pcntl
    pcre
    PDO
    pdo_mysql
    pdo_sqlite
    Phar
    posix
    pspell
    readline
    Reflection
    session
    shmop
    SimpleXML
    snmp
    soap
    sockets
    SPL
    sqlite3
    standard
    sysvmsg
    sysvsem
    sysvshm
    tidy
    tokenizer
    xml
    xmlreader
    xmlrpc
    xmlwriter
    Zend OPcache
    zip
    zlib
    [Zend Modules]
    1:15 AM
  3. BamaStangGuy
    BamaStangGuy Active Member
    669
    192
    10:15 AM
    It appears to be something with 5.3 which is for a vB 3.7 site we just purchased.
    1:15 AM
    see PHP-FPM - PHP Was Not Installed Properly might want to stick with CentOS 6.5 for PHP 5.3 for now
  5. BamaStangGuy
    669
    192
    10:15 AM
    5.3 works fine with 6.5 and .07.
    1:15 AM
    yup it does as CentOS 6.5 uses a different gcc version than CentOS 7
    1:15 AM
    Managed to get past one of the errors preventing compiling PHP 5.3.29 + CentOS 7 related PHP Intl extension enabling, PHP 5.3.29 doesn't seem to like enabling PHP Intl extension on CentOS 7. Latest commit to Centmin Mod .08 beta01 adds a new option to disable PHPINTL=y|n in centmin.sh prior to downgrading PHP to PHP 5.3.29.
    While PHP ends up installed, there's ALOT of other errors reported during compiling, so not entirely sure you'd be out of the woods with CentOS 7 and PHP 5.3.29. Probably better to stick with CentOS 6.5 for PHP 5.3.x setups right now
    1:15 AM
  9. Razib Hasan
    Razib Hasan Member
    37
    15
    Dhaka, Bangladesh
    9:15 PM
    1.7.6
    5.10
    PHP installation fails on latest .08
    [1;33;40mDownload php-5.4.34.tar.gz ...
    (B[m2014-10-28 21:01:15 URL:http://us2.php.net/distributions/php-5.4.34.tar.gz [15333397/15333397] -> "mirror" [1]
    [1;33;40mDownload done.
    (B[mtar (child): php-5.4.34.tar.gz: Cannot open: No such file or directory
    tar (child): Error is not recoverable: exiting now
    tar: Child returned status 2
    tar: Error is not recoverable: exiting now
    [1;32;40mError: php-5.4.34.tar.gz extraction failed.
    (B[mcheck Centmin Mod log for details at /root/centminlogs/
    Aborting script...
    Total Centmin Mod Install Time: 181.566928630 seconds
    [1;33;40mDownload php-5.6.2.tar.gz ...
    (B[m2014-10-28 20:29:22 URL:http://us1.php.net/distributions/php-5.6.2.tar.gz [17500319/17500319] -> "mirror" [1]
    (B[mtar (child): php-5.6.2.tar.gz: Cannot open: No such file or directory
    [1;32;40mError: php-5.6.2.tar.gz extraction failed.
    Aborting script...
    Total Centmin Mod Install Time: 222.362378842 seconds
    1:15 AM
    @Razib Hasan check to see if PHP tar.gz files were fully downloaded in /svr-setup
    ls -lahrt /svr-setup | grep php
    could be the downloads terminated before they completed or some problem with completing the downloads
  11. Razib Hasan
    Razib Hasan Member
    37
    15
    Dhaka, Bangladesh
    9:15 PM
    1.7.6
    5.10
  12. Razib Hasan
    Razib Hasan Member
    37
    15
    Dhaka, Bangladesh
    9:15 PM
    1.7.6
    5.10
    @eva2000
    Update: Seems like it might be an issue with CentOS 6.6. After fresh installation of CentOS 6.5, I've ran yum update command and then I tried to install CentminMod (both .07 and .08) and it returned with PHP download error. Right now I've done another fresh installation and running centminmod .08 installation without any yum update. No error this time :)
    1:15 AM
    looks like something else to investigate for compatibility but i believe it's related to my in place version checks at CentOS 6.6 & Centmin Mod compatibility | Centmin Mod Community
  14. Razib Hasan
    Razib Hasan Member
    37
    15
    Dhaka, Bangladesh
    9:15 PM
    1.7.6
    5.10
    @eva2000
    Just tried .07 on another VPS with CentOS 6.6 after changing the variables to 6.6. Got error again when it tried to download PHP.
