Sysadmin Grub Help?
Discussion in 'System Administration' started by Jimmy, Sep 15, 2017.
  1. Jimmy
    12:06 AM
    I'm not sure. None listed where it was mounted. Only the problem with the grub not working.
  2. rdan
    12:06 PM
    Same problem for me now, Don't know how to run this on Rescue Mode :(.
  3. Jimmy
    12:06 AM
    Are you booting to the grub prompt?
  4. rdan
    12:06 PM
    Yes same error.
  5. Jimmy
    12:06 AM
    First you have to find the drive with your OS.
    grub> ls
    Then you can boot into the server using:
    grub> set prefix=(md/md2)/boot/grub2
    grub> set root=(md/md2)
    grub> insmod linux
    grub> normal
    Where md/md2 is the drive with your OS.
  6. Jimmy
    12:06 AM
    Once the server boots, run:
    # yum reinstall grub2-efi shim
    # grub2-mkconfig -o /boot/efi/EFI/centos/grub.cfg
    # reboot
  7. rdan
    12:06 PM
    This is all via IPMI Console right?
    Still Installing Java to have access to it.
    Thanks!
  8. Jimmy
    12:06 AM
    Yea, do it all in the IPMI.
    I updated my post 2 above, so check that out.
  9. rdan
    12:06 PM
    Confuse on the next command:
  10. Jimmy
    12:06 AM
    Go through each one until you find the linux file system.
  11. Jimmy
    12:06 AM
    It's probably md/md2 or md/md3
  12. rdan
    12:06 PM
    Different on mine.
  13. rdan
    12:06 PM
    This is it right?
  14. Jimmy
    12:06 AM
    You know when you have the right drive when you see the home, root, sys, etc. folders.
    Try
    # ls (md/md2)
  15. Jimmy
    12:06 AM
  16. Jimmy
    12:06 AM
    Now run this:
    grub> insmod linux
    grub> normal
  17. rdan
    12:06 PM
  18. Jimmy
    12:06 AM
    Yes, run that when you're into the system.
  19. rdan
    12:06 PM
    Running this now, I hope it all goes fine :-(.
