Beta Branch wget 1.20 default for 123.09beta01
Discussion in 'Centmin Mod Github Commits' started by eva2000, Dec 4, 2018.
  1. Sunka
    Sunka Well-Known Member
    1,150
    325
    Pula, Croatia
    1:19 AM
    Nginx 1.17.9
    MariaDB 10.3.22
    jeeeeeeeeeeeee...
    # centmin
    /usr/local/src/centminmod ~
    update wget to 1.20 version... one time task
    Download wget-1.20.tar.gz ...
    wget-1.20.tar.gz Archive found, skipping download...
    wget-1.20.tar.gz valid file.
    Making clean in lib
    make[1]: Entering directory `/svr-setup/wget-1.20/lib'
    make[2]: Entering directory `/svr-setup/wget-1.20/lib'
    test -z "" || rm -f
    test -z "libgnu.a" || rm -f libgnu.a
    test -z "" || rm -f
    rm -f *.o
    rm -f glthread/*.o
    rm -f unicase/*.o
    rm -f unictype/*.o
    rm -f uninorm/*.o
    rm -f unistr/*.o
    rm -f uniwidth/*.o
    test -z "core *.stackdump alloca.h alloca.h-t arpa/inet.h arpa/inet.h-t byteswap.h byteswap.h-t errno.h errno.h-t fcntl.h fcntl.h-t float.h float.h-t fnmatch.h fnmatch.h-t getopt.h getopt.h-t getopt-cdefs.h getopt-cdefs.h-t iconv.h iconv.h-t inttypes.h inttypes.h-t langinfo.h langinfo.h-t limits.h limits.h-t locale.h locale.h-t netdb.h netdb.h-t netinet/in.h netinet/in.h-t sched.h sched.h-t signal.h signal.h-t spawn.h spawn.h-t stdalign.h stdalign.h-t stdbool.h stdbool.h-t stddef.h stddef.h-t stdint.h stdint.h-t stdio.h stdio.h-t stdlib.h stdlib.h-t string.h string.h-t strings.h strings.h-t sys/file.h sys/file.h-t sys/ioctl.h sys/ioctl.h-t sys/select.h sys/select.h-t sys/socket.h sys/socket.h-t sys/stat.h sys/stat.h-t sys/time.h sys/time.h-t sys/types.h sys/types.h-t sys/uio.h sys/uio.h-t sys/wait.h sys/wait.h-t time.h time.h-t unicase.h unicase.h-t unicase/special-casing-table.h-t unicase/special-casing.h unicase/special-casing.h-t unictype.h unictype.h-t uninorm.h uninorm.h-t unistd.h unistd.h-t unistr.h unistr.h-t unitypes.h unitypes.h-t uniwidth.h uniwidth.h-t utime.h utime.h-t wchar.h wchar.h-t wctype.h wctype.h-t" || rm -f core *.stackdump alloca.h alloca.h-t arpa/inet.h arpa/inet.h-t byteswap.h byteswap.h-t errno.h errno.h-t fcntl.h fcntl.h-t float.h float.h-t fnmatch.h fnmatch.h-t getopt.h getopt.h-t getopt-cdefs.h getopt-cdefs.h-t iconv.h iconv.h-t inttypes.h inttypes.h-t langinfo.h langinfo.h-t limits.h limits.h-t locale.h locale.h-t netdb.h netdb.h-t netinet/in.h netinet/in.h-t sched.h sched.h-t signal.h signal.h-t spawn.h spawn.h-t stdalign.h stdalign.h-t stdbool.h stdbool.h-t stddef.h stddef.h-t stdint.h stdint.h-t stdio.h stdio.h-t stdlib.h stdlib.h-t string.h string.h-t strings.h strings.h-t sys/file.h sys/file.h-t sys/ioctl.h sys/ioctl.h-t sys/select.h sys/select.h-t sys/socket.h sys/socket.h-t sys/stat.h sys/stat.h-t sys/time.h sys/time.h-t sys/types.h sys/types.h-t sys/uio.h sys/uio.h-t sys/wait.h sys/wait.h-t time.h time.h-t unicase.h unicase.h-t unicase/special-casing-table.h-t unicase/special-casing.h unicase/special-casing.h-t unictype.h unictype.h-t uninorm.h uninorm.h-t unistd.h unistd.h-t unistr.h unistr.h-t unitypes.h unitypes.h-t uniwidth.h uniwidth.h-t utime.h utime.h-t wchar.h wchar.h-t wctype.h wctype.h-t
    rmdir arpa
    rmdir sys
    make[2]: Leaving directory `/svr-setup/wget-1.20/lib'
    make[1]: Leaving directory `/svr-setup/wget-1.20/lib'
    Making clean in src
    make[1]: Entering directory `/svr-setup/wget-1.20/src'
    test -z "wget" || rm -f wget
    test -z "libunittest.a" || rm -f libunittest.a
    test -z "*~ *.bak core core.[0-9]* build_info.c version.c" || rm -f *~ *.bak core core.[0-9]* build_info.c version.c
    rm -f *.o
    make[1]: Leaving directory `/svr-setup/wget-1.20/src'
    Making clean in doc
    make[1]: Entering directory `/svr-setup/wget-1.20/doc'
    test -z "wget.dvi wget.pdf wget.ps wget.html" \
    || rm -rf wget.dvi wget.pdf wget.ps wget.html
    test -z "*~ *.bak *.cat *.pod" || rm -f *~ *.bak *.cat *.pod
    rm -rf wget.t2d wget.t2p
    rm -f vti.tmp* ./version.texi.tmp*
    make[1]: Leaving directory `/svr-setup/wget-1.20/doc'
    Making clean in po
    make[1]: Entering directory `/svr-setup/wget-1.20/po'
    rm -f *.insert-header
    rm -f remove-potcdate.sed
    rm -f stamp-poT
    rm -f core core.* wget.po wget.1po wget.2po *.new.po
    rm -fr *.o
    make[1]: Leaving directory `/svr-setup/wget-1.20/po'
    Making clean in util
    make[1]: Entering directory `/svr-setup/wget-1.20/util'
    make[1]: Nothing to be done for `clean'.
    make[1]: Leaving directory `/svr-setup/wget-1.20/util'
    Making clean in fuzz
    make[1]: Entering directory `/svr-setup/wget-1.20/fuzz'
    test -z "" || rm -f
    test -z "wget_css_fuzzer wget_cookie_fuzzer wget_ftpls_fuzzer wget_html_fuzzer wget_netrc_fuzzer wget_options_fuzzer wget_robots_fuzzer wget_url_fuzzer" || rm -f wget_css_fuzzer wget_cookie_fuzzer wget_ftpls_fuzzer wget_html_fuzzer wget_netrc_fuzzer wget_options_fuzzer wget_robots_fuzzer wget_url_fuzzer
    rm -rf *.gc?? *.log lcov
    rm -f *.o
    test -z "wget_css_fuzzer.log wget_cookie_fuzzer.log wget_ftpls_fuzzer.log wget_html_fuzzer.log wget_netrc_fuzzer.log wget_options_fuzzer.log wget_robots_fuzzer.log wget_url_fuzzer.log" || rm -f wget_css_fuzzer.log wget_cookie_fuzzer.log wget_ftpls_fuzzer.log wget_html_fuzzer.log wget_netrc_fuzzer.log wget_options_fuzzer.log wget_robots_fuzzer.log wget_url_fuzzer.log
    test -z "wget_css_fuzzer.trs wget_cookie_fuzzer.trs wget_ftpls_fuzzer.trs wget_html_fuzzer.trs wget_netrc_fuzzer.trs wget_options_fuzzer.trs wget_robots_fuzzer.trs wget_url_fuzzer.trs" || rm -f wget_css_fuzzer.trs wget_cookie_fuzzer.trs wget_ftpls_fuzzer.trs wget_html_fuzzer.trs wget_netrc_fuzzer.trs wget_options_fuzzer.trs wget_robots_fuzzer.trs wget_url_fuzzer.trs
    test -z "test-suite.log" || rm -f test-suite.log
    make[1]: Leaving directory `/svr-setup/wget-1.20/fuzz'
    Making clean in tests
    make[1]: Entering directory `/svr-setup/wget-1.20/tests'
    test -z "unit-tests" || rm -f unit-tests
    test -z "*~ *.bak core core.[0-9]*" || rm -f *~ *.bak core core.[0-9]*
    rm -f *.o
    test -z "./unit-tests.log Test-auth-basic.log Test-auth-no-challenge.log Test-auth-no-challenge-url.log Test-auth-with-content-disposition.log Test-auth-retcode.log Test-c-full.log Test-c-partial.log Test-c.log Test-c-shorter.log Test-cookies.log Test-cookies-401.log Test-E-k-K.log Test-E-k.log Test-ftp.log Test-ftp-pasv-fail.log Test-ftp-bad-list.log Test-ftp-recursive.log Test-ftp-iri.log Test-ftp-iri-fallback.log Test-ftp-iri-recursive.log Test-ftp-iri-disabled.log Test-ftp-list-Multinet.log Test-ftp-list-Unknown.log Test-ftp-list-Unknown-a.log Test-ftp-list-Unknown-hidden.log Test-ftp-list-Unknown-list-a-fails.log Test-ftp-list-UNIX-hidden.log Test-ftp--start-pos.log Test-HTTP-Content-Disposition-1.log Test-HTTP-Content-Disposition-2.log Test-HTTP-Content-Disposition.log Test-i-ftp.log Test-i-http.log Test-idn-headers.log Test-idn-meta.log Test-idn-cmd.log Test-idn-cmd-utf8.log Test-idn-robots.log Test-idn-robots-utf8.log Test-iri.log Test-iri-percent.log Test-iri-disabled.log Test-iri-forced-remote.log Test-iri-list.log Test-k.log Test-meta-robots.log Test-N-current.log Test-N-HTTP-Content-Disposition.log Test-N--no-content-disposition.log Test-N--no-content-disposition-trivial.log Test-N-no-info.log Test--no-content-disposition.log Test--no-content-disposition-trivial.log Test-N-old.log Test-nonexisting-quiet.log Test-noop.log Test-np.log Test-N.log Test-N-smaller.log Test-O-HTTP-Content-Disposition.log Test-O-nc.log Test-O--no-content-disposition.log Test-O--no-content-disposition-trivial.log Test-O-nonexisting.log Test-O.log Test--post-file.log Test-proxied-https-auth.log Test-proxied-https-auth-keepalive.log Test-proxy-auth-basic.log Test-restrict-ascii.log Test-Restrict-Lowercase.log Test-Restrict-Uppercase.log Test-stdouterr.log Test--spider-fail.log Test--spider.log Test--spider-r-HTTP-Content-Disposition.log Test--spider-r--no-content-disposition.log Test--spider-r--no-content-disposition-trivial.log Test--spider-r.log Test--start-pos.log Test--start-pos--continue.log Test--httpsonly-r.log Test-204.log