    59,946
    12,556
    8:11 AM
    when you guys run
    rm -rf /var/cache/yum/*
    afterwards does this file exist /var/cache/yum/base/mirrorlist.txt ? it shouldn't
    then try
    yum clean all
  2. Andy
    Andy Active Member
    546
    90
    5:11 PM
    It does not contain that file, @eva2000
    I just talked to the Rackspace guy know about their mirror url problem.
  3. Sebastian B.
    Sebastian B. New Member
    25
    12:11 AM
    1.7.2
    5.5
    They just tell me that everything is okay from theire side
    59,946
    12,556
    8:11 AM
    59,946
    12,556
    8:11 AM
  6. Andy
    Andy Active Member
    546
    90
    5:11 PM
    Fortunately, yes. I just got a new server to help speed the 08 along.
    The OS image is Centos 7 PVHVM
    59,946
    12,556
    8:11 AM
    yeah unfortunately been ages since I touched my Rackspace Cloud account as there's better alternatives with RamNode and DigitalOcean and Vultr
  8. Andy
    Andy Active Member
    546
    90
    5:11 PM
    I understand there are many cheaper options than Rackspace, for the same ram/cpu config, but can you elaborate what you mean the RamNode/DO/Vultr are better, George?
    I think Rackspace has updated the cloud server offer recently so it's worth a look.
    59,946
    12,556
    8:11 AM
    Server hardware wise with latest Intel E3-12xx Xeons and E5-26xx Xeons.
    Not sure what Rackspace are using now, when I tried them they had AMD Opterons and their bandwidth costs for Rackspace cloud where high around US$0.18/GB and limited you to fraction of full 1Gbit network connectivity.
    looks like pretty much same for some stuff US$0.20/GB bandwidth and 200Mb/s bandwidth for network on lowest plan Pay-as-you-go pricing | Rackspace Hosting
    so a performance1-4 4GB instance would cost US$115/month excluding bandwidth costs ! and only give 800Mb/s network connectivity ! Add bandwidth costs at US$200/TB for say 2TB/month = US$400/month in bandwidth costs + US$115/month for VPS = US$515/month ! :eek:
  10. Sebastian B.
    25
    12:11 AM
    1.7.2
    5.5
    The yum.conf gets brocken (for atleast linode UK) during the setup. thats why we get the mirror errors
  11. Sebastian B.
    25
    12:11 AM
    1.7.2
    5.5
    Here the differents maybe it helps.
    I need to start the setup 2 times. After the yum.conf gets an yum.bak file the yum isn't working anymore if I restore the backup and start the centminmod installer again its working here the 2 files: first the working one.
    [main]
    cachedir=/var/cache/yum/$basearch/$releasever
    keepcache=0
    debuglevel=2
    logfile=/var/log/yum.log
    exactarch=1
    obsoletes=1
    gpgcheck=1
    plugins=1
    installonly_limit=5
    bugtracker_url=http://bugs.centos.org/set_project.php?project_id=23&ref=http://bugs.centos.org/bug_report_page.php?category=yum
    distroverpkg=centos-release
    #  This is the default, if you make this bigger yum won't see if the metadata
    # is newer on the remote and so you'll "gain" the bandwidth of not having to
    # download the new metadata and "pay" for it by yum not having correct
    # information.
    #  It is esp. important, to have correct metadata, for distributions like
    # Fedora which don't keep old packages around. If you don't like this checking
    # interupting your command line usage, it's much better to have something
    # manually check the metadata once an hour (yum-updatesd will do this).
    # metadata_expire=90m
    # PUT YOUR REPOS HERE OR IN separate files named file.repo
    # in /etc/yum.repos.d
    [main]
    keepcache=0
    debuglevel=2
    distroverpkg=redhat-release
    tolerant=1
    exactarch=1
    obsoletes=1
    gpgcheck=1
    plugins=1
    exclude=*.i386 *.i586 *.i686
    # Note: yum-RHN-plugin doesn't honor this.
    metadata_expire=1h
    installonly_limit = 5
    59,946
    12,556
    8:11 AM
    nice catch @Sebastian B. it's probably related to old legacy yum.conf routine that originated from original Centmin script that comes with Centmin Mod from line 616 in centmin.sh which triggers when unattended mode (default now) + 64bit OS is detected to ensure 32bit packages are excluded and it's contents at centminmod/yum.conf at 123.08centos7beta01 · centminmod/centminmod · GitHub
    need to fix this it seems for CentOS 7 :)
    indeed fresh CentOS 7 /etc/yum.conf contents before Centmin Mod touches it
    [main]
