Beta Branch wget 1.20 default for 123.09beta01
Discussion in 'Centmin Mod Github Commits' started by eva2000, Dec 4, 2018.
    46,583
    10,580
    6:58 AM
  2. Sunka
    Sunka Well-Known Member
    1,145
    316
    Pula, Croatia
    10:58 PM
    Nginx 1.17.9
    MariaDB 10.3.22
    Still can not upgrade
    Look here for upgrade error log
    46,583
    10,580
    6:58 AM
    Seems to be the same error that you got for wget 1.19.5 too. Strange I haven't experienced this with wget 1.19.5 or 1.20 on my servers. For now as before to prevent the wget update prompt, set WGET_VERSION='1.19.4' in persistent config file /etc/centminmod/custom_config.inc for now.
    /svr-setup/wget-1.20/src/openssl.c:92: undefined reference to `RAND_egd'
    openssl.o: In function `ssl_init':
    /svr-setup/wget-1.20/src/openssl.c:207: undefined reference to `SSL_library_init'
    /svr-setup/wget-1.20/src/openssl.c:208: undefined reference to `SSL_load_error_strings'
    /svr-setup/wget-1.20/src/openssl.c:211: undefined reference to `OPENSSL_add_all_algorithms_noconf'
    /svr-setup/wget-1.20/src/openssl.c:212: undefined reference to `SSL_library_init'
    /svr-setup/wget-1.20/src/openssl.c:225: undefined reference to `SSLv3_client_method'
    /svr-setup/wget-1.20/src/openssl.c:231: undefined reference to `SSLv23_client_method'
    openssl.o: In function `ssl_connect_wget':
    /svr-setup/wget-1.20/src/openssl.c:650: undefined reference to `SSL_state'
    openssl.o: In function `ssl_check_certificate':
    /svr-setup/wget-1.20/src/openssl.c:918: undefined reference to `sk_num'
    /svr-setup/wget-1.20/src/openssl.c:922: undefined reference to `sk_value'
    /svr-setup/wget-1.20/src/openssl.c:963: undefined reference to `sk_pop_free'
    collect2: error: ld returned 1 exit status
    46,583
    10,580
    6:58 AM
    @Sunka also what's contents of your persistent config file at /etc/centminmod/custom_config.inc ?
    46,583
    10,580
    6:58 AM
  6. Sunka
    1,145
    316
    Pula, Croatia
    10:58 PM
    Nginx 1.17.9
    MariaDB 10.3.22
    Here it is:
    # cat /etc/centminmod/custom_config.inc
    NGINX_LIBBROTLI=y # Brotly extension
    NGXDYNAMIC_BROTLI=y # Brotly dynamic module extension
    PHP_MEMCACHE=n # memcache PHP extension
    PHP_MEMCACHED=n # memcached PHP extension
    PHP_PGO='y' # PGO Let It Go - Profile Guided Optimizations for PHP 7
    PHPPGO_INDEXPATH='/home/nginx/domains/pijanitvor.com/public/index.php' # path for PGO training
    AUDITD_ENABLE='y' # Auditd skripta
    RCLONE_ENABLE='y' # Rclone skripta
    NGINX_DEVTOOLSETGCC='y' # umjesto clang ide gcc kompilacija kod nginx
    #DEVTOOLSETEIGHT='y' # ide 8.x verzija gcc kompilacije umjesto defaultne 5.x ili 6.x ili 7.x
    CRYPTO_DEVTOOLSETGCC='y' # newer Intel GCC
    #NGINX_HPACK='y' # enabling HPACK for Nginx
    NGINX_DYNAMICTLS='y' # add Nginx Dynamic TLS Cloudflare Patch - http://bit.ly/2EYzhk7
    NGINXPATCH='y' # add Nginx Dynamic TLS Cloudflare Patch - http://bit.ly/2EYzhk7
    NGINX_GEOIPTWOLITE='y' # GeoIP2 Lite nginx module
    NGXDYNAMIC_GEOIPTWOLITE='y' # GeoIP2 Lite nginx module
    ENABLE_MARIADBTENTWOUPGRADE='y' # enabling upgrade MariaDB from 10.1.x to 10.2.x
    PHP_ARGON='y' # enabling argon for php 7.2.x, needed for xf 2.1 - delete for php 7.3
    OK
    wget_source_install_051218-211913
    strace_wget_make_install and strace_wget_make are here for download at Megaupload:
    46,583
    10,580
    6:58 AM
    Still not able to see fully where your problem is as wget should be compiled against system OpenSSL as intended and works for me on all my servers.
    You can try this
    1. in persistent config file remove entry for
    2. if you have done yum updates and there is kernel update, reboot server
    3. run centmin.sh menu option 4 to recompile nginx without CRYPTO_DEVTOOLSETGCC flag
    4. run yum reinstall for openssl and openssl-devel system packages
    yum reinstall openssl openssl-devel
    5. run centmin.sh to trigger the wget update and see what happens
  8. Sunka
    1,145
    316
    Pula, Croatia
    10:58 PM
    Nginx 1.17.9
    MariaDB 10.3.22
    same thing
    [Bash] [root@upcloud ~]# yum reinstall openssl openssl-devel Loaded plugins: fastestmi - Pastebin.com
  9. ENF
    ENF Premium Member Premium Member
    12
    Tokyo, Japan
    5:58 AM
    1.15.7
    I haven't had time to diagnosis this issue, but we have the same thing happening on one server.
    wget -V
    GNU Wget 1.19.4 built on linux-gnu.
    -cares +digest -gpgme +https +ipv6 -iri +large-file -metalink +nls
    +ntlm +opie -psl +ssl/openssl
    Wgetrc:
        /usr/local/etc/wgetrc (system)
    Locale:
        /usr/local/share/locale
    Compile:
        ccache gcc -DHAVE_CONFIG_H -DSYSTEM_WGETRC="/usr/local/etc/wgetrc"
        -DLOCALEDIR="/usr/local/share/locale" -I. -I../lib -I../lib -I
        /usr/local/include -DHAVE_LIBSSL -DNDEBUG -O2 -g -pipe -Wall
        -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong
        --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic
    Link:
        ccache gcc -I /usr/local/include -DHAVE_LIBSSL -DNDEBUG -O2 -g
        -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions
        -fstack-protector-strong --param=ssp-buffer-size=4
        -grecord-gcc-switches -m64 -mtune=generic -L /usr/local/lib -lpcre
        -lssl -lcrypto -lz ftp-opie.o openssl.o http-ntlm.o ../lib/libgnu.a
    Copyright (C) 2015 Free Software Foundation, Inc.
    License GPLv3+: GNU GPL version 3 or later
    <http://www.gnu.org/licenses/gpl.html>.
    This is free software: you are free to change and redistribute it.
    There is NO WARRANTY, to the extent permitted by law.
    Originally written by Hrvoje Niksic <hniksic@xemacs.org>.
    Please send bug reports and questions to <bug-wget@gnu.org>.
    wget 1.20 failed to update, still using system wget
    install log: /root/centminlogs/wget_source_install_141218-174703.log
    Total wget Install Time: 28.769028211 seconds
    Sample Grab from log file:
    make[2]: *** [wget] Error 1
    make[2]: Leaving directory `/svr-setup/wget-1.20/src'
    make[1]: *** [install-recursive] Error 1
    make[1]: Leaving directory `/svr-setup/wget-1.20'
    make: *** [install] Error 2
    Will have more time to circle back to this and take a deeper look.
    46,583
    10,580
    6:58 AM
    interesting your problem is with 1.20 but fine with 1.19.4. While @Sunka problem is with 1.19.5 but fine with 1.19.4.
