Cloudflare Cloudflare Dashboard and Cloudflare API service issues
Discussion in 'VPS Provider Network Status' started by eva2000, Sep 13, 2024.
    58,895
    12,490
    8:11 PM
    Sep 12, 16:55 UTC
    Identified - The issue has been identified and a fix is being implemented.
    Sep 12, 16:51 UTC
    Investigating - Cloudflare is investigating issues with Cloudflare Dashboard and related APIs.
    These issues do not affect the serving of cached files via the Cloudflare CDN or other security features at the Cloudflare Edge.
    Customers using the Dashboard / Cloudflare APIs are impacted as requests might fail and/or errors may be displayed.