Test-ftp-pasv-not-supported.log Test-https-pfs.log Test-https-tlsv1.log Test-https-tlsv1x.log Test-https-selfsigned.log Test-https-weboftrust.log Test-https-clientcert.log Test-https-crl.log Test-https-badcerts.log" || rm -f ./unit-tests.log Test-auth-basic.log Test-auth-no-challenge.log Test-auth-no-challenge-url.log Test-auth-with-content-disposition.log Test-auth-retcode.log Test-c-full.log Test-c-partial.log Test-c.log Test-c-shorter.log Test-cookies.log Test-cookies-401.log Test-E-k-K.log Test-E-k.log Test-ftp.log Test-ftp-pasv-fail.log Test-ftp-bad-list.log Test-ftp-recursive.log Test-ftp-iri.log Test-ftp-iri-fallback.log Test-ftp-iri-recursive.log Test-ftp-iri-disabled.log Test-ftp-list-Multinet.log Test-ftp-list-Unknown.log Test-ftp-list-Unknown-a.log Test-ftp-list-Unknown-hidden.log Test-ftp-list-Unknown-list-a-fails.log Test-ftp-list-UNIX-hidden.log Test-ftp--start-pos.log Test-HTTP-Content-Disposition-1.log Test-HTTP-Content-Disposition-2.log Test-HTTP-Content-Disposition.log Test-i-ftp.log Test-i-http.log Test-idn-headers.log Test-idn-meta.log Test-idn-cmd.log Test-idn-cmd-utf8.log Test-idn-robots.log Test-idn-robots-utf8.log Test-iri.log Test-iri-percent.log Test-iri-disabled.log Test-iri-forced-remote.log Test-iri-list.log Test-k.log Test-meta-robots.log Test-N-current.log Test-N-HTTP-Content-Disposition.log Test-N--no-content-disposition.log Test-N--no-content-disposition-trivial.log Test-N-no-info.log Test--no-content-disposition.log Test--no-content-disposition-trivial.log Test-N-old.log Test-nonexisting-quiet.log Test-noop.log Test-np.log Test-N.log Test-N-smaller.log Test-O-HTTP-Content-Disposition.log Test-O-nc.log Test-O--no-content-disposition.log Test-O--no-content-disposition-trivial.log Test-O-nonexisting.log Test-O.log Test--post-file.log Test-proxied-https-auth.log Test-proxied-https-auth-keepalive.log Test-proxy-auth-basic.log Test-restrict-ascii.log Test-Restrict-Lowercase.log Test-Restrict-Uppercase.log Test-stdouterr.log Test--spider-fail.log Test--spider.log Test--spider-r-HTTP-Content-Disposition.log Test--spider-r--no-content-disposition.log Test--spider-r--no-content-disposition-trivial.log Test--spider-r.log Test--start-pos.log Test--start-pos--continue.log Test--httpsonly-r.log Test-204.log Test-ftp-pasv-not-supported.log Test-https-pfs.log Test-https-tlsv1.log Test-https-tlsv1x.log Test-https-selfsigned.log Test-https-weboftrust.log Test-https-clientcert.log Test-https-crl.log Test-https-badcerts.log
    test -z "./unit-tests.trs Test-auth-basic.trs Test-auth-no-challenge.trs Test-auth-no-challenge-url.trs Test-auth-with-content-disposition.trs Test-auth-retcode.trs Test-c-full.trs Test-c-partial.trs Test-c.trs Test-c-shorter.trs Test-cookies.trs Test-cookies-401.trs Test-E-k-K.trs Test-E-k.trs Test-ftp.trs Test-ftp-pasv-fail.trs Test-ftp-bad-list.trs Test-ftp-recursive.trs Test-ftp-iri.trs Test-ftp-iri-fallback.trs Test-ftp-iri-recursive.trs Test-ftp-iri-disabled.trs Test-ftp-list-Multinet.trs Test-ftp-list-Unknown.trs Test-ftp-list-Unknown-a.trs Test-ftp-list-Unknown-hidden.trs Test-ftp-list-Unknown-list-a-fails.trs Test-ftp-list-UNIX-hidden.trs Test-ftp--start-pos.trs Test-HTTP-Content-Disposition-1.trs Test-HTTP-Content-Disposition-2.trs Test-HTTP-Content-Disposition.trs Test-i-ftp.trs Test-i-http.trs Test-idn-headers.trs Test-idn-meta.trs Test-idn-cmd.trs Test-idn-cmd-utf8.trs Test-idn-robots.trs Test-idn-robots-utf8.trs Test-iri.trs Test-iri-percent.trs Test-iri-disabled.trs Test-iri-forced-remote.trs Test-iri-list.trs Test-k.trs Test-meta-robots.trs Test-N-current.trs Test-N-HTTP-Content-Disposition.trs Test-N--no-content-disposition.trs Test-N--no-content-disposition-trivial.trs Test-N-no-info.trs Test--no-content-disposition.trs Test--no-content-disposition-trivial.trs Test-N-old.trs Test-nonexisting-quiet.trs Test-noop.trs Test-np.trs Test-N.trs Test-N-smaller.trs Test-O-HTTP-Content-Disposition.trs Test-O-nc.trs Test-O--no-content-disposition.trs Test-O--no-content-disposition-trivial.trs Test-O-nonexisting.trs Test-O.trs Test--post-file.trs Test-proxied-https-auth.trs Test-proxied-https-auth-keepalive.trs Test-proxy-auth-basic.trs Test-restrict-ascii.trs Test-Restrict-Lowercase.trs Test-Restrict-Uppercase.trs Test-stdouterr.trs Test--spider-fail.trs Test--spider.trs Test--spider-r-HTTP-Content-Disposition.trs Test--spider-r--no-content-disposition.trs Test--spider-r--no-content-disposition-trivial.trs Test--spider-r.trs Test--start-pos.trs Test--start-pos--continue.trs Test--httpsonly-r.trs Test-204.trs Test-ftp-pasv-not-supported.trs Test-https-pfs.trs Test-https-tlsv1.trs Test-https-tlsv1x.trs Test-https-selfsigned.trs Test-https-weboftrust.trs Test-https-clientcert.trs Test-https-crl.trs Test-https-badcerts.trs" || rm -f ./unit-tests.trs Test-auth-basic.trs Test-auth-no-challenge.trs Test-auth-no-challenge-url.trs Test-auth-with-content-disposition.trs Test-auth-retcode.trs Test-c-full.trs Test-c-partial.trs Test-c.trs Test-c-shorter.trs Test-cookies.trs Test-cookies-401.trs Test-E-k-K.trs Test-E-k.trs Test-ftp.trs Test-ftp-pasv-fail.trs Test-ftp-bad-list.trs Test-ftp-recursive.trs Test-ftp-iri.trs Test-ftp-iri-fallback.trs Test-ftp-iri-recursive.trs Test-ftp-iri-disabled.trs Test-ftp-list-Multinet.trs Test-ftp-list-Unknown.trs Test-ftp-list-Unknown-a.trs Test-ftp-list-Unknown-hidden.trs Test-ftp-list-Unknown-list-a-fails.trs Test-ftp-list-UNIX-hidden.trs Test-ftp--start-pos.trs Test-HTTP-Content-Disposition-1.trs Test-HTTP-Content-Disposition-2.trs Test-HTTP-Content-Disposition.trs Test-i-ftp.trs Test-i-http.trs Test-idn-headers.trs Test-idn-meta.trs Test-idn-cmd.trs Test-idn-cmd-utf8.trs Test-idn-robots.trs Test-idn-robots-utf8.trs Test-iri.trs Test-iri-percent.trs Test-iri-disabled.trs Test-iri-forced-remote.trs Test-iri-list.trs Test-k.trs Test-meta-robots.trs Test-N-current.trs Test-N-HTTP-Content-Disposition.trs Test-N--no-content-disposition.trs Test-N--no-content-disposition-trivial.trs Test-N-no-info.trs Test--no-content-disposition.trs Test--no-content-disposition-trivial.trs Test-N-old.trs Test-nonexisting-quiet.trs Test-noop.trs Test-np.trs Test-N.trs Test-N-smaller.trs Test-O-HTTP-Content-Disposition.trs Test-O-nc.trs Test-O--no-content-disposition.trs Test-O--no-content-disposition-trivial.trs Test-O-nonexisting.trs Test-O.trs Test--post-file.trs Test-proxied-https-auth.trs Test-proxied-https-auth-keepalive.trs Test-proxy-auth-basic.trs Test-restrict-ascii.trs Test-Restrict-Lowercase.trs Test-Restrict-Uppercase.trs Test-stdouterr.trs Test--spider-fail.trs Test--spider.trs Test--spider-r-HTTP-Content-Disposition.trs Test--spider-r--no-content-disposition.trs Test--spider-r--no-content-disposition-trivial.trs Test--spider-r.trs Test--start-pos.trs Test--start-pos--continue.trs Test--httpsonly-r.trs Test-204.trs Test-ftp-pasv-not-supported.trs Test-https-pfs.trs Test-https-tlsv1.trs Test-https-tlsv1x.trs Test-https-selfsigned.trs Test-https-weboftrust.trs Test-https-clientcert.trs Test-https-crl.trs Test-https-badcerts.trs
    make[1]: Leaving directory `/svr-setup/wget-1.20/tests'
    Making clean in testenv
    make[1]: Entering directory `/svr-setup/wget-1.20/testenv'
    test -z "" || rm -f
    test -z "" || rm -f
    make[1]: Leaving directory `/svr-setup/wget-1.20/testenv'
    make[1]: Entering directory `/svr-setup/wget-1.20'
    rm -f install-info
    make[1]: Leaving directory `/svr-setup/wget-1.20'
    configure: configuring for GNU Wget 1.20
    checking for a BSD-compatible install... /bin/install -c
    checking whether build environment is sane... yes
    checking for a thread-safe mkdir -p... /bin/mkdir -p
    checking for gawk... gawk
    checking whether make sets $(MAKE)... yes
    checking whether make supports nested variables... yes
    checking build system type... x86_64-pc-linux-gnu
    checking host system type... x86_64-pc-linux-gnu
    checking whether make supports nested variables... (cached) yes
    checking for gcc... ccache gcc
    checking whether the C compiler works... yes
    checking for C compiler default output file name... a.out
    checking for suffix of executables...