    @ENF which OS centos 6.10 or 7.5/7.6 ? who is web host and plan you're on ? can you provide the same info asked at Beta Branch - wget 1.19.5 default in 123.09beta01
    contents of persistent config file ?
    and output for
    updatedb
    locate libssl.so
    for now you can prevent the wget 1.20 update attempts by setting previous version that worked in persistent config file at /etc/centminmod/custom_config.inc
    WGET_VERSION='1.19.3'
    46,583
    10,580
    6:58 AM
    also @ENF and @Sunka what's output for this command
    ls -lah /usr/local/lib
    example output
    total 33M
    drwxr-xr-x.  5 root root 4.0K Aug 22 23:22 .
    drwxr-xr-x. 19 root root 4.0K Dec 12 13:14 ..
    -rw-r--r--   1 root root 2.1M Aug 22 23:01 libpcre16.a
    -rwxr-xr-x   1 root root  955 Aug 22 23:01 libpcre16.la
    lrwxrwxrwx   1 root root   19 Aug 22 23:01 libpcre16.so -> libpcre16.so.0.2.10
    lrwxrwxrwx   1 root root   19 Aug 22 23:01 libpcre16.so.0 -> libpcre16.so.0.2.10
    -rwxr-xr-x   1 root root 1.4M Aug 22 23:01 libpcre16.so.0.2.10
    -rw-r--r--   1 root root 2.1M Aug 22 23:01 libpcre32.a
    -rwxr-xr-x   1 root root  955 Aug 22 23:01 libpcre32.la
    lrwxrwxrwx   1 root root   19 Aug 22 23:01 libpcre32.so -> libpcre32.so.0.0.10
    lrwxrwxrwx   1 root root   19 Aug 22 23:01 libpcre32.so.0 -> libpcre32.so.0.0.10
    -rwxr-xr-x   1 root root 1.3M Aug 22 23:01 libpcre32.so.0.0.10
    -rw-r--r--   1 root root 2.2M Aug 22 23:01 libpcre.a
    -rw-r--r--   1 root root  46K Aug 22 23:01 libpcrecpp.a
    -rwxr-xr-x   1 root root  986 Aug 22 23:01 libpcrecpp.la
    lrwxrwxrwx   1 root root   19 Aug 22 23:01 libpcrecpp.so -> libpcrecpp.so.0.0.1
    lrwxrwxrwx   1 root root   19 Aug 22 23:01 libpcrecpp.so.0 -> libpcrecpp.so.0.0.1
    -rwxr-xr-x   1 root root  46K Aug 22 23:01 libpcrecpp.so.0.0.1
    -rwxr-xr-x   1 root root  941 Aug 22 23:01 libpcre.la
    -rw-r--r--   1 root root  24K Aug 22 23:01 libpcreposix.a
    -rwxr-xr-x   1 root root 1000 Aug 22 23:01 libpcreposix.la
    lrwxrwxrwx   1 root root   21 Aug 22 23:01 libpcreposix.so -> libpcreposix.so.0.0.6
    lrwxrwxrwx   1 root root   21 Aug 22 23:01 libpcreposix.so.0 -> libpcreposix.so.0.0.6
    -rwxr-xr-x   1 root root  23K Aug 22 23:01 libpcreposix.so.0.0.6
    lrwxrwxrwx   1 root root   17 Aug 22 23:01 libpcre.so -> libpcre.so.1.2.10
    lrwxrwxrwx   1 root root   17 Aug 22 23:01 libpcre.so.1 -> libpcre.so.1.2.10
    -rwxr-xr-x   1 root root 1.5M Aug 22 23:01 libpcre.so.1.2.10
    -rwxr-xr-x   1 root root  22M Aug 22 23:19 libphp5.so
    drwxr-xr-x  15 root root 4.0K Aug 22 23:19 php
    -rw-r--r--   1 root root  72K Aug 22 23:20 php.ini
    drwxr-xr-x   2 root root 4.0K Aug 22 23:01 pkgconfig
    drwxr-xr-x   4 root root 4.0K Aug 22 23:22 sproxy
    46,583
    10,580
    6:58 AM
    also @ENF and @Sunka can you also try this manual edit to see if it fixes the problem by editing manually /usr/local/src/centminmod/addons/wget.sh at line 457 add the following 3 lines
        # ensure wget.sh installer utilises system openssl
        export OPENSSL_CFLAGS="-I /usr/include"
        export OPENSSL_LIBS="-L /usr/lib64 -lssl -lcrypto"
    so it looks like
        export PCRE_CFLAGS="-I /usr/local/include"
        export PCRE_LIBS="-L /usr/local/lib -lpcre"
    the try re-running centmin.sh without any manually set WGET_VERSION variables persistent config file /etc/centminmod/custom_config.inc to retry wget update to 1.20
    i suspect if you had an old enough centmin mod 123.09beta01 install, at one stage you had openssl libs in /usr/local/lib which get picked up during wget compile instead of system openssl libs at /usr/lib64 for 64bit systems. This was fixed with new nginx recompiles via centmin.sh menu option 4 detecting such in /usr/local/lib and removing them. This was ages ago, so if you haven't updated nginx is months it could be a possibility.
  13. Sunka
    1,145
    316
    Pula, Croatia
    10:58 PM
    Nginx 1.17.9
    MariaDB 10.3.22
    Here you go
    # ls -lah /usr/local/lib
    total 81M
    drwxr-xr-x.  5 root root 8.0K Dec  9 19:05 .
    drwxr-xr-x. 21 root root 4.0K Sep  2 03:14 ..
    lrwxrwxrwx   1 root root   20 Feb 20  2018 libbrotlicommon.so -> libbrotlicommon.so.1
    lrwxrwxrwx   1 root root   24 Apr 15  2018 libbrotlicommon.so.1 -> libbrotlicommon.so.1.0.4
    -rwxr-xr-x   1 root root 130K Dec  2  2017 libbrotlicommon.so.1.0.1
    -rwxr-xr-x   1 root root 130K Mar 20  2018 libbrotlicommon.so.1.0.2
    -rwxr-xr-x   1 root root 138K Dec  6 19:18 libbrotlicommon.so.1.0.4
    -rw-r--r--   1 root root 136K Dec  6 19:18 libbrotlicommon-static.a
    -rw-r--r--   1 root root 606K Jun 28  2017 libbrotlidec.a
    -rwxr-xr-x   1 root root  952 Jun 28  2017 libbrotlidec.la
    lrwxrwxrwx   1 root root   17 Feb 20  2018 libbrotlidec.so -> libbrotlidec.so.1
    lrwxrwxrwx   1 root root   21 Apr 15  2018 libbrotlidec.so.1 -> libbrotlidec.so.1.0.4
    -rwxr-xr-x   1 root root 338K Jun 28  2017 libbrotlidec.so.1.0.0
    -rwxr-xr-x   1 root root 238K Dec  2  2017 libbrotlidec.so.1.0.1
    -rwxr-xr-x   1 root root 238K Mar 20  2018 libbrotlidec.so.1.0.2
    -rwxr-xr-x   1 root root 239K Dec  6 19:18 libbrotlidec.so.1.0.4
    -rw-r--r--   1 root root 315K Dec  6 19:18 libbrotlidec-static.a
    -rw-r--r--   1 root root 4.0M Jun 28  2017 libbrotlienc.a
    -rwxr-xr-x   1 root root  956 Jun 28  2017 libbrotlienc.la
    lrwxrwxrwx   1 root root   17 Feb 20  2018 libbrotlienc.so -> libbrotlienc.so.1
    lrwxrwxrwx   1 root root   21 Apr 15  2018 libbrotlienc.so.1 -> libbrotlienc.so.1.0.4
    -rwxr-xr-x   1 root root 2.8M Jun 28  2017 libbrotlienc.so.1.0.0
    -rwxr-xr-x   1 root root 1.5M Dec  2  2017 libbrotlienc.so.1.0.1
    -rwxr-xr-x   1 root root 1.5M Mar 20  2018 libbrotlienc.so.1.0.2
    -rwxr-xr-x   1 root root 3.7M Dec  6 19:18 libbrotlienc.so.1.0.4
    -rw-r--r--   1 root root 4.1M Dec  6 19:18 libbrotlienc-static.a
    -rw-r--r--   1 root root 4.0M May  9  2018 libcrypto.a
