Xenforo Xenforo forum performance issues: how to diagnose problem?
Discussion in 'Forum software usage' started by brainlet2000, May 19, 2020.
  1. brainlet2000
    brainlet2000 Member
    42
    10:00 AM
    1.17.7
    10.3.21
    Hi all,
    recently my forum has been having hiccups, being generally slow at times and issues loading some pages. I'm sure that this is not related to the server specs, since I have a dedicated server that is way overpowered for its purpose. My forum is quite active but CPU usage is only around 10-20%. My forum has been DDoSed a few times, but since then it has been having a few performance issues even while not being attacked.
    Are there any steps I can take to find out where the problem lies?
    Thanks!
  2. brainlet2000
    brainlet2000 Member
    42
    10:00 AM
    1.17.7
    10.3.21
    I have noticed high mariaDB cpu usage at times spiking up to 20%. I have not changed the settings from out the box centminmod.
  3. brainlet2000
    brainlet2000 Member
    42
    10:00 AM
    1.17.7
    10.3.21
    Server restart appears to have resolved for now.. Not sure what this is related to.
    55,180
    12,250
    6:00 PM
    If running Centmin Mod 123.09beta01 or higher, you will have access to a cminfo top command which can also provide a summary of statistics - some of which are explained in info and linked articles below.
    FYI, CPU load optimal is 1.0 per cpu thread so 8 cpu thread normal = 8x1 = 8.0. 16 cpu server normal is 16x1 = 16.0
    so cpu load of 8 for
    • 2 cpu server = 8/2 = 4.0 load average
    • 4 cpu server = 8/4 = 2.0 load average
    • 8 cpu server = 8/8 = 1.0 load average
    When you type top command, hit number 1 to break down per cpu stats
    2. What's your VPS/Server hardware specifications ? cpu type ? memory available ? disk space ?
    3. Who's your web host ? Different hosts have different limits for server resource usage and some are more restrictive that others so it could just be their resource usage policy you tripped which may or may not be restrictive. If restrictive, then real solution would be finding a better web host. If not restrictive, then it's finding out what caused high cpu load.
    4. If running Centmin Mod 123.09beta01 or higher, you will have access to a cminfo top command which can also provide a summary of statistics - some of which are explained in info and linked articles below.
    Notes:
    For example some commands which are also available automatically when you run cminfo top command
    top -bn1
    ps aufxw
    sar -q
    sar -r
    sar -q -f /var/log/sa/sa$(date +%d -d yesterday)
    sar -r -f /var/log/sa/sa$(date +%d -d yesterday)
    If you want to look at per process usage stats use pidstat run pidstat every 1 sec for 5 runs and sed is just to replace your main hostname with word hostname so mask your domain for posting on public places
    pidstat -durh 1 5 | sed -e "s|$(hostname)|hostname|g"
    for posting code you might want to use CODE tags for code How to use forum BBCODE code tags :)
  5. brainlet2000
    brainlet2000 Member
    42
    10:00 AM
    1.17.7
    10.3.21
    Hi again @eva2000. My server has 23 cores, with a load average of 0.18-0.30 so that should be fine.
    1. I am running centminmod 123.09beta01. Centminmod was installed around 6 months ago, last update a few days ago.
    2. It is a dedicated server. The specs are:
    P Proliant BL460c G7     2x Intel Xeon X5650 6-Core 2.67 GHz
    (11379)     32 GB ECC RAM     1x250GB SSD
    I believe that is more than adequate for running a single Xenforo forum.
    3. Web host is not the issue, I have contacted them and they said they found no issues.
    4. I've attached output of cminfo top command since it was too long to post and I wasn't sure what parts are most relevant.
    As far as I can see there are no issues. The only thing I can see is 73% of the home partition being used. Could that be causing issues? The forum has sudden lag issues seemingly out of nowhere, helped by a shutdown -r now reboot command. Is there anything that stands out from this log?
    Thanks.
  6. Dnyan
    Dnyan Member
    106
    24
    1:30 PM
    1.17.8
    10.3.22
    You should also consider looking at recently installed addon at xf system.
    I had performance issue in past when i had installed one of the addon which literally made my site offline for few days. Later, the dev rectified whatever wrong codes were there in his addon.
    So if you added any addon recently which does alteration of your database, then kindly do also look at that too.
  7. brainlet2000
    brainlet2000 Member
    42
    10:00 AM
    1.17.7
    10.3.21
    I've just went ahead and updated all the addons + updated importers. Also ran updates yesterday. Let's see if it continues.
  8. brainlet2000
    brainlet2000 Member
    42
    10:00 AM
    1.17.7
    10.3.21
    I also deleted the backups hosted on the server, freeing unnecessary taken space. Site seems to be performing better now, I suppose the filesystem being full of files can slow down the system somehow?
  9. STN
    STN CentMaxMod
    9
    1:00 PM
    1.19.0
    Mariadb 10.3
    No. Are you sure there's no malicious traffic eating away resources?
    Do you use cloudflare? If so i, suggest putting your login/register and search pages under cloudflare under attack mode using page rules. It's crazy how much bots eat cpu/memory trying to register and login.
    Also look at Google analytics if it's spike in traffic since you say it happens rarely.
    By the way, having spent a lot of time with phpbb, i have to say xenforo is really unoptimised and sucks with resource usage. If you're not already, use caching.
    I had my mysql memory usage at less than 5% with phpbb for years. Converted to xenforo and it's constantly 19% now at half the traffic phpbb had (suffered traffic loss after conversion to xenforo).
  10. negative
    negative Active Member
    415
    50
    11:00 AM
    1.9.10
    10.1.11