    checking whether we are cross compiling... no
    checking for suffix of object files... o
    checking whether we are using the GNU C compiler... yes
    checking whether ccache gcc accepts -g... yes
    checking for ccache gcc option to enable C11 features... -std=gnu11
    checking whether make supports the include directive... yes (GNU style)
    checking dependency style of ccache gcc -std=gnu11... gcc3
    checking how to run the C preprocessor... ccache gcc -std=gnu11 -E
    checking for ANSI C header files... yes
    checking for sys/types.h... yes
    checking for sys/stat.h... yes
    checking for stdlib.h... yes
    checking for string.h... yes
    checking for memory.h... yes
    checking for strings.h... yes
    checking for inttypes.h... yes
    checking for stdint.h... yes
    checking for unistd.h... yes
    checking minix/config.h usability... no
    checking minix/config.h presence... no
    checking for minix/config.h... no
    checking whether it is safe to define __EXTENSIONS__... yes
    checking whether _XOPEN_SOURCE should be defined... no
    checking for Minix Amsterdam compiler... no
    checking for ar... ar
    checking for ranlib... ranlib
    checking for _LARGEFILE_SOURCE value needed for large files... no
    checking for special C compiler options needed for large files... no
    checking for _FILE_OFFSET_BITS value needed for large files... no
    checking for a Python interpreter with version >= 3.0... none
    checking whether NLS is requested... yes
    checking for msgfmt... /bin/msgfmt
    checking for gmsgfmt... /bin/msgfmt
    checking for xgettext... /bin/xgettext
    checking for msgmerge... /bin/msgmerge
    checking for ld used by ccache gcc -std=gnu11... /bin/ld
    checking if the linker (/bin/ld) is GNU ld... yes
    checking for shared library run path origin... done
    checking 32-bit host C ABI... no
    checking for the common suffixes of directories in the library search path... lib64,lib64
    checking for CFPreferencesCopyAppValue... no
    checking for CFLocaleCopyCurrent... no
    checking for GNU gettext in libc... yes
    checking whether to use NLS... yes
    checking where the gettext function comes from... libc
    checking for ranlib... (cached) ranlib
    checking for flex... flex
    checking lex output file root... lex.yy
    checking lex library... none needed
    checking whether yytext is a pointer... no
    checking for an ANSI C-conforming const... yes
    checking for inline... inline
    checking for working volatile... yes
    checking for ANSI C header files... (cached) yes
    checking for special C compiler options needed for large files... (cached) no
    checking for _FILE_OFFSET_BITS value needed for large files... (cached) no
    checking size of off_t... 8
    checking for stdbool.h that conforms to C99... yes
    checking for _Bool... yes
    checking for unistd.h... (cached) yes
    checking sys/time.h usability... yes
    checking sys/time.h presence... yes
    checking for sys/time.h... yes
    checking termios.h usability... yes
    checking termios.h presence... yes
    checking for termios.h... yes
    checking sys/ioctl.h usability... yes
    checking sys/ioctl.h presence... yes
    checking for sys/ioctl.h... yes
    checking sys/select.h usability... yes
    checking sys/select.h presence... yes
    checking for sys/select.h... yes
    checking utime.h usability... yes
    checking utime.h presence... yes
    checking for utime.h... yes
    checking sys/utime.h usability... no
    checking sys/utime.h presence... no
    checking for sys/utime.h... no
    checking for stdint.h... (cached) yes
    checking for inttypes.h... (cached) yes
    checking pwd.h usability... yes
    checking pwd.h presence... yes
    checking for pwd.h... yes
    checking wchar.h usability... yes
    checking wchar.h presence... yes
    checking for wchar.h... yes
    checking dlfcn.h usability... yes
    checking dlfcn.h presence... yes
    checking for dlfcn.h... yes
    checking whether h_errno is declared... yes
    checking size of short... 2
    checking size of int... 4
    checking size of long... 8
    checking size of long long... 8
    checking size of void *... 8
    checking for size_t... yes
    checking for pid_t... yes
    checking for uint32_t... yes
    checking for uintptr_t... yes
    checking for intptr_t... yes
    checking for int64_t... yes
    checking for sig_atomic_t... yes
    checking for sys/socket.h... yes
    checking for arpa/inet.h... yes
    checking for features.h... yes
    checking for fnmatch.h... yes
    checking for wctype.h... yes
    checking for sys/stat.h... (cached) yes
    checking for netdb.h... yes
    checking for netinet/in.h... yes
    checking for getopt.h... yes
    checking for sys/cdefs.h... yes
    checking for stdio_ext.h... yes
    checking for termios.h... (cached) yes
    checking for sys/time.h... (cached) yes
    checking for iconv.h... yes
    checking for limits.h... yes
    checking for wchar.h... (cached) yes
    checking for crtdefs.h... no
    checking for langinfo.h... yes
    checking for xlocale.h... yes
    checking for sys/mman.h... yes
    checking for sys/select.h... (cached) yes
    checking for sys/param.h... yes
    checking for malloc.h... yes
    checking for spawn.h... yes
    checking for strings.h... (cached) yes
    checking for sys/file.h... yes
    checking for sys/ioctl.h... (cached) yes
    checking for sys/uio.h... yes
    checking for sys/wait.h... yes
    checking for utime.h... (cached) yes
    checking for stdlib.h... (cached) yes
    checking whether the preprocessor supports include_next... yes
    checking whether system header files limit the line length... no
    checking whether <sys/socket.h> is self-contained... yes
    checking for shutdown... yes
    checking whether <sys/socket.h> defines the SHUT_* macros... yes
    checking for struct sockaddr_storage... yes
    checking for sa_family_t... yes
    checking for struct sockaddr_storage.ss_family... yes
    checking for working alloca.h... yes
    checking for alloca... yes
    checking for C/C++ restrict keyword... __restrict
    checking whether <wchar.h> uses 'inline' correctly... yes
    checking for btowc... yes
    checking for _set_invalid_parameter_handler... no
    checking for fcntl... yes
    checking for symlink... yes
    checking for flock... yes
    checking for fnmatch... yes
    checking for isblank... yes
    checking for iswctype... yes
    checking for mbsrtowcs... yes
    checking for mempcpy... yes
    checking for wmemchr... yes
    checking for wmemcpy... yes
    checking for wmempcpy... yes
    checking for fpurge... no
    checking for __fpurge... yes
    checking for __freading... yes
    checking for futimens... yes
    checking for getdelim... yes
    checking for getdtablesize... yes
    checking for getpass... yes
    checking for __fsetlocking... yes
    checking for getprogname... no
    checking for getexecname... no
    checking for gettimeofday... yes
    checking for iswcntrl... yes
    checking for iswblank... yes
    checking for link... yes
    checking for lstat... yes
    checking for mbsinit... yes
    checking for mbrtowc... yes
    checking for mprotect... yes
    checking for mkostemp... yes
    checking for mkstemp... yes
    checking for tzset... yes
    checking for nl_langinfo... yes
    checking for pipe... yes
    checking for pipe2... yes
    checking for secure_getenv... yes
    checking for getuid... yes
    checking for geteuid... yes
    checking for getgid... yes
    checking for getegid... yes
    checking for sigaction... yes
    checking for sigaltstack... yes
    checking for siginterrupt... yes
    checking for snprintf... yes
    checking for strdup... yes
    checking for strerror_r... yes
    checking for __xpg_strerror_r... yes
    checking for catgets... yes
    checking for strndup... yes
    checking for strptime... yes
    checking for localtime_r... yes
    checking for timegm... yes
    checking for utime... yes
    checking for futimes... yes
    checking for futimesat... yes
    checking for utimensat... yes
    checking for lutimes... yes
    checking for vasnprintf... no
    checking for wcrtomb... yes
    checking for wcwidth... yes
    checking for nl_langinfo and CODESET... yes
    checking for a traditional french locale... fr_FR
    checking whether linux/if_alg.h has struct sockaddr_alg.... yes
    checking whether byte ordering is bigendian... no
    checking whether // is distinct from /... no
    checking if environ is properly declared... yes
    checking for complete errno.h... yes
    checking whether strerror_r is declared... yes
    checking for strerror_r... (cached) yes