    keepcache=0
    debuglevel=2
    exactarch=1
    obsoletes=1
    gpgcheck=1
    plugins=1
    installonly_limit=5
    # information.
    have a fix I will test out more
    instead of replacing yum.conf with one provided by Centmin Mod, on the fly add the exclude 32bit packages and modifying existing /etc/yum.conf using command code
    ex -s /etc/yum.conf << EOF
    :/plugins=1/
    :a
    :w
    :q
    EOF
    that will append to end of plugins=1 the exclude line
    [main]
    keepcache=0
    debuglevel=2
    exactarch=1
    obsoletes=1
    gpgcheck=1
    plugins=1
    installonly_limit=5
    # information.
    Committed a fix to this .08 beta branch at CentOS 7 fix for /etc/yum.conf for 32bit excludes · c2f3eb5 · centminmod/centminmod · GitHub :D
  13. Andy
    Andy Active Member
    546
    90
    5:11 PM
    Thanks for the explanation, George. I'm tempted to sign up and transfer one of my smaller site from RS to one of the alternatives you mentioned (use your link so you can get credit ;) )
    I like RS for its enterprise level support and uptime. Among the 3 you recommend, which one you think is closer to RS in term of the level of support and stability/uptime infrastructure?
    I don't care about saving few dollars and have to deal with downtime and unresponsive support.
  14. rdan
    6:11 AM
    1. Linode
    2. DigitalOcean
    3. Vultr
    4. Ramnode
    59,946
    12,556
    8:11 AM
    In that case check out Linode - it's what this very forum uses to host on Upgraded Linode VPS from 2GB to 4GB plan :D
    But Vultr is making a nice play for performance at a budget market Vultr - Vultr now with 24 cpu core and 64GB VPS options ! | Centmin Mod Community But out of them all, I have the most VPS with RamNode ~9 VPS around 6x OpenVZ and 3x KVM :)
    Probably better to discuss in a thread at Virtual Private Server (VPS) hosting | Centmin Mod Community ;)
  16. Sebastian B.
    25
    12:11 AM
    1.7.2
    5.5
    Linode has very awesome support. Typical response time is about 5 minutes on 24 Hours and even on sunday. Got with promotion codes some months free :). I got also some DigitalOcean Credit now but i think it will n't that awesome like Linode
    59,946
    12,556
    8:11 AM
    59,946
    12,556
    8:11 AM
    Proposing changes to how Centmin Mod .08 configures and sets up /tmp directory on initial installs.
    Thanks to @Josephm bug reports, it highlighted a problem I ran into when testing Centmin Mod .08 beta01 on CentOS 7.0 with RamNode 512MB CKVM VPS server - while doing PHP-FPM compile for initial install, I ran out of disk space in /tmp. This is a problem due to legacy code from original Centmin which automatically mounts and reconfigures /tmp by default to be mounted on a ramdisk, tmpfs system. And by default it creates the tmpfs filesystem to 1/2 the size of total memory. This means for a 512MB VPS, you would have 256MB tmpfs ramdisk based /tmp directory. On a 8GB VPS server, you would have a 4GB sizes tmpfs ramdisk for /tmp.
    Original Centmin was born out of trying to tailor to <512MB systems and originally didn't have as extensive a feature set of compile options for PHP-FPM and Nginx as I have done with Centmin Mod forked LEMP stack. This wasn't a problem with CentOS 6.5 it seemed as I could compile PHP-FPM fine even on 128-256MB memory based system with CentOS 6.5 32bit. But seems CentOS 7.0 adds more overhead being 64bit only.
    Centmin Mod while still tailors to low memory VPSes, it's more clear that larger sites/forums and web properties are starting to use Centmin Mod and their usage from my own experience would necessitate a much larger /tmp disk free space directory. At least 2-4GB sized usually.
    To address this long term, I will be changing the Centmin Mod .08 beta initial install's /tmp configuration routine
    1. So that /tmp will only be mounted on ramdisk tmpfs filesystem if the system's total memory is greater than 8GB (8,000,000 byes to be precise). So if you had 8GB of memory, you would get a 4GB sized ramdisk based tmpfs filesystem for /tmp. If you had 32GB of memory, /tmp will become a 16GB sized ramdisk using tmpfs filesystem.
