WP sites not running on CentOS 6 anymore
Discussion in 'Blogs & CMS usage' started by GASTAN, Dec 19, 2023.
  1. GASTAN
    GASTAN Member
    103
    12
    1:16 AM
    I am getting error on all the (WP)websites on CentOS 6 server :
    Composer detected issues in your platform: Your Composer dependencies require a PHP version ">= 7.2.0".
    I tried to update PHP to all the higher versions including 7.2 but it always fails.
    Any idea what to do?
    51,248
    11,900
    10:16 AM
    CentOS 6.x OS was end of life (EOL) along time ago. Where are you getting that Composer error message?
    Google search gives alot of results here
    might be a specific wordpress plugin related WordPress site is down. Probably need to update php but can’t log on to update ?
    You can check your Wordpress install's WP plugins installed via SSH command line
    cd /home/nginx/domains/yourdomain.com/public
    wp plugin list --allow-root
    and deactivate the problematic WP plugin
    wp plugin deactivate PLUGINNAME --allow-root
    what always fails, PHP 7.2 upgrade? That is because CentOS 6 is EOL and probably wget or curl isn't working anymore and might need manual download to /svr-setup directory before PHP 7.2 upgrade. Might want to share PHP upgrade log if it's failing to update https://community.centminmod.com/threads/how-to-troubleshoot-php-installs-upgrades.17857/
    But probably best to move to a AlmaLinux 8 based server with Centmin Mod 130.00beta01
  3. GASTAN
    GASTAN Member
    103
    12
    1:16 AM
    Thanks. Any other PHP version above 5.60 fails. I want to update server, but would like to revive sites in a meanwhile.
  4. GASTAN
    GASTAN Member
    103
    12
    1:16 AM
    returns these errors:
    PHP Warning: Cannot load module 'redis' because required module 'igbinary' is not loaded in Unknown on line 0
    PHP Fatal error: Composer detected issues in your platform: Your Composer dependencies require a PHP version ">= 7.2.0". You are running 5.6.40. in /home/nginx/domains/domain1/public/wp-content/plugins/backupbuddy/vendor/composer/platform_check.php on line 25
    Error: There has been a critical error on this website.Learn more about troubleshooting WordPress. There has been a critical error on this website.
    but at least gave me a hint about what plugin is crashing.
    I then manually renamed the directory and site worked.
    I am going to check if I can get PHP7 compiled
    thx
  5. GASTAN
    GASTAN Member
    103
    12
    1:16 AM
    I tried to update to 7.3.33 and got these errors:
    ccache: error: execv of /opt/rh/devtoolset-9/root/usr/bin/gcc failed: No such file or directory
    make: *** [argon2] Error 1
    make: *** Waiting for unfinished jobs....
    make: *** [libargon2.so.1] Error 1
    make: *** [src/argon2.o] Error 1
    make: *** [src/blake2/blake2b.o] Error 1
    make: *** [src/core.o] Error 1
    Building without optimizations
    ccache /opt/rh/devtoolset-9/root/usr/bin/gcc -O2 -m32 -mtune=generic -pipe -std=c89 -O3 -Wall -g -Iinclude -Isrc -pthread  src/argon2.c src/core.c src/blake2/blake2b.c src
    /thread.c src/encoding.c src/ref.c src/run.c -o argon2
    so that's no good, I guess some devtoolset 9 is missing , but I didnt know how to install it on centos 6
    and for 7.2.0 I got this
    PHPMUVER = 7.2
    PHP_PGO = n
    make -j4
    /svr-setup/php-7.2.0/ext/curl/interface.c: In function <E2><80><98>_php_curl_setopt<E2><80><99>:
    /svr-setup/php-7.2.0/ext/curl/interface.c:2792: warning: call to <E2><80><98>_curl_easy_setopt_err_progress_cb<E2><80><99> declared with attribute warning: curl_easy_setop
    t expects a curl_progress_callback argument for this option