    -rw-r--r--   1 root root 1.3M Oct  9 22:35 libgmp.a
    -rwxr-xr-x   1 root root  913 Oct  9 22:35 libgmp.la
    lrwxrwxrwx   1 root root   16 Oct  9 22:35 libgmp.so -> libgmp.so.10.3.2
    lrwxrwxrwx   1 root root   16 Oct  9 22:35 libgmp.so.10 -> libgmp.so.10.3.2
    -rwxr-xr-x   1 root root 516K Oct  9 22:35 libgmp.so.10.3.2
    -rw-r--r--   1 root root 107K Nov  2 17:27 liblz4.a
    lrwxrwxrwx   1 root root   15 Nov  2 17:27 liblz4.so -> liblz4.so.1.8.3
    lrwxrwxrwx   1 root root   15 Nov  2 17:27 liblz4.so.1 -> liblz4.so.1.8.3
    -rwxr-xr-x   1 root root  88K Nov  2 17:27 liblz4.so.1.8.3
    -rw-r--r--   1 root root  83K Nov  2 17:27 liblz.a
    -rw-r--r--   1 root root 176K May  9  2018 libmaxminddb.a
    -rwxr-xr-x   1 root root  956 May  9  2018 libmaxminddb.la
    lrwxrwxrwx   1 root root   21 May  9  2018 libmaxminddb.so -> libmaxminddb.so.0.0.7
    lrwxrwxrwx   1 root root   21 May  9  2018 libmaxminddb.so.0 -> libmaxminddb.so.0.0.7
    -rwxr-xr-x   1 root root  85K May  9  2018 libmaxminddb.so.0.0.7
    -rw-r--r--   1 root root 2.1M Nov 27 18:57 libpcre16.a
    -rwxr-xr-x   1 root root  955 Nov 27 18:57 libpcre16.la
    lrwxrwxrwx   1 root root   19 Nov 27 18:57 libpcre16.so -> libpcre16.so.0.2.10
    lrwxrwxrwx   1 root root   19 Nov 27 18:57 libpcre16.so.0 -> libpcre16.so.0.2.10
    -rwxr-xr-x   1 root root 1.4M Nov 27 18:57 libpcre16.so.0.2.10
    -rwxr-xr-x   1 root root 1.4M Nov 11  2016 libpcre16.so.0.2.7
    -rwxr-xr-x   1 root root 1.4M Feb 21  2017 libpcre16.so.0.2.8
    -rwxr-xr-x   1 root root 1.4M Oct 27  2017 libpcre16.so.0.2.9
    -rw-r--r--   1 root root 2.1M Nov 27 18:57 libpcre32.a
    -rwxr-xr-x   1 root root  955 Nov 27 18:57 libpcre32.la
    lrwxrwxrwx   1 root root   19 Nov 27 18:57 libpcre32.so -> libpcre32.so.0.0.10
    lrwxrwxrwx   1 root root   19 Nov 27 18:57 libpcre32.so.0 -> libpcre32.so.0.0.10
    -rwxr-xr-x   1 root root 1.3M Nov 27 18:57 libpcre32.so.0.0.10
    -rwxr-xr-x   1 root root 1.3M Nov 11  2016 libpcre32.so.0.0.7
    -rwxr-xr-x   1 root root 1.3M Feb 21  2017 libpcre32.so.0.0.8
    -rwxr-xr-x   1 root root 1.3M Oct 27  2017 libpcre32.so.0.0.9
    -rw-r--r--   1 root root 2.2M Nov 27 18:57 libpcre.a
    -rw-r--r--   1 root root  46K Nov 27 18:57 libpcrecpp.a
    -rwxr-xr-x   1 root root  986 Nov 27 18:57 libpcrecpp.la
    lrwxrwxrwx   1 root root   19 Nov 27 18:57 libpcrecpp.so -> libpcrecpp.so.0.0.1
    lrwxrwxrwx   1 root root   19 Nov 27 18:57 libpcrecpp.so.0 -> libpcrecpp.so.0.0.1
    -rwxr-xr-x   1 root root  46K Nov 27 18:57 libpcrecpp.so.0.0.1
    -rwxr-xr-x   1 root root  941 Nov 27 18:57 libpcre.la
    -rw-r--r--   1 root root  24K Nov 27 18:57 libpcreposix.a
    -rwxr-xr-x   1 root root 1000 Nov 27 18:57 libpcreposix.la
    lrwxrwxrwx   1 root root   21 Nov 27 18:57 libpcreposix.so -> libpcreposix.so.0.0.6
    lrwxrwxrwx   1 root root   21 Nov 27 18:57 libpcreposix.so.0 -> libpcreposix.so.0.0.6
    -rwxr-xr-x   1 root root  23K Feb 21  2017 libpcreposix.so.0.0.4
    -rwxr-xr-x   1 root root  23K Oct 27  2017 libpcreposix.so.0.0.5
    -rwxr-xr-x   1 root root  23K Nov 27 18:57 libpcreposix.so.0.0.6
    lrwxrwxrwx   1 root root   17 Nov 27 18:57 libpcre.so -> libpcre.so.1.2.10
    lrwxrwxrwx   1 root root   17 Nov 27 18:57 libpcre.so.1 -> libpcre.so.1.2.10
    -rwxr-xr-x   1 root root 1.5M Nov 27 18:57 libpcre.so.1.2.10
    -rwxr-xr-x   1 root root 1.5M Nov 11  2016 libpcre.so.1.2.7
    -rwxr-xr-x   1 root root 1.5M Feb 21  2017 libpcre.so.1.2.8
    -rwxr-xr-x   1 root root 1.5M Oct 27  2017 libpcre.so.1.2.9
    -rwxr-xr-x   1 root root  24M Dec  9 19:05 libphp7.so
    -rw-r--r--   1 root root 716K May  9  2018 libssl.a
    -rwxr-xr-x   1 root root  14K May  9  2018 libtap.a
    -rwxr-xr-x   1 root root  18K May  9  2018 libtap.so
    -rw-r--r--   1 root root 963K Nov  2 17:27 libzstd.a
    lrwxrwxrwx   1 root root   16 Nov  2 17:27 libzstd.so -> libzstd.so.1.3.7
    lrwxrwxrwx   1 root root   16 Nov  2 17:27 libzstd.so.1 -> libzstd.so.1.3.7
    -rwxr-xr-x   1 root root 806K Nov  2 17:27 libzstd.so.1.3.7
    drwxr-xr-x  15 root root 4.0K Jul  6  2017 php
    -rw-r--r--   1 root root  69K Dec  9 18:54 php.ini
    -rw-r--r--   1 root root  70K Feb  1  2018 php.ini-oldversion_010218-230038
    -rw-r--r--   1 root root  70K May  1  2017 php.ini-oldversion_010517-193727
    -rw-r--r--   1 root root  70K Aug  1  2017 php.ini-oldversion_010817-030451
    -rw-r--r--   1 root root  70K Sep  1  2017 php.ini-oldversion_010917-214520
    -rw-r--r--   1 root root  69K Nov  1 15:39 php.ini-oldversion_011118-153843
    -rw-r--r--   1 root root  70K Dec  1  2017 php.ini-oldversion_011217-210441
    -rw-r--r--   1 root root  69K Feb  2  2018 php.ini-oldversion_020218-214713
    -rw-r--r--   1 root root  69K Mar  2  2018 php.ini-oldversion_020318-002935
    -rw-r--r--   1 root root  70K Mar  4  2017 php.ini-oldversion_040317-021259
    -rw-r--r--   1 root root  70K Aug  4  2017 php.ini-oldversion_040817-015658
    -rw-r--r--   1 root root  70K Aug  4  2017 php.ini-oldversion_040817-021252
    -rw-r--r--   1 root root  70K Jan  5  2018 php.ini-oldversion_050118-011929
    -rw-r--r--   1 root root  69K Jul  5 22:33 php.ini-oldversion_050718-223300
    -rw-r--r--   1 root root  69K Aug  5 01:36 php.ini-oldversion_050818-013610
    -rw-r--r--   1 root root  70K Oct  5  2017 php.ini-oldversion_051017-163115
    -rw-r--r--   1 root root  69K Dec  5  2016 php.ini-oldversion_051216-034621
    -rw-r--r--   1 root root  69K Dec  5 22:26 php.ini-oldversion_051218-222526
    -rw-r--r--   1 root root  70K Jul  6  2017 php.ini-oldversion_060717-225909
    -rw-r--r--   1 root root  69K Dec  6 19:21 php.ini-oldversion_061218-191501
    -rw-r--r--   1 root root  69K Sep  7 01:35 php.ini-oldversion_070918-013516
    -rw-r--r--   1 root root  70K Apr  8  2017 php.ini-oldversion_080417-142648
    -rw-r--r--   1 root root  70K May  8  2017 php.ini-oldversion_080517-040454
