Xenforo wordpress and xenforo on the same vhost
Discussion in 'Forum software usage' started by upgrade81, Jun 8, 2018.
  1. upgrade81
    upgrade81 Member
    290
    CH
    11:40 PM
    1.17
    10.3
    Hello everyone, I installed Wordpress on domain.com and XenForo in the subdirectory /forum/
    is there any particular procedure to be respected?
    Wordpress was installed with option 22 and Cache Enabler.
    Can I generate the usual vhost relative to Xenforo 2.0 with the classic tool?
    Generate Centmin Mod Nginx Vhost - CentminMod.com LEMP Nginx web stack for CentOS
    Thank you very much.
    50,922
    11,805
    8:40 AM
  3. upgrade81
    upgrade81 Member
    290
    CH
    11:40 PM
    1.17
    10.3
    Seen and read I have already added the parts of the Vhost related to the forum directory with the new part for Xenforo2.
    But that discussion does not answer my question if they can coexist without problems using option 22 (cache enabler) and then modifying the vhost with the Xenphoro data.
    50,922
    11,805
    8:40 AM
    Yes they can if you start with centmin.sh menu option 22 wordpress install first then edit for xenforo.
  5. upgrade81
    upgrade81 Member
    290
    CH
    11:40 PM
    1.17
    10.3
    OK! I got it.
    then I leave unchanged:
    includes /usr/local/nginx/conf/pre-staticfiles-local-domain.it.conf;
    includes /usr/local/nginx/conf/pre-staticfiles-global.conf;
    includes /usr/local/nginx/conf/staticfiles.conf;
    50,922
    11,805
    8:40 AM
    yes but in each xenforo location context, need to add php.conf include for processing php as wordpress config uses it's own include for php within it's own location contexts
  7. upgrade81
    upgrade81 Member
    290
    CH
    11:40 PM
    1.17
    10.3
    do you mean that?
        #limit_conn xwpconlimit 30;
    location /forum/ {
         try_files $uri $uri/ /forum/index.php?$uri&$args;
    #location /forum/admin.php {
    #     auth_basic "Private";
    #     auth_basic_user_file /usr/local/nginx/conf/htpasswd_admin_php;
    #        include /usr/local/nginx/conf/php.conf;
    #        allow 127.0.0.1;
            #allow YOURIPADDRESS;
    #        deny all;
    location /forum/install/data/ {
         internal;
    location /forum/install/templates/ {
         internal;
    location /forum/internal_data/ {
         internal;
    location /forum/library/ {
         internal;
    # xenforo 2 uncomment / remove hash from next 3 lines
    location /forum/src/ {
         internal;
    include /usr/local/nginx/conf/wpincludes/mbenz.it/wpsecure_domain.it.conf;
      include /usr/local/nginx/conf/pre-staticfiles-local-domain.it.conf;
    50,922
    11,805
    8:40 AM
    yes for /forum as well as other xenforo `internal` locations too (whichever locations where php is processed/php files exist in xenforo locations use include file /usr/local/nginx/conf/php.conf). This allows you to separate it from Wordpress's caching.
