Wordpress Wordpress login issue
Discussion in 'Blogs & CMS usage' started by inthecloudblog, Jul 2, 2016.
    60,082
    12,584
    10:09 AM
    wp failed login or csf firewall blocked ?
    handy to have :)
    60,082
    12,584
    10:09 AM
    @inthecloudblog if you still have initial wp login issues after using centmin.sh menu option 22, can you provide examples of the username/passwords that are auto generated ? could be a character in them that wp doesn't like ?
  3. inthecloudblog
    inthecloudblog Active Member
    199
    36
    9:09 PM
    1.4.6
    I'll go ahead an spin a VM with some provider like DO and try to replicate it ( ASAP).
    Really appreciate it !
    60,082
    12,584
    10:09 AM
    also how you copying and pasting the generated user/pass data from ssh client output to your wordpress blog ? i recall vaguely someone had ssh client weirdness in the way they copy and pasted from their ssh client. I usually highlight the text with my mouse and hit right click and copy and then paste
  5. JarylW
    JarylW Active Member
    216
    41
    Singapore
    8:09 AM
    Or can test with self generated one..
    60,082
    12,584
    10:09 AM
    yes that too :)
  7. jauhari
    jauhari New Member
    7:09 AM
    MariaDB 10
    How to disable
    401 Authorization Required
    I can't loggin whatever I tried. Any clues how to fix it?
  8. inthecloudblog
    199
    36
    9:09 PM
    1.4.6
    Follow what I've been told to do before.
    Apparently I'm not alone :p
    EDIT: too drowsy to look dig for what was the fix but it was fairly easy and @eva2000 helped me install after install.
    60,082
    12,584
    10:09 AM