    -rw-r--r--   1 root root  69K Oct  8 01:57 php.ini-oldversion_081018-015706
    -rw-r--r--   1 root root  69K Nov  8 23:19 php.ini-oldversion_081118-231836
    -rw-r--r--   1 root root  70K Jun  9  2017 php.ini-oldversion_090617-002325
    -rw-r--r--   1 root root  69K Oct  9 22:37 php.ini-oldversion_091018-223614
    -rw-r--r--   1 root root  69K Dec  9 18:54 php.ini-oldversion_091218-185347
    -rw-r--r--   1 root root  69K Feb 10  2018 php.ini-oldversion_100218-044433
    -rw-r--r--   1 root root  70K Aug 10  2017 php.ini-oldversion_100817-152145
    -rw-r--r--   1 root root  70K Feb 11  2017 php.ini-oldversion_110217-113554
    -rw-r--r--   1 root root  70K Apr 11  2017 php.ini-oldversion_110417-234941
    -rw-r--r--   1 root root  70K Aug 11  2017 php.ini-oldversion_110817-145330
    -rw-r--r--   1 root root  69K Oct 11 22:29 php.ini-oldversion_111018-222813
    -rw-r--r--   1 root root  72K Nov 11  2016 php.ini-oldversion_111116-142742
    -rw-r--r--   1 root root  70K May 12  2017 php.ini-oldversion_120517-012428
    -rw-r--r--   1 root root  69K Jul 12 00:36 php.ini-oldversion_120718-003534
    -rw-r--r--   1 root root  69K Jul 12 14:45 php.ini-oldversion_120718-144507
    -rw-r--r--   1 root root  69K Nov 12  2016 php.ini-oldversion_121116-013505
    -rw-r--r--   1 root root  70K Apr 13  2017 php.ini-oldversion_130417-195918
    -rw-r--r--   1 root root  69K Sep 13 13:20 php.ini-oldversion_130918-132004
    -rw-r--r--   1 root root  70K Jan 14  2017 php.ini-oldversion_140117-021637
    -rw-r--r--   1 root root  69K Feb 14  2018 php.ini-oldversion_140218-132717
    -rw-r--r--   1 root root  69K Mar 14  2018 php.ini-oldversion_140318-184350
    -rw-r--r--   1 root root  70K Apr 14  2017 php.ini-oldversion_140417-115402
    -rw-r--r--   1 root root  69K Oct 14 00:05 php.ini-oldversion_141018-000502
    -rw-r--r--   1 root root  69K Nov 14  2016 php.ini-oldversion_141116-030059
    -rw-r--r--   1 root root  69K Mar 15  2018 php.ini-oldversion_150318-223111
    -rw-r--r--   1 root root  70K Jun 15  2017 php.ini-oldversion_150617-183458
    -rw-r--r--   1 root root  69K Jul 15 00:43 php.ini-oldversion_150718-004222
    -rw-r--r--   1 root root  70K Aug 15  2017 php.ini-oldversion_150817-165844
    -rw-r--r--   1 root root  69K Feb 16  2018 php.ini-oldversion_160218-180424
    -rw-r--r--   1 root root  70K Aug 16  2017 php.ini-oldversion_160817-034449
    -rw-r--r--   1 root root  69K Aug 16 00:12 php.ini-oldversion_160818-001141
    -rw-r--r--   1 root root  69K Nov 16  2016 php.ini-oldversion_161116-103734
    -rw-r--r--   1 root root  70K Mar 17  2017 php.ini-oldversion_170317-013441
    -rw-r--r--   1 root root  69K Mar 17  2018 php.ini-oldversion_170318-025102
    -rw-r--r--   1 root root  69K Aug 17 13:05 php.ini-oldversion_170818-130458
    -rw-r--r--   1 root root  70K Feb 18  2017 php.ini-oldversion_180217-033013
    -rw-r--r--   1 root root  69K May 19  2018 php.ini-oldversion_190518-143906
    -rw-r--r--   1 root root  69K May 19  2018 php.ini-oldversion_190518-164745
    -rw-r--r--   1 root root  69K Jul 19 02:07 php.ini-oldversion_190718-020625
    -rw-r--r--   1 root root  70K Jan 20  2017 php.ini-oldversion_200117-011716
    -rw-r--r--   1 root root  69K Feb 20  2018 php.ini-oldversion_200218-135429
    -rw-r--r--   1 root root  70K Apr 20  2017 php.ini-oldversion_200417-183840
    -rw-r--r--   1 root root  70K Jun 20  2017 php.ini-oldversion_200617-105240
    -rw-r--r--   1 root root  69K Feb 22  2018 php.ini-oldversion_220218-001018
    -rw-r--r--   1 root root  70K Feb 23  2017 php.ini-oldversion_230217-040808
    -rw-r--r--   1 root root  69K Jun 23 13:21 php.ini-oldversion_230618-131631
    -rw-r--r--   1 root root  69K Nov 23  2016 php.ini-oldversion_231116-235805
    -rw-r--r--   1 root root  70K Dec 23  2016 php.ini-oldversion_231216-015536
    -rw-r--r--   1 root root  70K Aug 24  2017 php.ini-oldversion_240817-205337
    -rw-r--r--   1 root root  70K Oct 24  2017 php.ini-oldversion_241017-135128
    -rw-r--r--   1 root root  70K Jan 25  2018 php.ini-oldversion_250118-210251
    -rw-r--r--   1 root root  70K Feb 25  2017 php.ini-oldversion_250217-191829
    -rw-r--r--   1 root root  69K Nov 25 03:20 php.ini-oldversion_251118-031953
    -rw-r--r--   1 root root  70K Jan 26  2018 php.ini-oldversion_260118-134551
    -rw-r--r--   1 root root  69K Apr 26  2018 php.ini-oldversion_260418-185437
    -rw-r--r--   1 root root  69K May 26  2018 php.ini-oldversion_260518-201739
    -rw-r--r--   1 root root  70K Nov 26  2017 php.ini-oldversion_261117-015016
    -rw-r--r--   1 root root  69K Nov 26 19:30 php.ini-oldversion_261118-192932
    -rw-r--r--   1 root root  70K Apr 27  2017 php.ini-oldversion_270417-035957
    -rw-r--r--   1 root root  70K Jul 27  2017 php.ini-oldversion_270717-133416
    -rw-r--r--   1 root root  70K Oct 27  2017 php.ini-oldversion_271017-104426
    -rw-r--r--   1 root root  69K Nov 27 19:31 php.ini-oldversion_271118-193046
    -rw-r--r--   1 root root  70K Apr 28  2017 php.ini-oldversion_280417-134347
    -rw-r--r--   1 root root  70K Jul 28  2017 php.ini-oldversion_280717-041101
    -rw-r--r--   1 root root  69K Mar 29  2018 php.ini-oldversion_290318-145242
    -rw-r--r--   1 root root  69K Aug 29 03:46 php.ini-oldversion_290818-034622
    -rw-r--r--   1 root root  70K Dec 29  2016 php.ini-oldversion_291216-174318
    -rw-r--r--   1 root root  70K Aug 30  2017 php.ini-oldversion_300817-195223
    -rw-r--r--   1 root root  70K Sep 30  2017 php.ini-oldversion_300917-175459
    drwxr-xr-x   2 root root 4.0K Dec  6 19:18 pkgconfig
    drwxr-xr-x   4 root root   51 Nov 11  2016 sproxy
    No such text inside /usr/local/src/centminmod/addons/wget.sh
    #!/bin/bash
    # set locale temporarily to english
    # for wget compile due to some non-english
    # locale issues
    export LC_ALL=en_US.UTF-8
    export LANG=en_US.UTF-8
    export LANGUAGE=en_US.UTF-8