    checking whether strerror_r returns char *... yes
    checking for sig_atomic_t... (cached) yes
    checking for working fcntl.h... yes
    checking for mode_t... yes
    checking for mbstate_t... yes
    checking whether stdin defaults to large file offsets... yes
    checking whether fseeko is declared... yes
    checking for fseeko... yes
    checking whether fflush works on input streams... no
    checking whether stat file-mode macros are broken... no
    checking for nlink_t... yes
    checking whether ftello is declared... yes
    checking for ftello... yes
    checking whether ftello works... yes
    checking for library containing gethostbyname... none required
    checking for gethostbyname... yes
    checking for library containing getservbyname... none required
    checking for getservbyname... yes
    checking for library containing inet_ntop... none required
    checking whether inet_ntop is declared... yes
    checking for IPv4 sockets... yes
    checking for IPv6 sockets... yes
    checking whether getdelim is declared... yes
    checking whether getdtablesize is declared... yes
    checking for uid_t in sys/types.h... yes
    checking type of array argument to getgroups... gid_t
    checking whether getline is declared... yes
    checking for getopt.h... (cached) yes
    checking for getopt_long_only... yes
    checking whether getopt is POSIX compatible... yes
    checking for working GNU getopt function... yes
    checking for working GNU getopt_long function... yes
    checking whether fflush_unlocked is declared... yes
    checking whether flockfile is declared... yes
    checking whether fputs_unlocked is declared... yes
    checking whether funlockfile is declared... yes
    checking whether putc_unlocked is declared... yes
    checking for struct timeval... yes
    checking for wide-enough struct timeval.tv_sec member... yes
    checking for iconv... yes
    checking for working iconv... yes
    checking for iconv declaration...
             extern size_t iconv (iconv_t cd, char * *inbuf, size_t *inbytesleft, char * *outbuf, size_t *outbytesleft);
    checking whether limits.h has LLONG_MAX, WORD_BIT, ULLONG_WIDTH etc.... no
    checking for wint_t... yes
    checking whether wint_t is too small... no
    checking for unsigned long long int... yes
    checking for long long int... yes
    checking whether stdint.h conforms to C99... no
    checking sys/inttypes.h usability... no
    checking sys/inttypes.h presence... no
    checking for sys/inttypes.h... no
    checking sys/bitypes.h usability... yes
    checking sys/bitypes.h presence... yes
    checking for sys/bitypes.h... yes
    checking for bit size of ptrdiff_t... 64
    checking for bit size of size_t... 64
    checking for bit size of sig_atomic_t... 32
    checking for bit size of wchar_t... 32
    checking for bit size of wint_t... 32
    checking whether sig_atomic_t is signed... yes
    checking whether wchar_t is signed... yes
    checking whether wint_t is signed... no
    checking for ptrdiff_t integer literal suffix... l
    checking for size_t integer literal suffix... ul
    checking for sig_atomic_t integer literal suffix...
    checking for wchar_t integer literal suffix...
    checking for wint_t integer literal suffix... u
    checking whether the inttypes.h PRIxNN macros are broken... no
    checking whether iswcntrl works... yes
    checking for towlower... yes
    checking for wctype_t... yes
    checking for wctrans_t... yes
    checking whether included libunistring is requested... no
    checking for libunistring... no, consider installing GNU libunistring
    checking for wchar_t... yes
    checking for good max_align_t... yes
    checking whether NULL can be used in arbitrary expressions... yes
    checking whether imported symbols can be declared weak... yes
    checking whether the linker supports --as-needed... yes
    checking whether the linker supports --push-state... yes
    checking pthread.h usability... yes
    checking pthread.h presence... yes
    checking for pthread.h... yes
    checking for multithread API to use... posix
    checking whether lstat correctly handles trailing slash... yes
    checking whether malloc, realloc, calloc are POSIX compliant... yes
    checking for GNU libc compatible malloc... yes
    checking for a traditional japanese locale... ja_JP
    checking for a transitional chinese locale... zh_CN.GB18030
    checking for a french Unicode locale... fr_FR.UTF-8
    checking for mmap... yes
    checking for MAP_ANONYMOUS... yes
    checking whether memchr works... yes
    checking whether memrchr is declared... yes
    checking whether <limits.h> defines MIN and MAX... no
    checking whether <sys/param.h> defines MIN and MAX... yes
    checking whether time_t is signed... yes
    checking whether alarm is declared... yes
    checking for working mktime... yes
    checking whether <sys/select.h> is self-contained... yes
    checking for library containing setsockopt... none needed
    checking whether select supports a 0 argument... yes
    checking whether select detects invalid fds... yes
    checking for O_CLOEXEC... yes
    checking for promoted mode_t type... mode_t
    checking for library containing posix_spawn... none required
    checking for posix_spawn... yes
    checking whether posix_spawn works... yes
    checking whether posix_spawnattr_setschedpolicy is supported... yes
    checking whether posix_spawnattr_setschedparam is supported... yes
    checking for sigset_t... yes
    checking for SIGPIPE... yes
    checking whether we are using the GNU C Library >= 2.1 or uClibc... yes
    checking whether C symbols are prefixed with underscore at the linker level... no
    checking whether snprintf returns a byte count as in C99... yes
    checking whether snprintf is declared... yes
    checking whether strdup is declared... yes
    checking whether strerror(0) succeeds... yes
    checking for strerror_r with POSIX signature... no
    checking whether __xpg_strerror_r works... yes
    checking whether strerror_r is declared... (cached) yes
    checking whether strndup is declared... yes
    checking whether strnlen is declared... yes
    checking for struct tm.tm_gmtoff... yes
    checking whether strtok_r is declared... yes
    checking for struct timespec in <time.h>... yes
    checking whether clearerr_unlocked is declared... yes
    checking whether feof_unlocked is declared... yes
    checking whether ferror_unlocked is declared... yes
    checking whether fgets_unlocked is declared... yes
    checking whether fputc_unlocked is declared... yes
    checking whether fread_unlocked is declared... yes
    checking whether fwrite_unlocked is declared... yes
    checking whether getc_unlocked is declared... yes
    checking whether getchar_unlocked is declared... yes
    checking whether putchar_unlocked is declared... yes
    checking whether the utimes function works... yes
    checking for intmax_t... yes
    checking where to find the exponent in a 'double'... word 1 bit 20
    checking for snprintf... (cached) yes
    checking for strnlen... yes
    checking for wcslen... yes
    checking for wcsnlen... yes
    checking for mbrtowc... (cached) yes
    checking for wcrtomb... (cached) yes
    checking whether _snprintf is declared... no
    checking whether vsnprintf is declared... yes
    checking for alloca as a compiler built-in... yes
    checking whether btowc(0) is correct... yes
    checking whether btowc(EOF) is correct... yes
    checking for __builtin_expect... yes
    checking byteswap.h usability... yes
    checking byteswap.h presence... yes
    checking for byteswap.h... yes
    checking for library containing clock_gettime... none required
    checking for clock_gettime... yes
    checking for clock_settime... yes
    checking whether // is distinct from /... (cached) no
    checking whether dup2 works... yes
    checking for error_at_line... yes
    checking whether fcntl handles F_DUPFD correctly... yes
    checking whether fcntl understands F_DUPFD_CLOEXEC... needs runtime check
    checking whether fflush works on input streams... (cached) no
    checking for flexible array member... yes
    checking whether conversion from 'int' to 'long double' works... yes
    checking for working POSIX fnmatch... yes
    checking whether fopen recognizes a trailing slash... yes
    checking whether fpurge is declared... no
    checking for fseeko... (cached) yes
    checking for _fseeki64... no
    checking for ftello... (cached) yes
    checking whether ftello works... (cached) yes
    checking whether futimens works... yes
    checking how to do getaddrinfo, freeaddrinfo and getnameinfo... checking for library containing getaddrinfo... none required