    /svr-setup/php-7.2.0/ext/dom/dom_iterators.c: In function <E2><80><98>php_dom_libxml_hash_iter<E2><80><99>:
    /svr-setup/php-7.2.0/ext/dom/dom_iterators.c:94: warning: passing argument 2 of <E2><80><98>xmlHashScan<E2><80><99> from incompatible pointer type
    /usr/include/libxml2/libxml/hash.h:212: note: expected <E2><80><98>xmlHashScanner<E2><80><99> but argument is of type <E2><80><98>void (*)(void *, void *, xmlChar *)<E2>
    <80><99>
    /svr-setup/php-7.2.0/ext/dom/dom_iterators.c: In function <E2><80><98>php_dom_libxml_notation_iter<E2><80><99>:
    /svr-setup/php-7.2.0/ext/dom/dom_iterators.c:115: warning: passing argument 2 of <E2><80><98>xmlHashScan<E2><80><99> from incompatible pointer type
    <80><99>
    /svr-setup/php-7.2.0/ext/snmp/snmp.c: In function <E2><80><98>zm_startup_snmp<E2><80><99>:
    /svr-setup/php-7.2.0/ext/snmp/snmp.c:2323: warning: assignment from incompatible pointer type
    /svr-setup/php-7.2.0/sapi/fpm/fpm/fpm_scoreboard.c:252: error: conflicting types for <E2><80><98>fpm_scoreboard_free<E2><80><99>
    /svr-setup/php-7.2.0/sapi/fpm/fpm/fpm_scoreboard.h:84: note: previous declaration of <E2><80><98>fpm_scoreboard_free<E2><80><99> was here
    /svr-setup/php-7.2.0/sapi/fpm/fpm/fpm_scoreboard.c:268: error: conflicting types for <E2><80><98>fpm_scoreboard_child_use<E2><80><99>
    /svr-setup/php-7.2.0/sapi/fpm/fpm/fpm_scoreboard.h:86: note: previous declaration of <E2><80><98>fpm_scoreboard_child_use<E2><80><99> was here
    make: *** [sapi/fpm/fpm/fpm_scoreboard.lo] Error 1
    no idea what's that
    the server is with ramnode and they have Alma8, even Alma9..., but I need to make sites work temporarily, before moving to new server
    51,248
    11,900
    10:16 AM
    So composer is used by BackupBuddy WP plugin which is where PHP 7.2+ requirement and your error is coming from. So if you use WP CLI command above to temporarily disable/deactivate BackupBuddy WP plugin, you should be able to get the site back online for now.
    Strange should be that devtoolset-9 GCC wouldn't even run if it doesn't exist
    What does the output for this command output - wrap in CODE/CODEB tags
    rpm -qa | grep devtoolset-9
    should be something like below for installed RPMs
    devtoolset-9-libstdc++-devel-9.1.1-2.5.el6.x86_64
    devtoolset-9-runtime-9.0-1.el6.x86_64
    devtoolset-9-binutils-2.32-14.el6.x86_64
    devtoolset-9-gcc-9.1.1-2.5.el6.x86_64
    devtoolset-9-gcc-c++-9.1.1-2.5.el6.x86_64
    If they don't exist, you can try downloading the devtoolset-9 GCC RPMs for EL6 manually using below commands as the Repo probably is EOL gone now that CentOS 6 is EOL.
    # disable wget certificate checks on CentOS 6 as system openssl version is EOL and system CA certs are out of date
    echo 'check_certificate = off' > /root/.wgetrc
    # download devtoolset-9 RPMs for GCC 9 for CentOS 6
    mkdir -p /svr-setup/devtoolset9
    cd /svr-setup/devtoolset9
    wget https://cbs.centos.org/kojifiles/packages/devtoolset-9-gcc/9.1.1/2.5.el6/x86_64/devtoolset-9-gcc-9.1.1-2.5.el6.x86_64.rpm
    wget https://cbs.centos.org/kojifiles/packages/devtoolset-9-gcc/9.1.1/2.5.el6/x86_64/devtoolset-9-gcc-c++-9.1.1-2.5.el6.x86_64.rpm
    wget https://cbs.centos.org/kojifiles/packages/devtoolset-9-gcc/9.1.1/2.5.el6/x86_64/devtoolset-9-gcc-gdb-plugin-9.1.1-2.5.el6.x86_64.rpm
    wget https://cbs.centos.org/kojifiles/packages/devtoolset-9-gcc/9.1.1/2.5.el6/x86_64/devtoolset-9-gcc-gfortran-9.1.1-2.5.el6.x86_64.rpm
    wget https://cbs.centos.org/kojifiles/packages/devtoolset-9-gcc/9.1.1/2.5.el6/x86_64/devtoolset-9-gcc-plugin-devel-9.1.1-2.5.el6.x86_64.rpm