    export LC_CTYPE=en_US.UTF-8
    # wget source installer to /usr/local/bin/wget path for
    # centminmod.com LEMP stacks
    # installs newer wget version than available via centos RPM
    # repos but does not interfere with YUM installed wget as it
    # is just an alias wget command setup
    DT=$(date +"%d%m%y-%H%M%S")
    DNF_ENABLE='n'
    DNF_COPR='y'
    CENTMINLOGDIR='/root/centminlogs'
    DIR_TMP='/svr-setup'
    LOCALCENTMINMOD_MIRROR='https://centminmod.com'
    ALTPCRE_VERSION='8.42'
    ALTPCRELINKFILE="pcre-${ALTPCRE_VERSION}.tar.gz"
    ALTPCRELINK="${LOCALCENTMINMOD_MIRROR}/centminmodparts/pcre/${ALTPCRELINKFILE}"
    WGET_VERSION='1.20'
    WGET_FILENAME="wget-${WGET_VERSION}.tar.gz"
    WGET_LINK="https://centminmod.com/centminmodparts/wget/${WGET_FILENAME}"
    WGET_LINKLOCAL="${LOCALCENTMINMOD_MIRROR}/centminmodparts/wget/${WGET_FILENAME}"
    WGET_STRACE='n'
    FORCE_IPVFOUR='y' # curl/wget commands through script force IPv4
    shopt -s expand_aliases
    for g in "" e f; do
        alias ${g}grep="LC_ALL=C ${g}grep"  # speed-up grep, egrep, fgrep
    done
    CENTOSVER=$(awk '{ print $3 }' /etc/redhat-release)
    if [ -f "/etc/centminmod/custom_config.inc" ]; then
      # default is at /etc/centminmod/custom_config.inc
      dos2unix -q "/etc/centminmod/custom_config.inc"
      . "/etc/centminmod/custom_config.inc"
    fi
    if [ ! -d "$CENTMINLOGDIR" ]; then
      mkdir -p "$CENTMINLOGDIR"
    fi
    if [ "$CENTOSVER" == 'release' ]; then
        CENTOSVER=$(awk '{ print $4 }' /etc/redhat-release | cut -d . -f1,2)
        if [[ "$(cat /etc/redhat-release | awk '{ print $4 }' | cut -d . -f1)" = '7' ]]; then
            CENTOS_SEVEN='7'
        fi
    fi
    if [[ "$(cat /etc/redhat-release | awk '{ print $3 }' | cut -d . -f1)" = '6' ]]; then
        CENTOS_SIX='6'
    fi
    # Check for Redhat Enterprise Linux 7.x
    if [ "$CENTOSVER" == 'Enterprise' ]; then
        CENTOSVER=$(awk '{ print $7 }' /etc/redhat-release)
        if [[ "$(awk '{ print $1,$2 }' /etc/redhat-release)" = 'Red Hat' && "$(awk '{ print $7 }' /etc/redhat-release | cut -d . -f1)" = '7' ]]; then
            CENTOS_SEVEN='7'
            REDHAT_SEVEN='y'
        fi
    fi
    if [[ -f /etc/system-release && "$(awk '{print $1,$2,$3}' /etc/system-release)" = 'Amazon Linux AMI' ]]; then
        CENTOS_SIX='6'
    fi
    if [ -f /proc/user_beancounters ]; then
        # CPUS='1'
        # MAKETHREADS=" -j$CPUS"
        # speed up make
        CPUS=$(grep -c "processor" /proc/cpuinfo)
        if [[ "$CPUS" -gt '8' ]]; then
            if [[ "$(grep -o 'AMD EPYC 7601' /proc/cpuinfo | sort -u)" = 'AMD EPYC 7601' ]]; then
                # 7601 at 12 cpu cores has 3.20hz clock frequency https://en.wikichip.org/wiki/amd/epyc/7601
                # while greater than 12 cpu cores downclocks to 2.70Ghz
                CPUS=12
            elif [[ "$(grep -o 'AMD EPYC 7551' /proc/cpuinfo | sort -u)" = 'AMD EPYC 7551' ]]; then
                # 7551P at 12 cpu cores has 3.0Ghz clock frequency https://en.wikichip.org/wiki/amd/epyc/7551p
                # while greater than 12 cpu cores downclocks to 2.55Ghz
                CPUS=12
            elif [[ "$(grep -o 'AMD EPYC 7401' /proc/cpuinfo | sort -u)" = 'AMD EPYC 7401' ]]; then
                # 7401P at 12 cpu cores has 3.0Ghz clock frequency https://en.wikichip.org/wiki/amd/epyc/7401p
                # while greater than 12 cpu cores downclocks to 2.8Ghz
                CPUS=12
            elif [[ "$(grep -o 'AMD EPYC 7371' /proc/cpuinfo | sort -u)" = 'AMD EPYC 7371' ]]; then
                # 7371 at 8 cpu cores has 3.8Ghz clock frequency https://en.wikichip.org/wiki/amd/epyc/7371
                # while greater than 8 cpu cores downclocks to 3.6Ghz
                CPUS=8
            else
                CPUS=$(echo $(($CPUS+2)))
            fi
        else
            CPUS=$(echo $(($CPUS+1)))
        fi
    else
        # speed up make
                CPUS=12
                CPUS=12
                CPUS=12
                CPUS=8
            else
                CPUS=$(echo $(($CPUS+4)))
            fi
        elif [[ "$CPUS" -eq '8' ]]; then
        else
        fi
    fi
    if [[ "$CENTOS_SEVEN" = '7' && "$DNF_ENABLE" = [yY] ]]; then
      # yum -y -q install epel-release
      if [[ ! -f /usr/bin/dnf ]]; then
        yum -y -q install dnf
      fi
      if [ -f /etc/yum.repos.d/rpmforge.repo ]; then
          sed -i 's|enabled .*|enabled = 0|g' /etc/yum.repos.d/rpmforge.repo
          DISABLEREPO_DNF=' --disablerepo=rpmforge'
          YUMDNFBIN="dnf${DISABLEREPO_DNF}"
      else
          DISABLEREPO_DNF=""
          YUMDNFBIN='dnf'
      fi
    else
      YUMDNFBIN='yum'
      else
        DISABLEREPO_DNF=""
      fi
    fi
    if [ ! -f /usr/bin/sar ]; then
      time $YUMDNFBIN -y -q install sysstat${DISABLEREPO_DNF}
      if [[ "$(uname -m)" = 'x86_64' || "$(uname -m)" = 'aarch64' ]]; then
        SARCALL='/usr/lib64/sa/sa1'
      else
        SARCALL='/usr/lib/sa/sa1'
      fi
      if [[ "$CENTOS_SEVEN" != '7' ]]; then
        sed -i 's|10|5|g' /etc/cron.d/sysstat
        service sysstat restart
        chkconfig sysstat on
      else
        systemctl restart sysstat.service
        systemctl enable sysstat.service
      fi
    elif [ -f /usr/bin/sar ]; then
      else
      fi
      else
      fi
    fi
    # Setup Colours
    black='\E[30;40m'
    red='\E[31;40m'
    green='\E[32;40m'
    yellow='\E[33;40m'
    blue='\E[34;40m'
    magenta='\E[35;40m'
    cyan='\E[36;40m'
    white='\E[37;40m'
    boldblack='\E[1;30;40m'
    boldred='\E[1;31;40m'
    boldgreen='\E[1;32;40m'
    boldyellow='\E[1;33;40m'
    boldblue='\E[1;34;40m'
    boldmagenta='\E[1;35;40m'
    boldcyan='\E[1;36;40m'
    boldwhite='\E[1;37;40m'
    Reset="tput sgr0"      #  Reset text attributes to normal
                           #+ without clearing screen.
    cecho ()                     # Coloured-echo.
