yum update need help
Discussion in 'Install & Upgrades or Pre-Install Questions' started by xenbiarritz, May 1, 2019.
  1. xenbiarritz
    xenbiarritz Member
    44
    9:53 PM
    hi
    after upgrading centminmod,
    i run a yum update
    yum update --disableplugin=priorities --setopt=deltarpm=0 --enablerepo=remi --exclude=python34-*,python35-*,python36-*
    and it return
    Error: Package: cmake3-data-3.13.4-2.el7.noarch (epel)
               Requires: /usr/bin/python3.6
     You could try using --skip-broken to work around the problem
     You could try running: rpm -Va --nofiles --nodigest
    what should i do?
    thank you for your help
    46,223
    10,507
    6:53 AM
    you can switch from IUS Community python packages o EPEL versions. I wrote a quick script to fix this which is added to all new 123.09beta01's addons/python34_install.sh routines but if your system is older you wouldn't have ran the script with the fix
    you can do that via SSH command which runs the code displayed at fix python34/python34u and python36/python36u conflicts on centos 7 in centminmod 123.09beta01
    curl -4s https://gist.github.com/centminmod/e050cf02794fb5bcdf3090c28efab202/raw/python-conflict-fix.sh | bash
    then yum update should be fine
  3. xenbiarritz
    xenbiarritz Member
    44
    9:53 PM
    thank you for quick replay
    i am on 123.09beta01
    i run
    then yum update
    and it still return
    46,223
    10,507
    6:53 AM
    after the fix the exclude python lines won't show on centmin.sh menu option 24 exits so yum update command would be
  5. xenbiarritz
    xenbiarritz Member
    44
    9:53 PM
    it workes
    next time, should i exclude python lines?
    thank you
    46,223
    10,507
    6:53 AM
    Use the yum update line reported/displayed by centmin.sh menu option 24 exit at the time of a particular exit run as it changes depending on what is detected by your system. So if python34u packages are no more, it won't show those exclude lines on next time you do a centmin.sh menu option 24 exit
  7. xenbiarritz
    xenbiarritz Member
    44
    9:53 PM
    thank you so much