    wget https://cbs.centos.org/kojifiles/packages/devtoolset-9-gcc/9.1.1/2.5.el6/x86_64/devtoolset-9-libasan-devel-9.1.1-2.5.el6.x86_64.rpm
    wget https://cbs.centos.org/kojifiles/packages/devtoolset-9-gcc/9.1.1/2.5.el6/x86_64/devtoolset-9-libatomic-devel-9.1.1-2.5.el6.x86_64.rpm
    wget https://cbs.centos.org/kojifiles/packages/devtoolset-9-gcc/9.1.1/2.5.el6/x86_64/devtoolset-9-libgccjit-9.1.1-2.5.el6.x86_64.rpm
    wget https://cbs.centos.org/kojifiles/packages/devtoolset-9-gcc/9.1.1/2.5.el6/x86_64/devtoolset-9-libgccjit-devel-9.1.1-2.5.el6.x86_64.rpm
    wget https://cbs.centos.org/kojifiles/packages/devtoolset-9-gcc/9.1.1/2.5.el6/x86_64/devtoolset-9-libgccjit-docs-9.1.1-2.5.el6.x86_64.rpm
    wget https://cbs.centos.org/kojifiles/packages/devtoolset-9-gcc/9.1.1/2.5.el6/x86_64/devtoolset-9-libitm-devel-9.1.1-2.5.el6.x86_64.rpm
    wget https://cbs.centos.org/kojifiles/packages/devtoolset-9-gcc/9.1.1/2.5.el6/x86_64/devtoolset-9-liblsan-devel-9.1.1-2.5.el6.x86_64.rpm
    wget https://cbs.centos.org/kojifiles/packages/devtoolset-9-gcc/9.1.1/2.5.el6/x86_64/devtoolset-9-libquadmath-devel-9.1.1-2.5.el6.x86_64.rpm
    wget https://cbs.centos.org/kojifiles/packages/devtoolset-9-gcc/9.1.1/2.5.el6/x86_64/devtoolset-9-libstdc++-devel-9.1.1-2.5.el6.x86_64.rpm
    wget https://cbs.centos.org/kojifiles/packages/devtoolset-9-gcc/9.1.1/2.5.el6/x86_64/devtoolset-9-libstdc++-docs-9.1.1-2.5.el6.x86_64.rpm
    wget https://cbs.centos.org/kojifiles/packages/devtoolset-9-gcc/9.1.1/2.5.el6/x86_64/devtoolset-9-libtsan-devel-9.1.1-2.5.el6.x86_64.rpm
    wget https://cbs.centos.org/kojifiles/packages/devtoolset-9-gcc/9.1.1/2.5.el6/x86_64/devtoolset-9-libubsan-devel-9.1.1-2.5.el6.x86_64.rpm
    wget https://cbs.centos.org/kojifiles/packages/devtoolset-9-gcc/9.1.1/2.5.el6/x86_64/libasan5-9.1.1-2.5.el6.x86_64.rpm
    wget https://cbs.centos.org/kojifiles/packages/devtoolset-9-gcc/9.1.1/2.5.el6/x86_64/liblsan-9.1.1-2.5.el6.x86_64.rpm
    wget https://cbs.centos.org/kojifiles/packages/devtoolset-9-gcc/9.1.1/2.5.el6/x86_64/libubsan1-9.1.1-2.5.el6.x86_64.rpm
    wget https://cbs.centos.org/kojifiles/packages/devtoolset-9-gcc/9.1.1/2.5.el6/x86_64/devtoolset-9-gcc-debuginfo-9.1.1-2.5.el6.x86_64.rpm
    wget https://cbs.centos.org/kojifiles/packages/devtoolset-9/9.0/1.el6/x86_64/devtoolset-9-9.0-1.el6.x86_64.rpm
    wget https://cbs.centos.org/kojifiles/packages/devtoolset-9/9.0/1.el6/x86_64/devtoolset-9-build-9.0-1.el6.x86_64.rpm
    wget https://cbs.centos.org/kojifiles/packages/devtoolset-9/9.0/1.el6/x86_64/devtoolset-9-perftools-9.0-1.el6.x86_64.rpm
    wget https://cbs.centos.org/kojifiles/packages/devtoolset-9/9.0/1.el6/x86_64/devtoolset-9-runtime-9.0-1.el6.x86_64.rpm
    wget https://cbs.centos.org/kojifiles/packages/devtoolset-9/9.0/1.el6/x86_64/devtoolset-9-toolchain-9.0-1.el6.x86_64.rpm
    wget https://cbs.centos.org/kojifiles/packages/devtoolset-9/9.0/1.el6/src/devtoolset-9-9.0-1.el6.src.rpm
    wget https://cbs.centos.org/kojifiles/packages/devtoolset-9-binutils/2.32/14.el6/x86_64/devtoolset-9-binutils-2.32-14.el6.x86_64.rpm
    wget https://cbs.centos.org/kojifiles/packages/devtoolset-9-binutils/2.32/14.el6/x86_64/devtoolset-9-binutils-devel-2.32-14.el6.x86_64.rpm
    wget https://cbs.centos.org/kojifiles/packages/devtoolset-9-binutils/2.32/14.el6/x86_64/devtoolset-9-binutils-debuginfo-2.32-14.el6.x86_64.rpm
    # install devtoolset-9 GCC 9 on CentOS 6
    yum -y localinstall devtoolset-9-gcc devtoolset-9-gcc-c++ devtoolset-9-binutils devtoolset-9-runtime
  7. GASTAN
    GASTAN Member
    103
    12
    1:16 AM
    I got
    Loaded plugins: fastestmirror, priorities, security, versionlock
    Setting up Local Package Process
    Skipping: devtoolset-9-gcc, filename does not end in .rpm.