                                 # Argument $1 = message
                                 # Argument $2 = color
    message=$1
    color=$2
    echo -e "$color$message" ; $Reset
    return
    sar_call() {
      $SARCALL 1 1
    scl_install() {
      # if gcc version is less than 4.7 (407) install scl collection yum repo
      if [[ "$CENTOS_SIX" = '6' ]]; then
        # if devtoolset exists, enable it first before checking gcc versions
        if [[ "$DEVTOOLSETSIX" = [yY] ]]; then
          if [[ -f /opt/rh/devtoolset-7/root/usr/bin/gcc && -f /opt/rh/devtoolset-7/root/usr/bin/g++ ]]; then
            source /opt/rh/devtoolset-7/enable
          fi
        else
          fi
        fi
        if [[ "$(gcc --version | head -n1 | awk '{print $3}' | cut -d . -f1,2 | sed "s|\.|0|")" -lt '407' ]]; then
          echo "install centos-release-scl for newer gcc and g++ versions"
          if [[ -z "$(rpm -qa | grep rpmforge)" ]]; then
            if [[ "$(rpm -ql centos-release-scl >/dev/null 2>&1; echo $?)" -ne '0' ]]; then
              time $YUMDNFBIN -y -q install centos-release-scl
            fi
            sar_call
          else
              time $YUMDNFBIN -y -q install centos-release-scl --disablerepo=rpmforge
            fi
            sar_call
          fi
              if [[ "$(rpm -ql devtoolset-7-gcc >/de6/null 2>&1; echo $?)" -ne '0' ]] || [[ "$(rpm -ql devtoolset-7-gcc-c++ 6/dev/null 2>&1; echo $?)" -ne '0' ]] || [[ "$(rpm -ql devtoolset-7-binutils6>/dev/null 2>&1; echo $?)" -ne '0' ]]; then
                time $YUMDNFBIN -y -q install devtoolset-7-gcc devtoolset-7-gcc-c++ devtoolset-7-binutils
              fi
              sar_call
            else
                time $YUMDNFBIN -y -q install devtoolset-7-gcc devtoolset-7-gcc-c++ devtoolset-7-binutils --disablerepo=rpmforge
              fi
              sar_call
            fi
            echo
            /opt/rh/devtoolset-7/root/usr/bin/gcc --version
            /opt/rh/devtoolset-7/root/usr/bin/g++ --version
          else
              if [[ "$(rpm -ql devtoolset-7-gcc >/dev/null 2>&1; echo $?)" -ne '0' ]] || [[ "$(rpm -ql devtoolset-7-gcc-c++ >/dev/null 2>&1; echo $?)" -ne '0' ]] || [[ "$(rpm -ql devtoolset-7-binutils >/dev/null 2>&1; echo $?)" -ne '0' ]]; then
              fi
              sar_call
            else
              fi
              sar_call
            fi
            echo
          fi
        fi
      elif [[ "$CENTOS_SEVEN" = '7' ]]; then
            fi
            sar_call
          else
            fi
            sar_call
          fi
              fi
              sar_call
            else
              fi
              sar_call
            fi
            echo
          else
              fi
              sar_call
            else
              fi
              sar_call
            fi
            echo
          fi
      fi # centos 6 only needed
    gccdevtools() {
      if [[ ! -f /opt/rh/devtoolset-7/root/usr/bin/gcc || ! -f /opt/rh/devtoolset-7/root/usr/bin/g++ ]] && [[ "$CENTOS_SIX" = '6' ]]; then
        scl_install
        unset CC
        unset CXX
        if [[ "$DEVTOOLSETSEVEN" = [yY] ]]; then
          export CC="/opt/rh/devtoolset-7/root/usr/bin/gcc"
          export CXX="/opt/rh/devtoolset-7/root/usr/bin/g++"
          export CFLAGS="-Wimplicit-fallthrough=0"
          export CXXFLAGS="${CFLAGS}"
        else
        fi
      elif [[ "$DEVTOOLSETSEVEN" = [yY] && -f /opt/rh/devtoolset-7/root/usr/bin/gcc && -f /opt/rh/devtoolset-7/root/usr/bin/g++ ]] && [[ "$(gcc --version | head -n1 | awk '{print $3}' | cut -d . -f1,2 | sed "s|\.|0|")" -lt '407' ]]; then
        unset CC
        unset CXX
      elif [[ -f /opt/rh/devtoolset-7/root/usr/bin/gcc && -f /opt/rh/devtoolset-7/root/usr/bin/g++ ]] && [[ "$(gcc --version | head -n1 | awk '{print $3}' | cut -d . -f1,2 | sed "s|\.|0|")" -lt '407' ]]; then
        unset CC
        unset CXX
      fi
    source_pcreinstall() {
      if [[ "$(/usr/local/bin/pcre-config --version 2>&1 | grep -q ${ALTPCRE_VERSION} >/dev/null 2>&1; echo $?)" != '0' ]] || [[ -f /usr/local/bin/pcretest && "$(/usr/local/bin/pcretest -C | grep 'No UTF-8 support' >/dev/null 2>&1; echo $?)" = '0' ]] || [[ -f /usr/local/bin/pcretest && "$(/usr/local/bin/pcretest -C | grep 'No just-in-time compiler support' >/dev/null 2>&1; echo $?)" = '0' ]]; then
      cd "$DIR_TMP"
      cecho "Download $ALTPCRELINKFILE ..." $boldyellow
      if [ -s "$ALTPCRELINKFILE" ]; then
        cecho "$ALTPCRELINKFILE Archive found, skipping download..." $boldgreen
      else
        wget -c${ipv_forceopt} --progress=bar "$ALTPCRELINK" --tries=3
        ERROR=$?
        if [[ "$ERROR" != '0' ]]; then
          cecho "Error: $ALTPCRELINKFILE download failed." $boldgreen
          exit #$ERROR
        else
          cecho "Download done." $boldyellow
        fi
      fi
      tar xzf "$ALTPCRELINKFILE"
      ERROR=$?
