Nginx Why Does Nginx Rewrite Rules Work Differently In Centmin
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by skringjer, May 22, 2020.
  1. skringjer
    skringjer NoobMaster69
    208
    26
    1:07 AM
    Nginx 1.21.6
    Hi everyone, so i wanted to know why does the nginx rewrite rules modifications to have them work in centmin, for example the below rewrite rule does not work, if i put it in my domains vhost conf.
    However, it works fine on Lemp stack or vestacp or cpanel. I had other rules like this which @eva2000 modified to fix them
    # nginx webdav rules
    # allow for paths ending with forward slashes
    rewrite ^/app/(.*)/ /plugins/webdav/site/control/$1 last;
    rewrite ^/app/(.*) /plugins/webdav/site/control/$1 last;
    # all webdav requests
    location /plugins/webdav/site/control/ {
        fastcgi_split_path_info ^(.+\.php)(/.+)$;
        fastcgi_param  SCRIPT_FILENAME $document_root$fastcgi_script_name;
        gzip off;
        fastcgi_pass   127.0.0.1:9000;
        fastcgi_index  index.php;
        include        fastcgi_params;
    55,797
    12,271
    6:07 AM
    it's because the default Centmin Mod vhost php.conf include file takes care of all PHP requests
    with a location match like
    location ~ [^/]\.php(/|$) {
    You might be able to make it work if you change
    from
       gzip off;
    to
    location /plugins/webdav/site/control/(.+\.php)(/.+)$ {
       gzip off;
  3. skringjer
    208
    26
    1:07 AM
    Nginx 1.21.6
    Ohh okay now i understand, And its a better way too.
    And should i put the new rules in php.conf or the domains vhost
    And also you didnt mention anything about this
    55,797
    12,271
    6:07 AM
    put in domain vhost
    the rewrite rules redirect to the suggested location match anyway
  5. skringjer
    208
    26
    1:07 AM
    Nginx 1.21.6
    Okay thank you, everything is clear now.
