    5:44 AM
    Yes, modify php-fpm.conf
  2. Matt Williams
    537
    105
    Virginia, USA
    5:44 PM
    latest
    Thanks Ronald!
    59,946
    12,556
    7:44 AM
    Getting Started guide item 14 for PHP-FPM security outlines how to add or remove them Getting Started with Centmin Mod
  4. Matt Williams
    537
    105
    Virginia, USA
    5:44 PM
    latest
    Been awhile since I've taken a glance at the getting started guide lol! Maybe I should though every once in awhile :=) Thanks George!
    59,946
    12,556
    7:44 AM
    I usually update this thread here Getting Started Guide | Centmin Mod Community for changes to Getting Started guide, so watch/subscribe to that thread ;)
  6. Cr0w
    Cr0w Member
    165
    9
    Iran
    1:14 AM
    1.9.x
    5.5
    ./centmin.sh: line 1132: incmemcachedinstall: command not found
    59,946
    12,556
    7:44 AM
    when was last time you updated Centmin Mod .08 beta 02 code ? last updated code commit was yesterday Commits · centminmod/centminmod · GitHub
    Also how did you update centmin mod .08 beta 02 ? could be you are missing inc/memcached_install.inc file when you updated
    pre-prepared instructions :D
    1. Upgrading the actual Centmin Mod code which you downloaded via zip file or via github. This is heart of Centmin Mod where the code is the engine that runs centmin.sh shell based menu and all the automation you're accustomed to.
    2. Upgrade software that Centmin Mod installed or manages. For this part following outline at Upgrade - How to upgrade Centmin Mod is best.
    There's 3 ways you can upgrade your .07 stable or .08 beta02 code you have on your server. They are outlined in respective upgrade sections of the first posts linked below:
    1. For .07 stable 1st post see section on upgrades Install - Centmin Mod 1.2.3-eva2000.07 stable install
    2. For .08 beta 02 1st post see section on upgrade to latest code CentOS 7.x - How to help test .08 CentOS 7 Betas with Github code ?
    3. For either .07 stable or .08 beta02 via github command line Upgrade - Working with git command line for updating Centmin Mod local copies
    Github commit log for
  8. rdan
    5:44 AM
    Latest 08 beta on Centos7, seems error?
    59,946
    12,556
    7:44 AM
    is this straight after initial install without a server reboot, or did you reboot server first ?
  10. rdan
    5:44 AM
    Yes.
    59,946
    12,556
    7:44 AM
    just tried on centos 7 and no problems here
    [root@centos7 ~]# service nsd stop
    Stopping nsd (via systemctl):                              [  OK  ]
    [root@centos7 ~]# chkconfig nsd off
    virtualised server ? OpenVZ, Xen or KVM or dedicated ?
    looks like NSD wasn't installed in the first place
    I bet you set in centmin.sh
    NSD_DISABLED=y
    NSD_INSTALL=n
    In that case NSD won't be installed so NSD_DISABLED=y can't do it's job and hence your error
  12. rdan
    5:44 AM
    Linode so Xen :)
    Yeah NSD is disable on post install :).
    59,946
    12,556
    7:44 AM
    you did not disable NSD on pre-install NSD_INSTALL=n?
  14. rdan
    5:44 AM
    I have it disabled.
    59,946
    12,556
    7:44 AM
    guess need to clarify my question, I need to know when you disabled NSD, before or after initial install
    before initial install (which you error at CentOS 7.x - How to help test .08 CentOS 7 Betas with Github code ? | Page 22 | Centmin Mod Community suggests as NSD wasn't installed to be able disable it) via
    NSD_DISABLED=y
    NSD_INSTALL=n
    or did you only set before initial install
    NSD_DISABLED=y
    NSD_INSTALL=y
    or did you leave it at defaults prior to initial install
    NSD_DISABLED=n
    NSD_INSTALL=y
  16. rdan
    5:44 AM
    Before.
    Before installing centmin, I have it disabled already.
    59,946
    12,556
    7:44 AM
    via NSD_INSTALL=n right ? if so then that's why you got the error, NSD wasn't available as it wasn't installed. So when you set NSD_DISABLED=y, the script can't disable/turn off NSD via service stop and chkconfig off as there was no NSD installed
  18. rdan
    5:44 AM
    Yeah :).
    59,946
    12,556
    7:44 AM
    59,946
    12,556
    7:44 AM
    Updated Centmin Mod .08 beta 02 with a few more updates, one of the more important ones is support for a separate and persistent custom_config.inc file to place custom centmin.sh settings/variables in which override centmin.sh defaults.
    Commit at add persistent custom centmin.sh options file support at inc/custom_conf... · centminmod/centminmod@6744e36 · GitHub
    supports 2 locations for custom_config.inc
    1. inc/custom_config.inc where centmin.sh base directory resides
    2. at ${CONFIGSCANBASE}/custom_config.inc which defaults to /etc/centminmod/custom_config.inc
    to override centmin.sh settings and allow them to persist on centmin mod code updates, create a custom_config.inc at one of the 2 locations mentioned above and add the centmin.sh option to the custom_config.inc file i.e.
    to set PHP 5.6.8 + Zend Opcache as default place in manually created file at /etc/centminmod/custom_config.inc the following variables which are in centmin.sh to override centmin.sh ones
    PHP_VERSION='5.6.8'
    ZOPCACHEDFT='y'