        cecho "Error: $ALTPCRELINKFILE extraction failed." $boldgreen
        exit #$ERROR
      else
        cecho "$ALTPCRELINKFILE valid file." $boldyellow
        echo ""
      fi
      cd "pcre-${ALTPCRE_VERSION}"
      make clean >/dev/null 2>&1
      ./configure --enable-utf8 --enable-unicode-properties --enable-pcre16 --enable-pcre32 --enable-pcregrep-libz --enable-pcregrep-libbz2 --enable-pcretest-libreadline --enable-jit
      sar_call
      if [[ "$WGET_STRACE" = [yY] ]]; then
        strace -o "${CENTMINLOGDIR}/strace_pcre_make_$DT.log" -f -s256 -tt -T -q make${MAKETHREADS}
      else
        make${MAKETHREADS}
      fi
      sar_call
        strace -o "${CENTMINLOGDIR}/strace_pcre_make_install_$DT.log" -f -s256 -tt -T -q make install
      else
        make install
      fi
      sar_call
      fi
    source_wgetinstall() {
      if [[ "$(/usr/local/bin/wget -V | head -n1 | awk '{print $3}' | grep -q ${WGET_VERSION} >/dev/null 2>&1; echo $?)" != '0' ]]; then
      cd "$DIR_TMP"
      cecho "Download $WGET_FILENAME ..." $boldyellow
      if [ -s "$WGET_FILENAME" ]; then
        cecho "$WGET_FILENAME Archive found, skipping download..." $boldgreen
      else
        curl -${ipv_forceopt}Is --connect-timeout 5 --max-time 5 "$WGET_LINK" | grep 'HTTP\/' | grep '200'
        WGET_CURLCHECK=$?
        if [[ "$WGET_CURLCHECK" = '0' ]]; then
          wget -c${ipv_forceopt} --progress=bar "$WGET_LINK" -O "$WGET_FILENAME" --tries=3
        else
          WGET_LINK="$WGET_LINKLOCAL"
          echo "wget -c${ipv_forceopt} --progress=bar "$WGET_LINK" -O "$WGET_FILENAME" --tries=3"
        fi
        ERROR=$?
          cecho "Error: $WGET_FILENAME download failed." $boldgreen
          exit #$ERROR
        else
        fi
      fi
      tar xzf "$WGET_FILENAME"
      ERROR=$?
        cecho "Error: $WGET_FILENAME extraction failed." $boldgreen
        exit #$ERROR
      else
        cecho "$WGET_FILENAME valid file." $boldyellow
        echo ""
      fi
      cd "wget-${WGET_VERSION}"
      gccdevtools
      if [ -f config.status ]; then
        make clean
      fi
      if [[ "$(uname -m)" = 'x86_64' ]]; then
        export CFLAGS="-O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic"
      else
        export CFLAGS="-O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -mtune=generic"
        if [ -f /root/.wgetrc ]; then
          \cp -fp /root/.wgetrc /root/.wgetrc-bak
          echo "ca_certificate=/etc/pki/tls/certs/ca-bundle.crt" > /root/.wgetrc
        else
        fi
      fi
      # ./configure --with-ssl=openssl PCRE_CFLAGS="-I /usr/local/include" PCRE_LIBS="-L /usr/local/lib -lpcre"
      sar_call
        make check
        make distcheck
        strace -o "${CENTMINLOGDIR}/strace_wget_make_$DT.log" -f -s256 -tt -T -q make${MAKETHREADS}
      else
        make${MAKETHREADS}
      fi
      sar_call
        strace -o "${CENTMINLOGDIR}/strace_wget_make_install_$DT.log" -f -s256 -tt -T -q make install
      else
        make install
      fi
      sar_call
      echo "/usr/local/lib/" > /etc/ld.so.conf.d/wget.conf
      ldconfig
      if [[ ! "$(grep '^alias wget' /root/.bashrc)" ]] && [[ "$(wget -V | head -n1 | awk '{print $3}' | grep -q ${WGET_VERSION} >/dev/null 2>&1; echo $?)" = '0' ]]; then
        echo "alias wget='/usr/local/bin/wget'" >> /root/.bashrc
      fi
      . /root/.bashrc
      echo
      cecho "--------------------------------------------------------" $boldgreen
      echo "ldconfig -p | grep libpcre.so.1"
      echo
      echo "ldd $(which wget)"
      ldd $(which wget)
      cecho "wget -V" $boldyellow
      wget -V
      if [[ "$(wget -V | head -n1 | awk '{print $3}' | grep -q ${WGET_VERSION} >/dev/null 2>&1; echo $?)" = '0' ]]; then
        cecho "wget ${WGET_VERSION} installed at /usr/local/bin/wget" $boldyellow
          # ls -lah ${CENTMINLOGDIR} | grep $DT
          if [ -f "${CENTMINLOGDIR}/strace_wget_make_$DT.log" ]; then
            gzip -6 "${CENTMINLOGDIR}/strace_wget_make_$DT.log"
            cecho "strace make log (gzip compressed): ${CENTMINLOGDIR}/strace_wget_make_$DT.log.gz" $boldyellow
          fi
          if [ -f "${CENTMINLOGDIR}/strace_wget_make_install_$DT.log" ]; then
            gzip -6 "${CENTMINLOGDIR}/strace_wget_make_install_$DT.log"
            cecho "strace make install log (gzip compressed): ${CENTMINLOGDIR}/strace_wget_make_install_$DT.log.gz" $boldyellow
          fi
        fi
      else
        cecho "wget ${WGET_VERSION} failed to update, still using system wget" $boldyellow
        cecho "install log: ${CENTMINLOGDIR}/wget_source_install_${DT}.log" $boldyellow
          fi
          fi
        fi
      fi
      # clean up strace logs older than 14 days
      find "${CENTMINLOGDIR}" -type f -mtime +14 \( -name 'strace_wget_make*' ! -name "strace_pcre_make*" \) -print
      find "${CENTMINLOGDIR}" -type f -mtime +14 \( -name 'strace_wget_make*' ! -name "strace_pcre_make*" \) -exec rm -rf {} \;
      echo
      fi
    case $1 in
      install)
    starttime=$(TZ=UTC date +%s.%N)
      # devtoolset SCL repo only supports 64bit OSes
      if [[ "$LOWMEM_INSTALL" != [yY] && "$(uname -m)" = 'x86_64' ]]; then
        source_pcreinstall
        source_wgetinstall
      fi
    } 2>&1 | tee "${CENTMINLOGDIR}/wget_source_install_${DT}.log"
    endtime=$(TZ=UTC date +%s.%N)
    INSTALLTIME=$(echo "scale=2;$endtime - $starttime"|bc )
    echo "" >> "${CENTMINLOGDIR}/wget_source_install_${DT}.log"
    echo "Total wget Install Time: $INSTALLTIME seconds" >> "${CENTMINLOGDIR}/wget_source_install_${DT}.log"
    tail -1 "${CENTMINLOGDIR}/wget_source_install_${DT}.log"
      pcre)
        source_pcreinstall
      fi
    } 2>&1 | tee "${CENTMINLOGDIR}/wget_source_install_pcre_${DT}.log"
    echo "" >> "${CENTMINLOGDIR}/wget_source_install_pcre_${DT}.log"
    echo "Total wget pcre Install Time: $INSTALLTIME seconds" >> "${CENTMINLOGDIR}/wget_source_install_pcre_${DT}.log"
    tail -1 "${CENTMINLOGDIR}/wget_source_install_pcre_${DT}.log"
        echo "$0 install"
    esac
    exit
    46,583
    10,580
    6:58 AM
    i see the lines exist in your posted code - 3rd and 4th lines below
      else
    change to become
      else
    46,583
    10,580
    6:58 AM
    indeed i see May 9, 2018 for libssl.a and libcrypto.a - centmin mod 123.09beta01 hasn't installed these here in many months after fixing it up
    though trying the workaround wget.sh edits should bypass the issue for wget failing to update
    46,583
    10,580
    6:58 AM
    You can also check your command history and grep filter for May 9, 2018 to see what commands you were running at the time
    history | grep '09.05.18'
    also check the 10th
    history | grep '10.05.18'
    don't post output on this public forum as it may reveal sensitive info, you can private message me the output.
  17. Sunka
    1,145
    316
    Pula, Croatia
    10:58 PM
    Nginx 1.17.9
    MariaDB 10.3.22
    After updating centminmod I see that those lines are inserted automatically into file, so no need to add them manually.
    After that I tried to update wget (through centmin) same error
  18. Sunka
    1,145
    316
    Pula, Croatia
    10:58 PM
    Nginx 1.17.9
    MariaDB 10.3.22
    I can not see sensitive data, so here we go...
