Nginx nginx/drop.conf duplicates?
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by rdan, Jun 6, 2019.
    11:36 AM
    From this config:
    https://raw.githubusercontent.com/centminmod/centminmod/123.09beta01/config/nginx/drop.conf
    location ~ /\.git { access_log off; log_not_found off; deny all; }
    location ~ /\.gitignore { access_log off; log_not_found off; deny all; }
    are duplicates and already captured in:
    location ~ /\.          { access_log off; log_not_found off; deny all; }
    expires 30d is also redundant here:
    location = /favicon.ico { access_log off; log_not_found off; expires 30d; }
    As it's already in staticfiles.conf
    Please remove:
    location ~* ^/wp-content/updraft { deny all; }
    On this config and move it on specific Wordpress Include file (not sure what the filename is, wpsecure I guess).
    Thanks!
    60,088
    12,584
    1:36 PM
    it was added again in staticfiles.conf include as some folks disable or modify the wpsecure include file and that location block could be wiped and this expose updraft wordpress backups to public access. It's extra security precaution just in case and has no negative effects :)
    will correct the rest though they also have no harm in having them there
