Wordpress woocommerce issue and question about whitelisting
Discussion in 'Blogs & CMS usage' started by Altair, Feb 10, 2018.
  1. Altair
    Altair Member
    33
    7:23 AM
    I installed wordpress manually by creating a mysql database and username and password via command line, then via winSCP I uploaded my wordpress files, imported backup through a wordpress plugin.
    However, I installed wordpress in a sub-directory, as on the main directory I have xenforo.
    I executed:
    chown -R nginx:nginx /home/nginx/domains/domain.com/public/wp/wp-content/plugins/
    chown nginx:nginx /home/nginx/domains/domain.com/public/wp
    nginx vhost:
    nano /usr/local/nginx/conf/conf.d/domain.com.conf
    #server {
    #            listen   80;
    #            server_name domain.com;
      # ssi  on;
      access_log /home/nginx/domains/domain.com/log/access.log combined buffer=256k flush=5m;
      include /usr/local/nginx/conf/autoprotect/domain.com/autoprotect-domain.com.conf;
      # server and/or vhost site
      #location ~ (?:^|/)\. {
      # deny all;
      #autoindex  on;
      #autoindex_localtime on;
      location /wp {
       try_files $uri $uri/ /wp/index.php?q=$request_uri;
      location /internal_data/ {
      internal;
      allow 127.0.0.1;
      deny all;
      location /library/ {
      internal;
      allow 127.0.0.1;
      deny all;
      location /install/templates/ {
               internal;
      location /install/data/ {
                internal;
      location /wp {
      internal;
      allow 127.0.0.1;
      deny all;
      internal;
      allow 127.0.0.1;
      deny all;
               internal;
                internal;
      include /usr/local/nginx/conf/pre-staticfiles-local-domain.com.conf;
      include /usr/local/nginx/conf/errorpage.conf;
    nano /usr/local/nginx/conf/wpsecure.conf
    # Deny access to any files with a .php extension in the uploads directory
    # Works in sub-directory installs and also in multisite network
    location ~* /(?:uploads|files)/.*\.php$ {
            deny all;
    # Whitelist Exception for https://wordpress.org/plugins/woocommerce/
    location ~ ^/wp-content/plugins/woocommerce/ {
    # Whitelist Exception for gravityforms
    location ~ ^/wp-content/plugins/gravityforms/ {
    # Whitelist Exception for gravityforms iframe master
    location ~ ^/wp-content/plugins/gravity-forms-iframe-master/ {
    # Whitelist Exception for gravityforms custom post types
    location ~ ^/wp-content/plugins/gravity-forms-custom-post-types/ {
    # Whitelist Exception for custom plugin
    location ~ ^/wp-content/plugins/reuse_cartItems_after_checkout_for_diff_payment_methods/ {
    # Whitelist Exception for woocommerce-conditional-product-fees-for-checkout
    location ~ ^/wp-content/plugins/woocommerce-conditional-product-fees-for-checkout/ {
    # Whitelist Exception for modular-custom-css
    location ~ ^/wp-content/plugins/modular-custom-css/ {
    # Make sure files with the following extensions do not get loaded by nginx because nginx would display the source code, and these files can contain PASSWORDS!
    location ~* \.(engine|inc|info|install|make|module|profile|test|po|sh|.*sql|theme|tpl(\.php)?|xtmpl)$|^(\..*|Entries.*|Repository|Root|Tag|Template)$|\.php_
            return 444;
    #nocgi
    location ~* \.(pl|cgi|py|sh|lua)\$ {
            return 444;
    #disallow
        location ~* (roundcube|webdav|smtp|http\:|soap|w00tw00t) {
            return 444;
    location ~ /(\.|wp-config\.php|readme\.html|license\.txt) { deny all; }
    Is my whitelisting of woocommerce right? or do I need to specify the subdirectory that wp is installed on, in this example and others:
    The issue is that on woocommerce checkout page for a product, the spinning wheel on choosing payment option keeps spinning like not loading the full page.
  2. Altair
    Altair Member
    33
    7:23 AM
    Aside from the woocommerce checkout page loading correctly however PAYMENT options spinning indefinitely which might be related to cache? even though I haven't set up any cache plugins or options. I saw this thread, does it apply here with centmin mod?
    Settings nginx + woocommerce
    I really appreciate any input as my whole project is based on this concept of iframing that specific form from my wordpress directory to my xenforo custom page.
    39,216
    8,655
    2:23 PM
    yes you need to tag your subdirectory on the front of the example whitelisting as that is only if wp installed in web root
    39,216
    8,655
    2:23 PM
    FYI your /usr/local/nginx/conf/conf.d/domain.com.conf listed above has duplication location contexts so might want to double check
  5. Altair
    Altair Member
    33
    7:23 AM
    would it be like that?
    location ~ ^wp/wp-content/plugins/woocommerce/ {
    I see it's at location /wp, I'll delete the duplicate.
    39,216
    8,655
    2:23 PM
    need forward slash
    location ~ ^/wp/wp-content/plugins/woocommerce/ {
    You also have duplicate xenforo location contexts too
  7. Altair
    Altair Member
    33
    7:23 AM
    thanks for the whitelisitng, in-regards to the duplicate I see it's at:
               internal;
                internal;
  8. Altair
    Altair Member
    33
    7:23 AM
    What about these?
            return 444;
    #nocgi
            return 444;
    #disallow
            return 444;
    Would it be:?
    location ~* \wp\.(engine|inc|info|install|make|module|profile|test|po|sh|.*sql|theme|tpl(\.php)?|xtmpl)$|^(\..*|Entries.*|Repository|Root|Tag|Template)$|\.php_
            return 444;
    #nocgi
    location ~* \wp\.(pl|cgi|py|sh|lua)\$ {
            return 444;
    #disallow
            return 444;
    location ~ /wp/(\.|wp-config\.php|readme\.html|license\.txt) { deny all; }
  9. Altair
    Altair Member
    33
    7:23 AM
    for iframe I figured out I need to add this:
    Configuring nginx
    To configure nginx to send the X-Frame-Options header, add this either to your http, server or location configuration:
    add_header X-Frame-Options SAMEORIGIN;
    Do I add it in
    and
    location /wp {
    or just outside locations?
    also, is location /wp -OR- location /wp/? trailing slash?