    2. If you have between 2GB and <8GB of memory on the system, you would have a non-ramdisk standard EXT4 setup at /home/usertmp_donotdelete mounted on /tmp setup with a size of 4GB. While you loose some performance going from ramdisk based to disk based, alot of new VPS are using faster SSD based storage so should be sufficient. I chose the location at /home/usertmp_donotdelete as /home would usually have the most free disk space and well the name is to ensure folks do not accidentally delete it :) So a 2GB, 4GB or 6GB sized VPS/server would all be configured with a EXT4 disk based /tmp with a size of 4GB as opposed to the old method where they would get a ramdisk based tmpfs /tmp of 1GB, 2GB and 3GB sizes respectively.
    3. If you have less <2GB of memory on system, you would have a non-ramdisk standard EXT4 setup /tmp with a size of 2GB. So if you have 256MB VPS, 512MB VPS or 1GB or <2GB VPS you would still have a /tmp size that is 2GB as opposed to the old method of creating a ramdisk tmpfs /tmp of 1/2 the size of total memory, which would only give a 256MB VPS a 128MB sized /tmp or a 512MB VPS a 256MB sized /tmp and thereby running up against potential problems with running out of free disk space for /tmp.
    The proposed changes is for centmin.sh around line 642 for this new code below
        # only mount /tmp on tmpfs if CentOS system
        # total memory size is greater than 8GB
        # will give /tmp a size equal to 1/2 total memory
        if [[ "$TOTALMEM" -ge '8000000' ]]; then
           rm -rf /tmp
           mkdir -p /tmp
           mount -t tmpfs -o rw,noexec,nosuid tmpfs /tmp
           chmod 1777 /tmp
           echo "tmpfs /tmp tmpfs rw,noexec,nosuid 0 0" >> /etc/fstab
           rm -rf /var/tmp
           ln -s /tmp /var/tmp
        elif [[ "$TOTALMEM" -ge '2000000' || "$TOTALMEM" -lt '8000000' ]]; then
           # set on disk non-tmpfs /tmp to 4GB size
           # if total memory is between 2GB and <8GB
           rm -rf /tmp
           dd if=/dev/zero of=/home/usertmp_donotdelete bs=1024 count=4000000
           echo Y | mkfs.ext4 /home/usertmp_donotdelete
           mkdir -p /tmp
           mount -t ext4 -o rw,noexec,nosuid /home/usertmp_donotdelete /tmp
           chmod 1777 /tmp
           echo "/home/usertmp_donotdelete /tmp ext4 rw,noexec,nosuid 0 0" >> /etc/fstab
           rm -rf /var/tmp
           ln -s /tmp /var/tmp
        elif [[ "$TOTALMEM" -le '2000000' ]]; then
           # set on disk non-tmpfs /tmp to 2GB size
           # if total memory is <2GB
           rm -rf /tmp
           dd if=/dev/zero of=/home/usertmp_donotdelete bs=1024 count=2000000
           mkdir -p /tmp
           chmod 1777 /tmp
           rm -rf /var/tmp
           ln -s /tmp /var/tmp
        fi
    If folks have any further suggestions or tweaks to this formula, please let me know as I have yet to implement this in .08 beta
    testing proposed changes on RamNode 512MB CKVM VPS CentOS 7.0 minimal install
    /tmp size is on disk instead of ramdisk
    df -hT
    /dev/vda1      ext4       49G  4.1G   43G   9% /
    devtmpfs       devtmpfs  240M     0  240M   0% /dev
    tmpfs          tmpfs     246M     0  246M   0% /dev/shm
    tmpfs          tmpfs     246M  8.3M  237M   4% /run
    tmpfs          tmpfs     246M     0  246M   0% /sys/fs/cgroup
    tmpfs          tmpfs     246M  8.3M  237M   4% /etc/machine-id
    /dev/loop0     ext4      3.7G   16M  3.5G   1% /tmp
    * Post-Install Check List....
    Check ccache Version:
    ccache version 3.1.9
    Copyright (C) 2009-2011 Joel Rosdahl
    version.
