Xenforo Xenforo friendly URLS 404 errors + general questions
Discussion in 'Forum software usage' started by brainlet2000, Jan 21, 2020.
  1. brainlet2000
    brainlet2000 Member
    42
    7:19 PM
    1.17.7
    10.3.21
    I've tried adjusting my config many times following the rewrite guides on here but I'm confused. When I enable the friendly urls option in Xenforo I just get 404s. I'm kind of desperate at this point as I've literally tried 100 different things. Below is my non ssl nginx config. I don't understand what is wrong as I literally copied it from the centmin guides. I edited out my domain name for privacy purposes.
                listen   80;
                server_name xx.net;
                return 301 $scheme://www.xx.net$request_uri;
      server_name xx.net www.xx.net;
      #add_header Feature-Policy "accelerometer 'none'; camera 'none'; geolocation 'none'; gyroscope 'none'; magnetometer 'none'; microphone 'none'; payment 'none'; usb 'none'";
      # ssi  on;
      access_log /home/nginx/domains/xx.net/log/access.log combined buffer=256k flush=5m;
      error_log /home/nginx/domains/xx.net/log/error.log;
      include /usr/local/nginx/conf/autoprotect/xx.net/autoprotect-xx.net.conf;
      root /home/nginx/domains/xx.net/public;
      # server and/or vhost site
      #location ~ (?:^|/)\. {
      # deny all;
    location /install/data/ {
         internal;
    location /install/templates/ {
         internal;
    location /internal_data/ {
         internal;
    location /library/ {
         internal;
    #xenforo 2 uncomment / remove hash from next 3 lines
    location /src/ {
         internal;
    Another thing I don't generally understand are the SSL certificates.. I basically just installed my website with menu option 2 without SSL then use cloudflare for ssl. Is this fine or do I need the SSL certificate stuff? I wish I would've seen this great thread: https://community.centminmod.com/th...on-centmin-mod-123-09beta01-lemp-stack.16060/ earlier as I could've just followed the steps.. Now I already have the site up and I'm stuck.
    Can anyone help me out here? I was thinking of just following the steps here https://centminmod.com/vhost.php and enabling SSL with those steps but I'm worried ill brick my server..
    What are the exact steps I should follow if I have already installed my forum with menu option 2, have cloudflare for SSL and want to enable friendly urls + let's encrypt SSL. Is this even possible with cloudflare?
    Also what would be the further steps to optimize as in the guide above? I'm just confused because I feel that I'm too dumb to figure this out without following a step by step guide. It really annoys me.
  2. brainlet2000
    brainlet2000 Member
    42
    7:19 PM
    1.17.7
    10.3.21
    I hate being stupid like this.. It really irritates me that I have to ask to be spoonfed but I just really can't figure this out. I've tried for weeks now.
    55,458
    12,257
    3:19 AM
    That would be fine as Cloudflare uses flexible SSL by default so it talks to non-HTTPS port 80 of Centmin Mod Nginx which is what you setup via centmin.sh menu option 2 when you select without SSL.
    There's generally 3 ways of setting up HTTPS SSL certificate for Centmin Mod Nginx HTTP/2 based HTTPS. You can't use method 1 or 2 now that you created your nginx vhost site, but can use method 3 for existing non-HTTPS nginx vhost migration to HTTPS if you choose to do so later down the road after you sorted out the rest.
    Method 1. The traditional way via centmin.sh menu option 2, 22 but ensuring you set LETSENCRYPT_DETECT='y' in persistent config file created at /etc/centminmod/custom_config.inc before you run centmin.sh menu option 2 or 22 for wordpress. You can do that using command below - only need to do this step once and every subsequent run of centmin.sh menu option 2 or 22 will have letsencrypt ssl certificate support enabled
    # enable letsencrypt ssl certificate integration https://centminmod.com/acmetool/
    touch /etc/centminmod/custom_config.inc
    echo "LETSENCRYPT_DETECT='y'" >> /etc/centminmod/custom_config.inc
    Method 3. Fully manual method for free Letsencrypt SSL certificates.
    For Xenforo see https://community.centminmod.com/th...nginx-friendly-url-rules-configuration.14289/ though there's a note for differences in vhosts generated if you used that vhost.php generator as opposed to https://centminmod.com/nginx_configure_xenforo_seo_friendly_urls.html
    Did you install Xenforo on web root at domain.com or subdirectory like domain.com/community as that would change the try_files rule for
    to
           location /community/ {
               try_files $uri $uri/ /community/index.php?$uri&$args;
  4. brainlet2000
    brainlet2000 Member
    42
    7:19 PM
    1.17.7
    10.3.21
    Hi, thanks for the swift reply.. Is there any point in migrating to https on the server when already using cloudflare? Any benefits? Because I already envision myself wrecking my whole dedicated server config.. I haven't figured out how to backup yet and there's no snapshots since it's a dedicated.. Is following that guide safe? I mean of course it is but what's the chance of fucking something up?
