Xenforo XenForo Redirects for vBulletin 1.0.2
Discussion in 'Forum software usage' started by Itworx4me, Feb 5, 2018.
  1. Itworx4me
    Itworx4me Active Member
    316
    29
    3:03 PM
    Nginx 1.27.4
    MariaDB 10.6.21
    Has anyone tested this on centmin yet?
    Thanks,
    Itworx4me
  2. Jon Snow
    Jon Snow Active Member
    855
    172
    7:03 PM
    Nginx 1.13.9
    MariaDB 10.1.31
    Was 1.0.2 a typo? o_O
  3. Itworx4me
    316
    29
    3:03 PM
    Nginx 1.27.4
    MariaDB 10.6.21
  4. Sunka
    Sunka Well-Known Member
    1,150
    325
    Pula, Croatia
    12:03 AM
    Nginx 1.17.9
    MariaDB 10.3.22
  5. Jon Snow
    855
    172
    7:03 PM
    Nginx 1.13.9
    MariaDB 10.1.31
  6. Rake-GH
    Rake-GH Active Member
    179
    93
    USA
    6:03 PM
    default
    default
    Several people on the Xenforo forum are complaining that this addon doesn't work on nginx and haven't got a formal response from Xenforo, they said it's not supported by them.
    The addon in question is for Xenforo 2:
    The latest version is 1.1.5
    It redirects old vbulletin URLs to Xenforo, but it only works correctly on apache. Has anyone got this working?
    I tried a recommended fix which fixed 95% of redirects but introduced another bug where certain URLs are redirecting to "domain.com/domain.com/"
    Besides this, everything is working perfectly, and other people are complaining of the same issue, so I'm mostly sure that it's not my config. The Xenforo friendly URL rewrites are setup and working correctly per the instructions, so again, that should not be a cause of the issue.
    Here is the important portion of my conf:
        index index.php index.html;
        #auth_basic "Private";
        #auth_basic_user_file /usr/local/nginx/conf/htpasswd;
    location /admin.php {
    location /install/ {
    location /install/data/ {
      internal;
    location /install/templates/ {
      internal;
    location /internal_data/ {
      internal;
    location /library/ { #legacy
      internal;
    location /src/ {
      internal;
    location ~ \.php$ {
      #vbulletin redirect partial fix:
      #try_files $uri /index.php?$uri&$args;
      #normal:
      #try_files $uri =404;
      fastcgi_pass    127.0.0.1:9000;
      fastcgi_param   SCRIPT_FILENAME $document_root$fastcgi_script_name;
      include         fastcgi_params;
    My post on Xenforo forum is here, for more info:
    Any help would be appreciated.
  7. Rake-GH
    179
    93
    USA
    6:03 PM
    default
    default
    Fixed!
    you must have the Xenforo Redirects for vBulletin addon installed, and select your "import_log" table in the addon options.
    In the PHP block:
    you must comment out:
    replace it with:
    Then restart nginx and clear your browser cache and maybe any other caches.
    Should that not solve your problem here is a fix for showthread.php, put this above you "location /" block
    location ~ ^/showthread.php
        if ($args ~* ^(\d+)-(.+)$)
            set $tid $1;
            set $args '';
            rewrite ^ /threads/$tid permanent;
       if ($args ~* ^t=(\d+)$)
        set $tid $1;
        set $args '';
  8. Rake-GH
    179
    93
    USA
    6:03 PM
    default
    default
  9. Earl
    Earl New Member
    16
    6
    3:33 AM
    My problem is related to the exact same thing so I will post it here,
    Vbulletin forum was on site.com/forum/
    new xenforo is on site.com/
    I have created a directory named forum and moved the index.php and corrected the path as in the xenforo guide, but it's still not redirecting.
    but all urls are redirecting correctly without the /forum/ part.
    Can you guys help me with a little rewrite rule to remove this /forum/ part from the nginx $uri?
    I've tried this:
     location ~ \.php$ {
      if ($uri ~ ^/forum/.*$) {
            rewrite ^/forum/(.*$) ^$1 permanent;
          add_header X-uri2 "$uri";
    and it gets stuck in a loop and stops the connection here
    https://site.comt/forum/%5E%5E%5E%5E%5E%5E%5E%5E%5E%5E%5E%5E%5E%5E%5E%5E%5E%5E%5Eshowthread.php?t=1449456
    there is something wrong with this part
    edit:
    location ~ ^/forum/.*$ {
    rewrite ^/forum/(.*$) /$1 permanent;
    this did the trick
