Wordpress woocommerce and x-accel-redirect for downloadable product
Discussion in 'Blogs & CMS usage' started by nikolaikapustin, Oct 5, 2016.
  1. nikolaikapustin
    nikolaikapustin Member
    38
    5
    7:44 AM
    Hi guys,
    anyone was success with x-accel-redirect setup? I need to serve some digital product as download. I migrate a shop from apache to nginx (redis cache). With apache and X-sendfile was easy, now i really can't figure out what is wrong with nginx.. i always get ERR_INVALID_RESPONSE.
    44,804
    10,216
    3:44 PM
    Never used woocommerce myself so best to see what others have to say.
  3. nikolaikapustin
    38
    5
    7:44 AM
    I partially solved removing
    location ~* ^/(wp-content)/(.*?)\.([B]zip[/B]|gz|tar|bzip2|7z)$ { deny all; }
    from wpsecure_domain.com.conf
    X-Accel-Redirect is now serving the downloads but the woocommerce path /wp-content/uploads/woocommerce_uploads/ is now free to everyone and not protected anymore.
    It seems that woocommerce php code is not really redirecting the downloads...
    I read some needed tweak on domain.com.conf
    location /protected/ {
     internal;
     root   /some/path/wp-content/uploads/woocommerce_uploads;
    but at this point you need to hard code woocommerce plugin. Can't be the solution.
    Anyone faced it?
  4. nikolaikapustin
    38
    5
    7:44 AM
    Solved. Now X-Accel-Redirect serves the downloads with nginx (redis cache) and the original files path is safely protected.
    I modified this line in wpsecure_domain.com.conf
    location ~* ^/(wp-content)/(.*?)\.(gz|tar|bzip2|7z)$ { deny all; }
    removing zip extension because my digital goods are mainly zipped archives.
    Then i added a new location (it can be placed in wpsecure too), the instruction "internal" gives 404 error to unwanted requests from outside, not "alias" needed since woocommerce php code will manage it.
    location ~* /wp-content/uploads/woocommerce_uploads/ {
    internal;
        include /usr/local/nginx/conf/php-rediscache.conf;
    and nginx is really faster than apache with X-Sendfile. ;)
    44,804
    10,216
    3:44 PM
    nice. you maybe able to keep zip in wpsecure if your woocommerce uploads directory location context is modified slightly
      internal;
      location ~* ^/wp-content/uploads/woocommerce_uploads/(.+/)?(.+)\.(zip)$ { allow all; }
  6. nikolaikapustin
    38
    5
    7:44 AM
    Unfortunately placing back "zip" in wpsecure and using that setup for location i'm getting ERR_INVALID_RESPONSE. :banghead:
    44,804
    10,216
    3:44 PM
    oh well
