Wordpress Gravatars and Nginx, Help..
Discussion in 'Blogs & CMS usage' started by Jesus Higuerey, Aug 31, 2018.
  1. Jesus Higuerey
    Jesus Higuerey New Member
    25
    11:40 AM
    So I found this guide which pretty much says how to pull gravatars from your server instead of their servers. (LINK)
    I added the following code to my vhost but is giving me an error..
    Line 24: location  / {
    sub_filter 'https://secure.gravatar.com/avatar/' 'https://domain.com/avatar/';
    sub_filter_once off;
    location /avatar {
    proxy_pass https://secure.gravatar.com$request_uri;
    The error is:
    nginx: [emerg] duplicate location "/" in /etc/nginx/sites-enabled/domain.com:24
    nginx: configuration file /etc/nginx/nginx.conf test failed
    Line 24 is the beginning of the previous code "location / { "
    Any clues on what might be happening?
    45,157
    10,272
    4:40 AM
    curl -I https://domain.com
    curl -I http://domain.com
    curl -I http://www.domain.com
    wrap output in CODE tags
  3. Jesus Higuerey
    25
    11:40 AM
    Hey, thanks for answering. As of right now just did a fresh install of centos, in a couple mins Ill be able to install centmin, once I create a vhost Ill post what you asked...
    Thank you!
  4. Jesus Higuerey
    25
    11:40 AM
    Hello,
    Here is the result of curl -I domain..
    HTTP/1.1 200 OK
    Date: Thu, 30 Aug 2018 18:23:27 GMT
    Connection: keep-alive
    Vary: Accept-Encoding
    Link: <http://host.domain.com/wp-json/>; rel="https://api.w.org/"
    Server: nginx centminmod
    X-Powered-By: centminmod
    The content of the vhost of the site
    #server {
    #            listen   80;
    #            server_name domain.com;
      # ssi  on;
      access_log /home/nginx/domains/domain.com/log/access.log combined buffer=256k flush=5m;
      include /usr/local/nginx/conf/autoprotect/domain.com/autoprotect-domain.com.conf;
      # server and/or vhost site
      include /usr/local/nginx/conf/wpincludes/domain.com/wpcacheenabler_domain.com.conf;
      #include /usr/local/nginx/conf/wpincludes/domain.com/wpsupercache_domain.com.conf;
      #include /usr/local/nginx/conf/wpincludes/domain.com/rediscache_domain.com.conf;
      #autoindex  on;
      # for wp cache enabler plugin
      try_files $cache_enabler_uri $uri $uri/ $custom_subdir/index.php?$args;
      # Wordpress Permalinks
      # Nginx level redis Wordpress
        #limit_conn xwpconlimit 30;
        auth_basic "Private";
        auth_basic_user_file /home/nginx/domains/domain.com/htpasswd_wplogin;
    location ~* /(xmlrpc\.php) {
      include /usr/local/nginx/conf/wpincludes/domain.com/wpsecure_domain.com.conf;
    Since this is a fresh instalation, I have not added the code I want to add, since whatever I try it gives me an error so..
    45,157
    10,272
    4:40 AM
    i suspect you added 2nd location / context to your vhost.
    Your existing location web root / context is already in your vhost at
      #autoindex  on;
    So the additional web root location / context you need to add goes in there so changes to
      #autoindex  on;
  6. Jesus Higuerey
    25
    11:40 AM
    Hello,
    Sorry I am kinda new to all of this. So the first code will go to the second part you mentioned? If yes, the second code "location /avatar " will go outside of it since is targeting the "Avatar" folder?
    Again, sorry for being such a newbie in this
    45,157
    10,272
    4:40 AM
  8. Jesus Higuerey
    25
    11:40 AM
    I did that, restarted nginx, everything ok.. Thing is, it doesn't seem to work, I am still getting gravatars served from their servers.
    The settings look like this
      #autoindex  on;
     location /avatar {
    45,157
    10,272
    4:40 AM
    try moving sub_filter directives out of location web root / context and above it
    so becomes
      #autoindex  on;
    45,157
    10,272
    4:40 AM
    or also clearing cache enabler cache
  11. Jesus Higuerey
    25
    11:40 AM
    Moved the two lines like you said, nginx reload was fine, cleared cache, still nothing..
    45,157
    10,272
    4:40 AM
    try moving the 2 lines back to previously placement + clear cache and restart nginx
  13. Jesus Higuerey
    25
    11:40 AM
    Still no luck :S
    45,157
    10,272
    4:40 AM
    It's quite possible Cache Enabler via Centmin Mod centmin.sh menu option 22 is interfering as it enables advanced caching at Nginx level which may cache the file before nginx sub filter can apply to it
    You can verify this by disabling cache enabler temporarily by changing try_files directive from cache enabler version to standard wp one by changing
    to comment out/disable cache enabler version and uncomment (remove hash #) from standard wp try_files
      #try_files $cache_enabler_uri $uri $uri/ $custom_subdir/index.php?$args;
     try_files $uri $uri/ /index.php?q=$uri&$args;
    restart nginx
    see if sub_filter works then to confirm if cache enabler advanced caching is preventing it from working
  15. Jesus Higuerey
    25
    11:40 AM
    Did that, but with not luck, still the same..
    Also found this "guide" which is basically the same thing, (LINK) and his gravatars are being loaded from his cdn..
    You lost me on this:
    45,157
    10,272
    4:40 AM
    if you tried the switch to below with cache enabler disabled and still doesn't work then it isn't cache enabler that is the problem
    so switch it back to previous
    post the contents of your current nginx vhost /usr/local/nginx/conf/conf.d/yourdomain.com.conf using SSH command cat to output it's contents
    cat /usr/local/nginx/conf/conf.d/yourdomain.com.conf
  17. Jesus Higuerey
    25
    11:40 AM
    Here you go :)
    [21:29][root@DevSrv conf.d]# cat /usr/local/nginx/conf/conf.d/domain.com.conf
    #server {
    #            listen   80;
      # ssi  on;
      #autoindex  on;
     location /avatar {
    45,157
    10,272
    4:40 AM
    believe i figured out your issue, you need to move the sub_filters higher up into the vhost just below root path directive and move proxy above location web root / context and also add sub_filter_last_modified on directive for better caching. That will get sub_filter working
    #server {
    #            listen   80;
      # ssi  on;
      sub_filter_last_modified on;
      location /avatar {
      #autoindex  on;
  19. Jesus Higuerey
    25
    11:40 AM
    Hey, thanks for the effort, but yet again doesn't seem to work. Made sure to delete all cache, but still..
    45,157
    10,272
    4:40 AM
    Should work as i tested it myself on my test cache enabler wordpress blog on Centmin Mod server. Only diff is if you do not have HTTPS SSL certificate then replacement url for domain.com/avatar/ should be using non-HTTPS http:// and not https://
