Xenforo Xenforo and Nginx when installation directory is underneath public folder
Discussion in 'Forum software usage' started by binventive, Feb 21, 2018.
  1. binventive
    binventive New Member
    6
    10:08 AM
    Latest via latest Centmin beta
    MariaDB 10
    • CentOS Version: Centos 7 64 Bit
    • Centmin Mod Version Installed: Latest beta as of about a week ago
    • Nginx Version Installed: 1.13.8
    • PHP Version Installed: 7.2.2
    • MariaDB MySQL Version Installed: 10.1.31
    • Persistent Config: No Do you have any persistent config file options set in /etc/centminmod/custom_config.inc ?
    I have installed Xenforo 2.0.2 in /home/nginx/domain/mydomain.com/public/community. When I go to my web site, the index.html from the public directory keeps being used. I want the default path to be https://mydomain.com/community rather than MyDomain | Domain Names, Web Hosting, and Free Domain Services, so Xenforo is referenced rather than the index.html in the public directory. Is it required that I complete the steps described for nginx at the link below at a minimum? If so, it does not seem to make any difference.
    Friendly URLs | XenForo
    I have looked at the information at the link below, but I want to start out simple and see if I can get things working correctly before I do additional step(s).
    Nginx Rewrites for Xenforo Friendly Urls - CentminMod.com LEMP Nginx web stack for CentOS
    47,474
    10,760
    1:08 AM
  3. binventive
    6
    10:08 AM
    MariaDB 10
    Thanks for the reply. I have looked at the Xenforo Friendly URLs link, but I found other references that indicated that some of the information there should no longer be used. I also looked at Nginx Rewrites for Xenforo Friendly Urls - CentminMod.com LEMP Nginx web stack for CentOS and I have tried to update the mydomain.ssl.conf file with a basic configuration based on some information I found on that page. See below. It is not working. I am thinking I might have to put the Xenforo installation in the public folder rather than in public/community, if I can't get this working fairly soon.
            location /community/ {
                try_files $uri $uri/ /community/index.php?$uri&$args;
            location /community/internal_data/ {
            internal;
            allow 127.0.0.1;
            allow 0.0.0.0;
            deny all;
            location /community/library/ {
            internal;
            allow 127.0.0.1;
            allow 0.0.0.0;
            deny all;
    47,474
    10,760
    1:08 AM
    after editing did you restart nginx server ?
    ngxrestart
    Or
    service nginx restart
    can you elaborate ?
  5. binventive
    6
    10:08 AM
    MariaDB 10
    47,474
    10,760
    1:08 AM
    fyi, if you don't want your domain name parsed in posts, you can wrap them in PLAIN bbcode tags [PLAIN][/PLAIN] ;)
    If you want https://domain.com/ to show your forums, you need to have installed Xenforo files in web root of your domain at /home/nginx/domains/domain.com/public. By installing at /home/nginx/domains/domain.com/public/community/ your forum would be located at https://domain.com/community
  7. binventive
    6
    10:08 AM
    MariaDB 10
    That is exactly what is happening! I can get to the Xenforo site by going to https://www.mydomain.com/community. I was perhaps taking the line below from the Xenforo 2 installation documentation a bit to literally (and assuming that since pages are already being displayed from the public folder, I should not install Xenforo there). Anyway, I was going to try and install into the public folder (rather than attempt to have it in public/community), so that is what I will now do. Thanks for your help.
  8. binventive
    6
    10:08 AM
    MariaDB 10
    It works find after I installed the Xenforo 2 into public rather than into public/community. Thanks again for helping me "think" through the process more clearly.
    47,474
    10,760
    1:08 AM
    Glad to hear :)
