Xenforo XenForo 2.1 CDN using Cloudflare free plan :D
Discussion in 'Forum software usage' started by rdan, Oct 7, 2019.
    1,412
    1:14 AM
    Free and not using Cloudflare on main Domain.
    Just to save bandwidth and accelerate static files.
        listen 443 ssl http2;
        server_name cdn.xf.com;
        include /usr/local/nginx/conf/ssl/xf.com_ssl.conf;
        access_log off;
        log_not_found off;
        error_log /home/nginx/domains/xf.com/cdn_error.log error;
        root /home/nginx/domains/xf.com/public;
        location /               { deny all; }
        location ~ \.(default|html|php|txt|xml)$ { deny all; }
        location /data/          { }
        location /js/            { }
        location /styles/        { }
        location ~ ^/(proxy.php) { include /usr/local/nginx/conf/php.conf; }
  2. pdinh97qng
    pdinh97qng Member
    121
    15
    10:14 AM
    If I'm not wrong, CloudFlare doesn't allow customer to serve only static files. I saw an email for this situation before:p Better to not violate the rules :yawn:
    55,983
    3:14 AM
    I believe @rdan is setting up non-cloudflare protected domain.com hostname that serves static files directly from a separate cloudflare protected cdn.domain.com hostname on Centmin Mod Nginx origin web server. Basically disabling cloudflare orange cloud on domain.com DNS record and enabling cloudflare orange cloud on cdn.domain.com DNS record.
    Yeah they do have such a rule though it's open for interpretation and with their release of Cloudflare Workers, it is all about serving static files :) Cloudflare will contact you if you overstep their usage policy. So you can ask them if unsure.
  4. rdan
    1,412
    1:14 AM
    My fully working and updated config.
        listen 80;
        server_name cdn.domain.com;
        return 301 https://cdn.domain.com$request_uri;
        include /usr/local/nginx/conf/ssl/domain.com/domain.com_ssl.conf;
        access_log off;
        log_not_found off;
        error_log /home/nginx/domains/domain.com/cdn_error.log error;
        location ~* \.(default|html|php|txt|xml)$ { deny all; }
        location ~* \.(gif|jpg|jpe|jpeg|png|ico)$ {
        gzip_static off;
        add_header Link "<https://domain.com$request_uri>; rel=\"canonical\"";
        add_header Access-Control-Allow-Origin *;
        add_header Cache-Control "public, must-revalidate, proxy-revalidate, immutable, stale-while-revalidate=86400, stale-if-error=604800";
        expires 30d;
        break;
        location ~* \.(3gp|wmv|avi|asf|asx|mpg|mpeg|mp4|pls|mp3|mid|wav|swf|flv|exe|zip|tar|rar|gz|tgz|bz2|uha|7z|doc|docx|xls|xlsx|pdf|iso|br)$ {
        gzip_static off;
        sendfile off;
        sendfile_max_chunk 1m;
        expires 30d;
        break;
        location ~* \.(js|json)$ {
        expires 30d;
        break;
        location ~* \.(css)$ {
        expires 30d;
        break;
        location ~* \.(eot|svg|ttf|woff|woff2|less|otf|scss)$ {
        add_header Cache-Control "public, must-revalidate, proxy-revalidate";
        expires 365d;
        break;
  5. pdinh97qng
    pdinh97qng Member
    121
    15
    10:14 AM
    @rdan can you share your page rules :nailbiting:
  6. rdan
    1,412
    1:14 AM
    Why :nailbiting:? :D
    Just basic Cache Everything option.
    55,983
    3:14 AM
    looks good with canonical headers properly in place too :)
  8. negative
    negative Active Member
    415
    50
    8:14 PM
    1.9.10
    10.1.11
    Do you advice that add the canonical header even without using the cloudflare as CDN in free plan ?
    55,983
    3:14 AM
    yeah doesn't hurt
  10. negative
    415
    50
    8:14 PM
    1.9.10
    10.1.11
    is it enough put that code to location / in my host conf ?
  11. rdan
    1,412
    1:14 AM
    Maybe, but static files won't have that header.
    After 1 month :)
    55,983
    3:14 AM
    excellent results there :)
  13. JJC84
    JJC84 Ad astra per aspera
    247
    109
    San Antonio, Texas
    12:14 PM
    10.x.x
    I have to say this is an exemplary config! Thank you for sharing this @rdan it has helped me in squeezing a bit more performance.
    Because... performance matters right!
  14. upgrade81
    upgrade81 Member
    296
    CH
    7:14 PM
    1.17
    10.3
    Hi, can I know how you configured static and image files on Xen to point to the Cdn subdomain?
    That is, I miss the step before configuring the vhost relative to the cdn ...
    How do you PULL towards subdomain, that's it.
  15. upgrade81
    upgrade81 Member
    296
    CH
    7:14 PM
    1.17
    10.3
    Hi, sorry.
    What did you use to tell XenForo to rewrite all urls pointing to various static images or files?
  16. rdan
    1,412
    1:14 AM
  17. rdan
    1,412
    1:14 AM
  18. upgrade81
    upgrade81 Member
    296
    CH
    7:14 PM
    1.17
    10.3
    Hi, thanks for the answers.
    and to move / synchronize files physically in the subdomain which is enabled on cloudflare?
  19. rdan
    1,412
    1:14 AM
    No need to move files, just point the nginx config to the same directory as your main domain.
  20. upgrade81
    upgrade81 Member
    296
    CH
    7:14 PM
    1.17
    10.3
    ingenious solution!
    Thank you very much
