MariaDB Where to create DB for Xenforo
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by quicksalad, Jun 8, 2015.
  1. quicksalad
    quicksalad Member
    223
    13
    2:03 AM
    I already installed PHPMyAdmin, now I'm on the way to install Xenforo. Where can I create DB username and password during installation of the software? Can i use root? Please advise.. Thanks
    50,902
    11,799
    6:33 AM
    For creating MySQL databases and MySQL username and password you have a few options all outlined via the following linked information (including mysqladmin_shell.sh addon below).
  3. quicksalad
    quicksalad Member
    223
    13
    2:03 AM
    how about phpMyAdmin? which part does it takes into action?
    50,902
    11,799
    6:33 AM
  5. quicksalad
    quicksalad Member
    223
    13
    2:03 AM
    does it mean I can create DB and users via phpMyAdmin web interface?
    50,902
    11,799
    6:33 AM
    yup or use mysqladmin_shell.sh which can be run from SSH command line instead
  7. quicksalad
    quicksalad Member
    223
    13
    2:03 AM
    50,902
    11,799
    6:33 AM
  9. quicksalad
    quicksalad Member
    223
    13
    2:03 AM
    thanks @eva2000 that cleared my confusion ;)
  10. quicksalad
    quicksalad Member
    223
    13
    2:03 AM
    by checking on the via phpMyAdmin, I see "No" on users grant field. I checked the privileges all is unchecked. While running
    /root/tools/mysqladmin_shell.sh showgrants tells below.
    | GRANT USAGE ON *.* TO 'username'@'localhost' IDENTIFIED BY PASSWORD '*rwerwerwerwerwerwerwerwerwr' |
    | GRANT SELECT, INSERT, UPDATE, DELETE, CREATE, DROP, ALTER, CREATE TEMPORARY TA BLES, LOCK TABLES, EXECUTE ON `dbname`.* TO 'username'@'localhost' |
    seeing the output, the grant select, insert etc is ON but it's different on phpMyAdmin users tab. Please advise. Thanks
    50,902
    11,799
    6:33 AM
    i never use phpmyadmin for such user privileges so no idea what phpmyadmin users show.. i use mysqladmin_shell.sh commands usually done manually via SSH
  12. quicksalad
    quicksalad Member
    223
    13
    2:03 AM
    thanks, hopefully other members in here who uses phpMyAdmin can give advise. :)