    [root@upcloud ~]# history | grep '09.05.18'
     8700  [09.05.18] 21:49:20   centmin
     8701  [09.05.18] 21:49:49   yum clean all
     8702  [09.05.18] 21:49:50   yum update
     8703  [09.05.18] 21:50:19   yum list updates --disableplugin=priorities --enablerepo=remi
     8704  [09.05.18] 21:50:26   yum list updates --enablerepo=city-fan.org --disableplugin=priorities
     8705  [09.05.18] 21:50:37   yum update --enablerepo=city-fan.org --disableplugin=priorities
     8706  [09.05.18] 21:51:08   cat /usr/local/nginx/conf/geoip.conf
     8707  [09.05.18] 21:54:13   centmin
     8708  [09.05.18] 21:55:23   nano /usr/local/nginx/conf/geoip.conf
     8709  [09.05.18] 21:56:18   centmin
     8710  [09.05.18] 21:56:37   nano /etc/centminmod/custom_config.inc
     8711  [09.05.18] 22:01:07   centmin
     8712  [09.05.18] 22:03:07   cat /usr/local/nginx/conf/geoip.conf
     8713  [09.05.18] 22:03:25   nginx -v
     8714  [09.05.18] 22:03:33   centmin
     8715  [09.05.18] 22:08:09   nginx -t
     8716  [09.05.18] 22:08:21   yum update
    10000  [15.12.18] 02:26:38   history | grep '09.05.18'
    [root@upcloud ~]# history | grep '10.05.18'
     8717  [10.05.18] 06:30:05   centmin
     8718  [10.05.18] 06:30:32   yum clean all
     8719  [10.05.18] 06:30:33   yum update
     8720  [10.05.18] 06:35:56   systemctl daemon-reload
     8721  [10.05.18] 06:36:01   /usr/local/src/centminmod/tools/setio.sh set
     8722  [10.05.18] 06:36:11   mysqlrestart
     8723  [10.05.18] 06:40:35   centmin
     8724  [10.05.18] 06:40:46   yum clean all
     8725  [10.05.18] 06:40:47   yum update
     8726  [10.05.18] 06:41:21   yum list updates --disableplugin=priorities --enablerepo=remi
     8727  [10.05.18] 06:41:28   yum list updates --enablerepo=city-fan.org --disableplugin=priorities
     8728  [10.05.18] 16:50:37   centmin
     8729  [10.05.18] 16:51:05   yum clean all
     8730  [10.05.18] 16:51:06   yum update
     8731  [10.05.18] 16:54:51   cd /usr/lib/python2.7/site-packages/
     8732  [10.05.18] 16:55:13   ls -la
     8733  [10.05.18] 16:55:55   rm -rf /usr/lib/python2.7/site-packages/backports.ssl_match_hostname-3.*
     8734  [10.05.18] 16:56:03   ls -la
     8735  [10.05.18] 16:56:22   yum reinstall python-backports-ssl_match_hostname
     8736  [10.05.18] 16:56:38   yum clean all
     8737  [10.05.18] 16:56:43   yum update
     8738  [10.05.18] 16:57:39   cd /
     8739  [10.05.18] 16:57:43   yum list updates --disableplugin=priorities --enablerepo=remi
     8740  [10.05.18] 16:57:49   yum list updates --enablerepo=city-fan.org --disableplugin=priorities
     8741  [10.05.18] 16:57:53   centmin
     8742  [10.05.18] 22:09:30   yum clean all
     8743  [10.05.18] 22:09:31   yum update
     8744  [10.05.18] 22:39:00   yum clean all
     8745  [10.05.18] 22:39:01   yum update
     8746  [10.05.18] 22:39:26   yum list updates --disableplugin=priorities --enablerepo=remi
     8747  [10.05.18] 22:39:32   yum list updates --enablerepo=city-fan.org --disableplugin=priorities
     8748  [10.05.18] 22:39:53   centmin
    10001  [15.12.18] 02:26:50   history | grep '10.05.18'
  19. Sunka
    1,145
    316
    Pula, Croatia
    10:58 PM
    Nginx 1.17.9
    MariaDB 10.3.22
    # cat /usr/local/src/centminmod/addons/wget.sh
    #!/bin/bash
    # locale issues
    DNF_ENABLE='n'
    DNF_COPR='y'
    WGET_VERSION='1.20'
    WGET_STRACE='n'
    for g in "" e f; do
    done
    fi
    fi
            CENTOS_SEVEN='7'
        fi
    fi
        CENTOS_SIX='6'
    fi
            CENTOS_SEVEN='7'
            REDHAT_SEVEN='y'
        fi
    fi
        CENTOS_SIX='6'
    fi
        # CPUS='1'
        # speed up make
                CPUS=12
                CPUS=12
                CPUS=12
                CPUS=8
            else
            fi
        else
        fi
    else
        # speed up make
                CPUS=12
                CPUS=12
                CPUS=12
                CPUS=8
            else
            fi
        else
        fi
    fi
      fi
      else
          DISABLEREPO_DNF=""
          YUMDNFBIN='dnf'
      fi
    else
      YUMDNFBIN='yum'
      else
        DISABLEREPO_DNF=""
      fi
    fi
      else
      fi
      else
      fi
      else
      fi
      else
      fi
    fi
    # Setup Colours
    black='\E[30;40m'
    red='\E[31;40m'
    green='\E[32;40m'
    yellow='\E[33;40m'
    blue='\E[34;40m'
    magenta='\E[35;40m'
    cyan='\E[36;40m'
    white='\E[37;40m'
    message=$1
    color=$2
    return
    sar_call() {
      $SARCALL 1 1
    scl_install() {
          fi
        else
          fi
        fi
            fi
            sar_call
          else
            fi
            sar_call
          fi
              fi
              sar_call
            else
              fi
              sar_call
            fi
            echo
          else
              fi
              sar_call
            else
              fi
              sar_call
            fi
            echo
          fi
        fi
            fi
            sar_call
          else
            fi
            sar_call
          fi
              fi
              sar_call
            else
              fi
              sar_call
            fi
            echo
          else
              fi
              sar_call
            else
              fi
              sar_call
            fi
            echo
          fi
    gccdevtools() {
        scl_install
        unset CC
        unset CXX
        else
        fi
        unset CC
        unset CXX
        unset CC
        unset CXX
      fi
      cd "$DIR_TMP"
      else
        ERROR=$?
          exit #$ERROR
        else
        fi
      fi
      ERROR=$?
        exit #$ERROR
      else
        echo ""
      fi
      sar_call
      else
        make${MAKETHREADS}
      fi
      sar_call
      else
        make install
      fi
      sar_call
      fi
      cd "$DIR_TMP"
      else
        WGET_CURLCHECK=$?
        else
        fi
        ERROR=$?
          exit #$ERROR
        else
        fi
      fi
      ERROR=$?
        exit #$ERROR
      else
        echo ""
      fi
      gccdevtools
        make clean
      fi
      else
        else
        fi
      fi
      sar_call
        make check
        make distcheck
      else
        make${MAKETHREADS}
      fi
      sar_call
      else
        make install
      fi
      sar_call
      ldconfig
      fi
      . /root/.bashrc
      echo
      echo
      ldd $(which wget)
      wget -V
          fi
          fi
        fi
      else
          fi
          fi
        fi
      fi
      echo
      fi
    case $1 in
      install)
        source_pcreinstall
        source_wgetinstall
      fi
      pcre)
        source_pcreinstall
      fi
        echo "$0 install"
    esac
    46,583
    10,580
    6:58 AM
    yeah i updated 123.09beta01 with the workaround.. there's a 2nd part that is in nginx update routine for the fix so try recompile nginx via centmin.sh menu option 4 after you have done 123.09beta01 update via cmupdate command.
