Woocommerce using Varnish, Hitch SSL, Cloudflare, Letsencrypt, NGINX with sockets
Discussion in 'Ecommerce / Shopping cart usage' started by Atrix, Jul 2, 2020.
  1. ahmed
    ahmed Active Member
    404
    49
    9:33 AM
    Looks like that was the magic code, thanks a lot :)
  2. ahmed
    ahmed Active Member
    404
    49
    9:33 AM
    Im so sorry fro many questions But I hope my questions will be of benefit to those who want to try this out
    on Eva steps;
    I got this error
    [12:03][root@centos-7-1 etc]# bash ~/cert-letsencrypt.sh
    [Wed Jul  8 12:04:27 UTC 2020] Unknown parameter : --renew-hook=/usr/bin/hitch-deploy-hook
    would appreciate ur help
  3. ahmed
    ahmed Active Member
    404
    49
    9:33 AM
    looks like this hook deparacted
    here is a google search
    Clarify and expand renewal-hook documentation · Issue #5935 · certbot/certbot
  4. ahmed
    ahmed Active Member
    404
    49
    9:33 AM
    certbot -q renew --renew-hook "service nginx reload"
  5. ahmed
    ahmed Active Member
    404
    49
    9:33 AM
    deploy-hook also is unknown parameter
    59,950
    12,556
    5:33 PM
  7. ahmed
    ahmed Active Member
    404
    49
    9:33 AM
    Im using your steps
    /root/.acme.sh/acme.sh --issue --dns dns_cf -d 1111.com -d '*.11111.com' -k 2048 --useragent centminmod-centos7-acmesh-dns --renew-hook="/usr/bin/hitch-deploy-hook" --post-hook="service reload hitch"
    this is the sh
  8. ahmed
    ahmed Active Member
    404
    49
    9:33 AM
  9. ahmed
    ahmed Active Member
    404
    49
    9:33 AM
    looks like he omitted the hook altogether
  10. ahmed
    ahmed Active Member
    404
    49
    9:33 AM
    I will go back to Artix method it was having an installation error (cloudflare version was not updated), but now installation is fine
    so much work 0:)
  11. ahmed
    ahmed Active Member
    404
    49
    9:33 AM
    good news almost done
    but the Cloudflare needs to be updated so as not to use the master account credential which is not safe
    I tried to update it but it was messy and asked for an updated OpenSSL so I give up
    also u need to add that is ok to have errors after bash command as the important is tp get
    Congratulations! Your certificate and chain have been saved at:
    /etc/letsencrypt/live/example.com/fullchain.pem
    Your key file has been saved at:
    /etc/letsencrypt/live/example.com/privkey.pem
  12. ahmed
    ahmed Active Member
    404
    49
    9:33 AM
    moving forward
    I guess it is better to use
    ## NGINX CONFIGS ##
    Nginx configuration for our hitch ssl, varnish setup
    Add this to line 59 of /usr/local/nginx/conf/nginx.conf
    real_ip_header X-Forwarded-For;
    set_real_ip_from unix:;
    real_ip_recursive on;
  13. ahmed
    ahmed Active Member
    404
    49
    9:33 AM
    also u need to correct this
    "missing the conf dir"
    rename /usr/local/nginx/conf/conf.d/site.com.ssl.conf to /usr/local/nginx/conf/conf.d/site.com.ssl.conf-disabled
    This is because nginx will only be serving http requests because that is all varnish understands. Hitch does ALL the SSL work.
  14. ahmed
    ahmed Active Member
    404
    49
    9:33 AM
    Hooray it is up and running now, thanks a lot to Atrix and Eva :):p:D:D:D:whistle::whistle::whistle::whistle::whistle:
  15. ahmed
    ahmed Active Member
    404
    49
    9:33 AM
    also u need to delet the crontab part for the chasing plugin u chosen during the centmin 22 option install
  16. ahmed
    ahmed Active Member
    404
    49
    9:33 AM
    also nano /etc/varnish/default.vcl and change logged in user cookie according to the plugin in wordpress
  17. ahmed
    ahmed Active Member
    404
    49
    9:33 AM
    do wee need this step?
  18. ahmed
    ahmed Active Member
    404
    49
    9:33 AM
    I have a question if I need to install another domain using varnish, what shall I will
    use another files:
    nano ~/cert-letsencrypt-domain2.sh
    nano /etc/hitch/hitch-domain2.conf
    or there is another thing I'm missing?
  19. ahmed
    ahmed Active Member
    404
    49
    9:33 AM
    also u are missing this code
    systemctl enable --now hitch varnish nginx
  20. ahmed
    ahmed Active Member
    404
    49
    9:33 AM
    still the above codes did not solve the error after reboot, I have to run bash ~/restartservices.sh
    also what about if PHP crashes shall theses services reboot by its own to prevent downtime?
