WP Rocket installation on Nginx
Discussion in 'Blogs & CMS usage' started by Mrbo, Feb 25, 2019.
  1. BamaStangGuy
    BamaStangGuy Active Member
    669
    192
    1:05 AM
    Unfortunately, I wasn't able to get this to work either. It kept saying mobile caching was active, even though it was disabled. I edited the default.conf to remove checks, then it would say it was cached but I could load a heavy page that uses MySQL and each request would hit php-fpm and MySQL despite it saying it was being served via Nginx.
  2. zkylizer
    zkylizer New Member
    16
    1:05 PM
    1.17.0
    MariaDB 10
    Same here, i try using at location / {
    Or
    try_files "/wp-content/cache/wp-rocket/$host${uri}$is_args$args/index-https.html_gzip" $uri $uri/ /index.php$is_args$args;
    Result still :
    X-Rocket-Nginx-Serving-Static: No
  3. EckyBrazzz
    190
    3:05 AM
    In my WP-Multidomain setup this is still working fine.
    In the beginning I noticed that if you selected a single time in wp-rocket cache mobile it stopped working correctly. After changing the settings still no go.
    Deleting or creating the directory with the cache file as indicated in the debug mode resolved the issue.
    So delete and/or (re)create the directory with the cache file.
    X-Rocket-Nginx-File: /home/nginx/domains/domain.com/public/wp-content/cache/wp-rocket/domain.com///index-https.html_gzip
  4. zkylizer
    zkylizer New Member
    16
    1:05 PM
    1.17.0
    MariaDB 10
    fixed by disable mobile cache in wprocket setting
  5. radbrad
    radbrad Member
    34
    11:35 AM
    Hi got these errors even after trying the steps @Mrbo said:
    nginx: [emerg] "set" directive is not allowed here in /etc/nginx/rocket-nginx/rocket-nginx.conf:17
    nginx: configuration file /etc/nginx/nginx.conf test failed
  6. EckyBrazzz
    190
    3:05 AM
    @radbrad . You are using the wrong directory. Should use include /usr/local/nginx/conf/wpincludes/mydomain.org/rocket-nginx/default.conf; and place the include just before the location/
      include /usr/local/nginx/conf/wpincludes/mydomain.org/wpcacheenabler_mydomain.org.conf;
      #include /usr/local/nginx/conf/wpincludes/mydomain.org/wpsupercache_mydomain.org.conf;
      #include /usr/local/nginx/conf/wpincludes/mydomain.org/rediscache_mydomain.org.conf;
      #WP ROCKET
  7. tininho
    tininho Active Member
    182
    44
    eu
    8:05 AM
    If you choose Wordpress Super Cache on Wordpress caching while running option 22, do the following to change to WP Rocket:
    Replace/add/comment out on your /usr/local/nginx/conf/conf.d/domain.com.ssl.conf:
    comment out
    include /usr/local/nginx/conf/wpincludes/domain.com/wpsupercache_domain.com.conf;
    add
    include /usr/local/nginx/rocket-nginx/conf.d/default.conf;
    replace try_files
    Run on terminal
    sed -i 's/php-wpsc/php/g' /usr/local/nginx/conf/conf.d/domain.com.ssl.conf
    cd /usr/local/nginx
    git clone https://github.com/SatelliteWP/rocket-nginx.git
    cd rocket-nginx; cp rocket-nginx.ini.disabled rocket-nginx.ini
    php rocket-nginx.ini; php rocket-parser.php
    ngxrestart
    Done. This is compiled from other users on this thread
    60,092
    12,584
    4:05 PM
    Nice thanks for sharing! (y)
