Xenforo xenforo theme; best way to deal with permissions?
Discussion in 'Forum software usage' started by Andreas, Feb 17, 2022.
  1. Andreas
    Andreas New Member
    12
    1:11 PM
    Hey There,
    after I have successfully installed xenforo & centminmod,
    I proceed to install a new theme for my forum.
    I have now the problem with the permissions.
    Is there an easy, convenient way to do that?
    I searched the forum and did not find a general answer to this;
    I mean, what commands to type in, or what chmod value exactly do I have to assign to the folders (?)
    Is nginx the webserver user? (do I have to assign ownership to nginx:nginx?)
    (btw: after installing the theme, do the permissions must stay like that,
    or can I switch them back / make the folders more safe again?)
    Thank you
    55,796
    12,271
    9:11 PM
    See https://community.centminmod.com/th...on-centmin-mod-123-09beta01-lemp-stack.16060/ and Getting started guide step 2 for permission which is dependent on how you uploaded the files
    Getting Started Guide
    For non-pure-ftpd uploaded files i.e SFTP uploads
    If you otherwise use pure-ftpd uploads, then the user group permissions are automatically set to correct nginx user and group
  3. Andreas
    Andreas New Member
    12
    1:11 PM
    Hi George,
    I have found another good post from you, from 2020:
    https://community.centminmod.com/threads/xf-2-2-2-cannot-install-style.20812/
    First backup your existing permissions for everything under /public with command below where yourdomain.com is your domain name
    getfacl -R -L --absolute-names /home/nginx/domains/yourdomain.com/public > /home/nginx/domains/yourdomain.com/backup/backup-permissions-$(date +"%d%m%y-%H%M%S").acl
    if you need to restore this backed up permissions use
    setfacl --restore=backup-/home/nginx/domains/yourdomain.com/backup/backup-permissions-XXXXXX-XXXXXX.acl
    where XXXXXX-XXXXXX is the day-month-year-hr-min-sec timestamp from the above backup command
    Then chown user and group permissions recursively for all directories and files below /public would take care of ownership of files
    chown -R nginx:nginx /home/nginx/domains/yourdomain.com/public
    That should take care of the user/group permissions but you still need properly permissions for directory and files
    Is this still valid?
    I think this is a good way to save old permissions,
    and then change to new ones.
    55,796
    12,271
    9:11 PM
    Yup that works fine