    39,216
    8,655
    2:23 PM
    no need to do anything those are extension matches not directory matches
    39,216
    8,655
    2:23 PM
    no trailing slash but try within each location.
    39,216
    8,655
    2:23 PM
  13. Altair
    Altair Member
    33
    7:23 AM
    got this in my error log:
    2018/02/09 20:30:04 [error] 23945#23945: *1121 connect() failed (111: Connection refused) while connecting to upstream, client: xx.xx.xx5.216, server: domain.com, request: "GET /wp/gfembed/?f=1 HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "domain.com"
    And on access log
    xx.xx.xx5.216 - - [09/Feb/2018:20:34:21 +0000] "GET /wp/gfembed/?f=1 HTTP/1.1" 500 2796 "-" "Mozilla/5.0 (Windows NT 6.3; Win64; x64; rv:58.0) Gecko/20100101 Firefox/58.0"
    also woocommerce checkout page, payment options still spinning wheel indefinitely.
    39,216
    8,655
    2:23 PM
    If on Centmin Mod 123.09beta01, you may have ran into the new tools/autoprotect.sh cronjob feature outlined at Beta Branch - autoprotect.sh - apache .htaccess check & migration to nginx deny all | Centmin Mod Community You uploaded scripts may have .htaccess deny from all type files in their directories which may need bypassing autoprotect. It's a security feature that no other nginx based stack has as far as I know :)
  15. Altair
    Altair Member
    33
    7:23 AM
    Yes I'm on
    and I don't have .htaccess in wordpress as far as I look into the directories of the wordpress installation and plugins using winSCP.
    39,216
    8,655
    2:23 PM
    contents of vhost include file /usr/local/nginx/conf/autoprotect/domain.com/autoprotect-domain.com.conf ?
    cat /usr/local/nginx/conf/autoprotect/domain.com/autoprotect-domain.com.conf
  17. Altair
    Altair Member
    33
    7:23 AM
    returns nothing, what should it be?
    39,216
    8,655
    2:23 PM
    as per Beta Branch - autoprotect.sh - apache .htaccess check & migration to nginx deny all if autoprotect.sh detects .htaccess files with deny all in any vhost directory it will auto convert the .htaccess to nginx rule within /usr/local/nginx/conf/autoprotect/domain.com/autoprotect-domain.com.conf which is sometimes cause of 403 permission denied errors etc which isn't the case for you if empty
    but you get HTTP 500 status errors in access log.. you sure you have correct woocommerce nginx rules ? I never used woocommerce so have no idea myself
    what's current contents of your /usr/local/nginx/conf/conf.d/domain.com.conf vhost config file now ?
  19. Altair
    Altair Member
    33
    7:23 AM
    Got both of the issues fixed, through including X-Frame-Options and changing wordpress location to:
    try_files $uri $uri/ /wp/index.php?$args;
    I'm now on the process of implementing ssl
    still @eva2000 what would you recommend for SSL, spdy or Nginx HTTP/2, I've seen that http/2 doesn't support android default browsers which might break user experience if the certificate isn't valid or something?
    39,216
    8,655
    2:23 PM
    glad to hear.. spdy is no longer supported in browsers so HTTP/2 HTTPS is centmin mod nginx default
    There's generally 3 ways of setting up HTTPS SSL certificate for Centmin Mod Nginx HTTP/2 based HTTPS
    Method 1. The traditional way via centmin.sh menu option 2, 22 and selecting yes to self-signed ssl certificates first. Then converting the self-signed ssl certificate to paid or free (Letsencrypt) web browser trusted SSL certificates outlined at How to switch self-signed SSL certificate to paid SSL certificate ? You would still need to follow the same steps outlined at Nginx SPDY SSL Configuration for obtaining and purchasing the paid SSL certificate and most important part is the concatenation of the SSL provider provided filesto create the mentioned /usr/local/nginx/conf/ssl/domaincom/ssl-unified.crt and /usr/local/nginx/conf/ssl/domaincom/ssl-trusted.crtfiles referenced in your Nginx SSL vhost config file.
    You may need to also decide if you want to enable HTTP to HTTPS redirect outlined at How to force redirect from HTTP:// to HTTPS:// ?
    If you didn't answer yes at time of initial nginx vhost creation to self-signed ssl certificates, you can manually setup the self-signed ssl certificate via the vhost generator by checking self-signed ssl box and enter a domain name. This will outline instructions for manually creating and setting up self-signed ssl certificate and nginx vhost settings. Then for web browser trusted ssl certificates you switch follow - How to switch self-signed SSL certificate to paid SSL certificate ?.
    Method 3. Fully manual method for free Letsencrypt SSL certificates.
    Note:
    • For wordpress auto installer, you actually need a read method 2 to enable LETSENCRYPT_DETECT='y' then run centmin.sh menu option 22 which will detect letsencrypt support and display the additional letsencrypt prompts required to issue free letsencrypt ssl certificates for wordpress auto installer