    Download php-5.4.33.tar.gz ...
    2014-10-29 01:48:29 URL:http://php.net/distributions/php-5.4.33.tar.gz [15330121/15330121] -> "mirror" [1]
    Download done.
    tar (child): php-5.4.33.tar.gz: Cannot open: No such file or directory
    Error: php-5.4.33.tar.gz extraction failed.
    Aborting script...
    1:15 AM
    yes it's expected to have errors due to this CentOS 6.6 & Centmin Mod compatibility | Centmin Mod Community
    I just updated Centmin Mod .08 beta and .07 stable with support for CentOS 6.6 throughout the code. For Centmin Mod .07 stable you still need to do the outlined step at CentOS 6.6 & Centmin Mod compatibility | Centmin Mod Community to set centmin.sh variable to TESTEDCENTOSVER='6.6' before running initial install.
    Github commits:
    1:15 AM
    Will be adding a few existing beta status addons to .08 beta as official addons Add Ons | Centmin Mod Community
    For example:
    Was thinking for addons like ioncube.sh which may need reinstalling with each PHP upgrade, of adding support for pre/post hook functions before and after PHP and Nginx installation, which end users can add their own scripts and define additional installations, steps of their own after PHP and Nginx install/upgrade process has run.
    For example, this way you could define ioncube.sh addon to run after a PHP upgrade automatically via a post hook or before/after initial Nginx install, define NGINX_GEOIP=y and run addons/geoip.sh to enable GEOIP support Nginx - GeoIP Thread | Centmin Mod Community
    1:15 AM
  18. Razib Hasan
    Razib Hasan Member
    37
    15
    Dhaka, Bangladesh
    9:15 PM
    1.7.6
    5.10
    setting up /svr-setup on tmpfs ramdisk for initial install
    /dev/simfs     simfs      60G  373M   60G   1% /
    none           devtmpfs  1.5G  4.0K  1.5G   1% /dev
    none           tmpfs     1.5G     0  1.5G   0% /dev/shm
    tmpfs          tmpfs     2.2G     0  2.2G   0% /svr-setup
    inc/zendopcache_reinstall.inc: line 31: syntax error near unexpected token `else                                         '
    inc/zendopcache_reinstall.inc: line 31: `       else'
    inc/zendopcache_reinstall.inc: line 31: warning: syntax errors in . or eval will                                          cause future versions of the shell to abort as Posix requires
    Getting that message while running latest version of .08.
    1:15 AM
    doh made another typo missing the ; then from line 29 - fixed in latest commit fix typo in inc/zendopcache_reinstall.inc · 804df16 · centminmod/centminmod · GitHub :)
    You can edit inc/zendopcache_reinstall.inc at line 29 if you want
    thanks for the feedback :D
  20. GhoHan
    GhoHan Member
    33
    14
    10:15 PM
    Nginx 1.13.X
    MariaDB 10.1.X
    @eva2000 this the new test install on Centos 7 still dont have mcrypt
    php -m
    [PHP Modules]
    apc
    bcmath
    bz2
    calendar
    Core
    ctype
    curl
    date
    dom
    enchant
    ereg
    exif
    filter
    ftp
    gd
    gettext
    gmp
    hash
    iconv
    igbinary
    imagick
    imap
    intl
    json
    libxml
    mbstring
    memcache
    memcached
    mhash
    mysql
    mysqli
    mysqlnd
    openssl
    pcntl
    pcre
    PDO
    pdo_mysql
    pdo_sqlite
    Phar
    posix
    pspell
    readline
    Reflection
    session
    shmop
    SimpleXML
    snmp
    soap
    sockets
    SPL
    sqlite3
    standard
    sysvmsg
    sysvsem
    sysvshm
    tidy
    tokenizer
    xml
    xmlreader
    xmlrpc
    xmlwriter
    zip
    zlib
    [Zend Modules]
