Xenforo Xenforo problem
Discussion in 'Forum software usage' started by DaB, Aug 10, 2016.
  1. DaB
    DaB Member
    45
    5
    10:56 AM
    Current
    Current
    I have edited the /usr/local/nginx/conf/conf.d/mydomain.com.conf file so I can enable friendly URLS.
    When I restart nginx, I get this error.
    Restarting nginx (via systemctl): Job for nginx.service failed because the control process exited with error code. See "systemctl status nginx.service" and "journalctl -xe" for details.
    Any ideas?
    TIA.
    55,417
    12,256
    7:56 PM
  3. DaB
    DaB Member
    45
    5
    10:56 AM
    Current
    Current
    #server {
    #            listen   80;
    #            server_name mydomain.com;
    #            return 301 $scheme://www.mydomain.com$request_uri;
      server_name mydomain.com www.mydomain.com;
      # ssi  on;
      access_log /home/nginx/domains/therailwaymen.com/log/access.log combined buffer=256k flush=60m;
      error_log /home/nginx/domains/mydomain.com/log/error.log;
      root /home/nginx/domains/mydomain.com/public;
      location ~ (?:^|/)\. {
       deny all;
      #autoindex  on;
      #autoindex_localtime on;
            location /internal_data/ {
            internal;
            allow 127.0.0.1;
            allow 111.222.333.444;
            deny all;
            location /library/ {
            internal;
            allow 127.0.0.1;
            deny all;
    55,417
    12,256
    7:56 PM
    55,417
    12,256
    7:56 PM
    also type output for
    nginx -t
  6. DaB
    DaB Member
    45
    5
    10:56 AM
    Current
    Current
    nginx: [emerg] "location" directive is not allowed here in /usr/local/nginx/conf/conf.d/mydomain.com.conf:59
    55,417
    12,256
    7:56 PM
    yup because you placed the xenforo rules outside of server{} context
    correct one would be below notice the placement
    #server {
    #            listen   80;
    #            server_name therailwaymen.com;
      # ssi  on;
            internal;
            allow 127.0.0.1;
            deny all;
            internal;
            allow 127.0.0.1;
            deny all;
    also read Nginx Rewrites for Xenforo Friendly Urls - CentminMod.com LEMP Nginx web stack for CentOS for password protecting admin.php