    checking for getaddrinfo... yes
    checking whether gai_strerror is declared... yes
    checking whether gai_strerrorA is declared... no
    checking for gai_strerror with POSIX signature... yes
    checking for struct sockaddr.sa_len... no
    checking whether getaddrinfo is declared... yes
    checking whether freeaddrinfo is declared... yes
    checking whether getnameinfo is declared... yes
    checking for struct addrinfo... yes
    checking for working getdelim function... yes
    checking whether getdtablesize works... yes
    checking for getgroups... yes
    checking for working getgroups... yes
    checking whether getgroups handles negative values... yes
    checking for getline... yes
    checking for working getline function... yes
    checking for getpass without length limitations... yes
    checking whether program_invocation_name is declared... yes
    checking whether program_invocation_short_name is declared... yes
    checking whether __argv is declared... no
    checking whether gettimeofday clobbers localtime buffer... no
    checking for gettimeofday with POSIX signature... almost
    checking for group_member... yes
    checking for library containing gethostbyname... (cached) none required
    checking for gethostbyname... (cached) yes
    checking for library containing inet_ntop... (cached) none required
    checking whether inet_ntop is declared... (cached) yes
    checking whether the compiler generally respects inline... yes
    checking whether INT32_MAX < INTMAX_MAX... yes
    checking whether INT64_MAX == LONG_MAX... yes
    checking whether UINT32_MAX < UINTMAX_MAX... yes
    checking whether UINT64_MAX == ULONG_MAX... yes
    checking for ioctl... yes
    checking for ioctl with POSIX signature... no
    checking whether iswblank is declared... yes
    checking whether langinfo.h defines CODESET... yes
    checking whether langinfo.h defines T_FMT_AMPM... yes
    checking whether langinfo.h defines ALTMON_1... no
    checking whether langinfo.h defines ERA... yes
    checking whether langinfo.h defines YESEXPR... yes
    checking whether the compiler supports the __inline keyword... yes
    checking whether to use the included libunistring... yes
    checking whether link obeys POSIX... yes
    checking whether locale.h conforms to POSIX:2001... yes
    checking whether locale.h defines locale_t... yes
    checking whether struct lconv is properly defined... yes
    checking for pthread_rwlock_t... yes
    checking whether pthread_rwlock_rdlock prefers a writer to a reader... no
    checking whether lseek detects pipes... yes
    checking whether mbrtowc handles incomplete characters... yes
    checking whether mbrtowc works as well as mbtowc... yes
    checking whether mbrtowc handles a NULL pwc argument... yes
    checking whether mbrtowc handles a NULL string argument... yes
    checking whether mbrtowc has a correct return value... yes
    checking whether mbrtowc returns 0 when parsing a NUL character... yes
    checking whether mbrtowc works on empty input... no
    checking whether the C locale is free of encoding errors... no
    checking whether mbrtowc handles incomplete characters... (cached) yes
    checking whether mbrtowc works as well as mbtowc... (cached) yes
    checking whether mbsrtowcs works... yes
    checking for memrchr... yes
    checking whether mkdir handles trailing slash... yes
    checking whether mkdir handles trailing dot... yes
    checking for working mkstemp... yes
    checking for __mktime_internal... no
    checking for library containing nanosleep... none required
    checking for working nanosleep... no (mishandles large arguments)
    checking whether <netinet/in.h> is self-contained... yes
    checking whether YESEXPR works... yes
    checking whether open recognizes a trailing slash... yes
    checking whether posix_spawn_file_actions_addclose works... yes
    checking whether posix_spawn_file_actions_adddup2 works... yes
    checking whether posix_spawn_file_actions_addopen works... yes
    checking for raise... yes
    checking for sigprocmask... yes
    checking for rawmemchr... yes
    checking for working re_compile_pattern... yes
    checking whether select supports a 0 argument... (cached) yes
    checking whether select detects invalid fds... (cached) yes
    checking for library containing getservbyname... (cached) none required
    checking for getservbyname... (cached) yes
    checking for struct sigaction.sa_sigaction... yes
    checking for volatile sig_atomic_t... yes
    checking for sighandler_t... yes
    checking for sigprocmask... (cached) yes
    checking for SIZE_MAX... yes
    checking whether snprintf respects a size of 1... yes
    checking whether printf supports POSIX/XSI format strings with positions... yes
    checking for socklen_t... yes
    checking for posix_spawnattr_t... yes
    checking for posix_spawn_file_actions_t... yes
    checking for ssize_t... yes
    checking whether stat handles trailing slashes on files... yes
    checking for struct stat.st_atim.tv_nsec... yes
    checking whether struct stat.st_atim is of type struct timespec... yes
    checking for struct stat.st_birthtimespec.tv_nsec... no
    checking for struct stat.st_birthtimensec... no
    checking for struct stat.st_birthtim.tv_nsec... no
    checking for working stdalign.h... yes
    checking for good max_align_t... (cached) yes
    checking whether NULL can be used in arbitrary expressions... (cached) yes
    checking which flavor of printf attribute matches inttypes macros... system
    checking for strcasecmp... yes
    checking for strncasecmp... yes
    checking whether strncasecmp is declared... yes
    checking for strchrnul... yes
    checking whether strchrnul works... yes
    checking for working strerror function... yes
    checking for working strndup... yes
    checking for working strnlen... yes
    checking for strpbrk... yes
    checking for strtok_r... yes
    checking whether strtok_r works... yes
    checking for strtol... yes
    checking for strtoll... yes
    checking whether symlink handles trailing slash correctly... yes
    checking whether <sys/ioctl.h> declares ioctl... yes
    checking for nlink_t... (cached) yes
    checking whether localtime_r is declared... yes
    checking whether localtime_r is compatible with its POSIX signature... yes
    checking whether unlink honors trailing slashes... yes
    checking whether unlink of a parent directory fails as it should... guessing yes
    checking for ptrdiff_t... yes
    checking for vasprintf... yes
    checking for vsnprintf... yes
    checking whether snprintf respects a size of 1... (cached) yes
    checking whether printf supports POSIX/XSI format strings with positions... (cached) yes
    checking for waitid... yes
    checking whether wcrtomb return value is correct... yes
    checking whether iswcntrl works... (cached) yes
    checking for towlower... (cached) yes
    checking for wctype_t... (cached) yes
    checking for wctrans_t... (cached) yes
    checking whether wcwidth is declared... yes
    checking whether wcwidth works reasonably in UTF-8 locales... yes
    checking for getpagesize... yes
    checking for working mmap... yes
    checking for _LARGEFILE_SOURCE value needed for large files... (cached) no
    checking for strptime... (cached) yes
    checking for timegm... (cached) yes
    checking for vsnprintf... (cached) yes
    checking for vasprintf... (cached) yes
    checking for drand48... yes
    checking for pathconf... yes
    checking for strtoll... (cached) yes
    checking for usleep... yes
    checking for sigblock... yes
    checking for sigsetjmp... no
    checking for memrchr... (cached) yes
    checking for wcwidth... (cached) yes
    checking for mbtowc... yes
    checking for sleep... yes
    checking for symlink... (cached) yes
    checking for utime... (cached) yes
    checking for strlcpy... no
    checking for random... yes
    checking for fmemopen... yes
    checking for pkg-config... /bin/pkg-config
    checking pkg-config is at least version 0.9.0... yes
    checking for LIBPSL... no
    checking for library containing psl_builtin... no
    configure: WARNING: *** libpsl was not found. Fallback to builtin cookie checking.
    checking for ZLIB... yes
    checking for OPENSSL... yes
    configure: compiling in support for SSL via OpenSSL
    checking for RAND_egd... yes
    checking for INET6 protocol support... yes
    checking for struct sockaddr_in6... yes
    checking for struct sockaddr_storage... (cached) yes
    checking for struct sockaddr_in6.sin6_scope_id... yes
    configure: Enabling support for IPv6.
