Xenforo Fastcgi cache configuration for Xenforo?
Discussion in 'Forum software usage' started by Everlind, Jun 17, 2014.
    12:26 AM
    Thanks a lot @hungphutho
    I hope @Floren can also share his thoughts about this.
    Hope :angelic::angelic::angelic:
  2. rdan
    12:26 AM
    I got this error:
  3. rdan
    12:26 AM
    @hungphutho
    Any advice on this?
  4. rdan
    12:26 AM
    I just move this:
    fastcgi_cache_path /var/cache/nginx levels=1:2 keys_zone=fastcgicache:10m inactive=10m max_size=100m;
    fastcgi_cache_key $scheme$request_method$host$request_uri;
    fastcgi_cache_lock on;
    fastcgi_cache_use_stale error timeout invalid_header updating http_500;
    fastcgi_cache_valid 5m;
    fastcgi_ignore_headers Cache-Control Expires Set-Cookie;
    on nginx.conf below
    http {
    Works now I think :)
  5. hungphutho
    hungphutho Member
    55
    35
    11:26 PM
    1.7.2
    Percona 5.6
    fastcgi cache you are using multiple domains ?
  6. rdan
    12:26 AM
    On the test vps, yes.
  7. hungphutho
    hungphutho Member
    55
    35
    11:26 PM
    1.7.2
    Percona 5.6
    If you use multiple domains on a server with fastcgi cache, the need to create separate files for each domain php.conf ???
    example .
    domain1.com.conf
    fastcgi_cache_path /var/cache/nginx levels=1:2 keys_zone=fastcgicache1:10m inactive=10m max_size=100m;
    include /usr/local/nginx/conf/php1.conf;
    domain2.com.conf
    fastcgi_cache_path /var/cache/nginx levels=1:2 keys_zone=fastcgicache2:10m inactive=10m max_size=100m;
    include /usr/local/nginx/conf/php2.conf;
    php1.conf
    fastcgi_cache fastcgicache1;
    fastcgi_cache_bypass $no_cache; # $is_mobile
    fastcgi_no_cache $no_cache; # $is_mobile
    fastcgi_cache_valid  200 302 2m;
    fastcgi_cache_valid  301 1h;
    fastcgi_cache_valid 404 1m;
    fastcgi_cache_valid  any 2m;
    #proxy_cache_min_uses 3; # cached only after 3 occurrences of the same request and held for 2 minute
    #add_header X-Cached $upstream_cache_status;
    php2.conf
    fastcgi_cache fastcgicache2;
  8. rdan
    12:26 AM
    Just an update, I got it working 99% as far as I tested :D
    My config:
    nginx.conf above
    include /usr/local/nginx/conf/conf.d/*.conf;
    ### fastcgi_cache
    fastcgi_cache_path /var/cache/nginx levels=1:2 keys_zone=phcornercache:1000m inactive=1d max_size=100m;
    fastcgi_cache_key "$scheme$request_method$host$request_uri";
    ### fastcgi_cache end
    php.conf above }
    ### fastcgi_cache
    fastcgi_cache phcornercache;
    fastcgi_cache_valid  200 302 15m;
    fastcgi_cache_valid  404 5m;
    fastcgi_cache_valid  any 15m;
    Domain conf above location / {
    ### fastCgi cache
        set $no_cache 0;
        # POST requests should always go to PHP
        if ($request_method = POST) {
            set $no_cache 1;
        # Don't use the cache for logged in users
        if ($http_cookie ~* "xf_session_admin|xf_user|xf_user_admin") {
            set $no_cache 1;
        # Don't cache uris containing the following segments
        if ($request_uri ~* "(/login/|/register/|/login|/register|/library/|/internal_data/)") {
            set $no_cache 1;
        ### fastCgi end
    2:26 AM
    This is on your live forums ?
  10. rdan
    12:26 AM
    Not yet, just a test VPS.
    2:26 AM
    look very good there :D (y) :woot:
  12. rdan
    12:26 AM
    I have read almost 10 articles that tackle fastcgi_cache including the main age at nginx.org Module ngx_http_fastcgi_module
    And strip some of the code by @hungphutho some of it are already the default value and some of he filter are redundant.
    I focus on filtering via cookies.
  13. rdan
    12:26 AM
    I will apply it on my Live Forum next few minutes :)
  14. rdan
    12:26 AM
  15. rdan
    12:26 AM
    @eva2000 Why not apply it on this forum?
    Lets unite the debugging mode :D
    Applying now on my live forum :D
    2:26 AM
    You can go first.. I'll watch :LOL::D
  17. rdan
    12:26 AM
    Already applied on my live forum, hopefully my members will not encounter any issues :D :woot:
  18. rdan
    12:26 AM
  19. rdan
    12:26 AM
    Here's the problem that I don't know how to fix.
    Guest can't change style :/
  20. Floren
    Floren Active Member
    148
    77
    12:26 PM
    @eva2000, let me know if you implemented this on these forums, so I can never login here. I don't want to have my private information (i.e. conversations) displayed to everyone. Start a conversation on AXIVO and let me know. Thanks. Logging out...
