Yum update dependency problem
Discussion in 'Install & Upgrades or Pre-Install Questions' started by Andy, Aug 6, 2015.
  1. Andy
    Andy Active Member
    544
    89
    12:20 AM
    One of my servers running 08stable got this error when doing a yum update.
    Error: Package: ntp-4.2.6p5-19.el7.centos.x86_64 (@updates)
               Requires: ntpdate = 4.2.6p5-19.el7.centos
               Removing: ntpdate-4.2.6p5-19.el7.centos.x86_64 (@updates)
               Updated By: ntpdate-4.2.6p5-19.el7.centos.1.x86_64 (updates)
                   ntpdate = 4.2.6p5-19.el7.centos.1
     You could try using --skip-broken to work around the problem
    ** Found 3 pre-existing rpmdb problem(s), 'yum check' output follows:
    iputils-20121221-6.el7_1.1.x86_64 is a duplicate with iputils-20121221-6.el7.x86_64
    ntp-4.2.6p5-19.el7.centos.1.x86_64 is a duplicate with ntp-4.2.6p5-19.el7.centos.x86_64
    ntp-4.2.6p5-19.el7.centos.1.x86_64 has missing requires of ntpdate = ('0', '4.2.6p5', '19.el7.centos.1')
    55,458
    12,257
    3:20 PM
    try running
    yum-complete-transaction
    or
    yum clean all
    yum distro-sync
    yum -y update
  3. Andy
    Andy Active Member
    544
    89
    12:20 AM
    Got same errors when running yum distro-sync
    55,458
    12,257
    3:20 PM
    what happens if you manually and specially remove the complaining package version and install the newer version
    rpm -e --nodeps iputils-20121221-6.el7
    yum -y install iputils-20121221-6.el7_1.1
    rpm -e --nodeps ntp-4.2.6p5-19.el7.centos
    yum -y install ntp-4.2.6p5-19.el7.centos.1
  5. Andy
    Andy Active Member
    544
    89
    12:20 AM
    Thank you. the rpm should have --nodeps, not -nodeps
    The yum install step will result in "already install and latest version"
    In any case, yum update will not complain anymore. Great job.
    55,458
    12,257
    3:20 PM
    haha double dash !
    Glad I could help
