Wordpress WordPress not using memcache and memcached warnings
Discussion in 'Blogs & CMS usage' started by EckyBrazzz, Aug 19, 2019.
    183
    10:13 AM
    Hi there,
    For testing, I install a plugin to see how my WordPress sites are preforming. The plugin is Query Monitor by John Blackbourn and it gives some nice information.
    It also told me that WordPress is not using memcache and memcached
    Object Cache
    98.9% hit rate (24,553 hits, 282 misses)
    External object cache not in use
    [LIST]
    [*]The Memcache extension for PHP is installed but is not in use by WordPress
    [*]The Memcached extension for PHP is installed but is not in use by WordPress
    [*]The Redis extension for PHP is installed but is not in use by WordPress
    [/LIST]
    Opcode cache in use: Zend OPcache
    But after installing this plugin MemcacheD Is Your Friend, an ancient one, it seems to be resolved. There is also a forked one here with some commits here on wpbullet/memcached-is-your-friend
    [SIZE=4]Object Cache[/SIZE]
    100.0% hit rate (23,189 hits, 4 misses)
    External object cache in use
    Now the question: Can we use it or not. Seems to be interesting.
    Now I can see the results of my Memcached
    45,384
    10,298
    11:13 PM
    Object caching is separate from full page caching and yes you can use redis or memcached object cache addons, but in past some folks report that with object caching enable, sometimes making wp-admin setting changes don't register until they clear the object cache. Reason why centmin.sh menu option 22 no longer installs a wordpress object cache plugin by default. So really depends on your needs and if you find it acceptable and are aware to always clear your caches after making wp-admin settings changes everytime when using object cache plugins.
    FYI, redis object cache Redis Object Cache is usually what I'd use instead of memcached if you have already installed redis server Redis - Insight Guide - How to install Redis server on Centmin Mod LEMP stack
  3. EckyBrazzz
    183
    10:13 AM
    Currently, I use on most of my sites Fastcgi_cache (PHP-FPM) on with the nginx cache and with the wp-rocket, but it sometime gives strange effects backend. Admin panel completely mixed up until I get it done to clear the cache.
    Will do some testing on my test domain and with duplicator to see what gives the best result
    As I see now, the Redis Object Cache is more actual than what I mentioned the wpbullet/memcached-is-your-friend
    I stopped using Redis after my issues with a theme, but that was resolved with a little edit in the wp_updater script.
    #/usr/bin/wp cli update --allow-root --skip-themes
    echo "update wp-cli"
    rm -rf /usr/bin/wp
    wget -4cnv --no-check-certificate https://raw.github.com/wp-cli/builds/gh-pages/phar/wp-cli.phar -O /usr/bin/wp --tries=3
    chmod 0700 /usr/bin/wp
    /usr/bin/wp --info --allow-root --skip-themes
    /usr/bin/wp plugin status --allow-root --skip-themes
    /usr/bin/wp plugin update --all --allow-root --skip-themes | tee .wpcli-status
    /usr/bin/wp core check-update --allow-root --skip-themes
    # for major core updates uncomment 3 lines directly below
    /usr/bin/wp core update --allow-root --skip-themes
    /usr/bin/wp core update-db --allow-root --skip-themes
    # for minor core updates uncomment 3 lines directly below
    /usr/bin/wp core update --minor --allow-root --skip-themes