    checking for makeinfo... ${SHELL} /svr-setup/wget-1.20/build-aux/missing makeinfo
    checking for perl5... no
    checking for perl... /bin/perl
    checking for pod2man... /bin/pod2man
    checking for library containing idn2_lookup_u8... no
    configure: WARNING: *** LIBIDN2 was not found. You will not be able to use IDN2008 support
    checking uuid.h usability... no
    checking uuid.h presence... no
    checking for uuid.h... no
    checking uuid/uuid.h usability... yes
    checking uuid/uuid.h presence... yes
    checking for uuid/uuid.h... yes
    checking for library containing uuid_generate... -luuid
    checking for PCRE2... no
    checking pcre2.h usability... no
    checking pcre2.h presence... no
    checking for pcre2.h... no
    checking for PCRE... yes
    checking pcre.h usability... yes
    checking pcre.h presence... yes
    checking for pcre.h... yes
    checking for gpgme-config... no
    checking for METALINK... no
    checking for fsetxattr... yes
    checking that generated files are newer than configure... done
    configure: creating ./config.status
    config.status: creating Makefile
    config.status: creating src/Makefile
    config.status: creating doc/Makefile
    config.status: creating util/Makefile
    config.status: creating po/Makefile.in
    config.status: creating tests/Makefile
    config.status: creating fuzz/Makefile
    config.status: creating lib/Makefile
    config.status: creating testenv/Makefile
    config.status: creating tests/certs/interca.conf
    config.status: creating tests/certs/rootca.conf
    config.status: creating src/config.h
    config.status: src/config.h is unchanged
    config.status: executing depfiles commands
    config.status: executing po-directories commands
    config.status: creating po/POTFILES
    configure: Summary of build options:
      Version:           1.20
      Host OS:           linux-gnu
      Install prefix:    /usr/local
      Compiler:          ccache gcc -std=gnu11
      CFlags:            -I /usr/local/include -I /usr/include -DHAVE_LIBSSL   -DNDEBUG -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic
      LDFlags:
      Libs:              -L /usr/local/lib -lpcre -luuid -L /usr/lib64 -lssl -lcrypto -lz
      SSL:               openssl
      Zlib:              yes
      PSL:               no
      PCRE:              yes, via libpcre
      Digest:            yes
      NTLM:              yes
      OPIE:              yes
      POSIX xattr:       yes
      Debugging:         yes
      Assertions:        no
      Valgrind:          Valgrind testing not enabled
      Metalink:          no
      Resolver:          libc, --bind-dns-address and --dns-servers not available
      GPGME:             no
      IRI:               no
      Fuzzing build:     no,
    make  all-recursive
    Making all in lib
      GEN      alloca.h
      GEN      fcntl.h
      GEN      arpa/inet.h
      GEN      inttypes.h
      GEN      langinfo.h
      GEN      limits.h
      GEN      locale.h
      GEN      netdb.h
      GEN      signal.h
      GEN      spawn.h
      GEN      stdint.h
      GEN      stdio.h
      GEN      stdlib.h
      GEN      string.h
      GEN      strings.h
      GEN      sys/file.h
      GEN      sys/ioctl.h
      GEN      sys/select.h
      GEN      sys/socket.h
      GEN      sys/stat.h
      GEN      sys/time.h
      GEN      sys/types.h
      GEN      sys/uio.h
      GEN      sys/wait.h
      GEN      time.h
      GEN      unicase.h
      GEN      unicase/special-casing.h
      GEN      unictype.h
      GEN      uninorm.h
      GEN      unistd.h
      GEN      unistr.h
      GEN      unitypes.h
      GEN      uniwidth.h
      GEN      wchar.h
      GEN      wctype.h
    make  all-recursive
    make[3]: Entering directory `/svr-setup/wget-1.20/lib'
    make[4]: Entering directory `/svr-setup/wget-1.20/lib'
      CC       base32.o
      CC       binary-io.o
      CC       c-ctype.o
      CC       c-strcasecmp.o
      CC       c-strncasecmp.o
      CC       c-strcasestr.o
      CC       cloexec.o
      CC       af_alg.o
      CC       md2.o
      CC       md4.o
      CC       md5.o
      CC       sha1.o
      CC       sha256.o
      CC       sha512.o
      CC       dirname.o
      CC       basename.o
      CC       dirname-lgpl.o
      CC       basename-lgpl.o
      CC       stripslash.o
      CC       exitfail.o
      CC       fatal-signal.o
      CC       fd-hook.o
      CC       fd-safer-flag.o
      CC       dup-safer-flag.o
      CC       freading.o
      CC       getprogname.o
      CC       gettime.o
      CC       hard-locale.o
      CC       localcharset.o
      CC       glthread/lock.o
      CC       malloca.o
      CC       mbchar.o
      CC       mbiter.o
      CC       pipe2.o
      CC       pipe2-safer.o
      CC       quotearg.o
      CC       sig-handler.o
      CC       sockets.o
      CC       spawn-pipe.o
      CC       stat-time.o
      CC       strnlen1.o
      CC       sys_socket.o
      CC       tempname.o
      CC       glthread/threadlib.o
      CC       timespec.o
      CC       tmpdir.o
      CC       u64.o
      CC       unicase/cased.o
      CC       unicase/empty-prefix-context.o
      CC       unicase/empty-suffix-context.o
      CC       unicase/ignorable.o
      CC       unicase/special-casing.o
      CC       unicase/tolower.o
      CC       unicase/u8-casemap.o
      CC       unicase/u8-tolower.o
      CC       unictype/combiningclass.o
      CC       unictype/pr_soft_dotted.o
      CC       uninorm/decompose-internal.o
      CC       uninorm/u8-normalize.o
      CC       unistd.o
      CC       dup-safer.o
      CC       fd-safer.o
      CC       pipe-safer.o
      CC       unistr/u8-cpy.o
      CC       unistr/u8-mbtouc-unsafe.o
      CC       unistr/u8-mbtouc-unsafe-aux.o
      CC       unistr/u8-strlen.o
      CC       unistr/u8-uctomb.o
      CC       unistr/u8-uctomb-aux.o
      CC       uniwidth/width.o
      CC       utimens.o
      CC       wait-process.o
      CC       wctype-h.o
      CC       xmalloc.o
      CC       xalloc-die.o
      CC       xsize.o
      CC       xstrndup.o
      CC       asnprintf.o
      CC       fcntl.o
      CC       fflush.o
      CC       fpurge.o
      CC       fseek.o
      CC       fseeko.o
      CC       ioctl.o
      CC       localtime-buffer.o
      CC       mbrtowc.o
      CC       mktime.o
      CC       nanosleep.o
      CC       nl_langinfo.o
      CC       printf-args.o
      CC       printf-parse.o
      CC       strerror_r.o
      CC       vasnprintf.o
      CC       xmemdup0.o
      AR       libgnu.a
    make[4]: Leaving directory `/svr-setup/wget-1.20/lib'
    make[3]: Leaving directory `/svr-setup/wget-1.20/lib'
    Making all in src
    make[2]: Entering directory `/svr-setup/wget-1.20/src'
    make  all-am
    make[3]: Entering directory `/svr-setup/wget-1.20/src'
    if test -n ""; then cp "./build_info.c.in" .; fi
    /bin/perl "../build-aux/build_info.pl" \
        "../src/build_info.c"
      CC       connect.o
      CC       convert.o
      CC       cookies.o
      CC       ftp.o
    if test -n ""; then rm -f build_info.c.in; fi
      CC       css_.o
      CC       css-url.o
      CC       ftp-basic.o
      CC       ftp-ls.o
      CC       hash.o
      CC       host.o
      CC       hsts.o
      CC       html-parse.o
      CC       html-url.o
      CC       http.o
      CC       init.o
    hsts.c: In function 'hsts_store_save':
    hsts.c:577:21: warning: ignoring return value of 'ftruncate', declared with attribute warn_unused_result [-Wunused-result]
               ftruncate (fd, 0);
      CC       log.o
      CC       main.o
      CC       netrc.o
      CC       progress.o
      CC       ptimer.o
      CC       recur.o
      CC       res.o
      CC       retr.o
      CC       spider.o
      CC       url.o
      CC       warc.o
      CC       xattr.o
      CC       utils.o
      CC       exits.o
      CC       build_info.o
    echo '/* version.c */' > version.c
    echo '/* Autogenerated by Makefile - DO NOT EDIT */' >> version.c
      CC       ftp-opie.o
    echo '' >> version.c
    echo '#include "version.h"' >> version.c
    echo 'const char *version_string = "1.20";' >> version.c
      CC       openssl.o
    echo 'const char *compilation_string = "'ccache gcc -std=gnu11 -DHAVE_CONFIG_H -DSYSTEM_WGETRC=\"/usr/local/etc/wgetrc\" -DLOCALEDIR=\"/usr/local/share/locale\" -I.  -I../lib -I../lib   -I /usr/local/include -I /usr/include -DHAVE_LIBSSL   -DNDEBUG -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic'";' \
        | sed -e 's/[\\"]/\\&/g' -e 's/\\"/"/' -e 's/\\";$/";/' >> version.c
      CC       http-ntlm.o
    echo 'const char *link_string = "'ccache gcc -std=gnu11  -I /usr/local/include -I /usr/include -DHAVE_LIBSSL   -DNDEBUG -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic \
      -L /usr/local/lib -lpcre -luuid -L /usr/lib64 -lssl -lcrypto -lz    ftp-opie.o openssl.o http-ntlm.o ../lib/libgnu.a              '";' \
      CC       version.o
      CCLD     wget
    make[3]: Leaving directory `/svr-setup/wget-1.20/src'
    make[2]: Leaving directory `/svr-setup/wget-1.20/src'
    Making all in doc
    make[2]: Entering directory `/svr-setup/wget-1.20/doc'
    ./texi2pod.pl -D VERSION="1.20" ./wget.texi wget.pod
    /bin/pod2man --center="GNU Wget" --release="GNU Wget 1.20" --utf8 wget.pod > wget.1 || \
    /bin/pod2man --center="GNU Wget" --release="GNU Wget 1.20" wget.pod > wget.1
    make[2]: Leaving directory `/svr-setup/wget-1.20/doc'
    Making all in po
    make[2]: Entering directory `/svr-setup/wget-1.20/po'
    make[2]: Leaving directory `/svr-setup/wget-1.20/po'
    Making all in util
    make[2]: Entering directory `/svr-setup/wget-1.20/util'
    make[2]: Nothing to be done for `all'.
    make[2]: Leaving directory `/svr-setup/wget-1.20/util'
    Making all in fuzz
    make[2]: Entering directory `/svr-setup/wget-1.20/fuzz'
    make[2]: Leaving directory `/svr-setup/wget-1.20/fuzz'
    Making all in tests
    make[2]: Entering directory `/svr-setup/wget-1.20/tests'
    make[2]: Leaving directory `/svr-setup/wget-1.20/tests'
    Making all in testenv
    make[2]: Entering directory `/svr-setup/wget-1.20/testenv'
    make[2]: Leaving directory `/svr-setup/wget-1.20/testenv'
    make[2]: Entering directory `/svr-setup/wget-1.20'
    make[2]: Nothing to be done for `all-am'.
    make[2]: Leaving directory `/svr-setup/wget-1.20'
    make  install-recursive
    Making install in lib
    make[5]: Entering directory `/svr-setup/wget-1.20/lib'
    make[5]: Nothing to be done for `install-exec-am'.
    make[5]: Nothing to be done for `install-data-am'.
    make[5]: Leaving directory `/svr-setup/wget-1.20/lib'
    Making install in src
     /bin/mkdir -p '/usr/local/bin'
      /bin/install -c wget '/usr/local/bin'
    make[3]: Nothing to be done for `install-data-am'.