    Skipping: devtoolset-9-gcc-c++, filename does not end in .rpm.
    Skipping: devtoolset-9-binutils, filename does not end in .rpm.
    Skipping: devtoolset-9-runtime, filename does not end in .rpm.
    Nothing to do
    and upon trying install rpm directly it said
     yum -y localinstall devtoolset-9-gcc-9.1.1-2.5.el6.x86_64.rpm
    Examining devtoolset-9-gcc-9.1.1-2.5.el6.x86_64.rpm: devtoolset-9-gcc-9.1.1-2.5.el6.x86_64
    Cannot add package devtoolset-9-gcc-9.1.1-2.5.el6.x86_64.rpm to transaction. Not a compatible architecture: x86_64
    Nothing to do
    I have 3.10.0-957.12.2.vz7.96.21 #1 SMP Thu Jun 27 15:10:55 MSK 2019 i686 i686 i386 GNU/Linux
    so I guess it's 32bit
    is it possible to get it in 32it? that kojifiles only seem to have 64bit archives?
    51,248
    11,900
    10:16 AM
    I don't think I've seen a 32bit devtoolset RPM package on CentOS 6. What output do you get from
    I think in your case, probably best to disable BackupBuddy WP plugin to get around composer PHP 7.2+ requirement and then migrate sites and data to new AlmaLinux 8 based Centmin Mod server.
  9. GASTAN
    GASTAN Member
    103
    12
    1:16 AM
    I get this
    # rpm -qa | grep devtoolset
    devtoolset-3-runtime-3.0-15.el6.noarch
    devtoolset-3-libstdc++-devel-4.9.1-10.el6.i686
    devtoolset-3-gcc-c++-4.9.1-10.el6.i686
    devtoolset-3-gcc-4.9.1-10.el6.i686
    devtoolset-3-binutils-2.24-18.el6.i686
    that's 32 bit, innit?
    I am getting new machine soon, so will try to migrate to it, but was hoping I can keep it afloat in a meanwhile :(
  10. GASTAN
    GASTAN Member
    103
    12
    1:16 AM
    I found this repo:
    Index of /cloudlinux/6/sclo/devtoolset-9/i386/
    and tried to install from there
    but still some stuff is missing :(
    Error: Package: devtoolset-9-toolchain-9.0-1.el6.i686 (cloudlinux)
               Requires: devtoolset-9-gdb
    Error: Package: devtoolset-9-gcc-gfortran-9.1.1-2.5.el6.i686 (cloudlinux)
               Requires: libgfortran5 >= 8.1.1
    Error: Package: devtoolset-9-perftools-9.0-1.el6.i686 (cloudlinux)
               Requires: devtoolset-9-systemtap
  11. GASTAN
    GASTAN Member
    103
    12
    1:16 AM
    oh, I did
     yum --disablerepo=\* --enablerepo=cloudlinux install devtoolset-9
    and it installer devtoolset-9
    but it's all red now:
    devtoolset-9-runtime-9.0-1.el6.i686
    devtoolset-9-gcc-9.1.1-2.5.el6.i686
    devtoolset-9-binutils-2.32-14.el6.i686
    gonna try to compile PHP, but feel like something is off