    I installed it on web root at domain.com, no sub folder. So I really don't understand why it doesn't work. I put in the rules, restarted nginx, then turned on friendly urls in Xenforo and immediately get 404 errors.. Is there anything wrong with my config file?
    55,458
    12,257
    3:19 AM
    Yes if you have HTTPS on Centmin Mod Nginx side, then Cloudflare servers when switched from Cloudflare Flexible SSL to Full SSL, can communicate with Centmin Mod Nginx over HTTPS via TLSv1.3 which is better for performance and security https://community.centminmod.com/th...s-tls-1-3-backend-origin-communication.16795/
    not that I can see. Make sure you uploaded all XF 2.1 files and didn't miss any and ensure permissions are correct as nginx user/group.
    Best way then is start up another hourly billed VPS like vultr, digitalocean, linode or like highly recommended Upcloud - signees also get US$25 credits to use as well as a test VPS and install test Xenforo forum on that as non-HTTPS centmin.sh menu option 2 created site like you have now and then do test method 3 manual migration to HTTPS on that test VPS until you get it all working and comfortable doing on live/production VPS
    That is usually how I test new things, on a test VPS before applying it on live VPS.
  6. Rake-GH
    Rake-GH Active Member
    179
    93
    USA
    1:19 PM
    default
    default
    55,458
    12,257
    3:19 AM
    no required as centmin mod nginx vhosts use php.conf include file
  8. brainlet2000
    brainlet2000 Member
    42
    7:19 PM
    1.17.7
    10.3.21
    I will try to implement HTTPS later on a test server first, but what is realistically the chance of any issues if I simply follow your steps? Can't be that hard right?
    I used a fresh install of XF 2.1 and imported from mybb 1.8. I followed your guide to chmod the correct files. It still doesn't work. I really don't get it.
  9. brainlet2000
    brainlet2000 Member
    42
    7:19 PM
    1.17.7
    10.3.21
  10. brainlet2000
    brainlet2000 Member
    42
    7:19 PM
    1.17.7
    10.3.21
    Hey guys, I managed to fix this issue. I had my cloudflare settings on SSL strict which made every page only grab the https config which I hadn't set up yet.. By moving it to flexible I was able to enable SEO urls successfully :). Wooo!
    One more question @eva2000, is it a problem enabling SEO links now with flexible ssl by cloudflare? Will there be an issue when I add the SSL certificate? Are the steps any different?
    AKA I'm worried that now all the thread urls are SEO that when I switch to https and there are no rewrite rules this will be broken.. Is this a valid concern or irrelevant?
    55,458
    12,257
    3:19 AM
    ah ha yes that would cause problems when you do not have Centmin Mod Nginx with HTTPS setup yet
    shouldn't be any problems with CF flexible SSL if Centmin Mod Nginx is non-HTTPS nor will there be problem with CF full ssl if you have Centmin Mod Nginx with HTTPS setup eventually.
    non-pretty urls will redirect to pretty ones via Xenforo's own code.
  12. Rake-GH
    179
    93
    USA
    1:19 PM
    default
    default
    To get the Xenforo 2 Friendly Redirects to work with the official Xenforo 2 Vbulletin -> XF redirect addon you have to do an "unofficial" fix which involves changing:
    try_files $uri =404;
    to
    try_files $uri /index.php?$uri&$args;
    view it in full here:
    location ~ \.php$ {
      #vbulletin redirect partial fix:
      #original:
      #try_files $uri =404;
      fastcgi_pass    127.0.0.1:9000;
      fastcgi_param   SCRIPT_FILENAME $document_root$fastcgi_script_name;
      include         fastcgi_params;
    It makes the vbulletin redirects work on XF but it causes some weird PHP errors. Sadly XF is not providing support for this addon.
    Do you think it might have something to do with your php.conf and the unofficial fix being redundant or being incompatible?
    55,458
    12,257
    3:19 AM
    which add on is that ? link url ?
  14. Rake-GH
    179
    93
    USA
    1:19 PM
    default
    default
    55,458
    12,257
    3:19 AM
    thanks for the heads up. I haven't tried vBulletin to XF 2.x redirections yet only vBulltin to XF 1.5.x redirects and usually I just use pure nginx rewrite rules without any XF vB to XF redirect addons.
  16. Rake-GH
    179
    93
    USA
    1:19 PM
    default
    default
    Xenforo still refuses to support their redirect addon so I'm not using it anymore.
    We only needed to redirect /showthread.php and /forumdisplay.php, the rest of the redirects aren't important, this is what we're using now:
      location = /showthread.php {
        if ($query_string ~* ^(?<threadid>\d+)) {
          return 301 /threads/$threadid;
      location = /forumdisplay.php {
        if ($query_string ~* ^(?<forumid>\d+)) {
          return 301 /forums/$forumid;
    Problem solved