    Making install in doc
    make[3]: Entering directory `/svr-setup/wget-1.20/doc'
    make[3]: Nothing to be done for `install-exec-am'.
    /bin/sh /svr-setup/wget-1.20/build-aux/install-sh -d /usr/local/etc
    /bin/sh /svr-setup/wget-1.20/build-aux/install-sh -d /usr/local/share/man/man1
    /bin/install -c -m 644 wget.1 /usr/local/share/man/man1/wget.1
     /bin/mkdir -p '/usr/local/share/info'
     /bin/install -c -m 644 ./wget.info '/usr/local/share/info'
     install-info --info-dir='/usr/local/share/info' '/usr/local/share/info/wget.info'
    make[3]: Leaving directory `/svr-setup/wget-1.20/doc'
    Making install in po
    /bin/mkdir -p /usr/local/share
    installing be.gmo as /usr/local/share/locale/be/LC_MESSAGES/wget.mo
    installing bg.gmo as /usr/local/share/locale/bg/LC_MESSAGES/wget.mo
    installing ca.gmo as /usr/local/share/locale/ca/LC_MESSAGES/wget.mo
    installing cs.gmo as /usr/local/share/locale/cs/LC_MESSAGES/wget.mo
    installing da.gmo as /usr/local/share/locale/da/LC_MESSAGES/wget.mo
    installing de.gmo as /usr/local/share/locale/de/LC_MESSAGES/wget.mo
    installing el.gmo as /usr/local/share/locale/el/LC_MESSAGES/wget.mo
    installing en_GB.gmo as /usr/local/share/locale/en_GB/LC_MESSAGES/wget.mo
    installing eo.gmo as /usr/local/share/locale/eo/LC_MESSAGES/wget.mo
    installing es.gmo as /usr/local/share/locale/es/LC_MESSAGES/wget.mo
    installing et.gmo as /usr/local/share/locale/et/LC_MESSAGES/wget.mo
    installing eu.gmo as /usr/local/share/locale/eu/LC_MESSAGES/wget.mo
    installing fi.gmo as /usr/local/share/locale/fi/LC_MESSAGES/wget.mo
    installing fr.gmo as /usr/local/share/locale/fr/LC_MESSAGES/wget.mo
    installing ga.gmo as /usr/local/share/locale/ga/LC_MESSAGES/wget.mo
    installing gl.gmo as /usr/local/share/locale/gl/LC_MESSAGES/wget.mo
    installing he.gmo as /usr/local/share/locale/he/LC_MESSAGES/wget.mo
    installing hr.gmo as /usr/local/share/locale/hr/LC_MESSAGES/wget.mo
    installing hu.gmo as /usr/local/share/locale/hu/LC_MESSAGES/wget.mo
    installing id.gmo as /usr/local/share/locale/id/LC_MESSAGES/wget.mo
    installing it.gmo as /usr/local/share/locale/it/LC_MESSAGES/wget.mo
    installing ja.gmo as /usr/local/share/locale/ja/LC_MESSAGES/wget.mo
    installing lt.gmo as /usr/local/share/locale/lt/LC_MESSAGES/wget.mo
    installing nb.gmo as /usr/local/share/locale/nb/LC_MESSAGES/wget.mo
    installing nl.gmo as /usr/local/share/locale/nl/LC_MESSAGES/wget.mo
    installing pl.gmo as /usr/local/share/locale/pl/LC_MESSAGES/wget.mo
    installing pt.gmo as /usr/local/share/locale/pt/LC_MESSAGES/wget.mo
    installing pt_BR.gmo as /usr/local/share/locale/pt_BR/LC_MESSAGES/wget.mo
    installing ro.gmo as /usr/local/share/locale/ro/LC_MESSAGES/wget.mo
    installing ru.gmo as /usr/local/share/locale/ru/LC_MESSAGES/wget.mo
    installing sk.gmo as /usr/local/share/locale/sk/LC_MESSAGES/wget.mo
    installing sl.gmo as /usr/local/share/locale/sl/LC_MESSAGES/wget.mo
    installing sr.gmo as /usr/local/share/locale/sr/LC_MESSAGES/wget.mo
    installing sv.gmo as /usr/local/share/locale/sv/LC_MESSAGES/wget.mo
    installing tr.gmo as /usr/local/share/locale/tr/LC_MESSAGES/wget.mo
    installing uk.gmo as /usr/local/share/locale/uk/LC_MESSAGES/wget.mo
    installing vi.gmo as /usr/local/share/locale/vi/LC_MESSAGES/wget.mo
    installing zh_CN.gmo as /usr/local/share/locale/zh_CN/LC_MESSAGES/wget.mo
    installing zh_TW.gmo as /usr/local/share/locale/zh_TW/LC_MESSAGES/wget.mo
    if test "wget" = "gettext-tools"; then \
      /bin/mkdir -p /usr/local/share/gettext/po; \
      for file in Makefile.in.in remove-potcdate.sin quot.sed boldquot.sed en@quot.header en@boldquot.header insert-header.sin Rules-quot   Makevars.template; do \
        /bin/install -c -m 644 ./$file \
                        /usr/local/share/gettext/po/$file; \
      done; \
      for file in Makevars; do \
        rm -f /usr/local/share/gettext/po/$file; \
      done; \
    else \
    fi
    Making install in util
    make[3]: Entering directory `/svr-setup/wget-1.20/util'
    make[3]: Leaving directory `/svr-setup/wget-1.20/util'
    Making install in fuzz
    make[3]: Entering directory `/svr-setup/wget-1.20/fuzz'
    make[3]: Leaving directory `/svr-setup/wget-1.20/fuzz'
    Making install in tests
    make[3]: Entering directory `/svr-setup/wget-1.20/tests'
    make[3]: Leaving directory `/svr-setup/wget-1.20/tests'
    Making install in testenv
    make[3]: Entering directory `/svr-setup/wget-1.20/testenv'
    make[3]: Leaving directory `/svr-setup/wget-1.20/testenv'
    make[3]: Entering directory `/svr-setup/wget-1.20'
    make[3]: Leaving directory `/svr-setup/wget-1.20'
    ldconfig -p | grep libpcre.so.1
            libpcre.so.1 (libc6,x86-64) => /usr/local/lib/libpcre.so.1
            libpcre.so.1 (libc6,x86-64) => /lib64/libpcre.so.1
    ldd alias wget='/usr/local/bin/wget'
            /usr/local/bin/wget
    alias:
    ldd: ./alias: No such file or directory
    wget='/usr/local/bin/wget':
    ldd: wget='/usr/local/bin/wget': No such file or directory
    /usr/local/bin/wget:
            linux-vdso.so.1 =>  (0x00007ffc393bb000)
            libpcre.so.1 => /usr/local/lib/libpcre.so.1 (0x00007f61c9968000)
            libuuid.so.1 => /lib64/libuuid.so.1 (0x00007f61c9763000)
            libssl.so.10 => /lib64/libssl.so.10 (0x00007f61c94f1000)
            libcrypto.so.10 => /lib64/libcrypto.so.10 (0x00007f61c9090000)
            libz.so.1 => /lib64/libz.so.1 (0x00007f61c8e7a000)
            libc.so.6 => /lib64/libc.so.6 (0x00007f61c8aad000)
            libpthread.so.0 => /lib64/libpthread.so.0 (0x00007f61c8891000)
            /lib64/ld-linux-x86-64.so.2 (0x00007f61c9bd7000)
            libgssapi_krb5.so.2 => /lib64/libgssapi_krb5.so.2 (0x00007f61c8644000)
            libkrb5.so.3 => /lib64/libkrb5.so.3 (0x00007f61c835b000)
            libcom_err.so.2 => /lib64/libcom_err.so.2 (0x00007f61c8157000)
            libk5crypto.so.3 => /lib64/libk5crypto.so.3 (0x00007f61c7f3c000)
            libdl.so.2 => /lib64/libdl.so.2 (0x00007f61c7d38000)
            libkrb5support.so.0 => /lib64/libkrb5support.so.0 (0x00007f61c7b29000)
            libkeyutils.so.1 => /lib64/libkeyutils.so.1 (0x00007f61c7925000)
            libresolv.so.2 => /lib64/libresolv.so.2 (0x00007f61c770c000)
            libselinux.so.1 => /lib64/libselinux.so.1 (0x00007f61c74e5000)
    wget -V
    GNU Wget 1.20 built on linux-gnu.