    Check Nginx Version:
    nginx version: nginx/1.7.4
    built by gcc 4.8.2 20140120 (Red Hat 4.8.2-16) (GCC)
    TLS SNI support enabled
    configure arguments: --sbin-path=/usr/local/sbin/nginx --conf-path=/usr/local/nginx/conf/nginx.conf --with-http_ssl_module --with-http_gzip_static_module --with-http_stub_status_module --with-http_sub_module --with-http_addition_module --with-http_image_filter_module --with-http_secure_link_module --with-http_flv_module --with-http_realip_module --with-openssl-opt=enable-tlsext --add-module=../ngx-fancyindex-ngx-fancyindex --add-module=../ngx_cache_purge-2.1 --add-module=../headers-more-nginx-module-0.25 --add-module=../nginx-accesskey-2.0.3 --add-module=../nginx-http-concat-master --with-http_dav_module --add-module=../nginx-dav-ext-module-0.0.3 --add-module=../openresty-memc-nginx-module-1518da4 --add-module=../openresty-srcache-nginx-module-ffa9ab7 --add-module=../nginx-sticky-module-1.2.5 --add-module=../nginx_upstream_check_module-0.1.9 --with-openssl=../openssl-1.0.1i --with-libatomic --with-pcre=../pcre-8.35 --with-pcre-jit --with-http_spdy_module --add-module=../ngx_pagespeed-release-1.8.31.4-beta
    Check PHP-FPM Version:
    PHP 5.4.32 (cli) (built: Sep  9 2014 16:10:08)
    MariaDB-server-10.0.13-1.el6.x86_64
    MariaDB-client-10.0.13-1.el6.x86_64
    MariaDB-compat-10.0.13-1.el6.x86_64
    MariaDB-shared-10.0.13-1.el6.x86_64
    MariaDB-common-10.0.13-1.el6.x86_64
    MariaDB-devel-10.0.13-1.el6.x86_64
    memcached 1.4.20
    Check CSF Firewall Version:
    csf: v7.15 (generic)
    SIEGE 3.0.7
    Copyright (C) 2014 by Jeffrey Fulmer, et al.
    FOR A PARTICULAR PURPOSE.
    Detected 7.0
    pscontrol handler
    pscontrol edit
    pscontrol on
    pscontrol off
    pscontrol statson
    pscontrol statsoff
    Check mysqlreport version:
    Check NSD Bind Version:
    NSD version 3.2.17
    Written by NLnet Labs.
    Check YUM Repo List
    * base: mirrors.usc.edu
    * epel: mirrors.cat.pdx.edu
    * extras: mirror.web-ster.com
    * rpmforge: repoforge.eecs.wsu.edu
    * updates: mirror.chpc.utah.edu
    96 packages excluded due to repository priority protections
    repo id            repo name                                         status
    base/7/x86_64      CentOS-7 - Base                                   6,551+1,914
    epel/x86_64        Extra Packages for Enterprise Linux 7 - x86_64      5,081+529
    extras/7/x86_64    CentOS-7 - Extras                                          31
    mariadb            MariaDB                                                  11+2
    rpmforge           RHEL 7 - RPMforge.net - dag                            185+60
    updates/7/x86_64   CentOS-7 - Updates                                    577+200
    repolist: 12,436
  19. Andy
    Andy Active Member
    546
    90
    5:11 PM
    I tried to install Axvio Elasticsearch but it couldn't find any package to install. Is anything else I need to do?
    https://www.axivo.com/resources/elasticsearch-setup.11/
    # yum --enablerepo=axivo install elasticsearch
    base        | 3.6 kB  00:00:00
    epel/x86_64/metalink        |  14 kB  00:00:00
    epel        | 4.4 kB  00:00:00
    extras        | 3.4 kB  00:00:00
    mariadb        | 1.9 kB  00:00:00
    rpmforge        | 1.9 kB  00:00:00
    updates        | 3.4 kB  00:00:00
    (1/6): epel/x86_64/group_gz        | 250 kB  00:00:00
    (2/6): extras/7/x86_64/primary_db        |  26 kB  00:00:00
    (3/6): base/7/x86_64/group_gz        | 157 kB  00:00:00
    (4/6): updates/7/x86_64/primary_db        | 2.9 MB  00:00:01
    (5/6): epel/x86_64/primary_db        | 3.1 MB  00:00:01
    (6/6): base/7/x86_64/primary_db        | 4.9 MB  00:00:02
    (1/4): epel/x86_64/updateinfo        | 1.6 kB  00:00:00
    (2/4): rpmforge/primary_db        | 125 kB  00:00:00
    (3/4): epel/x86_64/pkgtags        | 1.2 MB  00:00:01
    (4/4): mariadb/primary_db        |  21 kB  00:00:01
    Determining fastest mirrors
     * base: centos.mirror.constant.com
     * epel: epel.mirror.constant.com
     * extras: centos.mirror.constant.com
     * rpmforge: repoforge.mirror.constant.com
     * updates: centos.mirror.constant.com
    128 packages excluded due to repository priority protections
    No package elasticsearch available.
    Error: Nothing to do
    59,946
    12,556
    8:11 AM
