PHP-FPM What permisions phpfpm is using?
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by pamamolf, Dec 22, 2016.
    4,101
    428
    11:12 PM
    Nginx-1.26.x
    Hi :)
    Creating a folder using php has root permissions :(
    Any ideas how to automate permissions to nginx:nginx for the new generated folders/files using a php file?
    Thank you
    55,458
    12,257
    6:12 AM
    AFAIK, it shouldn't php created files should be nginx permission based if the php script executing has nginx permissions. But if you as root user ran php script, then that would have root permissions. In which case you just chown them.
    How is the php script executed/ran/called ? Does the script itself use nginx:nginx user/group permissions ?
  3. pamamolf
    4,101
    428
    11:12 PM
    Nginx-1.26.x
    It is running using a cron and the permissions on php file are nginx:nginx
    55,458
    12,257
    6:12 AM