    -cares +digest -gpgme +https +ipv6 -iri +large-file -metalink +nls
    +ntlm +opie -psl +ssl/openssl
    Wgetrc:
        /usr/local/etc/wgetrc (system)
    Locale:
    Compile:
        -DSYSTEM_WGETRC="/usr/local/etc/wgetrc"
        -DLOCALEDIR="/usr/local/share/locale" -I. -I../lib -I../lib -I
    Link:
        -grecord-gcc-switches -m64 -mtune=generic -L /usr/local/lib -lpcre
    Copyright (C) 2015 Free Software Foundation, Inc.
    License GPLv3+: GNU GPL version 3 or later
    <http://www.gnu.org/licenses/gpl.html>.
    This is free software: you are free to change and redistribute it.
    There is NO WARRANTY, to the extent permitted by law.
    Originally written by Hrvoje Niksic <hniksic@xemacs.org>.
    Please send bug reports and questions to <bug-wget@gnu.org>.
    wget 1.20 installed at /usr/local/bin/wget
    Total wget Install Time: 22.760303987 seconds
    60,082
    12,584
    9:19 AM
    looks good wget 1.20 installed :)
  3. ENF
    ENF SquareEnix (Eng.)
    20
    Tokyo, Japan
    8:19 AM
    10.6.x
    Which step was the final solution to make it go?
    Here's some feedback from my system:
    OUTPUT: ls -lah /usr/local/lib
    [root@hyperion ~]# ls -lah /usr/local/lib
    total 64M
    drwxr-xr-x.  5 root root 4.0K Oct 18 13:10 .
    drwxr-xr-x. 19 root root 4.0K Jul  7 19:46 ..
    -rw-r--r--   1 root root 4.0M May 10  2018 libcrypto.a
    -rw-r--r--   1 root root 2.1M Apr  2  2018 libpcre16.a
    -rwxr-xr-x   1 root root  955 Apr  2  2018 libpcre16.la
    lrwxrwxrwx   1 root root   19 Apr  2  2018 libpcre16.so -> libpcre16.so.0.2.10
    lrwxrwxrwx   1 root root   19 Apr  2  2018 libpcre16.so.0 -> libpcre16.so.0.2.10
    -rwxr-xr-x   1 root root 1.4M Apr  2  2018 libpcre16.so.0.2.10
    -rwxr-xr-x   1 root root 1.4M Mar  3  2017 libpcre16.so.0.2.8
    -rwxr-xr-x   1 root root 1.4M Nov  8  2017 libpcre16.so.0.2.9
    -rw-r--r--   1 root root 2.1M Apr  2  2018 libpcre32.a
    -rwxr-xr-x   1 root root  955 Apr  2  2018 libpcre32.la
    lrwxrwxrwx   1 root root   19 Apr  2  2018 libpcre32.so -> libpcre32.so.0.0.10
    lrwxrwxrwx   1 root root   19 Apr  2  2018 libpcre32.so.0 -> libpcre32.so.0.0.10
    -rwxr-xr-x   1 root root 1.3M Apr  2  2018 libpcre32.so.0.0.10
    -rwxr-xr-x   1 root root 1.3M Mar  3  2017 libpcre32.so.0.0.8
    -rwxr-xr-x   1 root root 1.3M Nov  8  2017 libpcre32.so.0.0.9
    -rw-r--r--   1 root root 2.2M Apr  2  2018 libpcre.a
    -rw-r--r--   1 root root  47K Apr  2  2018 libpcrecpp.a
    -rwxr-xr-x   1 root root  986 Apr  2  2018 libpcrecpp.la
    lrwxrwxrwx   1 root root   19 Apr  2  2018 libpcrecpp.so -> libpcrecpp.so.0.0.1
    lrwxrwxrwx   1 root root   19 Apr  2  2018 libpcrecpp.so.0 -> libpcrecpp.so.0.0.1
    -rwxr-xr-x   1 root root  46K Apr  2  2018 libpcrecpp.so.0.0.1
    -rwxr-xr-x   1 root root  941 Apr  2  2018 libpcre.la
    -rw-r--r--   1 root root  24K Apr  2  2018 libpcreposix.a
    -rwxr-xr-x   1 root root 1000 Apr  2  2018 libpcreposix.la
    lrwxrwxrwx   1 root root   21 Apr  2  2018 libpcreposix.so -> libpcreposix.so.0.0.6
    lrwxrwxrwx   1 root root   21 Apr  2  2018 libpcreposix.so.0 -> libpcreposix.so.0.0.6
    -rwxr-xr-x   1 root root  23K Mar  3  2017 libpcreposix.so.0.0.4
    -rwxr-xr-x   1 root root  23K Nov  8  2017 libpcreposix.so.0.0.5
    -rwxr-xr-x   1 root root  23K Apr  2  2018 libpcreposix.so.0.0.6
    lrwxrwxrwx   1 root root   17 Apr  2  2018 libpcre.so -> libpcre.so.1.2.10
    lrwxrwxrwx   1 root root   17 Apr  2  2018 libpcre.so.1 -> libpcre.so.1.2.10
    -rwxr-xr-x   1 root root 1.5M Apr  2  2018 libpcre.so.1.2.10
    -rwxr-xr-x   1 root root 1.5M Mar  3  2017 libpcre.so.1.2.8
    -rwxr-xr-x   1 root root 1.5M Nov  8  2017 libpcre.so.1.2.9
    -rwxr-xr-x   1 root root  40M Oct 18 13:10 libphp7.so
    -rw-r--r--   1 root root 712K May 10  2018 libssl.a
    drwxr-xr-x  15 root root 4.0K Jul 27  2017 php
    -rw-r--r--   1 root root  69K Oct 18 13:01 php.ini
    -rw-r--r--   1 root root  72K Mar  3  2017 php.ini-oldversion_030317-003520
    -rw-r--r--   1 root root  69K Sep  4  2017 php.ini-oldversion_040917-135145
    -rw-r--r--   1 root root  69K Nov  8  2017 php.ini-oldversion_081117-155710
    -rw-r--r--   1 root root  69K Dec 17  2017 php.ini-oldversion_171217-155943
    -rw-r--r--   1 root root  69K Oct 18 13:01 php.ini-oldversion_181018-125320
    -rw-r--r--   1 root root  69K Mar 21  2017 php.ini-oldversion_210317-140617
    -rw-r--r--   1 root root  69K Jul 26 12:28 php.ini-oldversion_260718-121753
    -rw-r--r--   1 root root  69K Jul 27  2017 php.ini-oldversion_270717-031155
    drwxr-xr-x   2 root root 4.0K May 10  2018 pkgconfig
    drwxr-xr-x   4 root root 4.0K Mar  3  2017 sproxy
    [root@hyperion ~]#
    GREP from May 10 - Reflecting from Listing Above
    [root@hyperion ~]# history | grep '10.05.18'
       19  [10.05.18] 13:53:14   centmin
       20  [10.05.18] 13:53:31   cd /usr/local/src/centminmod
       21  [10.05.18] 13:53:33   centmin
       22  [10.05.18] 14:53:04   yum update --disableplugin=priorities --enablerepo=remi
       23  [10.05.18] 15:09:55   centmin
       24  [10.05.18] 15:13:37   logout
      197  [17.12.18] 13:18:06   history | grep '10.05.18'
    [root@hyperion ~]#
    Other Output:
    [root@hyperion ~]# cat /etc/centminmod/custom_config.inc
    MARCH_TARGETNATIVE='n'
    [root@hyperion ~]#
    [root@hyperion ~]# updatedb
    [root@hyperion ~]# locate libssl.so
    /opt/libressl/lib/libssl.so
    /opt/libressl/lib/libssl.so.39
    /opt/libressl/lib/libssl.so.39.0.0
    /opt/libressl/lib/libssl.so.43
    /opt/libressl/lib/libssl.so.43.0.2
    /opt/libressl/lib/libssl.so.44
    /opt/libressl/lib/libssl.so.44.0.1
    /opt/openssl/lib/libssl.so
    /opt/openssl/lib/libssl.so.1.1
    /usr/lib64/.libssl.so.1.0.2k.hmac
    /usr/lib64/.libssl.so.10.hmac
    /usr/lib64/libssl.so
    /usr/lib64/libssl.so.1.0.2k
    /usr/lib64/libssl.so.10
    [root@hyperion ~]#
    60,082
    12,584
    9:19 AM
    1. cmupdate for 123.09beta01 code updates
    2. centmin.sh menu option 4 to remove /usr/local/lib/ libssl libs etc
    3. re-run centmin.sh to update wget 1.20
  5. ENF
    20
    Tokyo, Japan
    8:19 AM
    10.6.x
    Ah.... just saw that and now we're good...
    wget -V
    Wgetrc:
    Locale:
    Compile:
    Link:
    Thanks so much! :)
    60,082
    12,584
    9:19 AM
    excellent :D
