Xenforo Login & Logout Problem
Discussion in 'Forum software usage' started by Mike05, Sep 18, 2022.
  1. Mike05
    Mike05 New Member
    5
    11:03 PM
    1.18.o
    I recently installed xenforo 2.2.10 and I'm having two problem.
    1. When I login , it doesn't display my nick, it's like I'm not logged , then I refresh the forum but nothing happens unless I click on Members then my nick displays on the Bar. I think it's some sort of Caching proglem.
    2. When I tried to log out, it throws error at me ( Security error occurred. Please press back, refresh the page, and try again ) Refreshing doesn't help.
    I'm still trying to fix it. But I think I just dump the Data Base and start from scratch..
    But I would highly appreciate your help. If that doesn't resolve the situation.
    And could you please provide me the best Xenforo 2 fastcgi cache directives and config.php file.
    Thanks again.
    55,417
    12,256
    4:03 PM
    What caching options are you using on the server itself for the Xenforo forum domain i.e. PHP-FPM fastcgi_cache - did you set that up? If so improper setup will cause what you describe. I'd remove/undo the PHP-FPM fastcgi_cache setup and see if that fixes your problems first.
    Are you enabling Xenforo's native guest full HTML page caching? That's another one that has been reported to cause a similar issue you have now. So disable Xenforo's native guest full HTML page caching and see if that fixes your problems first.
  3. duderuud
    duderuud Premium Member Premium Member
    265
    88
    The Netherlands
    8:03 AM
    1.27 x
    10.6
    Had the same problem here. Logged in, nothing happened. Hard refresh the page, still nothing.
    Tried to login again, not logged in. Hard refresh...logged in :confused:
    55,417
    12,256
    4:03 PM
    When you log out, do you also manually clear cookies for the site?
  5. duderuud
    265
    88
    The Netherlands
    8:03 AM
    1.27 x
    10.6
    No
  6. duderuud
    265
    88
    The Netherlands
    8:03 AM
    1.27 x
    10.6
    This was the first time experiencing this BTW. Logged in without any problems before.
    55,417
    12,256
    4:03 PM
    Interesting then. Was about to ask you that very question if it's happened before or first time. Take note of the web browser/device (laptop/phone/desktop/tablet) used if it occurs in future. On this forum itself you can also post a report at https://community.centminmod.com/forums/forum-feedback-suggestions.15/ :)
  8. Mike05
    Mike05 New Member
    5
    11:03 PM
    1.18.o
    @eva2000 ; Thank you for your prompt response. I enabled, disabled all the caching directives and I clear all caches when ever I login but the problem remains the same.
    I even enabled, disabled Caching directives in config.php... But getting nowhere.
    The logging out problem has been resolved.
    55,417
    12,256
    4:03 PM
  10. Mike05
    Mike05 New Member
    5
    11:03 PM
    1.18.o
    @eva2000 ;
    You are right, I just disabled php-fpm Cache Path and cache key directive and problem solved..
    Thank you so much for pointing out that for me. Much appreciated.
