Wordpress wordpress speed, with centmin beta
Discussion in 'Blogs & CMS usage' started by ahmed, Mar 11, 2017.
  1. ahmed
    ahmed Member
    243
    19
    3:51 AM
    Hello Wordpress friends
    what is your setting after installing the beta?
    Mine:
    1-enable PHP 7
    2-enable Let's encrypt
    3-enable redis
    4-plugin :nginx helper with redis cach option
    5-redis object cache
    6-Key CDN
    what do u do in AMP?
    what do u choose during centmin setup to prevent mobile caching and why?
    Best
  2. RB1
    RB1 Active Member
    285
    75
    California
    6:51 PM
    Nginx 1.18.x
    MariaDB 10.1.x
    For my Wordpress installations I use:
    Lets Encrypt
    Cloudflare for DNS/CDN
    PHP 7
    PageSpeed
  3. ahmed
    ahmed Member
    243
    19
    3:51 AM
  4. ahmed
    ahmed Member
    243
    19
    3:51 AM
    I remeber that pagespeed is not quite stable and it doesn't play well with CDN
  5. RB1
    RB1 Active Member
    285
    75
    California
    6:51 PM
    Nginx 1.18.x
    MariaDB 10.1.x
    True...I'm still trying to figure out some issues with the rewritten images not serving via the Cloudflare CDN.
    41,076
    9,177
    11:51 AM
    I use centmin.sh menu option 22 wordpress installer in centmin mod 123.09beta01 for my Wordpress7 site currently use Redis cache at nginx level - see site's blog posts for benchmark stats on 2GB DigitalOcean KVM VPS
    i choose to prevent mobile caching due to responsive themes looking different on mobile versus desktop
  7. ndha
    ndha Member
    77
    9
    8:51 AM
    @eva2000 any additional nginx config to prevent mobile caching with CMM??
    41,076
    9,177
    11:51 AM
    centmin.sh menu option 22 auto installed wordpress takes care of it when you answer yes to the prompt asking if you want to exclude mobile from caching
  9. ndha
    ndha Member
    77
    9
    8:51 AM
    @eva2000 IIRC i don't see that prompt at first time i use option 22 with CMM 123.08 a year ago :(
    what config do we use for already setup sites??
    41,076
    9,177
    11:51 AM
    Prompt only in 123.09beta01
  11. ndha
    ndha Member
    77
    9
    8:51 AM
    So, disable mobile cache can't be used with already setup site with 123.08, right??
    can i copy nginx config for it from 123.09??
    Fyi, i already upgrade to 123.09beta but my sites create from 123.08 before..
    41,076
    9,177
    11:51 AM
    you can manually add the exclusions if you know how
    which usually involve editing your keycdn cache enabler, wordpress super cache or redis cache include files
    i.e. where ${vhostname} is replaced with your domain.com
    for keycdn cache enabler edit and add to /usr/local/nginx/conf/wpincludes/${vhostname}/wpcacheenabler_${vhostname}.conf the following
        # exclude mobile devices from redis caching
        if ($cmwpcache_device = mobile) { set $cache_uri 'nullcache'; }
    for redis nginx level cache, edit and add to /usr/local/nginx/conf/wpincludes/${vhostname}/rediscache_${vhostname}.conf the following
    if ($redis_device = mobile) { set $skip_cache 1; }
    For redis nginx cache, then create a new file at /usr/local/nginx/conf/redisupstream.conf and add the code to it
    map $http_user_agent $redis_device {
        default                                     'desktop';
        ~*(iPad|iPhone|Android|IEMobile|Blackberry) 'mobile';
        "~*Firefox.*Mobile"                         'mobile';
        "~*ipod.*mobile"                            'mobile';
        "~*Opera\ Mini"                             'mobile';
        "~*Opera\ Mobile"                           'mobile';
        "~*Mobile"                                  'mobile';
        "~*Tablet"                                  'mobile';
        "~*Kindle"                                  'mobile';
        "~*Windows\ Phone"                          'mobile';
    upstream redisbackend {
      zone upstream_redis 64k;
      server 127.0.0.1:6379 weight=1 max_fails=3 fail_timeout=30s;
      #server 127.0.0.1:6380 weight=1 max_fails=3 fail_timeout=30s;
      #server 127.0.0.1:6381 weight=1 max_fails=3 fail_timeout=30s;
      #server 127.0.0.1:6382 weight=1 max_fails=3 fail_timeout=30s;
      #server 127.0.0.1:6383 weight=1 max_fails=3 fail_timeout=30s;
      #server 127.0.0.1:6384 weight=1 max_fails=3 fail_timeout=30s;
      #server 127.0.0.1:6380 backup;
      keepalive 4096;
    then edit /usr/local/nginx/conf/nginx.conf and add an include file for /usr/local/nginx/conf/redisupstream.conf after the existing /usr/local/nginx/conf/fastcgi_param_https_map.conf include file
    include /usr/local/nginx/conf/fastcgi_param_https_map.conf;
    include /usr/local/nginx/conf/redisupstream.conf;
    for keycdn cache enabler, create file at /usr/local/nginx/conf/wpcacheenabler_map.conf and add code to it
    map $http_user_agent $cmwpcache_device {
        default                                     'desktop';
    then edit /usr/local/nginx/conf/nginx.conf and add an include file for /usr/local/nginx/conf/wpcacheenabler_map.conf after the existing /usr/local/nginx/conf/fastcgi_param_https_map.conf include file
    include /usr/local/nginx/conf/wpcacheenabler_map.conf;
    then restart nginx and php-fpm
    nprestart
    If older wordpress auto installs had different path to include file you need to edit, post your nginx vhost contents here.
    • Like Like x 2
  13. RootPass
    RootPass New Member
    25
    4:51 AM
    CentMin
    CentMin
    hey guys
    just used the stable centminmod auto installer and WP Super cache giving me problems (need to click a lot of
    times to change the settings)
    any recommendation on the best cache options? many thanks ! :)
    41,076
    9,177
    11:51 AM
    yeah that's why Centmin Mod 123.09beta01 switched centmin.sh to allow KeyCDN Cache Enabler or Redis nginx level caching selections on top of WP Super Cache
    also why I highly recommend using Centmin Mod 123.09beta01 :)
    You can try manually switching to keycdn cacher enabler Wordpress - WP Cacher Enabler Plugin by KeyCDN folks.
    Latest details on what KeyCDN Cache Enabler is Free WordPress Cache Enabler Plugin
  15. JarylW
    JarylW Active Member
    216
    40
    Singapore
    9:51 AM
    Never understood why people want to disable mobile caching. Care to share your reason?
  16. elargento
    elargento Member
    340
    10:51 PM
    @eva2000 said
  17. JarylW
    216
    40
    Singapore
    9:51 AM
    Hmm, which responsive theme does that? Most latest or updated ones should have similar look whether cache is on or off?
  18. ahmed
    ahmed Member
    243
    19
    3:51 AM
    Actually I was asking too, I'm not expert
    41,076
    9,177
    11:51 AM
    Choice is let up to end users to decide for themselves as to whether to disable mobile caching :)
  20. ahmed
    ahmed Member
    243
    19
    3:51 AM
    ok, then how to edit this option after installing the wordpress/domain?
