MariaDB WHMCS and MySQL issues
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by Robust, Jun 14, 2015.
  1. Robust
    Robust Member
    49
    6:48 PM
    1.9.7
    10.1
    Alright.
    @eva2000 Trying to install WHMCS and running into a lot of problems.
    Here's my ticket to WHMCS:
    and
    I'm using PHP 5.6 using the latest ioncube loader which is meant to have support for PHP 5.6 with backwards compatibility. WHMCS is not giving an error saying there are ioncube problems though. ioncube self installed, your script doesn't support 5.6.
    Edit: Tried with PHP 5.4 using PHP 5.4 ioncube loaders and also using Centmin Mod provided ioncube loaders.
    The database gives errors during install until I visit the homepage, which gives an error saying tables are corrupt. Then I can continue the install. Even when I complete the install, I get crit errors that WHMCS can't connect to the database.
    55,926
    6:48 PM
    Centmin Mod is provide as is, so short of scripted related bugs or issues, any further optimisation to the web stack components - nginx, php-fpm, mariadb mysql, csf firewall etc or web app specific configurations are left to the Centmin Mod user to deal with. So I do not provide any free support for such. Would help if you provided the exact error messages too.
    More info would be nice though
    • Server or VPS details ? XEN, KVM, OpenVZ, VMWare or dedicated server ? OS ? CentOS 6.6 or 7.1 ? 32bit or 64bit ?
    • What version of Centmin Mod ? .07 stable or .08 beta03 ?
    To troubleshoot initial installation, you need to check the initial install log at /root/centminlogs. You can see full details at How to troubleshoot Centmin Mod initial install issues | Centmin Mod Community
    MySQL Error Logs
    You can check your mysql error log which is listed along with all other log file locations as per How to troubleshoot Centmin Mod initial install issues (/var/log/mysqld.log) for clues.
    1. Upgrading the actual Centmin Mod code which you downloaded via zip file or via github. This is heart of Centmin Mod where the code is the engine that runs centmin.sh shell based menu and all the automation you're accustomed to.
    2. Upgrade software that Centmin Mod installed or manages. For this part following outline at Upgrade - How to upgrade Centmin Mod is best.
    There's 3 ways you can upgrade your .07 stable or .08 beta02 code you have on your server. They are outlined in respective upgrade sections of the first posts linked below:
    1. For .07 stable 1st post see section on upgrades Install - Centmin Mod 1.2.3-eva2000.07 stable install
    2. For .08 beta 02 1st post see section on upgrade to latest code CentOS 7.x - How to help test .08 CentOS 7 Betas with Github code ?
    3. For either .07 stable or .08 beta02 via github command line Upgrade - Working with git command line for updating Centmin Mod local copies
    Github commit log for
  3. Robust
    Robust Member
    49
    6:48 PM
    1.9.7
    10.1
    It is the latest version, installed yesterday. No problems in installation, 99% sure.
    • Server or VPS details ? KVM
      OS ? CentOS 6.6 64bit
    • What version of Centmin Mod ? .07 stable or .08 beta03 ? Centmin Mod v1.2.3-eva2000.07
    • Was it fresh install or upgrade ? Fresh
    • How long ago did you install Centmin Mod ? 2 days
    WHMCS support said:
    55,926
    6:48 PM
  5. Robust
    Robust Member
    49
    6:48 PM
    1.9.7
    10.1
    @eva2000 As far as errors go
    /var/log/mysqld.log has no errors in it
    Edit: just read new response, will do it
  6. Robust
    Robust Member
    49
    6:48 PM
    1.9.7
    10.1
    Already tried 5.4, didn't help, and I used your loaders. I already have the PHP 5.4 loaders installed as well, the ioncube wizard has all the loaders. Just need to edit ioncube.ini to choose one.
    Latest ionCube has backwards compatibility (5.0.7). It should work fine. I'm using PHP 5.6 with latest ionCube and it's currently working. Just the way I managed to install it was sketchy, as mentioned above, and perhaps not definitive.
  7. Robust
    Robust Member
    49
    6:48 PM
    1.9.7
    10.1
    Alright, worked now. Recreated the database, all good. Thank you.
    55,926
    6:48 PM
    so what fixed it ? reinstall ioncube after downgrade to PHP 5.4 ?
  9. Robust
    Robust Member
    49
    6:48 PM
    1.9.7
    10.1
    Nothing, drop database and reinstall just worked. Still using 5.6 with ioncube 5.0.7.
    55,926
    6:48 PM
    strange then.. glad it works now :)
  11. Steve Tozer
    Steve Tozer Member
    70
    42
    South Wales, UK
    9:48 AM
    1.91
    10.0.19
    :confused: Seems odd how WHMCS is working with PHP 5.6 as its not supported, unless the OP is using the beta of whmcs.
    55,926
    6:48 PM
    yes i thought WHMCS only worked with <= PHP 5.4
  13. Robust
    Robust Member
    49
    6:48 PM
    1.9.7
    10.1
    ionCube latest version has backwards compatibility support. We're using v5 Stable version, not the v6 Beta.
    55,926
    6:48 PM
    Good to know :)
