Upgrade Yum Update Issue - Python Conflicts
Discussion in 'Install & Upgrades or Pre-Install Questions' started by BigIron, Dec 9, 2018.
  1. BigIron
    BigIron Member
    62
    15
    1:49 AM
    • Nginx Version Installed: 1.15.3
    • PHP Version Installed: 7.2.10
    • MariaDB MySQL Version Installed: 10.1.36
    • When was last time updated Centmin Mod code base ? : Today
    • Persistent Config: Do you have any persistent config file options set in /etc/centminmod/custom_config.inc ? No
    Trying to update via
    yum update --disableplugin=priorities --enablerepo=remi
    Getting this error
    Transaction check error:
      file /usr/lib/python2.7/site-packages/socks.py conflicts between attempted installs of python2-pysocks-1.6.8-5.el7.noarch and python-SocksiPy-1.00-4.el7.art.noarch
      file /usr/lib/python2.7/site-packages/socks.pyc conflicts between attempted installs of python2-pysocks-1.6.8-5.el7.noarch and python-SocksiPy-1.00-4.el7.art.noarch
      file /usr/lib/python2.7/site-packages/socks.pyo conflicts between attempted installs of python2-pysocks-1.6.8-5.el7.noarch and python-SocksiPy-1.00-4.el7.art.noarch
    Any ideas?
    44,406
    10,139
    6:49 PM
    belongs to 3rd party Atomic YUM repository python-SocksiPy-1.00-4.el7.art.noarch.rpm CentOS 7 Download. You installed that Atomic repo manually yourself ? As Centmin Mod doesn't install this and for 3rd party YUM repos that Centmin Mod does install, ones that can cause potential conflict are managed via YUM Priorities outlined at Third Party YUM Repos with Centmin Mod - CentminMod.com LEMP Nginx web stack for CentOS.
    You can try to just use yum to remove python-SocksiPy-1.00-4.el7.art.noarch and install the proper yum package for python2-pysocks-1.6.8-5.el7.noarch which seems to be an EPEL YUM repo package.
    For CentOS 7, maybe able to use yum swap command
    yum swap python-SocksiPy-1.00-4 python2-pysocks-1.6.8-5
    Then you need to configure your Atomic YUM config to use YUM priorities and maybe in Atomic YUM config file set exclude=python-SocksiPy so future conflicts don't happen PackageManagement/Yum/Priorities - CentOS Wiki.
