Xenforo X-Accel-Redirect Nginx Configuration help for Xenforo
Discussion in 'Forum software usage' started by Sunka, Feb 2, 2016.
  1. Sunka
    Sunka Well-Known Member
    1,150
    325
    Pula, Croatia
    9:09 AM
    Nginx 1.17.9
    MariaDB 10.3.22
    @eva2000 could you help me with this:
    First part will going into my SSL conf domain
    so this part:
    location /internal_data/ {
            internal;
            allow 127.0.0.1;
            allow MY IP;
            deny all;
    will become this:
            add_header X-Frame-Options SAMEORIGIN;
            add_header X-Content-Type-Options nosniff;
            internal;
    But this part
    location ~ [^/]*\.php$ {
    try_files $fastcgi_script_name =404;
    include fastcgi.conf;
    fastcgi_pass_header Etag;
    Should be added into (nginx) staticfiles.conf?
    55,942
    5:09 PM
    don't need add_header for
    in /internal_data as it's an internal; set so general web public won't be accessing that
    edit your /usr/local/nginx/conf/php.conf includes via cmd shortcut phpinc or if you copied /usr/local/nginx/conf/php.conf to a new file to include in your vhosts i.e. wordpress setups
    55,942
    5:09 PM
    You can find all your php.conf include copies via grep for open_basedir
    grep -rl 'open_basedir' /usr/local/nginx/conf/*
    /usr/local/nginx/conf/php-pool2.conf
    /usr/local/nginx/conf/php-pool3.conf
    /usr/local/nginx/conf/php-pool4.conf
    /usr/local/nginx/conf/php-pool5.conf
    /usr/local/nginx/conf/phpalt.conf
    /usr/local/nginx/conf/phpssl.conf
  4. Sunka
    1,150
    325
    Pula, Croatia
    9:09 AM
    Nginx 1.17.9
    MariaDB 10.3.22
    so this ((nginx) php.conf) part:
    location ~ \.php$ {
        try_files $uri =404;
        fastcgi_split_path_info ^(.+\.php)(/.+)$;
        fastcgi_pass   127.0.0.1:9000;
        #fastcgi_pass   unix:/tmp/php5-fpm.sock;
        fastcgi_index  index.php;
        #fastcgi_param  SCRIPT_FILENAME  $document_root$fastcgi_script_name;
        fastcgi_param  SCRIPT_FILENAME    $request_filename;
        #fastcgi_param PHP_ADMIN_VALUE open_basedir=$document_root/:/usr/local/lib/php/:/tmp/;
    to this:
    location ~ \.php$ {
    Don't needed at all, or not needed add_header part?
    I am lost again :unsure:
    55,942
    5:09 PM
    yup and yup
    55,942
    5:09 PM
    oh you don't need this part for centmin mod as it's all in php.conf already
  7. Sunka
    1,150
    325
    Pula, Croatia
    9:09 AM
    Nginx 1.17.9
    MariaDB 10.3.22
    And if I see right, "}" is extra
    So it will be this (just two last rows):
    location ~ \.php$ {
    And another code for domain.conf I do not need? I need just two new rows in code above?
    55,942
    5:09 PM
    not sure if that is needed since this already exists
  9. Sunka
    1,150
    325
    Pula, Croatia
    9:09 AM
    Nginx 1.17.9
    MariaDB 10.3.22
    Ok, then just one change (last row)
    location ~ \.php$ {
    What about second code change in internal data in domain.conf
    location ^~ /internal_data/ {
            if ($upstream_http_etag != "") {
                add_header Etag $upstream_http_etag;
            internal;
  10. Sunka
    1,150
    325
    Pula, Croatia
    9:09 AM
    Nginx 1.17.9
    MariaDB 10.3.22
    Sorry for wrong thread postings, have many tabs opened at the moment
    55,942
    5:09 PM
    should be good for both
  12. Sunka
    1,150
    325
    Pula, Croatia
    9:09 AM
    Nginx 1.17.9
    MariaDB 10.3.22
    Sorry, I do not understand
    55,942
    5:09 PM
  14. Sunka
    1,150
    325
    Pula, Croatia
    9:09 AM
    Nginx 1.17.9
    MariaDB 10.3.22
    But second part was a question.
    Should I change also domain.conf and somehow add/merge below code, or not?
            internal;
    Btw, this is link to github
    55,942
    5:09 PM
    just saying that syntax looks correct, whether you use it, merge it or alter your existing version is up to you as I no idea what that/your trying to do with that code heh
    55,942
    5:09 PM
    oh if it's XAR - Attachment | XenForo Community then just follow that instructed outline
      internal;
    55,942
    5:09 PM
    ah reading up on XAR Attachment addon seems won't benefit me at all as I use bd Attachment addon already XAR - Attachment | Page 2 | XenForo Community :)
    @Xon quote
  18. Sunka
    1,150
    325
    Pula, Croatia
    9:09 AM
    Nginx 1.17.9
    MariaDB 10.3.22
    I do not know too..
    I asked Yoskaldyr, Xon and you Eva2000, and with help from all of you I can not do that correct way.
    It is not XAR - attahment mode, because Yoskaldyr addon (beside rest) also has this part integrated, and I have to have installed that addon because another two addons from Yoskaldyr. So, his addon (beside rest) do same thing like Xon's addon, but it will be unlogical to have installed two addons with same purpose.
    I just can not understand how to integrate that 2 codes.
    cmf_core/toc.md at master · Yoskaldyr/cmf_core · GitHub
    OK, for first part it is just 1 line into nginx php, but another part is going inot domain.conf, but all I can do from my level of knowledge is to integrate this
            internal;
    into this:
            internal;
            allow 127.0.0.1;
            allow 46.101.130.248;
            deny all;
    and will become this on the end
            internal;
    Deleted stuff is this:
    allow 127.0.0.1;
    deny all;
    55,942
    5:09 PM
    just
            internal;
  20. Sunka
    1,150
    325
    Pula, Croatia
    9:09 AM
    Nginx 1.17.9
    MariaDB 10.3.22
    Conclusion...
    from this suggested part of code I will use only one row:
    In (nginx) php.conf add just that one row (last in code)
    location ~ \.php$ {
    And regarding second suggested code:
            internal;
    I just put it into SSL domain.conf
    Replacing this code:
            internal;
            allow 127.0.0.1;
            allow MY IP;
            deny all;
